=========================== USB Port7 =========================== Connection Status : 0x01 (Device is connected) Port Chain : 2-7 ========================== Summary ========================= Vendor ID : 0x2341 (Arduino SA) Product ID : 0x0369 USB Version : 2.0 -> but Device is Full-Speed only Port maximum Speed : High-Speed Device maximum Speed : Full-Speed Device Connection Speed : Full-Speed Self powered : no Demanded Current : 100 mA Device Manager Problem : 28 (CM_PROB_FAILED_INSTALL) Used Endpoints : 1 ======================== USB Device ======================== DriverKeyName : ERROR_FILE_NOT_FOUND +++++++++++++++++ Device Information ++++++++++++++++++ Device Description : Santiago DFU Device ID : USB\VID_2341&PID_0369\370D280D58313330D23A33324B572D98 Hardware IDs : USB\VID_2341&PID_0369&REV_0100 USB\VID_2341&PID_0369 Driver KeyName : - Legacy BusType : PNPBus Enumerator : USB Location Info : Port_#0007.Hub_#0003 Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(7), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HS07) Container ID : {8e07e11b-21a5-571b-9de4-2ac14e09ff5c} Manufacturer Info : - Capabilities : 0x14 (Removable, UniqueID) Status : 0x01806400 (DN_HAS_PROBLEM, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER) Problem Code : 28 (CM_PROB_FAILED_INSTALL) Power State : D3 (supported: D0, D3, wake from D0) +++++++++++++++++ Registry USB Flags +++++++++++++++++ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\234103690100 osvc : REG_BINARY 00 00 ---------------- Connection Information --------------- Connection Index : 0x07 (Port 7) Connection Status : 0x01 (DeviceConnected) Current Config Value : 0x00 (Configuration 0) Device Address : 0x04 (4) Is Hub : 0x00 (no) Device Bus Speed : 0x01 (Full-Speed) Number Of Open Pipes : 0x00 (0 pipes to data endpoints) Data (HexDump) : 07 00 00 00 12 01 00 02 00 00 00 40 41 23 69 03 ...........@A#i. 00 01 01 02 03 01 00 01 00 04 00 00 00 00 00 01 ................ 00 00 00 ... --------------- Connection Information V2 ------------- Connection Index : 0x07 (7) Length : 0x10 (16 bytes) SupportedUsbProtocols : 0x03 Usb110 : 1 (yes, port supports USB 1.1) Usb200 : 1 (yes, port supports USB 2.0) Usb300 : 0 (no, port not supports USB 3.0) ReservedMBZ : 0x00 Flags : 0x00 DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher) DevIsSsCapOrHigher : 0 (Device is not SuperSpeed capable or higher) DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher) DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher) ReservedMBZ : 0x00 Data (HexDump) : 07 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00 ................ ---------------------- Device Descriptor ---------------------- bLength : 0x12 (18 bytes) bDescriptorType : 0x01 (Device Descriptor) bcdUSB : 0x200 (USB Version 2.0) -> but device is Full-Speed only bDeviceClass : 0x00 (defined by the interface descriptors) bDeviceSubClass : 0x00 bDeviceProtocol : 0x00 bMaxPacketSize0 : 0x40 (64 bytes) idVendor : 0x2341 (Arduino SA) idProduct : 0x0369 bcdDevice : 0x0100 iManufacturer : 0x01 (String Descriptor 1) iProduct : 0x02 (String Descriptor 2) iSerialNumber : 0x03 (String Descriptor 3) bNumConfigurations : 0x01 (1 Configuration) Data (HexDump) : 12 01 00 02 00 00 00 40 41 23 69 03 00 01 01 02 .......@A#i..... 03 01 .. ------------------ Configuration Descriptor ------------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x02 (Configuration Descriptor) wTotalLength : 0x0024 (36 bytes) bNumInterfaces : 0x01 (1 Interface) bConfigurationValue : 0x01 (Configuration 1) iConfiguration : 0x00 (No String Descriptor) bmAttributes : 0x80 D7: Reserved, set 1 : 0x01 D6: Self Powered : 0x00 (no) D5: Remote Wakeup : 0x00 (no) D4..0: Reserved, set 0 : 0x00 MaxPower : 0x32 (100 mA) Data (HexDump) : 09 02 24 00 01 01 00 80 32 09 04 00 00 00 FE 01 ..$.....2....... 02 04 09 04 00 01 00 FE 01 02 05 09 21 07 E8 03 ............!... 40 00 01 01 @... ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x00 (Interface 0) bAlternateSetting : 0x00 bNumEndpoints : 0x00 (Default Control Pipe only) bInterfaceClass : 0xFE (Application Specific) bInterfaceSubClass : 0x01 (Device Firmware Upgrade) bInterfaceProtocol : 0x02 (DFU mode) iInterface : 0x04 (String Descriptor 4) Data (HexDump) : 09 04 00 00 00 FE 01 02 04 ......... ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x00 (Interface 0) bAlternateSetting : 0x01 bNumEndpoints : 0x00 (Default Control Pipe only) bInterfaceClass : 0xFE (Application Specific) bInterfaceSubClass : 0x01 (Device Firmware Upgrade) bInterfaceProtocol : 0x02 (DFU mode) iInterface : 0x05 (String Descriptor 5) Data (HexDump) : 09 04 00 01 00 FE 01 02 05 ......... ----- Device Firmware Update Functional Descriptor ---- bLength : 0x09 (9 bytes) bDescriptorType : 0x21 (DFU Functional Descriptor) bmAttributes : 0x07 Bit 7..4: reserved : 0x00 Bit 3: WillDetach : 0x00 Bit 2: ManifestTolerant : 0x01 Bit 1: CanUpload : 0x01 Bit 0: CanDownload : 0x01 wDetachTimeOut : 0x03E8 (1000 ms) wTransferSize : 0x0040 (max 64 bytes) bcdDFUVersion : 0x0101 (Version 1.1) Data (HexDump) : 09 21 07 E8 03 40 00 01 01 .!...@... ----------------- Device Qualifier Descriptor ----------------- Error : ERROR_GEN_FAILURE (because the device has problem code CM_PROB_FAILED_INSTALL) -------------------- String Descriptors ------------------- String descriptors are not available (because the device has problem code CM_PROB_FAILED_INSTALL)
