BUS RESET BUS RESET SETUP: 80 06 00 01 00 00 40 00 - Get Standard Device Descriptor (Len:40) IN 12: 12 01 00 02 FF 00 00 40 11 01 11 11 04 00 01 02 03 01 OUT (ACK) BUS RESET SETUP: 00 05 01 00 00 00 00 00 - Set Address: 01 IN (ACK) SETUP: 80 06 00 01 00 00 12 00 - Get Standard Device Descriptor (Len:12) IN 12: 12 01 00 02 FF 00 00 40 11 01 11 11 04 00 01 02 03 01 OUT (ACK) SETUP: 80 06 00 02 00 00 FF 00 - Get Standard Configuration Descriptor (Len:FF) IN 20: 09 02 20 00 01 01 00 C0 32 09 04 00 00 02 FF 00 00 00 07 05 81 02 40 00 00 07 05 02 02 40 00 00 OUT (ACK) SETUP: 80 06 EE 03 00 00 12 00 - Get Standard String Descriptor Index:EE (Len:12) IN 12: 12 03 4D 00 53 00 46 00 54 00 31 00 30 00 30 00 21 00 OUT (ACK) SETUP: 80 06 03 03 09 04 FF 00 - Get Standard String Descriptor Index:03 (Len:FF) (Serial Number) IN 08: 08 03 43 00 43 00 50 00 OUT (ACK) SETUP: C0 21 00 00 04 00 10 00 - Get MS Compatible ID Feature Descriptor (Len:10) IN 10: 28 00 00 00 00 01 04 00 01 00 00 00 00 00 00 00 OUT (ACK) SETUP: C0 21 00 00 04 00 28 00 - Get MS Compatible ID Feature Descriptor (Len:28) IN 28: 28 00 00 00 00 01 04 00 01 00 00 00 00 00 00 00 00 01 57 49 4E 55 53 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 OUT (ACK) SETUP: 80 06 00 03 00 00 FF 00 - Get Standard String Descriptor Index:00 (Len:FF) (Language) IN 04: 04 03 09 04 OUT (ACK) SETUP: 80 06 02 03 09 04 FF 00 - Get Standard String Descriptor Index:02 (Len:FF) (Product) IN 14: 14 03 47 00 42 00 55 00 20 00 23 00 31 00 20 00 76 00 30 00 OUT (ACK) SETUP: 80 06 00 06 00 00 0A 00 - Get Standard Device Qualifier Descriptor Index:00 (Len:0A) SETUP with general error STALL SETUP: C1 21 00 00 05 00 0A 00 - Get MS Extended Properties OS Feature Descriptor (Len:0A) IN 0A: 8E 00 00 00 00 01 05 00 01 00 OUT (ACK) SETUP: C1 21 00 00 05 00 8E 00 - Get MS Extended Properties OS Feature Descriptor (Len:8E) IN 40: 8E 00 00 00 00 01 05 00 01 00 84 00 00 00 01 00 00 00 28 00 44 00 65 00 76 00 69 00 63 00 65 00 49 00 6E 00 74 00 65 00 72 00 66 00 61 00 63 00 65 00 47 00 55 00 49 00 44 00 00 00 4E 00 00 00 IN 40: 7B 00 30 00 31 00 31 00 42 00 42 00 34 00 38 00 39 00 2D 00 38 00 31 00 31 00 45 00 2D 00 34 00 44 00 37 00 42 00 2D 00 41 00 33 00 34 00 38 00 2D 00 30 00 34 00 31 00 42 00 33 00 46 00 38 00 IN 0E: 37 00 32 00 38 00 38 00 34 00 7D 00 00 00 OUT (ACK) SETUP: 80 06 00 01 00 00 12 00 - Get Standard Device Descriptor (Len:12) IN 12: 12 01 00 02 FF 00 00 40 11 01 11 11 04 00 01 02 03 01 OUT (ACK) SETUP: 80 06 00 02 00 00 09 00 - Get Standard Configuration Descriptor (Len:09) IN 09: 09 02 20 00 01 01 00 C0 32 OUT (ACK) SETUP: 80 06 00 02 00 00 20 00 - Get Standard Configuration Descriptor (Len:20) IN 20: 09 02 20 00 01 01 00 C0 32 09 04 00 00 02 FF 00 00 00 07 05 81 02 40 00 00 07 05 02 02 40 00 00 OUT (ACK) SETUP: 80 00 00 00 00 00 02 00 - Get Status IN 02: 01 00 OUT (ACK) SETUP: 00 09 01 00 00 00 00 00 - Set Configuration: 01 IN (ACK) SETUP: 80 06 00 03 00 00 FF 00 - Get Standard String Descriptor Index:00 (Len:FF) (Language) IN 04: 04 03 09 04 OUT (ACK) SETUP: 80 06 01 03 09 04 FF 00 - Get Standard String Descriptor Index:01 (Len:FF) (Manufacturer) IN 2C: 2C 03 49 00 6E 00 67 00 2E 00 20 00 47 00 65 00 72 00 6E 00 6F 00 74 00 20 00 53 00 63 00 68 00 72 00 65 00 69 00 6E 00 65 00 72 00 OUT (ACK) SETUP: 80 06 02 03 09 04 FF 00 - Get Standard String Descriptor Index:02 (Len:FF) (Product) IN 14: 14 03 47 00 42 00 55 00 20 00 23 00 31 00 20 00 76 00 30 00 OUT (ACK)
