User : 4 0 options.c:53 configuration_output_handler(): debug_level: 3User : 5 0 options.c:53 configuration_output_handler(): Debug: 6 0 options.c:234 add_default_dirs(): bindir=../../bin Debug: 7 0 options.c:235 add_default_dirs(): pkgdatadir=../../share/openocd Debug: 8 0 options.c:236 add_default_dirs(): exepath=E:/OpenOCD-20230712-0.12.0/bin Debug: 9 0 options.c:237 add_default_dirs(): bin2data=../share/openocd Debug: 10 0 configuration.c:33 add_script_search_dir(): adding C:/Users/Adam.Parusel/AppData/Roaming/OpenOCD Debug: 11 0 configuration.c:33 add_script_search_dir(): adding E:/OpenOCD-20230712-0.12.0/bin/../share/openocd/site Debug: 12 0 configuration.c:33 add_script_search_dir(): adding E:/OpenOCD-20230712-0.12.0/bin/../share/openocd/scripts Debug: 13 0 command.c:152 script_debug(): command - ocd_find openocd.cfg Debug: 14 0 configuration.c:88 find_file(): found openocd.cfg Debug: 15 0 command.c:152 script_debug(): command - adapter driver cmsis-dap Debug: 16 0 command.c:152 script_debug(): command - cmsis_dap_vid_pid 0x03eb 0x2141 Debug: 17 0 command.c:152 script_debug(): command - transport select jtag Debug: 18 0 command.c:152 script_debug(): command - ocd_find target/at91sam4sXX.cfg Debug: 19 0 configuration.c:88 find_file(): found E:/OpenOCD-20230712-0.12.0/bin/../share/openocd/scripts/target/at91sam4sXX.cfg Debug: 20 0 command.c:152 script_debug(): command - ocd_find target/at91sam4XXX.cfg Debug: 21 0 configuration.c:88 find_file(): found E:/OpenOCD-20230712-0.12.0/bin/../share/openocd/scripts/target/at91sam4XXX.cfg Debug: 22 16 command.c:152 script_debug(): command - ocd_find target/swj-dp.tcl Debug: 23 16 configuration.c:88 find_file(): found E:/OpenOCD-20230712-0.12.0/bin/../share/openocd/scripts/target/swj-dp.tcl Debug: 24 16 command.c:152 script_debug(): command - transport select Debug: 25 16 command.c:152 script_debug(): command - transport select Debug: 26 16 command.c:152 script_debug(): command - transport select Debug: 27 16 command.c:152 script_debug(): command - jtag newtap SAM4E16E cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id 0x4ba00477 Debug: 28 16 tcl.c:418 handle_jtag_newtap_args(): Creating New Tap, Chip: SAM4E16E, Tap: cpu, Dotted: SAM4E16E.cpu, 8 params Debug: 29 16 core.c:1474 jtag_tap_init(): Created Tap: SAM4E16E.cpu @ abs position 0, irlen 4, capture: 0x1 mask: 0xf Debug: 30 16 command.c:152 script_debug(): command - dap create SAM4E16E.dap -chain-position SAM4E16E.cpu Debug: 31 16 command.c:152 script_debug(): command - target create SAM4E16E.cpu cortex_m -endian little -dap SAM4E16E.dap Debug: 32 16 command.c:286 register_command(): command 'tpiu' is already registered Debug: 33 16 command.c:286 register_command(): command 'rtt' is already registered Debug: 34 16 command.c:152 script_debug(): command - SAM4E16E.cpu configure -work-area-phys 0x20000000 -work-area-size 0x4000 -work-area-backup 0 Debug: 35 16 target.c:2171 target_free_all_working_areas_restore(): freeing all working areas Debug: 36 16 target.c:2171 target_free_all_working_areas_restore(): freeing all working areas Debug: 37 16 target.c:2171 target_free_all_working_areas_restore(): freeing all working areas Debug: 38 16 command.c:152 script_debug(): command - adapter speed 2000 Debug: 39 16 adapter.c:249 adapter_config_khz(): handle adapter khz Debug: 40 16 adapter.c:213 adapter_khz_to_speed(): convert khz to adapter specific speed value Debug: 41 16 adapter.c:213 adapter_khz_to_speed(): convert khz to adapter specific speed value Debug: 42 16 command.c:152 script_debug(): command - adapter srst delay 100 Debug: 43 16 command.c:152 script_debug(): command - transport select Debug: 44 16 command.c:152 script_debug(): command - jtag_ntrst_delay 100 Debug: 45 16 command.c:152 script_debug(): command - transport select Debug: 46 16 command.c:152 script_debug(): command - cortex_m reset_config sysresetreq Debug: 47 16 command.c:152 script_debug(): command - flash bank SAM4E16E.flash at91sam4 0x00400000 0 1 1 SAM4E16E.cpu Debug: 48 16 tcl.c:1306 handle_flash_bank_command(): 'at91sam4' driver usage field missing Debug: 49 16 command.c:152 script_debug(): command - init Debug: 50 16 command.c:152 script_debug(): command - target init Debug: 51 16 command.c:152 script_debug(): command - target names Debug: 52 16 command.c:152 script_debug(): command - SAM4E16E.cpu cget -event gdb-flash-erase-start Debug: 53 16 command.c:152 script_debug(): command - SAM4E16E.cpu configure -event gdb-flash-erase-start reset init Debug: 54 16 command.c:152 script_debug(): command - SAM4E16E.cpu cget -event gdb-flash-write-end Debug: 55 16 command.c:152 script_debug(): command - SAM4E16E.cpu configure -event gdb-flash-write-end reset halt Debug: 56 16 command.c:152 script_debug(): command - SAM4E16E.cpu cget -event gdb-attach Debug: 57 16 command.c:152 script_debug(): command - SAM4E16E.cpu configure -event gdb-attach halt 1000 Debug: 58 16 target.c:1629 handle_target_init_command(): Initializing targets... Debug: 59 16 semihosting_common.c:107 semihosting_common_init(): Debug: 60 16 cmsis_dap_usb_bulk.c:150 cmsis_dap_usb_open(): found product string of 0x03eb:0x2141 'Atmel-ICE CMSIS-DAP' Debug: 61 16 cmsis_dap_usb_bulk.c:170 cmsis_dap_usb_open(): enumerating interfaces of 0x03eb:0x2141 Debug: 62 16 cmsis_dap_usb_bulk.c:211 cmsis_dap_usb_open(): could not read interface string 4 for device 0x03eb:0x2141: Invalid parameter Debug: 63 16 cmsis_dap_usb_bulk.c:237 cmsis_dap_usb_open(): skipping interface 0, endpoint[0] is not bulk out Debug: 64 16 cmsis_dap_usb_bulk.c:211 cmsis_dap_usb_open(): could not read interface string 5 for device 0x03eb:0x2141: Invalid parameter Debug: 65 16 cmsis_dap_usb_bulk.c:237 cmsis_dap_usb_open(): skipping interface 1, endpoint[0] is not bulk out Info : 66 47 cmsis_dap.c:1112 cmsis_dap_get_caps_info(): CMSIS-DAP: SWD supported Info : 67 47 cmsis_dap.c:1112 cmsis_dap_get_caps_info(): CMSIS-DAP: JTAG supported Info : 68 47 cmsis_dap.c:1089 cmsis_dap_get_version_info(): CMSIS-DAP: FW Version = 1.0 Info : 69 47 cmsis_dap.c:1074 cmsis_dap_get_serial_info(): CMSIS-DAP: Serial# = J42700040742 Info : 70 47 cmsis_dap.c:1284 cmsis_dap_init(): CMSIS-DAP: Interface Initialised (JTAG) Debug: 71 47 cmsis_dap.c:1304 cmsis_dap_init(): CMSIS-DAP: Packet Size = 64 Debug: 72 47 cmsis_dap.c:1328 cmsis_dap_init(): CMSIS-DAP: Packet Count = 4 Debug: 73 47 cmsis_dap.c:1331 cmsis_dap_init(): Allocating FIFO for 4 pending packets Info : 74 47 cmsis_dap.c:1145 cmsis_dap_get_status(): SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 1 TDO = 1 nTRST = 0 nRESET = 1 Info : 75 63 cmsis_dap.c:1383 cmsis_dap_init(): CMSIS-DAP: Interface ready Debug: 76 63 adapter.c:213 adapter_khz_to_speed(): convert khz to adapter specific speed value Debug: 77 63 adapter.c:217 adapter_khz_to_speed(): have adapter set up Debug: 78 63 adapter.c:213 adapter_khz_to_speed(): convert khz to adapter specific speed value Debug: 79 63 adapter.c:217 adapter_khz_to_speed(): have adapter set up Info : 80 63 adapter.c:177 adapter_init(): clock speed 2000 kHz Debug: 81 63 openocd.c:133 handle_init_command(): Debug Adapter init complete Debug: 82 63 command.c:152 script_debug(): command - transport init Debug: 83 63 transport.c:219 handle_transport_init(): handle_transport_init Debug: 84 63 core.c:830 jtag_add_reset(): SRST line released Debug: 85 63 core.c:855 jtag_add_reset(): TRST line released Debug: 86 63 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Debug: 87 417 command.c:152 script_debug(): command - jtag arp_init Debug: 88 417 core.c:1509 jtag_init_inner(): Init JTAG chain Debug: 89 417 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Info : 90 417 cmsis_dap.c:1440 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET Debug: 91 417 core.c:1234 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS Debug: 92 417 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Info : 93 417 cmsis_dap.c:1440 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET Info : 94 417 core.c:1133 jtag_examine_chain_display(): JTAG tap: SAM4E16E.cpu tap/device found: 0x4ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x4) Debug: 95 417 core.c:1364 jtag_validate_ircapture(): IR capture validation scan Debug: 96 417 core.c:1421 jtag_validate_ircapture(): SAM4E16E.cpu: IR capture 0x01 Debug: 97 417 command.c:152 script_debug(): command - dap init Debug: 98 417 arm_dap.c:95 dap_init_all(): Initializing all DAPs ... Debug: 99 417 arm_dap.c:119 dap_init_all(): DAP SAM4E16E.cpu configured by default to use ADIv5 protocol Debug: 100 417 arm_adi_v5.c:679 dap_dp_init(): SAM4E16E.dap Debug: 101 417 arm_adi_v5.c:711 dap_dp_init(): DAP: wait CDBGPWRUPACK Debug: 102 417 arm_adi_v5.h:641 dap_dp_poll_register(): DAP: poll 4, mask 0x20000000, value 0x20000000 Debug: 103 432 arm_adi_v5.c:719 dap_dp_init(): DAP: wait CSYSPWRUPACK Debug: 104 432 arm_adi_v5.h:641 dap_dp_poll_register(): DAP: poll 4, mask 0x80000000, value 0x80000000 Debug: 105 448 openocd.c:150 handle_init_command(): Examining targets... Debug: 106 448 target.c:1815 target_call_event_callbacks(): target event 19 (examine-start) for core SAM4E16E.cpu Debug: 107 448 arm_adi_v5.c:1095 dap_get_ap(): refcount AP#0x0 get 1 Debug: 108 464 arm_adi_v5.c:1038 dap_find_get_ap(): Found MEM-AP AHB3 at AP index: 0 (IDR=0x24770011) Debug: 109 479 arm_adi_v5.c:825 mem_ap_init(): MEM_AP Packed Transfers: enabled Debug: 110 479 arm_adi_v5.c:836 mem_ap_init(): MEM_AP CFG: large data 0, long address 0, big-endian 0 Debug: 111 495 target.c:2600 target_read_u32(): address: 0xe000ed00, value: 0x410fc241 Info : 112 495 cortex_m.c:2716 cortex_m_examine(): [SAM4E16E.cpu] Cortex-M4 r0p1 processor detected Debug: 113 495 cortex_m.c:2731 cortex_m_examine(): [SAM4E16E.cpu] cpuid: 0x410fc241 Debug: 114 501 target.c:2600 target_read_u32(): address: 0xe000ef40, value: 0x10110021 Debug: 115 501 target.c:2600 target_read_u32(): address: 0xe000ef44, value: 0x11000011 Debug: 116 501 cortex_m.c:2739 cortex_m_examine(): [SAM4E16E.cpu] Cortex-M4 floating point feature FPv4_SP found Debug: 117 517 target.c:2600 target_read_u32(): address: 0xe000edf0, value: 0x00030003 Debug: 118 517 target.c:2688 target_write_u32(): address: 0xe000edfc, value: 0x01000000 Debug: 119 533 target.c:2600 target_read_u32(): address: 0xe0002000, value: 0x00000261 Debug: 120 533 target.c:2688 target_write_u32(): address: 0xe0002008, value: 0x00000000 Debug: 121 533 target.c:2688 target_write_u32(): address: 0xe000200c, value: 0x00000000 Debug: 122 548 target.c:2688 target_write_u32(): address: 0xe0002010, value: 0x00000000 Debug: 123 548 target.c:2688 target_write_u32(): address: 0xe0002014, value: 0x00000000 Debug: 124 548 target.c:2688 target_write_u32(): address: 0xe0002018, value: 0x00000000 Debug: 125 564 target.c:2688 target_write_u32(): address: 0xe000201c, value: 0x00000000 Debug: 126 564 target.c:2688 target_write_u32(): address: 0xe0002020, value: 0x00000000 Debug: 127 564 target.c:2688 target_write_u32(): address: 0xe0002024, value: 0x00000000 Debug: 128 580 cortex_m.c:2835 cortex_m_examine(): [SAM4E16E.cpu] FPB fpcr 0x261, numcode 6, numlit 2 Debug: 129 580 target.c:2600 target_read_u32(): address: 0xe0001000, value: 0x40000000 Debug: 130 580 cortex_m.c:2534 cortex_m_dwt_setup(): [SAM4E16E.cpu] DWT_CTRL: 0x40000000 Debug: 131 595 target.c:2600 target_read_u32(): address: 0xe0001fbc, value: 0x00000000 Debug: 132 595 cortex_m.c:2541 cortex_m_dwt_setup(): [SAM4E16E.cpu] DWT_DEVARCH: 0x0 Debug: 133 595 target.c:2688 target_write_u32(): address: 0xe0001028, value: 0x00000000 Debug: 134 602 target.c:2688 target_write_u32(): address: 0xe0001038, value: 0x00000000 Debug: 135 602 target.c:2688 target_write_u32(): address: 0xe0001048, value: 0x00000000 Debug: 136 617 target.c:2688 target_write_u32(): address: 0xe0001058, value: 0x00000000 Debug: 137 617 cortex_m.c:2588 cortex_m_dwt_setup(): [SAM4E16E.cpu] DWT dwtcr 0x40000000, comp 4, watch/trigger Info : 138 617 cortex_m.c:2845 cortex_m_examine(): [SAM4E16E.cpu] target has 6 breakpoints, 4 watchpoints Debug: 139 617 target.c:1815 target_call_event_callbacks(): target event 21 (examine-end) for core SAM4E16E.cpu Debug: 140 617 command.c:152 script_debug(): command - flash init Debug: 141 617 tcl.c:1363 handle_flash_init_command(): Initializing flash devices... Debug: 142 617 command.c:152 script_debug(): command - nand init Debug: 143 617 tcl.c:484 handle_nand_init_command(): Initializing NAND devices... Debug: 144 617 command.c:152 script_debug(): command - pld init Debug: 145 617 pld.c:250 handle_pld_init_command(): Initializing PLDs... Debug: 146 617 command.c:152 script_debug(): command - tpiu init Info : 147 617 gdb_server.c:3825 gdb_target_start(): starting gdb server for SAM4E16E.cpu on 3333 Info : 148 633 server.c:297 add_service(): Listening on port 3333 for gdb connections Debug: 149 633 command.c:152 script_debug(): command - reset init Debug: 150 633 target.c:1834 target_call_reset_callbacks(): target reset 3 (init) Debug: 151 633 command.c:152 script_debug(): command - target names Debug: 152 633 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-start Debug: 153 633 command.c:152 script_debug(): command - transport select Debug: 154 633 command.c:152 script_debug(): command - jtag arp_init-reset Debug: 155 633 core.c:1606 jtag_init_reset(): Initializing with hard TRST+SRST reset Debug: 156 633 core.c:843 jtag_add_reset(): JTAG reset with TLR instead of TRST Debug: 157 633 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Info : 158 633 cmsis_dap.c:1440 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET Debug: 159 633 core.c:1509 jtag_init_inner(): Init JTAG chain Debug: 160 633 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Info : 161 633 cmsis_dap.c:1440 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET Debug: 162 633 core.c:1234 jtag_examine_chain(): DR scan interrogation for IDCODE/BYPASS Debug: 163 633 core.c:328 jtag_call_event_callbacks(): jtag event: TAP reset Info : 164 633 cmsis_dap.c:1440 cmsis_dap_execute_tlr_reset(): cmsis-dap JTAG TLR_RESET Info : 165 633 core.c:1133 jtag_examine_chain_display(): JTAG tap: SAM4E16E.cpu tap/device found: 0x4ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x4) Debug: 166 633 core.c:1364 jtag_validate_ircapture(): IR capture validation scan Debug: 167 649 core.c:1421 jtag_validate_ircapture(): SAM4E16E.cpu: IR capture 0x01 Debug: 168 649 command.c:152 script_debug(): command - transport select Debug: 169 649 command.c:152 script_debug(): command - SAM4E16E.cpu cget -chain-position Debug: 170 649 command.c:152 script_debug(): command - jtag tapisenabled SAM4E16E.cpu Debug: 171 649 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event examine-start Debug: 172 649 command.c:152 script_debug(): command - SAM4E16E.cpu arp_examine allow-defer Debug: 173 664 arm_adi_v5.c:825 mem_ap_init(): MEM_AP Packed Transfers: enabled Debug: 174 664 arm_adi_v5.c:836 mem_ap_init(): MEM_AP CFG: large data 0, long address 0, big-endian 0 Debug: 175 664 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event examine-end Debug: 176 664 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-assert-pre Debug: 177 664 command.c:152 script_debug(): command - transport select Debug: 178 664 command.c:152 script_debug(): command - SAM4E16E.cpu cget -chain-position Debug: 179 664 command.c:152 script_debug(): command - jtag tapisenabled SAM4E16E.cpu Debug: 180 664 command.c:152 script_debug(): command - SAM4E16E.cpu arp_reset assert 1 Debug: 181 664 target.c:2171 target_free_all_working_areas_restore(): freeing all working areas Debug: 182 664 cortex_m.c:1744 cortex_m_assert_reset(): [SAM4E16E.cpu] target->state: unknown, examined Debug: 183 680 cortex_m.c:1863 cortex_m_assert_reset(): [SAM4E16E.cpu] Using Cortex-M SYSRESETREQ Debug: 184 695 arm_adi_v5.c:754 dap_dp_init_or_reconnect(): SAM4E16E.dap Debug: 185 702 arm_adi_v5.c:679 dap_dp_init(): SAM4E16E.dap Debug: 186 702 arm_adi_v5.c:711 dap_dp_init(): DAP: wait CDBGPWRUPACK Debug: 187 702 arm_adi_v5.h:641 dap_dp_poll_register(): DAP: poll 4, mask 0x20000000, value 0x20000000 Debug: 188 702 arm_adi_v5.c:719 dap_dp_init(): DAP: wait CSYSPWRUPACK Debug: 189 702 arm_adi_v5.h:641 dap_dp_poll_register(): DAP: poll 4, mask 0x80000000, value 0x80000000 Debug: 190 818 cortex_m.c:1088 cortex_m_halt_one(): [SAM4E16E.cpu] target->state: reset Debug: 191 818 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-assert-post Debug: 192 818 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-deassert-pre Debug: 193 818 command.c:152 script_debug(): command - transport select Debug: 194 818 command.c:152 script_debug(): command - SAM4E16E.cpu cget -chain-position Debug: 195 818 command.c:152 script_debug(): command - jtag tapisenabled SAM4E16E.cpu Debug: 196 818 command.c:152 script_debug(): command - SAM4E16E.cpu arp_reset deassert 1 Debug: 197 818 target.c:2171 target_free_all_working_areas_restore(): freeing all working areas Debug: 198 818 cortex_m.c:1916 cortex_m_deassert_reset(): [SAM4E16E.cpu] target->state: reset, examined Debug: 199 818 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-deassert-post Debug: 200 818 command.c:152 script_debug(): command - transport select Debug: 201 818 command.c:152 script_debug(): command - SAM4E16E.cpu cget -chain-position Debug: 202 818 command.c:152 script_debug(): command - jtag tapisenabled SAM4E16E.cpu Debug: 203 818 command.c:152 script_debug(): command - SAM4E16E.cpu was_examined Debug: 204 818 command.c:152 script_debug(): command - SAM4E16E.cpu arp_waitstate halted 1000 Debug: 205 818 target.c:3258 target_wait_state(): waiting for target halted... Debug: 206 833 cortex_m.c:920 cortex_m_poll_one(): [SAM4E16E.cpu] Exit from reset with dcb_dhcsr 0x30003 Debug: 207 833 cortex_m.c:590 cortex_m_endreset_event(): [SAM4E16E.cpu] DCB_DEMCR = 0x01000501 Debug: 208 833 target.c:2688 target_write_u32(): address: 0xe0002000, value: 0x00000003 Debug: 209 865 target.c:2600 target_read_u32(): address: 0xe0002000, value: 0x00000261 Debug: 210 865 target.c:2688 target_write_u32(): address: 0xe0002008, value: 0x00000000 Debug: 211 865 target.c:2688 target_write_u32(): address: 0xe000200c, value: 0x00000000 Debug: 212 880 target.c:2688 target_write_u32(): address: 0xe0002010, value: 0x00000000 Debug: 213 880 target.c:2688 target_write_u32(): address: 0xe0002014, value: 0x00000000 Debug: 214 880 target.c:2688 target_write_u32(): address: 0xe0002018, value: 0x00000000 Debug: 215 896 target.c:2688 target_write_u32(): address: 0xe000201c, value: 0x00000000 Debug: 216 902 target.c:2688 target_write_u32(): address: 0xe0002020, value: 0x00000000 Debug: 217 902 target.c:2688 target_write_u32(): address: 0xe0002024, value: 0x00000000 Debug: 218 918 target.c:2688 target_write_u32(): address: 0xe0001020, value: 0x00000000 Debug: 219 918 target.c:2688 target_write_u32(): address: 0xe0001024, value: 0x00000000 Debug: 220 918 target.c:2688 target_write_u32(): address: 0xe0001028, value: 0x00000000 Debug: 221 934 target.c:2688 target_write_u32(): address: 0xe0001030, value: 0x00000000 Debug: 222 934 target.c:2688 target_write_u32(): address: 0xe0001034, value: 0x00000000 Debug: 223 949 target.c:2688 target_write_u32(): address: 0xe0001038, value: 0x00000000 Debug: 224 949 target.c:2688 target_write_u32(): address: 0xe0001040, value: 0x00000000 Debug: 225 965 target.c:2688 target_write_u32(): address: 0xe0001044, value: 0x00000000 Debug: 226 965 target.c:2688 target_write_u32(): address: 0xe0001048, value: 0x00000000 Debug: 227 965 target.c:2688 target_write_u32(): address: 0xe0001050, value: 0x00000000 Debug: 228 980 target.c:2688 target_write_u32(): address: 0xe0001054, value: 0x00000000 Debug: 229 980 target.c:2688 target_write_u32(): address: 0xe0001058, value: 0x00000000 Debug: 230 1003 cortex_m.c:787 cortex_m_debug_entry(): [SAM4E16E.cpu] Debug: 231 1018 cortex_m.c:528 cortex_m_clear_halt(): [SAM4E16E.cpu] NVIC_DFSR 0x9 Debug: 232 1250 cortex_m.c:330 cortex_m_fast_read_all_regs(): [SAM4E16E.cpu] read 53 32-bit registers Debug: 233 1250 cortex_m.c:857 cortex_m_debug_entry(): [SAM4E16E.cpu] entered debug state in core mode: Thread at PC 0x405418, cpu in Non-Secure state, target->state: halted Debug: 234 1250 target.c:1815 target_call_event_callbacks(): target event 0 (gdb-halt) for core SAM4E16E.cpu Debug: 235 1250 target.c:1815 target_call_event_callbacks(): target event 1 (halted) for core SAM4E16E.cpu User : 236 1250 armv7m.c:741 armv7m_arch_state(): [SAM4E16E.cpu] halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x00405418 msp: 0x200055e8 Debug: 237 1250 command.c:152 script_debug(): command - SAM4E16E.cpu curstate Debug: 238 1250 command.c:152 script_debug(): command - transport select Debug: 239 1250 command.c:152 script_debug(): command - SAM4E16E.cpu cget -chain-position Debug: 240 1250 command.c:152 script_debug(): command - jtag tapisenabled SAM4E16E.cpu Debug: 241 1250 command.c:152 script_debug(): command - SAM4E16E.cpu was_examined Debug: 242 1250 command.c:152 script_debug(): command - SAM4E16E.cpu arp_waitstate halted 5000 Debug: 243 1250 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-init Debug: 244 1250 command.c:152 script_debug(): command - SAM4E16E.cpu invoke-event reset-end Debug: 245 1266 command.c:152 script_debug(): command - echo ** Programming Started ** User : 246 1266 command.c:690 handle_echo(): ** Programming Started ** Debug: 247 1266 command.c:152 script_debug(): command - flash write_image erase fw_10.hex Debug: 248 1266 configuration.c:88 find_file(): found fw_10.hex Debug: 249 1266 image.c:76 autodetect_image_type(): IHEX image detected. Debug: 250 1266 configuration.c:88 find_file(): found fw_10.hex Debug: 251 1416 at91sam4.c:2640 sam4_probe(): Begin: Bank: 0 Debug: 252 1424 target.c:2600 target_read_u32(): address: 0x400e0420, value: 0x01003e29 Debug: 253 1424 target.c:2600 target_read_u32(): address: 0x400e0424, value: 0x000119c3 Debug: 254 1434 target.c:2600 target_read_u32(): address: 0x400e0428, value: 0x08133f01 Debug: 255 1434 target.c:2600 target_read_u32(): address: 0x400e041c, value: 0x00000000 Debug: 256 1450 target.c:2600 target_read_u32(): address: 0x400e0470, value: 0x00040000 Debug: 257 1450 target.c:2600 target_read_u32(): address: 0x400e0474, value: 0x00000000 Debug: 258 1466 target.c:2600 target_read_u32(): address: 0x400e046c, value: 0x00000000 Debug: 259 1466 target.c:2600 target_read_u32(): address: 0x400e0430, value: 0x00000012 Debug: 260 1481 target.c:2600 target_read_u32(): address: 0x400e0440, value: 0x00000000 Debug: 261 1481 target.c:2600 target_read_u32(): address: 0x400e0444, value: 0x00000000 Debug: 262 1481 target.c:2600 target_read_u32(): address: 0x400e0448, value: 0x00000000 Debug: 263 1497 target.c:2600 target_read_u32(): address: 0x400e0418, value: 0xc12b7e80 Debug: 264 1497 target.c:2600 target_read_u32(): address: 0x400e0408, value: 0x00000081 Debug: 265 1512 target.c:2600 target_read_u32(): address: 0x400e0468, value: 0x0003000b Debug: 266 1512 target.c:2600 target_read_u32(): address: 0x400e0740, value: 0xa3cc0ce1 Debug: 267 1528 target.c:2600 target_read_u32(): address: 0x400e0744, value: 0x00120200 Debug: 268 1528 at91sam4.c:2656 sam4_probe(): Here Debug: 269 1528 at91sam4.c:2562 sam4_get_details(): Begin Debug: 270 1528 at91sam4.c:2580 sam4_get_details(): SAM4 Found chip at91sam4e16e, CIDR 0xa3cc0ce0 Debug: 271 1528 at91sam4.c:2612 sam4_get_details(): End Debug: 272 1528 at91sam4.c:2668 sam4_probe(): SAM4 Set flash bank to 0x00400000 - 0x00500000, idx 0 Debug: 273 1528 at91sam4.c:2450 sam4_protect_check(): Begin Debug: 274 1528 at91sam4.c:1829 flashd_get_lock_bits(): Here Debug: 275 1535 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 276 1535 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 277 1535 at91sam4.c:1561 efc_start_command(): Command: 0x5a00000a Debug: 278 1535 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00000a Debug: 279 1550 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 280 1550 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 281 1550 target.c:2600 target_read_u32(): address: 0x400e0a0c, value: 0x00000000 Debug: 282 1550 at91sam4.c:1477 efc_get_result(): Result: 0x00000000 Debug: 283 1566 target.c:2600 target_read_u32(): address: 0x400e0a0c, value: 0x00000000 Debug: 284 1566 at91sam4.c:1477 efc_get_result(): Result: 0x00000000 Debug: 285 1566 target.c:2600 target_read_u32(): address: 0x400e0a0c, value: 0x00000000 Debug: 286 1566 at91sam4.c:1477 efc_get_result(): Result: 0x00000000 Debug: 287 1581 target.c:2600 target_read_u32(): address: 0x400e0a0c, value: 0x00000000 Debug: 288 1581 at91sam4.c:1477 efc_get_result(): Result: 0x00000000 Debug: 289 1581 at91sam4.c:1837 flashd_get_lock_bits(): End: 0 Debug: 290 1581 at91sam4.c:2472 sam4_protect_check(): Done Debug: 291 1581 at91sam4.c:2698 sam4_probe(): Bank = 0, nbanks = 1 Debug: 292 1581 at91sam4.c:1631 flashd_read_uid(): Begin Debug: 293 1581 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 294 1581 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 295 1581 at91sam4.c:1561 efc_start_command(): Command: 0x5a00000e Debug: 296 1581 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00000e Debug: 297 1597 target.c:2600 target_read_u32(): address: 0x00400000, value: 0x53363100 Debug: 298 1613 target.c:2600 target_read_u32(): address: 0x00400004, value: 0x59414b53 Debug: 299 1613 target.c:2600 target_read_u32(): address: 0x00400008, value: 0x34303232 Debug: 300 1613 target.c:2600 target_read_u32(): address: 0x0040000c, value: 0x30343034 Debug: 301 1613 at91sam4.c:1561 efc_start_command(): Command: 0x5a00000f Debug: 302 1613 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00000f Debug: 303 1635 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 304 1635 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 305 1635 at91sam4.c:1646 flashd_read_uid(): End: R=0, id = 0x53363100, 0x59414b53, 0x34303232, 0x30343034 Debug: 306 1635 core.c:939 flash_write_unlock_verify(): image_read_section: section = 0, t_section_num = 0, section_offset = 0, buffer_idx = 0, size_read = 1048576 Debug: 307 1635 at91sam4.c:2730 sam4_erase(): Here Debug: 308 1635 at91sam4.c:2748 sam4_erase(): Here Debug: 309 1635 at91sam4.c:1662 flashd_erase_entire_bank(): Here Debug: 310 1635 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 311 1635 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 312 1635 at91sam4.c:1561 efc_start_command(): Command: 0x5a000005 Debug: 313 1635 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000005 Debug: 314 1650 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 315 1650 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 316 1666 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 317 1666 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 318 1666 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 319 1666 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 320 1682 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 321 1682 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 322 1682 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 323 1682 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 324 1697 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 325 1697 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 326 1697 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 327 1697 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 328 1713 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 329 1713 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 330 1713 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 331 1713 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 332 1735 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 333 1735 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 334 1735 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 335 1735 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 336 1751 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 337 1751 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 338 1751 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 339 1751 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 340 1766 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 341 1766 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 342 1766 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 343 1766 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 344 1782 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 345 1782 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 346 1782 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 347 1782 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 348 1798 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 349 1798 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 350 1798 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 351 1798 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 352 1813 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 353 1813 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 354 1813 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 355 1813 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 356 1829 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 357 1829 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 358 1835 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 359 1835 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 360 1835 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 361 1835 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 362 1851 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 363 1851 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 364 1851 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 365 1851 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 366 1866 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 367 1866 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 368 1866 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 369 1866 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 370 1882 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 371 1882 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 372 1882 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 373 1882 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 374 1898 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 375 1898 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 376 1898 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 377 1898 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 378 1913 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 379 1913 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 380 1913 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 381 1913 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 382 1929 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 383 1929 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 384 1935 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 385 1935 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 386 1951 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 387 1951 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 388 1951 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 389 1951 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 390 1967 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 391 1967 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 392 1967 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 393 1967 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 394 1982 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 395 1982 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 396 1982 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 397 1982 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 398 1998 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 399 1998 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 400 1998 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 401 1998 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 402 2014 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 403 2014 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 404 2014 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 405 2014 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 406 2029 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 407 2029 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 408 2036 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 409 2036 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 410 2036 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 411 2036 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 412 2051 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 413 2051 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 414 2051 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 415 2051 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 416 2067 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 417 2067 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 418 2067 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 419 2067 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 420 2083 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 421 2083 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 422 2083 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 423 2083 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 424 2098 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 425 2098 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 426 2098 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 427 2098 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 428 2114 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 429 2114 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 430 2114 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 431 2114 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 432 2129 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 433 2129 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 434 2136 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 435 2136 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 436 2136 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 437 2136 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 438 2152 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 439 2152 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 440 2167 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 441 2167 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 442 2167 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 443 2167 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 444 2183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 445 2183 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 446 2183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 447 2183 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 448 2198 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 449 2198 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 450 2198 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 451 2198 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 452 2214 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 453 2214 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 454 2214 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 455 2214 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 456 2230 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 457 2230 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 458 2236 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 459 2236 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 460 2236 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 461 2236 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 462 2252 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 463 2252 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 464 2252 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 465 2252 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 466 2267 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 467 2267 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 468 2267 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 469 2267 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 470 2283 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 471 2283 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 472 2283 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 473 2283 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 474 2299 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 475 2299 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 476 2299 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 477 2299 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 478 2314 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 479 2314 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 480 2314 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 481 2314 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 482 2330 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 483 2330 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 484 2336 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 485 2336 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 486 2336 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 487 2336 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 488 2352 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 489 2352 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 490 2352 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 491 2352 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 492 2368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 493 2368 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 494 2383 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 495 2383 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 496 2383 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 497 2383 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 498 2399 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 499 2399 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 500 2399 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 501 2399 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 502 2415 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 503 2415 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 504 2415 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 505 2415 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 506 2430 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 507 2430 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 508 2437 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 509 2437 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 510 2437 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 511 2437 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 512 2452 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 513 2452 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 514 2452 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 515 2452 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 516 2468 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 517 2468 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 518 2468 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 519 2468 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 520 2484 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 521 2484 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 522 2484 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 523 2484 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 524 2499 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 525 2499 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 526 2499 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 527 2499 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 528 2515 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 529 2515 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 530 2515 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 531 2515 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 532 2530 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 533 2530 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 534 2537 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 535 2537 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 536 2537 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 537 2537 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 538 2553 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 539 2553 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 540 2553 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 541 2553 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 542 2568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 543 2568 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 544 2568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 545 2568 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 546 2584 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 547 2584 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 548 2584 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 549 2584 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 550 2599 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 551 2599 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 552 2615 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 553 2615 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 554 2615 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 555 2615 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 556 2631 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 557 2631 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 558 2637 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 559 2637 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 560 2637 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 561 2637 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 562 2653 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 563 2653 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 564 2653 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 565 2653 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 566 2668 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 567 2668 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 568 2668 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 569 2668 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 570 2684 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 571 2684 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 572 2684 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 573 2684 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 574 2700 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 575 2700 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 576 2700 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 577 2700 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 578 2715 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 579 2715 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 580 2715 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 581 2715 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 582 2731 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 583 2731 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 584 2737 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 585 2737 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 586 2737 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 587 2737 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 588 2753 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 589 2753 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 590 2753 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 591 2753 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 592 2769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 593 2769 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 594 2769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 595 2769 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 596 2784 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 597 2784 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 598 2784 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 599 2784 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 600 2800 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 601 2800 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 602 2800 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 603 2800 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 604 2816 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 605 2816 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 606 2831 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 607 2831 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 608 2838 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 609 2838 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 610 2838 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 611 2838 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 612 2853 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 613 2853 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 614 2853 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 615 2853 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 616 2869 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 617 2869 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 618 2869 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 619 2869 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 620 2885 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 621 2885 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 622 2885 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 623 2885 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 624 2900 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 625 2900 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 626 2900 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 627 2900 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 628 2916 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 629 2916 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 630 2916 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 631 2916 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 632 2931 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 633 2931 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 634 2938 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 635 2938 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 636 2938 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 637 2938 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 638 2954 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 639 2954 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 640 2954 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 641 2954 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 642 2969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 643 2969 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 644 2969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 645 2969 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 646 2985 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 647 2985 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 648 2985 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 649 2985 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 650 3000 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 651 3000 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 652 3000 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 653 3000 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 654 3016 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 655 3016 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 656 3016 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 657 3016 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 658 3038 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 659 3038 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 660 3038 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 661 3038 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 662 3054 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 663 3054 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 664 3054 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 665 3054 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 666 3069 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 667 3069 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 668 3069 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 669 3069 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 670 3085 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 671 3085 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 672 3085 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 673 3085 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 674 3101 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 675 3101 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 676 3101 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 677 3101 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 678 3116 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 679 3116 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 680 3116 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 681 3116 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 682 3132 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 683 3132 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 684 3138 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 685 3138 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 686 3138 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 687 3138 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 688 3154 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 689 3154 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 690 3154 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 691 3154 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 692 3170 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 693 3170 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 694 3170 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 695 3170 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 696 3185 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 697 3185 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 698 3185 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 699 3185 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 700 3201 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 701 3201 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 702 3201 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 703 3201 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 704 3217 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 705 3217 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 706 3217 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 707 3217 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 708 3239 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 709 3239 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 710 3239 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 711 3239 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 712 3254 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 713 3254 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 714 3254 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 715 3254 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 716 3270 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 717 3270 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 718 3270 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 719 3270 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 720 3286 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 721 3286 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 722 3286 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 723 3286 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 724 3301 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 725 3301 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 726 3301 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 727 3301 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 728 3317 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 729 3317 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 730 3317 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 731 3317 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 732 3332 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 733 3332 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 734 3339 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 735 3339 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 736 3339 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 737 3339 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 738 3355 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 739 3355 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 740 3355 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 741 3355 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 742 3370 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 743 3370 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 744 3370 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 745 3370 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 746 3386 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 747 3386 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 748 3386 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 749 3386 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 750 3401 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 751 3401 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 752 3401 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 753 3401 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 754 3417 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 755 3417 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 756 3417 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 757 3417 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 758 3439 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 759 3439 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 760 3439 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 761 3439 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 762 3455 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 763 3455 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 764 3455 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 765 3455 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 766 3470 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 767 3470 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 768 3470 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 769 3470 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 770 3486 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 771 3486 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 772 3486 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 773 3486 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 774 3502 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 775 3502 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 776 3502 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 777 3502 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 778 3517 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 779 3517 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 780 3517 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 781 3517 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 782 3533 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 783 3533 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 784 3539 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 785 3539 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 786 3539 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 787 3539 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 788 3555 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 789 3555 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 790 3555 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 791 3555 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 792 3571 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 793 3571 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 794 3571 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 795 3571 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 796 3586 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 797 3586 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 798 3586 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 799 3586 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 800 3602 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 801 3602 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 802 3602 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 803 3602 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 804 3618 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 805 3618 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 806 3618 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 807 3618 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 808 3633 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 809 3633 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 810 3640 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 811 3640 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 812 3655 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 813 3655 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 814 3655 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 815 3655 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 816 3671 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 817 3671 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 818 3671 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 819 3671 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 820 3687 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 821 3687 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 822 3687 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 823 3687 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 824 3702 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 825 3702 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 826 3702 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 827 3702 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 828 3718 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 829 3718 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 830 3718 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 831 3718 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 832 3733 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 833 3733 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 834 3740 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 835 3740 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 836 3740 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 837 3740 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 838 3756 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 839 3756 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 840 3756 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 841 3756 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 842 3771 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 843 3771 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 844 3771 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 845 3771 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 846 3787 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 847 3787 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 848 3787 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 849 3787 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 850 3802 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 851 3802 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 852 3802 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 853 3802 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 854 3818 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 855 3818 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 856 3818 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 857 3818 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 858 3834 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 859 3834 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 860 3840 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 861 3840 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 862 3840 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 863 3840 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 864 3856 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 865 3856 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 866 3871 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 867 3871 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 868 3871 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 869 3871 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 870 3887 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 871 3887 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 872 3887 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 873 3887 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 874 3903 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 875 3903 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 876 3903 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 877 3903 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 878 3918 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 879 3918 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 880 3918 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 881 3918 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 882 3934 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 883 3934 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 884 3940 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 885 3940 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 886 3940 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 887 3940 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 888 3956 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 889 3956 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 890 3956 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 891 3956 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 892 3972 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 893 3972 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 894 3972 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 895 3972 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 896 3987 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 897 3987 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 898 3987 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 899 3987 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 900 4003 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 901 4003 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 902 4003 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 903 4003 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 904 4018 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 905 4018 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 906 4018 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 907 4018 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 908 4034 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 909 4034 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 910 4041 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 911 4041 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 912 4041 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 913 4041 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 914 4056 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 915 4056 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 916 4056 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 917 4056 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 918 4072 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 919 4072 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 920 4072 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 921 4072 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 922 4087 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 923 4087 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 924 4103 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 925 4103 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 926 4103 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 927 4103 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 928 4119 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 929 4119 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 930 4119 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 931 4119 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 932 4134 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 933 4134 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 934 4141 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 935 4141 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 936 4141 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 937 4141 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 938 4156 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 939 4156 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 940 4156 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 941 4156 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 942 4172 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 943 4172 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 944 4172 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 945 4172 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 946 4188 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 947 4188 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 948 4188 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 949 4188 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 950 4203 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 951 4203 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 952 4203 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 953 4203 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 954 4219 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 955 4219 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 956 4219 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 957 4219 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 958 4235 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 959 4235 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 960 4241 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 961 4241 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 962 4241 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 963 4241 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 964 4257 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 965 4257 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 966 4257 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 967 4257 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 968 4272 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 969 4272 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 970 4272 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 971 4272 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 972 4288 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 973 4288 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 974 4288 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 975 4288 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 976 4304 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 977 4304 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 978 4319 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 979 4319 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 980 4319 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 981 4319 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 982 4335 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 983 4335 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 984 4341 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 985 4341 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 986 4341 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 987 4341 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 988 4357 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 989 4357 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 990 4357 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 991 4357 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 992 4373 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 993 4373 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 994 4373 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 995 4373 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 996 4388 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 997 4388 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 998 4388 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 999 4388 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1000 4404 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1001 4404 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1002 4404 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1003 4404 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1004 4419 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1005 4419 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1006 4419 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1007 4419 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1008 4435 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1009 4435 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1010 4442 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1011 4442 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1012 4442 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1013 4442 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1014 4457 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1015 4457 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1016 4457 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1017 4457 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1018 4473 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1019 4473 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1020 4473 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1021 4473 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1022 4488 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1023 4488 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1024 4488 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1025 4488 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1026 4504 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1027 4504 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1028 4504 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1029 4504 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1030 4520 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1031 4520 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1032 4535 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1033 4535 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1034 4542 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1035 4542 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1036 4542 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1037 4542 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1038 4557 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1039 4557 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1040 4557 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1041 4557 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1042 4573 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1043 4573 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1044 4573 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1045 4573 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1046 4589 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1047 4589 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1048 4589 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1049 4589 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1050 4604 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1051 4604 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1052 4604 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1053 4604 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1054 4620 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1055 4620 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1056 4620 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1057 4620 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1058 4636 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1059 4636 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1060 4642 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1061 4642 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1062 4642 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1063 4642 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1064 4658 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1065 4658 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1066 4658 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1067 4658 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1068 4673 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1069 4673 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1070 4673 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1071 4673 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1072 4689 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1073 4689 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1074 4689 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1075 4689 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1076 4705 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1077 4705 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1078 4705 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1079 4705 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1080 4720 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1081 4720 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1082 4720 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1083 4720 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1084 4742 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1085 4742 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1086 4742 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1087 4742 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1088 4758 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1089 4758 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1090 4758 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1091 4758 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1092 4774 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1093 4774 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1094 4774 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1095 4774 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1096 4789 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1097 4789 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1098 4789 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1099 4789 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1100 4805 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1101 4805 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1102 4805 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1103 4805 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1104 4820 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1105 4820 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1106 4820 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1107 4820 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1108 4836 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1109 4836 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1110 4843 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1111 4843 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1112 4843 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1113 4843 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1114 4858 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1115 4858 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1116 4858 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1117 4858 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1118 4874 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1119 4874 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1120 4874 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1121 4874 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1122 4889 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1123 4889 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1124 4889 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1125 4889 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1126 4905 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1127 4905 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1128 4905 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1129 4905 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1130 4921 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1131 4921 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1132 4921 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1133 4921 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1134 4943 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1135 4943 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1136 4943 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1137 4943 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1138 4958 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1139 4958 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1140 4958 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1141 4958 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1142 4974 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1143 4974 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1144 4974 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1145 4974 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1146 4990 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1147 4990 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1148 4990 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1149 4990 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1150 5005 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1151 5005 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1152 5005 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1153 5005 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1154 5021 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1155 5021 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1156 5021 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1157 5021 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1158 5037 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1159 5037 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1160 5043 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1161 5043 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1162 5043 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1163 5043 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1164 5059 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1165 5059 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1166 5059 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1167 5059 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1168 5074 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1169 5074 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1170 5074 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1171 5074 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1172 5090 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1173 5090 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1174 5090 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1175 5090 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1176 5106 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1177 5106 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1178 5106 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1179 5106 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1180 5121 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1181 5121 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1182 5121 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1183 5121 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1184 5143 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1185 5143 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1186 5143 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1187 5143 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1188 5159 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1189 5159 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1190 5159 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1191 5159 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1192 5175 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1193 5175 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1194 5175 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1195 5175 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1196 5190 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1197 5190 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1198 5190 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1199 5190 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1200 5206 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1201 5206 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1202 5206 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1203 5206 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1204 5221 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1205 5221 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1206 5221 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1207 5221 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1208 5237 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1209 5237 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1210 5244 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1211 5244 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1212 5244 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1213 5244 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1214 5259 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1215 5259 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1216 5259 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1217 5259 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1218 5275 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1219 5275 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1220 5275 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1221 5275 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1222 5290 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1223 5290 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1224 5290 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1225 5290 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1226 5306 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1227 5306 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1228 5306 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1229 5306 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1230 5322 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1231 5322 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1232 5322 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1233 5322 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1234 5337 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1235 5337 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1236 5344 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1237 5344 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1238 5344 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1239 5359 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1240 5359 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1241 5359 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1242 5375 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1243 5375 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1244 5375 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1245 5375 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1246 5391 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1247 5391 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1248 5391 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1249 5391 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1250 5406 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1251 5406 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1252 5406 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1253 5406 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1254 5422 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1255 5422 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1256 5422 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1257 5422 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1258 5438 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1259 5438 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1260 5444 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1261 5444 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1262 5444 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1263 5444 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1264 5460 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1265 5460 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1266 5460 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1267 5460 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1268 5475 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1269 5475 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1270 5475 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1271 5475 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1272 5491 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1273 5491 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1274 5491 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1275 5491 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1276 5507 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1277 5507 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1278 5507 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1279 5507 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1280 5522 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1281 5522 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1282 5522 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1283 5522 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1284 5538 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1285 5538 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1286 5544 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1287 5544 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1288 5544 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1289 5544 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1290 5560 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1291 5560 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1292 5560 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1293 5560 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1294 5576 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1295 5576 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1296 5591 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1297 5591 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1298 5591 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1299 5591 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1300 5607 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1301 5607 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1302 5607 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1303 5607 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1304 5622 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1305 5622 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1306 5622 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1307 5622 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1308 5638 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1309 5638 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1310 5645 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1311 5645 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1312 5645 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1313 5645 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1314 5660 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1315 5660 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1316 5660 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1317 5660 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1318 5676 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1319 5676 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1320 5676 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1321 5676 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1322 5691 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1323 5691 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1324 5691 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1325 5691 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1326 5707 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1327 5707 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1328 5707 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1329 5707 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1330 5723 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1331 5723 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1332 5723 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1333 5723 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1334 5738 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1335 5738 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1336 5745 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1337 5745 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1338 5745 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1339 5745 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1340 5760 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1341 5760 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1342 5760 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1343 5760 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1344 5776 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1345 5776 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1346 5776 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1347 5776 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1348 5792 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1349 5792 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1350 5807 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1351 5807 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1352 5807 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1353 5807 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1354 5823 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1355 5823 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1356 5823 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1357 5823 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1358 5839 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1359 5839 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1360 5845 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1361 5845 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1362 5845 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1363 5845 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1364 5861 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1365 5861 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1366 5861 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1367 5861 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1368 5876 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1369 5876 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1370 5876 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1371 5876 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1372 5892 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1373 5892 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1374 5892 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1375 5892 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1376 5908 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1377 5908 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1378 5908 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1379 5908 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1380 5923 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1381 5923 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1382 5923 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1383 5923 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1384 5939 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1385 5939 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1386 5945 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1387 5945 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1388 5945 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000000 Debug: 1389 5945 at91sam4.c:1454 efc_get_status(): Status: 0x00000000 (lockerror: 0, cmderror: 0, ready: 0) Debug: 1390 5961 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1391 5961 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1392 5961 target.c:2600 target_read_u32(): address: 0x400e0a00, value: 0x05000500 Debug: 1393 5961 at91sam4.c:2836 sam4_set_wait(): Flash Mode: 0x05000500 Debug: 1394 5961 target.c:2688 target_write_u32(): address: 0x400e0a00, value: 0x05000500 Debug: 1395 5977 at91sam4.c:2947 sam4_write(): Offset: 0x00000000, Count: 0x00100000 Debug: 1396 5977 at91sam4.c:2948 sam4_write(): Page start: 0, Page End: 2047 Debug: 1397 5977 at91sam4.c:3008 sam4_write(): Full Page Loop: cur=0, end=2047, count = 0x00100000 Debug: 1398 5977 at91sam4.c:2856 sam4_page_write(): Wr Page 0 @ phys address: 0x00400000 Debug: 1399 6161 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1400 6161 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1401 6161 at91sam4.c:1561 efc_start_command(): Command: 0x5a000001 Debug: 1402 6161 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000001 Debug: 1403 6177 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1404 6177 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1405 6177 at91sam4.c:2856 sam4_page_write(): Wr Page 1 @ phys address: 0x00400200 Debug: 1406 6362 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1407 6362 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1408 6362 at91sam4.c:1561 efc_start_command(): Command: 0x5a000101 Debug: 1409 6362 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000101 Debug: 1410 6377 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1411 6377 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1412 6377 at91sam4.c:2856 sam4_page_write(): Wr Page 2 @ phys address: 0x00400400 Debug: 1413 6562 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1414 6562 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1415 6562 at91sam4.c:1561 efc_start_command(): Command: 0x5a000201 Debug: 1416 6562 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000201 Debug: 1417 6578 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1418 6578 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1419 6578 at91sam4.c:2856 sam4_page_write(): Wr Page 3 @ phys address: 0x00400600 Debug: 1420 6763 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1421 6763 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1422 6763 at91sam4.c:1561 efc_start_command(): Command: 0x5a000301 Debug: 1423 6763 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000301 Debug: 1424 6778 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1425 6778 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1426 6778 at91sam4.c:2856 sam4_page_write(): Wr Page 4 @ phys address: 0x00400800 Debug: 1427 6963 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1428 6963 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1429 6963 at91sam4.c:1561 efc_start_command(): Command: 0x5a000401 Debug: 1430 6963 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000401 Debug: 1431 6979 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1432 6979 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1433 6979 at91sam4.c:2856 sam4_page_write(): Wr Page 5 @ phys address: 0x00400a00 Debug: 1434 7164 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1435 7164 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1436 7164 at91sam4.c:1561 efc_start_command(): Command: 0x5a000501 Debug: 1437 7164 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000501 Debug: 1438 7179 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1439 7179 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1440 7179 at91sam4.c:2856 sam4_page_write(): Wr Page 6 @ phys address: 0x00400c00 Debug: 1441 7364 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1442 7364 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1443 7364 at91sam4.c:1561 efc_start_command(): Command: 0x5a000601 Debug: 1444 7364 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000601 Debug: 1445 7380 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1446 7380 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1447 7380 at91sam4.c:2856 sam4_page_write(): Wr Page 7 @ phys address: 0x00400e00 Debug: 1448 7565 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1449 7565 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1450 7565 at91sam4.c:1561 efc_start_command(): Command: 0x5a000701 Debug: 1451 7565 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000701 Debug: 1452 7580 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1453 7580 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1454 7580 at91sam4.c:2856 sam4_page_write(): Wr Page 8 @ phys address: 0x00401000 Debug: 1455 7765 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1456 7765 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1457 7765 at91sam4.c:1561 efc_start_command(): Command: 0x5a000801 Debug: 1458 7765 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000801 Debug: 1459 7781 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1460 7781 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1461 7781 at91sam4.c:2856 sam4_page_write(): Wr Page 9 @ phys address: 0x00401200 Debug: 1462 7966 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1463 7966 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1464 7966 at91sam4.c:1561 efc_start_command(): Command: 0x5a000901 Debug: 1465 7966 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000901 Debug: 1466 7981 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1467 7981 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1468 7981 at91sam4.c:2856 sam4_page_write(): Wr Page 10 @ phys address: 0x00401400 Debug: 1469 8166 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1470 8166 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1471 8166 at91sam4.c:1561 efc_start_command(): Command: 0x5a000a01 Debug: 1472 8166 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000a01 Debug: 1473 8182 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1474 8182 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1475 8182 at91sam4.c:2856 sam4_page_write(): Wr Page 11 @ phys address: 0x00401600 Debug: 1476 8366 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1477 8366 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1478 8366 at91sam4.c:1561 efc_start_command(): Command: 0x5a000b01 Debug: 1479 8366 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000b01 Debug: 1480 8382 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1481 8382 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1482 8382 at91sam4.c:2856 sam4_page_write(): Wr Page 12 @ phys address: 0x00401800 Debug: 1483 8567 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1484 8567 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1485 8567 at91sam4.c:1561 efc_start_command(): Command: 0x5a000c01 Debug: 1486 8567 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000c01 Debug: 1487 8583 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1488 8583 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1489 8583 at91sam4.c:2856 sam4_page_write(): Wr Page 13 @ phys address: 0x00401a00 Debug: 1490 8767 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1491 8767 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1492 8767 at91sam4.c:1561 efc_start_command(): Command: 0x5a000d01 Debug: 1493 8767 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000d01 Debug: 1494 8783 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1495 8783 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1496 8783 at91sam4.c:2856 sam4_page_write(): Wr Page 14 @ phys address: 0x00401c00 Debug: 1497 8968 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1498 8968 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1499 8968 at91sam4.c:1561 efc_start_command(): Command: 0x5a000e01 Debug: 1500 8968 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000e01 Debug: 1501 8968 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1502 8968 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1503 8968 at91sam4.c:2856 sam4_page_write(): Wr Page 15 @ phys address: 0x00401e00 Debug: 1504 9168 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1505 9168 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1506 9168 at91sam4.c:1561 efc_start_command(): Command: 0x5a000f01 Debug: 1507 9168 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a000f01 Debug: 1508 9168 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1509 9168 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1510 9168 at91sam4.c:2856 sam4_page_write(): Wr Page 16 @ phys address: 0x00402000 Debug: 1511 9369 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1512 9369 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1513 9369 at91sam4.c:1561 efc_start_command(): Command: 0x5a001001 Debug: 1514 9369 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001001 Debug: 1515 9369 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1516 9369 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1517 9369 at91sam4.c:2856 sam4_page_write(): Wr Page 17 @ phys address: 0x00402200 Debug: 1518 9569 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1519 9569 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1520 9569 at91sam4.c:1561 efc_start_command(): Command: 0x5a001101 Debug: 1521 9569 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001101 Debug: 1522 9569 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1523 9569 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1524 9569 at91sam4.c:2856 sam4_page_write(): Wr Page 18 @ phys address: 0x00402400 Debug: 1525 9754 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1526 9754 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1527 9754 at91sam4.c:1561 efc_start_command(): Command: 0x5a001201 Debug: 1528 9754 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001201 Debug: 1529 9770 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1530 9770 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1531 9770 at91sam4.c:2856 sam4_page_write(): Wr Page 19 @ phys address: 0x00402600 Debug: 1532 9955 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1533 9955 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1534 9955 at91sam4.c:1561 efc_start_command(): Command: 0x5a001301 Debug: 1535 9955 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001301 Debug: 1536 9970 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1537 9970 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1538 9970 at91sam4.c:2856 sam4_page_write(): Wr Page 20 @ phys address: 0x00402800 Debug: 1539 10155 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1540 10155 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1541 10155 at91sam4.c:1561 efc_start_command(): Command: 0x5a001401 Debug: 1542 10155 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001401 Debug: 1543 10171 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1544 10171 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1545 10171 at91sam4.c:2856 sam4_page_write(): Wr Page 21 @ phys address: 0x00402a00 Debug: 1546 10356 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1547 10356 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1548 10356 at91sam4.c:1561 efc_start_command(): Command: 0x5a001501 Debug: 1549 10356 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001501 Debug: 1550 10371 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1551 10371 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1552 10371 at91sam4.c:2856 sam4_page_write(): Wr Page 22 @ phys address: 0x00402c00 Debug: 1553 10556 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1554 10556 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1555 10556 at91sam4.c:1561 efc_start_command(): Command: 0x5a001601 Debug: 1556 10556 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001601 Debug: 1557 10572 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1558 10572 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1559 10572 at91sam4.c:2856 sam4_page_write(): Wr Page 23 @ phys address: 0x00402e00 Debug: 1560 10757 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1561 10757 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1562 10757 at91sam4.c:1561 efc_start_command(): Command: 0x5a001701 Debug: 1563 10757 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001701 Debug: 1564 10772 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1565 10772 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1566 10772 at91sam4.c:2856 sam4_page_write(): Wr Page 24 @ phys address: 0x00403000 Debug: 1567 10957 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1568 10957 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1569 10957 at91sam4.c:1561 efc_start_command(): Command: 0x5a001801 Debug: 1570 10957 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001801 Debug: 1571 10973 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1572 10973 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1573 10973 at91sam4.c:2856 sam4_page_write(): Wr Page 25 @ phys address: 0x00403200 Debug: 1574 11158 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1575 11158 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1576 11158 at91sam4.c:1561 efc_start_command(): Command: 0x5a001901 Debug: 1577 11158 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001901 Debug: 1578 11173 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1579 11173 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1580 11173 at91sam4.c:2856 sam4_page_write(): Wr Page 26 @ phys address: 0x00403400 Debug: 1581 11358 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1582 11358 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1583 11358 at91sam4.c:1561 efc_start_command(): Command: 0x5a001a01 Debug: 1584 11358 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001a01 Debug: 1585 11374 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1586 11374 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1587 11374 at91sam4.c:2856 sam4_page_write(): Wr Page 27 @ phys address: 0x00403600 Debug: 1588 11559 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1589 11559 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1590 11559 at91sam4.c:1561 efc_start_command(): Command: 0x5a001b01 Debug: 1591 11559 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001b01 Debug: 1592 11574 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1593 11574 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1594 11574 at91sam4.c:2856 sam4_page_write(): Wr Page 28 @ phys address: 0x00403800 Debug: 1595 11759 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1596 11759 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1597 11759 at91sam4.c:1561 efc_start_command(): Command: 0x5a001c01 Debug: 1598 11759 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001c01 Debug: 1599 11775 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1600 11775 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1601 11775 at91sam4.c:2856 sam4_page_write(): Wr Page 29 @ phys address: 0x00403a00 Debug: 1602 11960 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1603 11960 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1604 11960 at91sam4.c:1561 efc_start_command(): Command: 0x5a001d01 Debug: 1605 11960 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001d01 Debug: 1606 11975 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1607 11975 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1608 11975 at91sam4.c:2856 sam4_page_write(): Wr Page 30 @ phys address: 0x00403c00 Debug: 1609 12160 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1610 12160 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1611 12160 at91sam4.c:1561 efc_start_command(): Command: 0x5a001e01 Debug: 1612 12160 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001e01 Debug: 1613 12176 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1614 12176 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1615 12176 at91sam4.c:2856 sam4_page_write(): Wr Page 31 @ phys address: 0x00403e00 Debug: 1616 12361 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1617 12361 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1618 12361 at91sam4.c:1561 efc_start_command(): Command: 0x5a001f01 Debug: 1619 12361 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a001f01 Debug: 1620 12376 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1621 12376 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1622 12376 at91sam4.c:2856 sam4_page_write(): Wr Page 32 @ phys address: 0x00404000 Debug: 1623 12561 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1624 12561 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1625 12561 at91sam4.c:1561 efc_start_command(): Command: 0x5a002001 Debug: 1626 12561 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002001 Debug: 1627 12577 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1628 12577 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1629 12577 at91sam4.c:2856 sam4_page_write(): Wr Page 33 @ phys address: 0x00404200 Debug: 1630 12762 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1631 12762 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1632 12762 at91sam4.c:1561 efc_start_command(): Command: 0x5a002101 Debug: 1633 12762 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002101 Debug: 1634 12777 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1635 12777 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1636 12777 at91sam4.c:2856 sam4_page_write(): Wr Page 34 @ phys address: 0x00404400 Debug: 1637 12962 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1638 12962 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1639 12962 at91sam4.c:1561 efc_start_command(): Command: 0x5a002201 Debug: 1640 12962 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002201 Debug: 1641 12978 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1642 12978 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1643 12978 at91sam4.c:2856 sam4_page_write(): Wr Page 35 @ phys address: 0x00404600 Debug: 1644 13163 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1645 13163 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1646 13163 at91sam4.c:1561 efc_start_command(): Command: 0x5a002301 Debug: 1647 13163 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002301 Debug: 1648 13178 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1649 13178 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1650 13178 at91sam4.c:2856 sam4_page_write(): Wr Page 36 @ phys address: 0x00404800 Debug: 1651 13363 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1652 13363 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1653 13363 at91sam4.c:1561 efc_start_command(): Command: 0x5a002401 Debug: 1654 13363 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002401 Debug: 1655 13379 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1656 13379 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1657 13379 at91sam4.c:2856 sam4_page_write(): Wr Page 37 @ phys address: 0x00404a00 Debug: 1658 13564 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1659 13564 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1660 13564 at91sam4.c:1561 efc_start_command(): Command: 0x5a002501 Debug: 1661 13564 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002501 Debug: 1662 13579 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1663 13579 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1664 13579 at91sam4.c:2856 sam4_page_write(): Wr Page 38 @ phys address: 0x00404c00 Debug: 1665 13764 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1666 13764 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1667 13764 at91sam4.c:1561 efc_start_command(): Command: 0x5a002601 Debug: 1668 13764 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002601 Debug: 1669 13780 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1670 13780 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1671 13780 at91sam4.c:2856 sam4_page_write(): Wr Page 39 @ phys address: 0x00404e00 Debug: 1672 13964 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1673 13964 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1674 13964 at91sam4.c:1561 efc_start_command(): Command: 0x5a002701 Debug: 1675 13964 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002701 Debug: 1676 13980 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1677 13980 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1678 13980 at91sam4.c:2856 sam4_page_write(): Wr Page 40 @ phys address: 0x00405000 Debug: 1679 14165 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1680 14165 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1681 14165 at91sam4.c:1561 efc_start_command(): Command: 0x5a002801 Debug: 1682 14165 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002801 Debug: 1683 14181 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1684 14181 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1685 14181 at91sam4.c:2856 sam4_page_write(): Wr Page 41 @ phys address: 0x00405200 Debug: 1686 14365 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1687 14365 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1688 14365 at91sam4.c:1561 efc_start_command(): Command: 0x5a002901 Debug: 1689 14365 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002901 Debug: 1690 14381 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1691 14381 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1692 14381 at91sam4.c:2856 sam4_page_write(): Wr Page 42 @ phys address: 0x00405400 Debug: 1693 14566 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1694 14566 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1695 14566 at91sam4.c:1561 efc_start_command(): Command: 0x5a002a01 Debug: 1696 14566 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002a01 Debug: 1697 14582 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1698 14582 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1699 14582 at91sam4.c:2856 sam4_page_write(): Wr Page 43 @ phys address: 0x00405600 Debug: 1700 14766 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1701 14766 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1702 14766 at91sam4.c:1561 efc_start_command(): Command: 0x5a002b01 Debug: 1703 14766 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002b01 Debug: 1704 14782 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1705 14782 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1706 14782 at91sam4.c:2856 sam4_page_write(): Wr Page 44 @ phys address: 0x00405800 Debug: 1707 14967 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1708 14967 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1709 14967 at91sam4.c:1561 efc_start_command(): Command: 0x5a002c01 Debug: 1710 14967 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002c01 Debug: 1711 14983 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1712 14983 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1713 14983 at91sam4.c:2856 sam4_page_write(): Wr Page 45 @ phys address: 0x00405a00 Debug: 1714 15167 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1715 15167 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1716 15167 at91sam4.c:1561 efc_start_command(): Command: 0x5a002d01 Debug: 1717 15167 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002d01 Debug: 1718 15183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1719 15183 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1720 15183 at91sam4.c:2856 sam4_page_write(): Wr Page 46 @ phys address: 0x00405c00 Debug: 1721 15368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1722 15368 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1723 15368 at91sam4.c:1561 efc_start_command(): Command: 0x5a002e01 Debug: 1724 15368 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002e01 Debug: 1725 15368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1726 15368 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1727 15368 at91sam4.c:2856 sam4_page_write(): Wr Page 47 @ phys address: 0x00405e00 Debug: 1728 15568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1729 15568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1730 15568 at91sam4.c:1561 efc_start_command(): Command: 0x5a002f01 Debug: 1731 15568 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a002f01 Debug: 1732 15568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1733 15568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1734 15568 at91sam4.c:2856 sam4_page_write(): Wr Page 48 @ phys address: 0x00406000 Debug: 1735 15769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1736 15769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1737 15769 at91sam4.c:1561 efc_start_command(): Command: 0x5a003001 Debug: 1738 15769 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003001 Debug: 1739 15769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1740 15769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1741 15769 at91sam4.c:2856 sam4_page_write(): Wr Page 49 @ phys address: 0x00406200 Debug: 1742 15969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1743 15969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1744 15969 at91sam4.c:1561 efc_start_command(): Command: 0x5a003101 Debug: 1745 15969 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003101 Debug: 1746 15969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1747 15969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1748 15969 at91sam4.c:2856 sam4_page_write(): Wr Page 50 @ phys address: 0x00406400 Debug: 1749 16163 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1750 16163 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1751 16163 at91sam4.c:1561 efc_start_command(): Command: 0x5a003201 Debug: 1752 16163 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003201 Debug: 1753 16170 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1754 16170 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1755 16170 at91sam4.c:2856 sam4_page_write(): Wr Page 51 @ phys address: 0x00406600 Debug: 1756 16364 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1757 16364 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1758 16364 at91sam4.c:1561 efc_start_command(): Command: 0x5a003301 Debug: 1759 16364 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003301 Debug: 1760 16370 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1761 16370 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1762 16370 at91sam4.c:2856 sam4_page_write(): Wr Page 52 @ phys address: 0x00406800 Debug: 1763 16564 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1764 16564 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1765 16564 at91sam4.c:1561 efc_start_command(): Command: 0x5a003401 Debug: 1766 16564 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003401 Debug: 1767 16571 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1768 16571 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1769 16571 at91sam4.c:2856 sam4_page_write(): Wr Page 53 @ phys address: 0x00406a00 Debug: 1770 16765 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1771 16765 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1772 16765 at91sam4.c:1561 efc_start_command(): Command: 0x5a003501 Debug: 1773 16765 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003501 Debug: 1774 16771 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1775 16771 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1776 16771 at91sam4.c:2856 sam4_page_write(): Wr Page 54 @ phys address: 0x00406c00 Debug: 1777 16965 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1778 16965 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1779 16965 at91sam4.c:1561 efc_start_command(): Command: 0x5a003601 Debug: 1780 16965 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003601 Debug: 1781 16972 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1782 16972 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1783 16972 at91sam4.c:2856 sam4_page_write(): Wr Page 55 @ phys address: 0x00406e00 Debug: 1784 17166 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1785 17166 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1786 17166 at91sam4.c:1561 efc_start_command(): Command: 0x5a003701 Debug: 1787 17166 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003701 Debug: 1788 17172 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1789 17172 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1790 17172 at91sam4.c:2856 sam4_page_write(): Wr Page 56 @ phys address: 0x00407000 Debug: 1791 17366 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1792 17366 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1793 17366 at91sam4.c:1561 efc_start_command(): Command: 0x5a003801 Debug: 1794 17366 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003801 Debug: 1795 17373 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1796 17373 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1797 17373 at91sam4.c:2856 sam4_page_write(): Wr Page 57 @ phys address: 0x00407200 Debug: 1798 17567 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1799 17567 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1800 17567 at91sam4.c:1561 efc_start_command(): Command: 0x5a003901 Debug: 1801 17567 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003901 Debug: 1802 17573 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1803 17573 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1804 17573 at91sam4.c:2856 sam4_page_write(): Wr Page 58 @ phys address: 0x00407400 Debug: 1805 17767 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1806 17767 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1807 17767 at91sam4.c:1561 efc_start_command(): Command: 0x5a003a01 Debug: 1808 17767 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003a01 Debug: 1809 17774 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1810 17774 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1811 17774 at91sam4.c:2856 sam4_page_write(): Wr Page 59 @ phys address: 0x00407600 Debug: 1812 17968 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1813 17968 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1814 17968 at91sam4.c:1561 efc_start_command(): Command: 0x5a003b01 Debug: 1815 17968 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003b01 Debug: 1816 17974 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1817 17974 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1818 17974 at91sam4.c:2856 sam4_page_write(): Wr Page 60 @ phys address: 0x00407800 Debug: 1819 18168 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1820 18168 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1821 18168 at91sam4.c:1561 efc_start_command(): Command: 0x5a003c01 Debug: 1822 18168 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003c01 Debug: 1823 18175 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1824 18175 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1825 18175 at91sam4.c:2856 sam4_page_write(): Wr Page 61 @ phys address: 0x00407a00 Debug: 1826 18369 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1827 18369 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1828 18369 at91sam4.c:1561 efc_start_command(): Command: 0x5a003d01 Debug: 1829 18369 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003d01 Debug: 1830 18375 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1831 18375 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1832 18375 at91sam4.c:2856 sam4_page_write(): Wr Page 62 @ phys address: 0x00407c00 Debug: 1833 18569 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1834 18569 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1835 18569 at91sam4.c:1561 efc_start_command(): Command: 0x5a003e01 Debug: 1836 18569 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003e01 Debug: 1837 18576 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1838 18576 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1839 18576 at91sam4.c:2856 sam4_page_write(): Wr Page 63 @ phys address: 0x00407e00 Debug: 1840 18754 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1841 18754 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1842 18754 at91sam4.c:1561 efc_start_command(): Command: 0x5a003f01 Debug: 1843 18754 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a003f01 Debug: 1844 18776 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1845 18776 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1846 18776 at91sam4.c:2856 sam4_page_write(): Wr Page 64 @ phys address: 0x00408000 Debug: 1847 18955 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1848 18955 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1849 18955 at91sam4.c:1561 efc_start_command(): Command: 0x5a004001 Debug: 1850 18955 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004001 Debug: 1851 18977 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1852 18977 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1853 18977 at91sam4.c:2856 sam4_page_write(): Wr Page 65 @ phys address: 0x00408200 Debug: 1854 19155 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1855 19155 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1856 19155 at91sam4.c:1561 efc_start_command(): Command: 0x5a004101 Debug: 1857 19155 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004101 Debug: 1858 19177 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1859 19177 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1860 19177 at91sam4.c:2856 sam4_page_write(): Wr Page 66 @ phys address: 0x00408400 Debug: 1861 19356 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1862 19356 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1863 19356 at91sam4.c:1561 efc_start_command(): Command: 0x5a004201 Debug: 1864 19356 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004201 Debug: 1865 19378 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1866 19378 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1867 19378 at91sam4.c:2856 sam4_page_write(): Wr Page 67 @ phys address: 0x00408600 Debug: 1868 19556 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1869 19556 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1870 19556 at91sam4.c:1561 efc_start_command(): Command: 0x5a004301 Debug: 1871 19556 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004301 Debug: 1872 19578 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1873 19578 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1874 19578 at91sam4.c:2856 sam4_page_write(): Wr Page 68 @ phys address: 0x00408800 Debug: 1875 19757 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1876 19757 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1877 19757 at91sam4.c:1561 efc_start_command(): Command: 0x5a004401 Debug: 1878 19757 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004401 Debug: 1879 19779 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1880 19779 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1881 19779 at91sam4.c:2856 sam4_page_write(): Wr Page 69 @ phys address: 0x00408a00 Debug: 1882 19957 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1883 19957 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1884 19957 at91sam4.c:1561 efc_start_command(): Command: 0x5a004501 Debug: 1885 19957 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004501 Debug: 1886 19979 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1887 19979 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1888 19979 at91sam4.c:2856 sam4_page_write(): Wr Page 70 @ phys address: 0x00408c00 Debug: 1889 20157 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1890 20157 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1891 20157 at91sam4.c:1561 efc_start_command(): Command: 0x5a004601 Debug: 1892 20157 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004601 Debug: 1893 20180 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1894 20180 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1895 20180 at91sam4.c:2856 sam4_page_write(): Wr Page 71 @ phys address: 0x00408e00 Debug: 1896 20358 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1897 20358 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1898 20358 at91sam4.c:1561 efc_start_command(): Command: 0x5a004701 Debug: 1899 20358 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004701 Debug: 1900 20380 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1901 20380 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1902 20380 at91sam4.c:2856 sam4_page_write(): Wr Page 72 @ phys address: 0x00409000 Debug: 1903 20558 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1904 20558 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1905 20558 at91sam4.c:1561 efc_start_command(): Command: 0x5a004801 Debug: 1906 20558 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004801 Debug: 1907 20581 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1908 20581 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1909 20581 at91sam4.c:2856 sam4_page_write(): Wr Page 73 @ phys address: 0x00409200 Debug: 1910 20759 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1911 20759 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1912 20759 at91sam4.c:1561 efc_start_command(): Command: 0x5a004901 Debug: 1913 20759 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004901 Debug: 1914 20781 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1915 20781 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1916 20781 at91sam4.c:2856 sam4_page_write(): Wr Page 74 @ phys address: 0x00409400 Debug: 1917 20959 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1918 20959 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1919 20959 at91sam4.c:1561 efc_start_command(): Command: 0x5a004a01 Debug: 1920 20959 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004a01 Debug: 1921 20982 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1922 20982 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1923 20982 at91sam4.c:2856 sam4_page_write(): Wr Page 75 @ phys address: 0x00409600 Debug: 1924 21160 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1925 21160 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1926 21160 at91sam4.c:1561 efc_start_command(): Command: 0x5a004b01 Debug: 1927 21160 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004b01 Debug: 1928 21182 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1929 21182 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1930 21182 at91sam4.c:2856 sam4_page_write(): Wr Page 76 @ phys address: 0x00409800 Debug: 1931 21360 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1932 21360 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1933 21360 at91sam4.c:1561 efc_start_command(): Command: 0x5a004c01 Debug: 1934 21360 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004c01 Debug: 1935 21383 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1936 21383 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1937 21383 at91sam4.c:2856 sam4_page_write(): Wr Page 77 @ phys address: 0x00409a00 Debug: 1938 21561 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1939 21561 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1940 21561 at91sam4.c:1561 efc_start_command(): Command: 0x5a004d01 Debug: 1941 21561 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004d01 Debug: 1942 21583 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1943 21583 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1944 21583 at91sam4.c:2856 sam4_page_write(): Wr Page 78 @ phys address: 0x00409c00 Debug: 1945 21761 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1946 21761 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1947 21761 at91sam4.c:1561 efc_start_command(): Command: 0x5a004e01 Debug: 1948 21761 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004e01 Debug: 1949 21777 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1950 21777 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1951 21777 at91sam4.c:2856 sam4_page_write(): Wr Page 79 @ phys address: 0x00409e00 Debug: 1952 21962 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1953 21962 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1954 21962 at91sam4.c:1561 efc_start_command(): Command: 0x5a004f01 Debug: 1955 21962 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a004f01 Debug: 1956 21978 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1957 21978 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1958 21978 at91sam4.c:2856 sam4_page_write(): Wr Page 80 @ phys address: 0x0040a000 Debug: 1959 22162 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1960 22162 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1961 22162 at91sam4.c:1561 efc_start_command(): Command: 0x5a005001 Debug: 1962 22162 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005001 Debug: 1963 22178 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1964 22178 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1965 22178 at91sam4.c:2856 sam4_page_write(): Wr Page 81 @ phys address: 0x0040a200 Debug: 1966 22363 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1967 22363 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1968 22363 at91sam4.c:1561 efc_start_command(): Command: 0x5a005101 Debug: 1969 22363 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005101 Debug: 1970 22378 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1971 22378 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1972 22378 at91sam4.c:2856 sam4_page_write(): Wr Page 82 @ phys address: 0x0040a400 Debug: 1973 22563 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1974 22563 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1975 22563 at91sam4.c:1561 efc_start_command(): Command: 0x5a005201 Debug: 1976 22563 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005201 Debug: 1977 22579 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1978 22579 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1979 22579 at91sam4.c:2856 sam4_page_write(): Wr Page 83 @ phys address: 0x0040a600 Debug: 1980 22764 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1981 22764 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1982 22764 at91sam4.c:1561 efc_start_command(): Command: 0x5a005301 Debug: 1983 22764 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005301 Debug: 1984 22779 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1985 22779 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1986 22779 at91sam4.c:2856 sam4_page_write(): Wr Page 84 @ phys address: 0x0040a800 Debug: 1987 22964 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1988 22964 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1989 22964 at91sam4.c:1561 efc_start_command(): Command: 0x5a005401 Debug: 1990 22964 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005401 Debug: 1991 22980 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1992 22980 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1993 22980 at91sam4.c:2856 sam4_page_write(): Wr Page 85 @ phys address: 0x0040aa00 Debug: 1994 23165 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1995 23165 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 1996 23165 at91sam4.c:1561 efc_start_command(): Command: 0x5a005501 Debug: 1997 23165 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005501 Debug: 1998 23180 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 1999 23180 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2000 23180 at91sam4.c:2856 sam4_page_write(): Wr Page 86 @ phys address: 0x0040ac00 Debug: 2001 23365 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2002 23365 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2003 23365 at91sam4.c:1561 efc_start_command(): Command: 0x5a005601 Debug: 2004 23365 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005601 Debug: 2005 23381 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2006 23381 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2007 23381 at91sam4.c:2856 sam4_page_write(): Wr Page 87 @ phys address: 0x0040ae00 Debug: 2008 23566 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2009 23566 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2010 23566 at91sam4.c:1561 efc_start_command(): Command: 0x5a005701 Debug: 2011 23566 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005701 Debug: 2012 23581 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2013 23581 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2014 23581 at91sam4.c:2856 sam4_page_write(): Wr Page 88 @ phys address: 0x0040b000 Debug: 2015 23766 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2016 23766 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2017 23766 at91sam4.c:1561 efc_start_command(): Command: 0x5a005801 Debug: 2018 23766 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005801 Debug: 2019 23782 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2020 23782 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2021 23782 at91sam4.c:2856 sam4_page_write(): Wr Page 89 @ phys address: 0x0040b200 Debug: 2022 23967 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2023 23967 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2024 23967 at91sam4.c:1561 efc_start_command(): Command: 0x5a005901 Debug: 2025 23967 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005901 Debug: 2026 23982 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2027 23982 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2028 23982 at91sam4.c:2856 sam4_page_write(): Wr Page 90 @ phys address: 0x0040b400 Debug: 2029 24167 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2030 24167 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2031 24167 at91sam4.c:1561 efc_start_command(): Command: 0x5a005a01 Debug: 2032 24167 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005a01 Debug: 2033 24183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2034 24183 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2035 24183 at91sam4.c:2856 sam4_page_write(): Wr Page 91 @ phys address: 0x0040b600 Debug: 2036 24368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2037 24368 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2038 24368 at91sam4.c:1561 efc_start_command(): Command: 0x5a005b01 Debug: 2039 24368 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005b01 Debug: 2040 24383 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2041 24383 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2042 24383 at91sam4.c:2856 sam4_page_write(): Wr Page 92 @ phys address: 0x0040b800 Debug: 2043 24568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2044 24568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2045 24568 at91sam4.c:1561 efc_start_command(): Command: 0x5a005c01 Debug: 2046 24568 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005c01 Debug: 2047 24568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2048 24568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2049 24568 at91sam4.c:2856 sam4_page_write(): Wr Page 93 @ phys address: 0x0040ba00 Debug: 2050 24769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2051 24769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2052 24769 at91sam4.c:1561 efc_start_command(): Command: 0x5a005d01 Debug: 2053 24769 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005d01 Debug: 2054 24769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2055 24769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2056 24769 at91sam4.c:2856 sam4_page_write(): Wr Page 94 @ phys address: 0x0040bc00 Debug: 2057 24969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2058 24969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2059 24969 at91sam4.c:1561 efc_start_command(): Command: 0x5a005e01 Debug: 2060 24969 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005e01 Debug: 2061 24969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2062 24969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2063 24969 at91sam4.c:2856 sam4_page_write(): Wr Page 95 @ phys address: 0x0040be00 Debug: 2064 25154 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2065 25154 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2066 25154 at91sam4.c:1561 efc_start_command(): Command: 0x5a005f01 Debug: 2067 25154 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a005f01 Debug: 2068 25170 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2069 25170 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2070 25170 at91sam4.c:2856 sam4_page_write(): Wr Page 96 @ phys address: 0x0040c000 Debug: 2071 25355 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2072 25355 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2073 25355 at91sam4.c:1561 efc_start_command(): Command: 0x5a006001 Debug: 2074 25355 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006001 Debug: 2075 25370 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2076 25370 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2077 25370 at91sam4.c:2856 sam4_page_write(): Wr Page 97 @ phys address: 0x0040c200 Debug: 2078 25555 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2079 25555 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2080 25555 at91sam4.c:1561 efc_start_command(): Command: 0x5a006101 Debug: 2081 25555 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006101 Debug: 2082 25571 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2083 25571 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2084 25571 at91sam4.c:2856 sam4_page_write(): Wr Page 98 @ phys address: 0x0040c400 Debug: 2085 25756 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2086 25756 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2087 25756 at91sam4.c:1561 efc_start_command(): Command: 0x5a006201 Debug: 2088 25756 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006201 Debug: 2089 25771 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2090 25771 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2091 25771 at91sam4.c:2856 sam4_page_write(): Wr Page 99 @ phys address: 0x0040c600 Debug: 2092 25956 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2093 25956 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2094 25956 at91sam4.c:1561 efc_start_command(): Command: 0x5a006301 Debug: 2095 25956 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006301 Debug: 2096 25972 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2097 25972 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2098 25972 at91sam4.c:2856 sam4_page_write(): Wr Page 100 @ phys address: 0x0040c800 Debug: 2099 26157 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2100 26157 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2101 26157 at91sam4.c:1561 efc_start_command(): Command: 0x5a006401 Debug: 2102 26157 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006401 Debug: 2103 26172 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2104 26172 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2105 26172 at91sam4.c:2856 sam4_page_write(): Wr Page 101 @ phys address: 0x0040ca00 Debug: 2106 26357 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2107 26357 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2108 26357 at91sam4.c:1561 efc_start_command(): Command: 0x5a006501 Debug: 2109 26357 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006501 Debug: 2110 26373 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2111 26373 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2112 26373 at91sam4.c:2856 sam4_page_write(): Wr Page 102 @ phys address: 0x0040cc00 Debug: 2113 26557 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2114 26557 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2115 26557 at91sam4.c:1561 efc_start_command(): Command: 0x5a006601 Debug: 2116 26557 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006601 Debug: 2117 26573 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2118 26573 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2119 26573 at91sam4.c:2856 sam4_page_write(): Wr Page 103 @ phys address: 0x0040ce00 Debug: 2120 26758 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2121 26758 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2122 26758 at91sam4.c:1561 efc_start_command(): Command: 0x5a006701 Debug: 2123 26758 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006701 Debug: 2124 26774 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2125 26774 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2126 26774 at91sam4.c:2856 sam4_page_write(): Wr Page 104 @ phys address: 0x0040d000 Debug: 2127 26958 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2128 26958 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2129 26958 at91sam4.c:1561 efc_start_command(): Command: 0x5a006801 Debug: 2130 26958 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006801 Debug: 2131 26974 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2132 26974 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2133 26974 at91sam4.c:2856 sam4_page_write(): Wr Page 105 @ phys address: 0x0040d200 Debug: 2134 27159 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2135 27159 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2136 27159 at91sam4.c:1561 efc_start_command(): Command: 0x5a006901 Debug: 2137 27159 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006901 Debug: 2138 27175 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2139 27175 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2140 27175 at91sam4.c:2856 sam4_page_write(): Wr Page 106 @ phys address: 0x0040d400 Debug: 2141 27359 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2142 27359 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2143 27359 at91sam4.c:1561 efc_start_command(): Command: 0x5a006a01 Debug: 2144 27359 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006a01 Debug: 2145 27375 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2146 27375 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2147 27375 at91sam4.c:2856 sam4_page_write(): Wr Page 107 @ phys address: 0x0040d600 Debug: 2148 27560 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2149 27560 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2150 27560 at91sam4.c:1561 efc_start_command(): Command: 0x5a006b01 Debug: 2151 27560 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006b01 Debug: 2152 27576 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2153 27576 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2154 27576 at91sam4.c:2856 sam4_page_write(): Wr Page 108 @ phys address: 0x0040d800 Debug: 2155 27760 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2156 27760 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2157 27760 at91sam4.c:1561 efc_start_command(): Command: 0x5a006c01 Debug: 2158 27760 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006c01 Debug: 2159 27776 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2160 27776 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2161 27776 at91sam4.c:2856 sam4_page_write(): Wr Page 109 @ phys address: 0x0040da00 Debug: 2162 27961 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2163 27961 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2164 27961 at91sam4.c:1561 efc_start_command(): Command: 0x5a006d01 Debug: 2165 27961 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006d01 Debug: 2166 27977 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2167 27977 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2168 27977 at91sam4.c:2856 sam4_page_write(): Wr Page 110 @ phys address: 0x0040dc00 Debug: 2169 28161 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2170 28161 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2171 28161 at91sam4.c:1561 efc_start_command(): Command: 0x5a006e01 Debug: 2172 28161 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006e01 Debug: 2173 28177 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2174 28177 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2175 28177 at91sam4.c:2856 sam4_page_write(): Wr Page 111 @ phys address: 0x0040de00 Debug: 2176 28362 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2177 28362 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2178 28362 at91sam4.c:1561 efc_start_command(): Command: 0x5a006f01 Debug: 2179 28362 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a006f01 Debug: 2180 28378 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2181 28378 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2182 28378 at91sam4.c:2856 sam4_page_write(): Wr Page 112 @ phys address: 0x0040e000 Debug: 2183 28562 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2184 28562 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2185 28562 at91sam4.c:1561 efc_start_command(): Command: 0x5a007001 Debug: 2186 28562 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007001 Debug: 2187 28578 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2188 28578 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2189 28578 at91sam4.c:2856 sam4_page_write(): Wr Page 113 @ phys address: 0x0040e200 Debug: 2190 28763 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2191 28763 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2192 28763 at91sam4.c:1561 efc_start_command(): Command: 0x5a007101 Debug: 2193 28763 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007101 Debug: 2194 28778 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2195 28778 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2196 28778 at91sam4.c:2856 sam4_page_write(): Wr Page 114 @ phys address: 0x0040e400 Debug: 2197 28963 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2198 28963 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2199 28963 at91sam4.c:1561 efc_start_command(): Command: 0x5a007201 Debug: 2200 28963 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007201 Debug: 2201 28979 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2202 28979 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2203 28979 at91sam4.c:2856 sam4_page_write(): Wr Page 115 @ phys address: 0x0040e600 Debug: 2204 29164 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2205 29164 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2206 29164 at91sam4.c:1561 efc_start_command(): Command: 0x5a007301 Debug: 2207 29164 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007301 Debug: 2208 29179 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2209 29179 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2210 29179 at91sam4.c:2856 sam4_page_write(): Wr Page 116 @ phys address: 0x0040e800 Debug: 2211 29364 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2212 29364 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2213 29364 at91sam4.c:1561 efc_start_command(): Command: 0x5a007401 Debug: 2214 29364 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007401 Debug: 2215 29380 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2216 29380 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2217 29380 at91sam4.c:2856 sam4_page_write(): Wr Page 117 @ phys address: 0x0040ea00 Debug: 2218 29565 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2219 29565 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2220 29565 at91sam4.c:1561 efc_start_command(): Command: 0x5a007501 Debug: 2221 29565 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007501 Debug: 2222 29580 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2223 29580 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2224 29580 at91sam4.c:2856 sam4_page_write(): Wr Page 118 @ phys address: 0x0040ec00 Debug: 2225 29765 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2226 29765 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2227 29765 at91sam4.c:1561 efc_start_command(): Command: 0x5a007601 Debug: 2228 29765 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007601 Debug: 2229 29781 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2230 29781 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2231 29781 at91sam4.c:2856 sam4_page_write(): Wr Page 119 @ phys address: 0x0040ee00 Debug: 2232 29964 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2233 29964 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2234 29964 at91sam4.c:1561 efc_start_command(): Command: 0x5a007701 Debug: 2235 29964 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007701 Debug: 2236 29980 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2237 29980 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2238 29980 at91sam4.c:2856 sam4_page_write(): Wr Page 120 @ phys address: 0x0040f000 Debug: 2239 30163 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2240 30163 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2241 30163 at91sam4.c:1561 efc_start_command(): Command: 0x5a007801 Debug: 2242 30163 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007801 Debug: 2243 30179 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2244 30179 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2245 30179 at91sam4.c:2856 sam4_page_write(): Wr Page 121 @ phys address: 0x0040f200 Debug: 2246 30366 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2247 30366 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2248 30366 at91sam4.c:1561 efc_start_command(): Command: 0x5a007901 Debug: 2249 30366 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007901 Debug: 2250 30382 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2251 30382 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2252 30382 at91sam4.c:2856 sam4_page_write(): Wr Page 122 @ phys address: 0x0040f400 Debug: 2253 30566 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2254 30566 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2255 30566 at91sam4.c:1561 efc_start_command(): Command: 0x5a007a01 Debug: 2256 30566 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007a01 Debug: 2257 30582 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2258 30582 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2259 30582 at91sam4.c:2856 sam4_page_write(): Wr Page 123 @ phys address: 0x0040f600 Debug: 2260 30767 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2261 30767 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2262 30767 at91sam4.c:1561 efc_start_command(): Command: 0x5a007b01 Debug: 2263 30767 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007b01 Debug: 2264 30783 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2265 30783 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2266 30783 at91sam4.c:2856 sam4_page_write(): Wr Page 124 @ phys address: 0x0040f800 Debug: 2267 30967 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2268 30967 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2269 30967 at91sam4.c:1561 efc_start_command(): Command: 0x5a007c01 Debug: 2270 30967 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007c01 Debug: 2271 30983 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2272 30983 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2273 30983 at91sam4.c:2856 sam4_page_write(): Wr Page 125 @ phys address: 0x0040fa00 Debug: 2274 31168 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2275 31168 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2276 31168 at91sam4.c:1561 efc_start_command(): Command: 0x5a007d01 Debug: 2277 31168 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007d01 Debug: 2278 31183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2279 31183 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2280 31183 at91sam4.c:2856 sam4_page_write(): Wr Page 126 @ phys address: 0x0040fc00 Debug: 2281 31368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2282 31368 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2283 31368 at91sam4.c:1561 efc_start_command(): Command: 0x5a007e01 Debug: 2284 31368 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007e01 Debug: 2285 31368 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2286 31368 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2287 31368 at91sam4.c:2856 sam4_page_write(): Wr Page 127 @ phys address: 0x0040fe00 Debug: 2288 31569 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2289 31569 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2290 31569 at91sam4.c:1561 efc_start_command(): Command: 0x5a007f01 Debug: 2291 31569 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a007f01 Debug: 2292 31569 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2293 31569 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2294 31569 at91sam4.c:2856 sam4_page_write(): Wr Page 128 @ phys address: 0x00410000 Debug: 2295 31769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2296 31769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2297 31769 at91sam4.c:1561 efc_start_command(): Command: 0x5a008001 Debug: 2298 31769 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008001 Debug: 2299 31769 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2300 31769 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2301 31769 at91sam4.c:2856 sam4_page_write(): Wr Page 129 @ phys address: 0x00410200 Debug: 2302 31954 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2303 31954 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2304 31954 at91sam4.c:1561 efc_start_command(): Command: 0x5a008101 Debug: 2305 31954 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008101 Debug: 2306 31970 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2307 31970 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2308 31970 at91sam4.c:2856 sam4_page_write(): Wr Page 130 @ phys address: 0x00410400 Debug: 2309 32155 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2310 32155 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2311 32155 at91sam4.c:1561 efc_start_command(): Command: 0x5a008201 Debug: 2312 32155 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008201 Debug: 2313 32170 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2314 32170 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2315 32170 at91sam4.c:2856 sam4_page_write(): Wr Page 131 @ phys address: 0x00410600 Debug: 2316 32355 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2317 32355 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2318 32355 at91sam4.c:1561 efc_start_command(): Command: 0x5a008301 Debug: 2319 32355 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008301 Debug: 2320 32371 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2321 32371 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2322 32371 at91sam4.c:2856 sam4_page_write(): Wr Page 132 @ phys address: 0x00410800 Debug: 2323 32556 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2324 32556 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2325 32556 at91sam4.c:1561 efc_start_command(): Command: 0x5a008401 Debug: 2326 32556 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008401 Debug: 2327 32571 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2328 32571 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2329 32571 at91sam4.c:2856 sam4_page_write(): Wr Page 133 @ phys address: 0x00410a00 Debug: 2330 32756 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2331 32756 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2332 32756 at91sam4.c:1561 efc_start_command(): Command: 0x5a008501 Debug: 2333 32756 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008501 Debug: 2334 32772 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2335 32772 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2336 32772 at91sam4.c:2856 sam4_page_write(): Wr Page 134 @ phys address: 0x00410c00 Debug: 2337 32957 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2338 32957 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2339 32957 at91sam4.c:1561 efc_start_command(): Command: 0x5a008601 Debug: 2340 32957 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008601 Debug: 2341 32972 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2342 32972 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2343 32972 at91sam4.c:2856 sam4_page_write(): Wr Page 135 @ phys address: 0x00410e00 Debug: 2344 33157 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2345 33157 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2346 33157 at91sam4.c:1561 efc_start_command(): Command: 0x5a008701 Debug: 2347 33157 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008701 Debug: 2348 33173 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2349 33173 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2350 33173 at91sam4.c:2856 sam4_page_write(): Wr Page 136 @ phys address: 0x00411000 Debug: 2351 33358 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2352 33358 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2353 33358 at91sam4.c:1561 efc_start_command(): Command: 0x5a008801 Debug: 2354 33358 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008801 Debug: 2355 33373 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2356 33373 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2357 33373 at91sam4.c:2856 sam4_page_write(): Wr Page 137 @ phys address: 0x00411200 Debug: 2358 33558 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2359 33558 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2360 33558 at91sam4.c:1561 efc_start_command(): Command: 0x5a008901 Debug: 2361 33558 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008901 Debug: 2362 33574 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2363 33574 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2364 33574 at91sam4.c:2856 sam4_page_write(): Wr Page 138 @ phys address: 0x00411400 Debug: 2365 33759 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2366 33759 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2367 33759 at91sam4.c:1561 efc_start_command(): Command: 0x5a008a01 Debug: 2368 33759 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008a01 Debug: 2369 33774 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2370 33774 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2371 33774 at91sam4.c:2856 sam4_page_write(): Wr Page 139 @ phys address: 0x00411600 Debug: 2372 33959 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2373 33959 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2374 33959 at91sam4.c:1561 efc_start_command(): Command: 0x5a008b01 Debug: 2375 33959 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008b01 Debug: 2376 33975 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2377 33975 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2378 33975 at91sam4.c:2856 sam4_page_write(): Wr Page 140 @ phys address: 0x00411800 Debug: 2379 34160 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2380 34160 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2381 34160 at91sam4.c:1561 efc_start_command(): Command: 0x5a008c01 Debug: 2382 34160 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008c01 Debug: 2383 34175 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2384 34175 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2385 34175 at91sam4.c:2856 sam4_page_write(): Wr Page 141 @ phys address: 0x00411a00 Debug: 2386 34360 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2387 34360 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2388 34360 at91sam4.c:1561 efc_start_command(): Command: 0x5a008d01 Debug: 2389 34360 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008d01 Debug: 2390 34376 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2391 34376 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2392 34376 at91sam4.c:2856 sam4_page_write(): Wr Page 142 @ phys address: 0x00411c00 Debug: 2393 34560 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2394 34560 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2395 34560 at91sam4.c:1561 efc_start_command(): Command: 0x5a008e01 Debug: 2396 34560 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008e01 Debug: 2397 34576 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2398 34576 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2399 34576 at91sam4.c:2856 sam4_page_write(): Wr Page 143 @ phys address: 0x00411e00 Debug: 2400 34761 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2401 34761 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2402 34761 at91sam4.c:1561 efc_start_command(): Command: 0x5a008f01 Debug: 2403 34761 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a008f01 Debug: 2404 34777 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2405 34777 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2406 34777 at91sam4.c:2856 sam4_page_write(): Wr Page 144 @ phys address: 0x00412000 Debug: 2407 34961 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2408 34961 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2409 34961 at91sam4.c:1561 efc_start_command(): Command: 0x5a009001 Debug: 2410 34961 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009001 Debug: 2411 34977 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2412 34977 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2413 34977 at91sam4.c:2856 sam4_page_write(): Wr Page 145 @ phys address: 0x00412200 Debug: 2414 35162 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2415 35162 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2416 35162 at91sam4.c:1561 efc_start_command(): Command: 0x5a009101 Debug: 2417 35162 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009101 Debug: 2418 35178 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2419 35178 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2420 35178 at91sam4.c:2856 sam4_page_write(): Wr Page 146 @ phys address: 0x00412400 Debug: 2421 35362 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2422 35362 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2423 35362 at91sam4.c:1561 efc_start_command(): Command: 0x5a009201 Debug: 2424 35362 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009201 Debug: 2425 35378 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2426 35378 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2427 35378 at91sam4.c:2856 sam4_page_write(): Wr Page 147 @ phys address: 0x00412600 Debug: 2428 35563 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2429 35563 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2430 35563 at91sam4.c:1561 efc_start_command(): Command: 0x5a009301 Debug: 2431 35563 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009301 Debug: 2432 35579 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2433 35579 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2434 35579 at91sam4.c:2856 sam4_page_write(): Wr Page 148 @ phys address: 0x00412800 Debug: 2435 35763 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2436 35763 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2437 35763 at91sam4.c:1561 efc_start_command(): Command: 0x5a009401 Debug: 2438 35763 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009401 Debug: 2439 35779 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2440 35779 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2441 35779 at91sam4.c:2856 sam4_page_write(): Wr Page 149 @ phys address: 0x00412a00 Debug: 2442 35964 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2443 35964 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2444 35964 at91sam4.c:1561 efc_start_command(): Command: 0x5a009501 Debug: 2445 35964 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009501 Debug: 2446 35980 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2447 35980 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2448 35980 at91sam4.c:2856 sam4_page_write(): Wr Page 150 @ phys address: 0x00412c00 Debug: 2449 36164 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2450 36164 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2451 36164 at91sam4.c:1561 efc_start_command(): Command: 0x5a009601 Debug: 2452 36164 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009601 Debug: 2453 36180 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2454 36180 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2455 36180 at91sam4.c:2856 sam4_page_write(): Wr Page 151 @ phys address: 0x00412e00 Debug: 2456 36365 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2457 36365 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2458 36365 at91sam4.c:1561 efc_start_command(): Command: 0x5a009701 Debug: 2459 36365 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009701 Debug: 2460 36381 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2461 36381 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2462 36381 at91sam4.c:2856 sam4_page_write(): Wr Page 152 @ phys address: 0x00413000 Debug: 2463 36565 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2464 36565 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2465 36565 at91sam4.c:1561 efc_start_command(): Command: 0x5a009801 Debug: 2466 36565 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009801 Debug: 2467 36581 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2468 36581 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2469 36581 at91sam4.c:2856 sam4_page_write(): Wr Page 153 @ phys address: 0x00413200 Debug: 2470 36766 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2471 36766 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2472 36766 at91sam4.c:1561 efc_start_command(): Command: 0x5a009901 Debug: 2473 36766 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009901 Debug: 2474 36782 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2475 36782 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2476 36782 at91sam4.c:2856 sam4_page_write(): Wr Page 154 @ phys address: 0x00413400 Debug: 2477 36966 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2478 36966 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2479 36966 at91sam4.c:1561 efc_start_command(): Command: 0x5a009a01 Debug: 2480 36966 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009a01 Debug: 2481 36982 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2482 36982 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2483 36982 at91sam4.c:2856 sam4_page_write(): Wr Page 155 @ phys address: 0x00413600 Debug: 2484 37167 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2485 37167 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2486 37167 at91sam4.c:1561 efc_start_command(): Command: 0x5a009b01 Debug: 2487 37167 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009b01 Debug: 2488 37183 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2489 37183 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2490 37183 at91sam4.c:2856 sam4_page_write(): Wr Page 156 @ phys address: 0x00413800 Debug: 2491 37367 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2492 37367 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2493 37367 at91sam4.c:1561 efc_start_command(): Command: 0x5a009c01 Debug: 2494 37367 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009c01 Debug: 2495 37383 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2496 37383 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2497 37383 at91sam4.c:2856 sam4_page_write(): Wr Page 157 @ phys address: 0x00413a00 Debug: 2498 37568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2499 37568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2500 37568 at91sam4.c:1561 efc_start_command(): Command: 0x5a009d01 Debug: 2501 37568 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009d01 Debug: 2502 37568 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2503 37568 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2504 37583 at91sam4.c:2856 sam4_page_write(): Wr Page 158 @ phys address: 0x00413c00 Debug: 2505 37768 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2506 37768 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2507 37768 at91sam4.c:1561 efc_start_command(): Command: 0x5a009e01 Debug: 2508 37768 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009e01 Debug: 2509 37768 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2510 37768 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2511 37768 at91sam4.c:2856 sam4_page_write(): Wr Page 159 @ phys address: 0x00413e00 Debug: 2512 37969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2513 37969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2514 37969 at91sam4.c:1561 efc_start_command(): Command: 0x5a009f01 Debug: 2515 37969 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a009f01 Debug: 2516 37969 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2517 37969 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2518 37969 at91sam4.c:2856 sam4_page_write(): Wr Page 160 @ phys address: 0x00414000 Debug: 2519 38169 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2520 38169 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2521 38169 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a001 Debug: 2522 38169 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a001 Debug: 2523 38169 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2524 38169 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2525 38169 at91sam4.c:2856 sam4_page_write(): Wr Page 161 @ phys address: 0x00414200 Debug: 2526 38354 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2527 38354 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2528 38354 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a101 Debug: 2529 38354 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a101 Debug: 2530 38370 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2531 38370 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2532 38370 at91sam4.c:2856 sam4_page_write(): Wr Page 162 @ phys address: 0x00414400 Debug: 2533 38555 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2534 38555 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2535 38555 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a201 Debug: 2536 38555 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a201 Debug: 2537 38570 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2538 38570 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2539 38570 at91sam4.c:2856 sam4_page_write(): Wr Page 163 @ phys address: 0x00414600 Debug: 2540 38755 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2541 38755 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2542 38755 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a301 Debug: 2543 38755 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a301 Debug: 2544 38771 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2545 38771 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2546 38771 at91sam4.c:2856 sam4_page_write(): Wr Page 164 @ phys address: 0x00414800 Debug: 2547 38956 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2548 38956 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2549 38956 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a401 Debug: 2550 38956 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a401 Debug: 2551 38971 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2552 38971 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2553 38971 at91sam4.c:2856 sam4_page_write(): Wr Page 165 @ phys address: 0x00414a00 Debug: 2554 39156 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2555 39156 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2556 39156 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a501 Debug: 2557 39156 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a501 Debug: 2558 39172 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2559 39172 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2560 39172 at91sam4.c:2856 sam4_page_write(): Wr Page 166 @ phys address: 0x00414c00 Debug: 2561 39357 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2562 39357 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2563 39357 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a601 Debug: 2564 39357 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a601 Debug: 2565 39372 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2566 39372 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2567 39372 at91sam4.c:2856 sam4_page_write(): Wr Page 167 @ phys address: 0x00414e00 Debug: 2568 39557 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2569 39557 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2570 39557 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a701 Debug: 2571 39557 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a701 Debug: 2572 39573 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2573 39573 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2574 39573 at91sam4.c:2856 sam4_page_write(): Wr Page 168 @ phys address: 0x00415000 Debug: 2575 39757 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2576 39757 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2577 39757 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a801 Debug: 2578 39757 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a801 Debug: 2579 39773 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2580 39773 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2581 39773 at91sam4.c:2856 sam4_page_write(): Wr Page 169 @ phys address: 0x00415200 Debug: 2582 39958 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2583 39958 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2584 39958 at91sam4.c:1561 efc_start_command(): Command: 0x5a00a901 Debug: 2585 39958 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00a901 Debug: 2586 39974 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2587 39974 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2588 39974 at91sam4.c:2856 sam4_page_write(): Wr Page 170 @ phys address: 0x00415400 Debug: 2589 40158 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2590 40158 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2591 40158 at91sam4.c:1561 efc_start_command(): Command: 0x5a00aa01 Debug: 2592 40158 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00aa01 Debug: 2593 40174 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2594 40174 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2595 40174 at91sam4.c:2856 sam4_page_write(): Wr Page 171 @ phys address: 0x00415600 Debug: 2596 40359 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2597 40359 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2598 40359 at91sam4.c:1561 efc_start_command(): Command: 0x5a00ab01 Debug: 2599 40359 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00ab01 Debug: 2600 40375 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2601 40375 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2602 40375 at91sam4.c:2856 sam4_page_write(): Wr Page 172 @ phys address: 0x00415800 Debug: 2603 40559 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2604 40559 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2605 40559 at91sam4.c:1561 efc_start_command(): Command: 0x5a00ac01 Debug: 2606 40559 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00ac01 Debug: 2607 40575 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2608 40575 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2609 40575 at91sam4.c:2856 sam4_page_write(): Wr Page 173 @ phys address: 0x00415a00 Debug: 2610 40760 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2611 40760 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2612 40760 at91sam4.c:1561 efc_start_command(): Command: 0x5a00ad01 Debug: 2613 40760 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00ad01 Debug: 2614 40776 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2615 40776 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2616 40776 at91sam4.c:2856 sam4_page_write(): Wr Page 174 @ phys address: 0x00415c00 Debug: 2617 40960 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2618 40960 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2619 40960 at91sam4.c:1561 efc_start_command(): Command: 0x5a00ae01 Debug: 2620 40960 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00ae01 Debug: 2621 40976 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2622 40976 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2623 40976 at91sam4.c:2856 sam4_page_write(): Wr Page 175 @ phys address: 0x00415e00 Debug: 2624 41161 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2625 41161 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2626 41161 at91sam4.c:1561 efc_start_command(): Command: 0x5a00af01 Debug: 2627 41161 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00af01 Debug: 2628 41177 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2629 41177 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2630 41177 at91sam4.c:2856 sam4_page_write(): Wr Page 176 @ phys address: 0x00416000 Debug: 2631 41361 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2632 41361 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2633 41361 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b001 Debug: 2634 41361 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b001 Debug: 2635 41377 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2636 41377 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2637 41377 at91sam4.c:2856 sam4_page_write(): Wr Page 177 @ phys address: 0x00416200 Debug: 2638 41562 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2639 41562 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2640 41562 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b101 Debug: 2641 41562 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b101 Debug: 2642 41577 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2643 41577 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2644 41577 at91sam4.c:2856 sam4_page_write(): Wr Page 178 @ phys address: 0x00416400 Debug: 2645 41762 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2646 41762 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2647 41762 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b201 Debug: 2648 41762 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b201 Debug: 2649 41778 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2650 41778 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2651 41778 at91sam4.c:2856 sam4_page_write(): Wr Page 179 @ phys address: 0x00416600 Debug: 2652 41963 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2653 41963 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2654 41963 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b301 Debug: 2655 41963 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b301 Debug: 2656 41978 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2657 41978 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2658 41978 at91sam4.c:2856 sam4_page_write(): Wr Page 180 @ phys address: 0x00416800 Debug: 2659 42163 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2660 42163 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2661 42163 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b401 Debug: 2662 42163 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b401 Debug: 2663 42179 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2664 42179 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2665 42179 at91sam4.c:2856 sam4_page_write(): Wr Page 181 @ phys address: 0x00416a00 Debug: 2666 42364 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2667 42364 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2668 42364 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b501 Debug: 2669 42364 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b501 Debug: 2670 42379 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2671 42379 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2672 42379 at91sam4.c:2856 sam4_page_write(): Wr Page 182 @ phys address: 0x00416c00 Debug: 2673 42564 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2674 42564 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2675 42564 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b601 Debug: 2676 42564 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b601 Debug: 2677 42580 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2678 42580 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2679 42580 at91sam4.c:2856 sam4_page_write(): Wr Page 183 @ phys address: 0x00416e00 Debug: 2680 42765 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2681 42765 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2682 42765 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b701 Debug: 2683 42765 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b701 Debug: 2684 42780 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2685 42780 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2686 42780 at91sam4.c:2856 sam4_page_write(): Wr Page 184 @ phys address: 0x00417000 Debug: 2687 42965 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2688 42965 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2689 42965 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b801 Debug: 2690 42965 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b801 Debug: 2691 42981 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2692 42981 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2693 42981 at91sam4.c:2856 sam4_page_write(): Wr Page 185 @ phys address: 0x00417200 Debug: 2694 43166 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2695 43166 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2696 43166 at91sam4.c:1561 efc_start_command(): Command: 0x5a00b901 Debug: 2697 43166 target.c:2688 target_write_u32(): address: 0x400e0a04, value: 0x5a00b901 Debug: 2698 43181 target.c:2600 target_read_u32(): address: 0x400e0a08, value: 0x00000001 Debug: 2699 43181 at91sam4.c:1454 efc_get_status(): Status: 0x00000001 (lockerror: 0, cmderror: 0, ready: 1) Debug: 2700 43181 at91sam4.c:2856 sam4_page_write(): Wr Page 186 @ phys address: 0x00417400 Error: 2701 43282 cmsis_dap_usb_hid.c:198 cmsis_dap_hid_write(): error writing data: Ein an das System angeschlossenes Gerät funktioniert nicht. Error: 2702 43282 cmsis_dap.c:1550 cmsis_dap_flush(): CMSIS-DAP command CMD_DAP_JTAG_SEQ failed.
