Monitor Model name............... LONTIUM Manufacturer............. LTM Plug and Play ID......... LTM2C02 Serial number............ n/a Manufacture date......... 2011, ISO week 1 Filter driver............ None ------------------------- EDID revision............ 1.3 Input signal type........ Digital Color bit depth.......... Undefined Display type............. RGB color Screen size.............. 890 x 500 mm (40,2 in) Power management......... Not supported Extension blocs.......... 1 (CEA/CTA-EXT) ------------------------- DDC/CI................... Not supported Color characteristics Default color space...... Non-sRGB Display gamma............ 2,20 Red chromaticity......... Rx 0,625 - Ry 0,340 Green chromaticity....... Gx 0,280 - Gy 0,595 Blue chromaticity........ Bx 0,155 - By 0,070 White point (default).... Wx 0,283 - Wy 0,298 Additional descriptors... None Timing characteristics Horizontal scan range.... 30-70kHz Vertical scan range...... 48-62Hz Video bandwidth.......... 150MHz CVT standard............. Not supported GTF standard............. Not supported Additional descriptors... None Preferred timing......... Yes Native/preferred timing.. 1920x1080p at 60Hz (16:9) Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync Detailed timing #1....... 1280x720p at 60Hz (16:9) Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync Standard timings supported 640 x 480p at 60Hz - IBM VGA EIA/CEA/CTA-861 Information Revision number.......... 3 IT underscan............. Supported Basic audio.............. Supported YCbCr 4:4:4.............. Supported YCbCr 4:2:2.............. Supported Native formats........... 1 Detailed timing #1....... 1920x1080i at 60Hz (16:9) Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync CE video identifiers (VICs) - timing/formats supported 1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native] 1920 x 1080p at 50Hz - HDTV (16:9, 1:1) 1920 x 1080i at 60Hz - HDTV (16:9, 1:1) 1280 x 720p at 60Hz - HDTV (16:9, 1:1) 1280 x 720p at 50Hz - HDTV (16:9, 1:1) 1920 x 1080i at 50Hz - HDTV (16:9, 1:1) 720 x 480p at 60Hz - EDTV (16:9, 32:27) 720 x 480p at 60Hz - EDTV (4:3, 8:9) 640 x 480p at 60Hz - Default (4:3, 1:1) NB: NTSC refresh rate = (Hz*1000)/1001 CE audio data (formats supported) LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz CE speaker allocation data Channel configuration.... 2.0 Front left/right......... Yes Front LFE................ No Front center............. No Rear left/right.......... No Rear center.............. No Front left/right center.. No Rear left/right center... No Rear LFE................. No CE vendor specific data (VSDB) IEEE registration number. 0x000C03 CEC physical address..... 0.0.0.0 Supports AI (ACP, ISRC).. Yes Supports 48bpp........... No Supports 36bpp........... Yes Supports 30bpp........... Yes Supports YCbCr 4:4:4..... Yes Supports dual-link DVI... No Maximum TMDS clock....... 225MHz CE video capability data CE scan behavior......... Supports overscan and underscan IT scan behavior......... Supports overscan and underscan PT scan behavior......... Not supported RGB quantization range... Not supported YCC quantization range... Not supported Report information Date generated........... 08.06.2023 Software revision........ 2.91.0.1043 Data source.............. Real-time 0x0092 Operating system......... 10.0.19044.2 Raw data 00,FF,FF,FF,FF,FF,FF,00,32,8D,02,2C,01,01,01,01,01,15,01,03,80,59,32,78,0A,0D,C9,A0,57,47,98,27, 12,48,4C,20,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C, 45,00,A0,5A,00,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,76,F2,31,00,00,1E,00,00,00,FD,00,30, 3E,1E,46,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,4C,4F,4E,54,49,55,4D,0A,20,20,20,20,20,01,F2, 02,03,21,F1,49,90,1F,05,04,13,14,03,02,01,23,09,7F,07,83,01,00,00,67,03,0C,00,00,00,B8,2D,E2,00, 0F,01,1D,80,18,71,1C,16,20,58,2C,25,00,C4,8E,21,00,00,9E,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,06
