#include #include #include #include #define F_TIMER1 100 // Timer 1 frequency /Hz #define KEY_DDR DDRC #define KEY_PORT PORTC #define KEY_PIN PINC #define H_ENCODER_TASTER 0 // Hand-Encoder Taster #define KEY1 1 #define H_ENCODER_SPUR_B ( 1<<2 ) // Hand-Encoder Spur B #define KEY3 3 #define H_ENCODER_SPUR_A ( 1<<4 ) // Hand-Encoder Spur A volatile char enc_delta; // -128 ... 127 char enc_delta_neu; //////////////////////////////////////////////////////////////////////////////// // void setup() // void setup() { Serial.begin( 9600 ); // put your setup code here, to run once: // Timer 1, CTC mode 4, prescaler 64 TCCR1A = 0; TCCR1B = (1<
