set!********<\n> [XRADIO_INTERNAL_CODEC] LINEOUT set volume Level-[31]<\n> [XRADIO_INTERNAL_CODEC] Route(play): lineout Enable<\n> [XRADIO_INTERNAL_CODEC] LINEOUT set volume Level-[31]<\n> [XRADIO_INTERNAL_CODEC] Route(play): lineout Disable<\n> ----avi fr 25 375<\n> /record/2021/07_2/01/00/001004_100_00.avi<\n> [bl ERR] main():642, white led off<\n> [FD I]: mode: 0x4, freq: 48000000Hz, drv: 0<\n> <\r><\n> Password:PMA: mode select:e<\n> <\n> wlan information ===================================================<\n> firmware:<\n> version : R-XR_C10.08.52.64_01.80 Jul 6 2019 20:05:10-P01.46-R<\n> buffer : 12<\n> driver:<\n> version : XR_V02.05<\n> ====================================================================<\n> <\n> PMA: wlan mode:a<\n> <\n> platform information ===============================================<\n> XRADIO Skylark SDK 1.2.0 Apr 22 2023 11:49:50<\n> <\n> sram heap space [0x227628, 0x257c00), total size 198104 Bytes<\n> psram heap space [0x14b20d0, 0x1800000), total size 3465008 Bytes<\n> <\n> cpu clock 240000000 Hz<\n> HF clock 40000000 Hz<\n> <\n> sdk option:<\n> PSRAM : enable<\n> INT LF OSC : enable<\n> <\n> mac address:<\n> efuse : dc:44:6d:eb:6a:6e<\n> in use : b0:8c:02:c1:a2:79<\n> ====================================================================<\n> <\n> bCheckEncrypt:1<\n> StartupState:6<\n> <27>[0;32;31mError: VVV_FLASH_Init 182 key partition size ffffffff 00001000 error<\n> <27>[0mhw_id:1547A<\n> qrcode.g726<\n> wait.g726<\n> network_connected.g726<\n> reset.g726<\n> language<\n> <27>[0;32;31m<-500119_192428 led_proc.c:67><27>[mnot support status led<\n> detect by adc<\n> [WRN] switch to high speed error, use DS: 25 MHz<\n> [FS INF] mmc init<\n> [WRN] switch to high speed error, use DS: 25 MHz<\n> WARN at mmc_attach_bus:819!<\n> [FS INF] mmc init<\n> [FS INF] mount success<\n> SD File System initialized! freespace:30013MB<\n> [mthread]Create task:sdcardth(stack:2048),prio:3,ret:0 <\n> XXXX task:sdcardth<\n> open file"/res.bin" failed: 4<\n> open file"/xr_system_sdcard.img" failed: 4<\n> err cmd:use_fw_rate_policy<\n> vif=0, rts_threshold = 3000<\n> ssid is NULL. AP <\n> lpdtim:10, lplis:10<\n> [mthread]Create task:wifitask(stack:4096),prio:3,ret:0 <\n> XXXX task:wifitask<\n> [XRADIO_INTERNAL_CODEC] AMIC set volume Level-[7]<\n> [XRADIO_INTERNAL_CODEC] AMIC set volume Gain-[39]<\n> wifi task run<\n> en1: CTRL-EVENT-TERMINATING <\n> WAR join_status:0<\n> <\n> wlan information ===================================================<\n> firmware:<\n> version : R-XR_C10.08.52.64_01.80 Jul 6 2019 20:05:10-P01.46-R<\n> buffer : 12<\n> driver:<\n> version : XR_V02.05<\n> ====================================================================<\n> <\n> interface name: en1<\n> Using interface en1 with hwaddr b0:8c:02:c1:a2:79 and ssid "AP-XRADIO"<\n> [XRADIO_INTERNAL_CODEC] AMIC set volume Gain-[39]<\n> [XRADIO_INTERNAL_CODEC] LINEIN set volume Level-[1]<\n> [XRADIO_INTERNAL_CODEC] AUDIO_IN_DEV_ALL set volume Gain-[0]<\n> [XRADIO_INTERNAL_CODEC] Route(cap): amic Enable<\n> en1: interface state UNINITIALIZED->ENABLED<\n> en1: AP-ENABLED <\n> en1: AP-DISABLED <\n> [net INF] msg <\n> [net INF] netif is link up<\n> [net INF] bring up netif<\n> [net INF] netif (IPv4) is up<\n> [net INF] address: 192.168.238.1<\n> [net INF] gateway: 192.168.238.1<\n> [net INF] netmask: 255.255.255.0<\n> ---->detect gc0307 <\n> WLAN CONNECTED<\n> err cmd:use_fw_rate_policy<\n> vif=0, rts_threshold = 3000<\n> vif0, AP/GO mode THROTTLE=38<\n> [net INF] msg <\n> NETWORK UP<\n> Cmutex:0<\n> Cmutex:0x22f468<\n> en1: interface state ENABLED->DISABLED<\n> [net INF] msg <\n> [net INF] netif is link down<\n> WLAN DISCONNECTED<\n> lwip_socket(PF_INET, UDP, 17) = SKT_0<\n> Using interface en1 with hwaddr b0:8c:02:c1:a2:79 and ssid "CAMA042338NGFDS1A"<\n> [ERR] BUG at pm_unregister_ops:585 dev:0<\0><\0>'<\0><1><1><\0><\0>O<1><\0>[ERR] BUG at pm_unregister_ops:590 dev:i2c0(0x200090)!<\n> [os E] OS_MutexDelete():54, handle 0<\n> [os E] OS_SemaphoreDelete():67, handle 0<\n> GC0307 chip id read success 0x99<\n> Cmutex:0<\n> Cmutex:0x22f0c0<\n> lwip_socket(PF_INET, UDP, 17) = SKT_1<\n> en1: interface state DISABLED->ENABLED<\n> en1: AP-ENABLED <\n> [net INF] msg <\n> [mthread]Create task:taskP(stack:2048),prio:3,ret:0 <\n> XXXX task:taskP<\n> WiFi ap start ok:CAMA042338NGFDS1A, 0, 11<\n> wifi task exit<\n> [mthread]vvvthread wifitask, tid:2246548 EXIT<\n> [net INF] netif is link up<\n> [XRADIO_INTERNAL_CODEC] LINEOUT set volume Level-[31]<\n> [XRADIO_INTERNAL_CODEC] Route(play): lineout Enable<\n> [XRADIO_INTERNAL_CODEC] LINEOUT set volume Level-[31]<\n> [net INF] netif is already up<\n> WLAN CONNECTED<\n> err cmd:use_fw_rate_policy<\n> vif=0, rts_threshold = 3000<\n> vif0, AP/GO mode THROTTLE=38<\n> GC0307 Init Done <\r><\n> [mthread]Create task:vtask(stack:3072),prio:3,ret:0 <\n> XXXX task:vtask<\n> [mthread]Create task:atask(stack:3072),prio:3,ret:0 <\n> XXXX task:atask<\n> [mthread]Create task:thdImage(stack:2048),prio:3,ret:0 <\n> XXXX task:thdImage<\n> [mthread]Create task:RT_REC(stack:2048),prio:3,ret:0 <\n> XXXX task:RT_REC<\n> [mthread]Create task:MD_TH(stack:2048),prio:3,ret:0 <\n> XXXX task:MD_TH<\n> [mthread]Create task:RT_Recv(stack:4096),prio:3,ret:0 <\n> XXXX task:RT_Recv<\n> [mthread]Create task:atask2(stack:4096),prio:3,ret:0 <\n> XXXX task:atask2<\n> task_aenc_stream runing<\n> Cmutex:0<\n> Cmutex:0x23ed80<\n> lwip_socket(PF_INET, UDP, 0) = SKT_2<\n> Cmutex:0<\n> Cmutex:0x23eed0<\n> lwip_socket(PF_INET, UDP, 0) = SKT_3<\n> Cmutex:0<\n> Cmutex:0x23f020<\n> lwip_socket(PF_INET, UDP, 0) = SKT_4<\n> 503 RT_IRCUT_Proc [IRCUT]101010<\n> [mthread]Create task:CameraTest(stack:2048),prio:3,ret:0 <\n> XXXX task:CameraTest<\n> set br:-1--1<\n> /camera_test.txt does not exist!<\n> [mthread]vvvthread CameraTest, tid:21699796 EXIT<\n> [mthread]Create task:vtask2(stack:4096),prio:3,ret:0 <\n> XXXX task:vtask2<\n> record freespace:30013MB <\n> [IRCUT]Call BW->Color,6<\n> cut to Day <\n> [XRADIO_INTERNAL_CODEC] Route(play): lineout Disable<\n> [mthread]vvvthread taskP, tid:2246376 EXIT<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> <\r><\n> Password:<\r><\n> Password:----avi fr 25 1500<\n> /record/2021/07_3/01/00/000004_100_00.avi<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x00000000<\n> [FW-DBG] DbgId = 10<\n> [FW-DBG] 0x0
