#pragma once #include "MyFRAM_I2C.h" namespace MY_FRAMCONTROL { consteval uint32_t sizeofObject (const auto &data) { return sizeof(data); } consteval uint32_t lengthStructure (const auto &data, const size_t N) { return sizeofObject(data)/N; } constinit uint8_t TWI_BUFFER_SIZE {BUFFER_LENGTH-2}; // 'BUFFER_LENGTH' in twi.h abzüglich 2 Bytes Speicherzellenadressierung } /* I2C Addr | wire0/wire1 | | Capacity in kBit | | | Object for length determination etc. | | | | initial address of object in FRAM | | | | | */ template class MyFramControl // allgemeines Template { static_assert((10<=BUFFER_LENGTH), "TWI buffer size smaller than 10 is possible but not practical, Wire src twi.h" ); static_assert(((initObjAddr+sizeof(myObj)) < (1024UL*memorySize/8)), "Object to large or Addr to high" ); private: MyFRAM_I2C fram; uint32_t calcMemberAddr (const uint32_t objStartIndex, const uint32_t memberOffset) { using namespace MY_FRAMCONTROL; return initObjAddr + (objStartIndex*lengthStructure(myObj,1)) + memberOffset; } public: MyFramControl() = default; uint8_t isConnected (void) { return fram.isConnected(); } uint8_t getError (void) { return fram.getError(); } uint32_t getCellAddr (void) { return fram.getCellAddr(); } void setCellAddr (const uint32_t var) { fram.setCellAddr(var); } void update (const uint32_t objStartIndex, const uint32_t memberOffset, auto &data) { const uint32_t memberAddr = calcMemberAddr(objStartIndex, memberOffset); fram.write(memberAddr, data); } void monitor (Stream &out, uint32_t fromAddr, uint32_t toAddr, const uint8_t width, const uint8_t base = DEC) { fram.monitor (out, fromAddr, toAddr, width, base); } void clear (const uint32_t fromAddr, const uint32_t toAddr) { fram.fill (fromAddr, toAddr, 0xFF); } void clear (const uint32_t fromAddr, const uint32_t toAddr, const uint8_t data) { fram.fill (fromAddr, toAddr, data); } void read (void) { fram.read(initObjAddr, myObj); } void write (void) { fram.write(initObjAddr, myObj); } void readTo (auto(&otherObj)[1]) { fram.read(initObjAddr, otherObj); } void wasBinIch (void) { cout.println("allg. Template"); } }; template class MyFramControl // array Template Spezialisierung { static_assert((10<=BUFFER_LENGTH), "TWI buffer size smaller than 10 is possible but not practical, Wire src twi.h" ); static_assert(((initObjAddr+sizeof(myObj)) < (1024UL*memorySize/8)), "Object to large or Addr to high" ); private: MyFRAM_I2C fram; uint32_t calcMemberAddr (const uint32_t objStartIndex, const uint32_t memberOffset) { using namespace MY_FRAMCONTROL; return initObjAddr + (objStartIndex*lengthStructure(myObj,N)) + memberOffset; } public: MyFramControl() = default; uint8_t isConnected (void) { return fram.isConnected(); } uint8_t getError (void) { return fram.getError(); } uint32_t getCellAddr (void) { return fram.getCellAddr(); } void setCellAddr (const uint32_t var) { fram.setCellAddr(var); } void update (const uint32_t objStartIndex, const uint32_t memberOffset, auto &data) { const uint32_t memberAddr = calcMemberAddr(objStartIndex, memberOffset); fram.write(memberAddr, data); } void monitor (Stream &out, uint32_t fromAddr, uint32_t toAddr, const uint8_t width, const uint8_t base = DEC) { fram.monitor (out, fromAddr, toAddr, width, base); } void clear (const uint32_t fromAddr, const uint32_t toAddr) { fram.fill (fromAddr, toAddr, 0xFF); } void clear (const uint32_t fromAddr, const uint32_t toAddr, const uint8_t data) { fram.fill (fromAddr, toAddr, data); } void read (void) { fram.read(initObjAddr, myObj); } void write (void) { fram.write(initObjAddr, myObj); } void readTo (T(&otherObj)[N]) { fram.read(initObjAddr, otherObj); } void wasBinIch (void) { cout.println("array spez. Template"); } };
