\file LiquidCrystal_PCF8574.h /// \brief LiquidCrystal library with PCF8574 I2C adapter. /// /// \author Matthias Hertel, http://www.mathertel.de /// /// \copyright Copyright (c) 2019 by Matthias Hertel.\n /// /// The library work is licensed under a BSD style license.\n /// See http://www.mathertel.de/License.aspx /// /// \details /// This library can drive a Liquid Crystal Display (LCD) based on the Hitachi HD44780 chip that is connected /// through a PCF8574 I2C adapter. It uses the original Wire library for communication. /// The API if common to many LCD libraries and documented in https://www.arduino.cc/en/Reference/LiquidCrystal. /// and partially functions from https://playground.arduino.cc/Code/LCDAPI/. /// /// ChangeLog: /// -------- /// * 19.10.2013 created. /// * 05.06.2019 rewrite from scratch. /// * 26.05.2022 8-bit datatypes in interfaces and compatibility topics. /// * 26.05.2022 createChar with PROGMEM character data for AVR processors. /// * 26.05.2022 constructor with pin assignments. Thanks to @markisch. #ifndef LiquidCrystal_PCF8574_h #define LiquidCrystal_PCF8574_h #include "Arduino.h" #include #include "Print.h" #include #include class LiquidCrystal_PCF8574 : public Print { public: LiquidCrystal_PCF8574(uint8_t i2cAddr=0x27); // note: // // When using multiple I2C ports one can initialize with // LiquidCrystal_PCF8574 lcd(0x27); // create lcd // TwoWire myWire = TwoWire(); // create new wire instance // myWire.begin(sdaPin, sclPin); // define SDA and SCL pins // myWire.setClock(100000); // I2C speed 100kHz // myWire.setClockStretchLimit(200000); // I2C clock stretch to 200ms for slow devices // lcd_port = &myWire; // Keep address to wire instance // lcd.begin(clos, rows, *lcd_port); // Initialize lcd // // and in the main program one updates display with // # if defined(ESP8266) // ESP8266 is special case because there is only one wire structure available // Although we can created multiple wire interfaces we still need to specify SDA and SCL // before each transmission: // lcd_port->begin(sdaPin, sclPin); // lcd_port->setClock(100000); // lcd_port->setClockStretchLimit(200000); // 200ms, for slow devices // # endif // lcd.setCursor(0, 0); // lcd.print(lcdbuf); // constructors, which allow to redefine bit assignments in case your adapter is wired differently LiquidCrystal_PCF8574(uint8_t i2cAddr, uint8_t rs, uint8_t enable, uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7, uint8_t backlight=255); LiquidCrystal_PCF8574(uint8_t i2cAddr, uint8_t rs, uint8_t rw, uint8_t enable, uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7, uint8_t backlight=255); // Functions from reference: void begin(uint8_t cols, uint8_t rows, TwoWire &wirePort = Wire); void clear(); void home(); void setCursor(uint8_t col, uint8_t row); void cursor(); void noCursor(); void blink(); void noBlink(); void display(); void noDisplay(); void scrollDisplayLeft(); void scrollDisplayRight(); void autoscroll(); void noAutoscroll(); void leftToRight(); void rightToLeft(); void createChar(uint8_t location, uint8_t charmap[]); #ifdef __AVR__ void createChar_P(uint8_t, const uint8_t *); inline void createChar(uint8_t n, const uint8_t *data) { createChar_P(n, data); }; #endif // plus functions from LCDAPI: void setBacklight(uint8_t brightness); inline void command(uint8_t value) { _send(value); } // support of Print class virtual size_t write(uint8_t ch); private: TwoWire *_i2cPort; //The generic connection to user's chosen I2C hardware // instance variables uint8_t _i2cAddr; ///< Wire Address of the LCD uint8_t _backlight; ///< the backlight intensity uint8_t _cols; ///< number of cols of the display uint8_t _lines; ///< number of lines of the display uint8_t _entrymode; ///
