Arduino: 1.8.19 (Windows 10), Board: "AVR DB-series (Optiboot), AVR128DB64, 20 MHz crystal, 2.85V, Enabled/Enabled, PF6: Reset (default boot entry on reset pin & SW resets, 1 sec timeout), Default (see documentation), TCB4 (64-pin parts only), Default (doesn't print floats, 1.4k flash use), On all pins, with new implementation., Disabled (burn bootloader req'd), 8ms, 1x Wire, Master or Slave (least Flash & RAM), USART2 (alt): TX PF4, RX PF5 (>28 pin only), Disabled (recommended), No delay before window "opens", Use last FLMAP section, lock FLMAP, provide PROGMEM_MAPPED" C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_164294 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_432184 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_164294 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_432184 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino Using board 'avrdbopti' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Using core 'dxcore' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Detecting libraries used... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for Wire.h: [Wire@2.0.10] ResolveLibrary(Wire.h) -> candidates: [Wire@2.0.10] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for AVRxDB_Pin.h: [AVRxDB_Pin@0.9.7] ResolveLibrary(AVRxDB_Pin.h) -> candidates: [AVRxDB_Pin@0.9.7] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for Streaming.h: [Streaming@6.1.1] ResolveLibrary(Streaming.h) -> candidates: [Streaming@6.1.1] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for TypeTraits.h: [TypeTraits@0.0.9] ResolveLibrary(TypeTraits.h) -> candidates: [TypeTraits@0.0.9] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyToolbox.h: [MyToolbox@1.0.2] ResolveLibrary(MyToolbox.h) -> candidates: [MyToolbox@1.0.2] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for HallsensorBoard.h: [Modellbahn@0.4.0] ResolveLibrary(HallsensorBoard.h) -> candidates: [Modellbahn@0.4.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyPCF8575.h: [MyPCF8575@0.2.0] ResolveLibrary(MyPCF8575.h) -> candidates: [MyPCF8575@0.2.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyPCA9685.h: [MyPCA9685@0.1.0] ResolveLibrary(MyPCA9685.h) -> candidates: [MyPCA9685@0.1.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyTimer.h: [MyTimer@1.0.0] ResolveLibrary(MyTimer.h) -> candidates: [MyTimer@1.0.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyPCF8574.h: [MyPCF8574@0.9.0] ResolveLibrary(MyPCF8574.h) -> candidates: [MyPCF8574@0.9.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyPCA8574.h: [MyPCA8574@0.1.0] ResolveLibrary(MyPCA8574.h) -> candidates: [MyPCA8574@0.1.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for AVRxDB_TCAn_FreqGen.h: [AVRxDB_TCAn_FreqGen@0.1.0] ResolveLibrary(AVRxDB_TCAn_FreqGen.h) -> candidates: [AVRxDB_TCAn_FreqGen@0.1.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for AVRxDB_TCAn.h: [AVRxDB_TCAn@0.9.0] ResolveLibrary(AVRxDB_TCAn.h) -> candidates: [AVRxDB_TCAn@0.9.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyEncoder.h: [MyEncoder@1.0.0] ResolveLibrary(MyEncoder.h) -> candidates: [MyEncoder@1.0.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyFramControl.h: [MyFramControl@0.7.0] ResolveLibrary(MyFramControl.h) -> candidates: [MyFramControl@0.7.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul Alternatives for MyFRAM_I2C.h: [MyFRAM_I2C@0.4.0] ResolveLibrary(MyFRAM_I2C.h) -> candidates: [MyFRAM_I2C@0.4.0] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o nul "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\Wire.cpp" -o nul "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\twi.c" -o nul "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\twi_pins.c" -o nul "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src\\MyPCF8574.cpp" -o nul "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src\\MyPCA8574.cpp" -o nul Generating function prototypes... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\preproc\\ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp.o" In file included from C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:13, from C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:265: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFRAM_I2C\src/MyFRAM_I2C.h:194:40: warning: use of 'auto' in parameter declaration only available with -fconcepts void read(const uint32_t cellAddr, auto &data) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFRAM_I2C\src/MyFRAM_I2C.h:227:41: warning: use of 'auto' in parameter declaration only available with -fconcepts void write(const uint32_t cellAddr, auto &data) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFRAM_I2C\src/MyFRAM_I2C.h:254:15: warning: use of 'auto' in parameter declaration only available with -fconcepts void read(auto &data) { read(currentCellAddr, data); } ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFRAM_I2C\src/MyFRAM_I2C.h:256:16: warning: use of 'auto' in parameter declaration only available with -fconcepts void write(auto &data) { write(currentCellAddr, data); } ^~~~ In file included from C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:265: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:24:44: warning: use of 'auto' in parameter declaration only available with -fconcepts constexpr uint32_t sizeofObject (const auto &data) { return sizeof(data); } ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:25:47: warning: use of 'auto' in parameter declaration only available with -fconcepts constexpr uint32_t lengthStructure (const auto &data, const size_t N) { return sizeofObject(data)/N; } ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:80:77: warning: use of 'auto' in parameter declaration only available with -fconcepts void update (const uint32_t objStartIndex, const uint32_t memberOffset, auto &data) { ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:111:18: warning: use of 'auto' in parameter declaration only available with -fconcepts void readTo (auto(&otherObj)) { fram.read(initObjAddr, otherObj); } ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:113:21: warning: use of 'auto' in parameter declaration only available with -fconcepts void writeFrom (auto(&otherObj)) { fram.write(initObjAddr, otherObj); } ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl\src/MyFramControl.h:147:77: warning: use of 'auto' in parameter declaration only available with -fconcepts void update (const uint32_t objStartIndex, const uint32_t memberOffset, auto &data) { ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:301:33: warning: use of 'auto' in parameter declaration only available with -fconcepts void showDatenObj (Stream &cout, auto &data) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:638:21: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t splitString (auto &string, auto &structure) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:638:35: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t splitString (auto &string, auto &structure) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:666:38: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToCommand (const auto &token, auto &cmd) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:666:51: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToCommand (const auto &token, auto &cmd) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:38: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:51: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:118: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:140: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:739:43: warning: use of 'auto' in parameter declaration only available with -fconcepts void commandProcessing (Stream &out, const auto &data) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:1118:33: warning: use of 'auto' in parameter declaration only available with -fconcepts bool readSerial (Stream &stream, auto &data, const uint8_t LENGTH) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:301:34: warning: use of 'auto' in parameter declaration only available with -fconcepts void showDatenObj (Stream &cout, auto &data) ^~~~ In file included from C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:325: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Modellbahn\src/ControlGleis.h:60:16: warning: use of 'auto' in parameter declaration only available with -fconcepts void update (auto &sens) { ^~~~ In file included from C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:348: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Modellbahn\src/SpeedMeasurement.h:35:18: warning: use of 'auto' in parameter declaration only available with -fconcepts void update (auto &hs) { ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Modellbahn\src/SpeedMeasurement.h:69:16: warning: use of 'auto' in parameter declaration only available with -fconcepts void init (auto &hs) { ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Modellbahn\src/SpeedMeasurement.h:76:16: warning: use of 'auto' in parameter declaration only available with -fconcepts bool calc (auto &hs) { ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:638:22: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t splitString (auto &string, auto &structure) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:638:36: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t splitString (auto &string, auto &structure) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:666:39: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToCommand (const auto &token, auto &cmd) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:666:52: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToCommand (const auto &token, auto &cmd) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:39: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:52: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:119: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:698:141: warning: use of 'auto' in parameter declaration only available with -fconcepts uint8_t transferTokenToInteger (const auto &token, auto &integer, const uint8_t MAXDIGIT, const bool TYPSIGNED, const auto &rangeMin, const auto &rangeMax) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:739:44: warning: use of 'auto' in parameter declaration only available with -fconcepts void commandProcessing (Stream &out, const auto &data) ^~~~ C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\AVR128DB64_5500-0086-V1_Board\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino:1118:34: warning: use of 'auto' in parameter declaration only available with -fconcepts bool readSerial (Stream &stream, auto &data, const uint8_t LENGTH) ^~~~ Compiling libraries... Compiling library "Wire" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\twi.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\twi.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\twi_pins.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\twi_pins.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\Wire.cpp.o" Compiling library "AVRxDB_Pin" Compiling library "Streaming" Compiling library "TypeTraits" Compiling library "MyToolbox" Compiling library "Modellbahn" Compiling library "MyPCF8575" Compiling library "MyPCA9685" Compiling library "MyTimer" Compiling library "MyPCF8574" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src\\MyPCF8574.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\MyPCF8574\\MyPCF8574.cpp.o" Compiling library "MyPCA8574" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\libraries\\Wire\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_Pin\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\TypeTraits\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyToolbox\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Modellbahn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8575\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA9685\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyTimer\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCF8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn_FreqGen\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\AVRxDB_TCAn\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyEncoder\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFramControl\\src" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyFRAM_I2C\\src" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\sketchbook\\libraries\\MyPCA8574\\src\\MyPCA8574.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\MyPCA8574\\MyPCA8574.cpp.o" Compiling library "AVRxDB_TCAn_FreqGen" Compiling library "AVRxDB_TCAn" Compiling library "MyEncoder" Compiling library "MyFramControl" Compiling library "MyFRAM_I2C" Compiling core... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.S" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PD.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PG.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_digital.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\pinswap.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PA.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PA.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\hooks.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_analog.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PF.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PB.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PB.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PC.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_shift.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PE.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART0.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART4.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WMath.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART3.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\new.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Stream.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\PluggableUSB.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\RingBuffer.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART5.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Common.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART2.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\Tone.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_extra.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_extra.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Print.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\String.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\IPAddress.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\main.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART1.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\abi.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PA.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PB.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\core\\wiring_extra.cpp.o" Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Worker\AppData\Local\Temp\arduino_cache_432184\core\core_10ba67014c910c57c04950a9125b31e3.a Linking everything together... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -mrelax -Wl,--gc-sections,--section-start=.text=0x200,--section-start=.FLMAP_SECTION1=0x8000,--section-start=.FLMAP_SECTION2=0x10000,--section-start=.FLMAP_SECTION3=0x18000 -mmcu=avr128db64 -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294/Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.elf" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\sketch\\Modellbahn_TestEncoderInterfacePCF8575_PCA9685_FRAM_016.ino.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\twi.c.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\twi_pins.c.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\MyPCF8574\\MyPCF8574.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294\\libraries\\MyPCA8574\\MyPCA8574.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294/core\\core.a" "-LC:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_164294" -lm c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: --relax and -r may not be used together collect2.exe: error: ld returned 1 exit status lto-wrapper.exe: fatal error: C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc returned 1 exit status compilation terminated. c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed collect2.exe: error: ld returned 1 exit status Bibliothek Wire in Version 2.0.10 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\libraries\Wire wird verwendet Bibliothek AVRxDB_Pin in Version 0.9.7 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\AVRxDB_Pin wird verwendet Bibliothek Streaming in Version 6.1.1 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Streaming wird verwendet Bibliothek TypeTraits in Version 0.0.9 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\TypeTraits wird verwendet Bibliothek MyToolbox in Version 1.0.2 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyToolbox wird verwendet Bibliothek Modellbahn in Version 0.4.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\Modellbahn wird verwendet Bibliothek MyPCF8575 in Version 0.2.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyPCF8575 wird verwendet Bibliothek MyPCA9685 in Version 0.1.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyPCA9685 wird verwendet Bibliothek MyTimer in Version 1.0.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyTimer wird verwendet Bibliothek MyPCF8574 in Version 0.9.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyPCF8574 wird verwendet Bibliothek MyPCA8574 in Version 0.1.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyPCA8574 wird verwendet Bibliothek AVRxDB_TCAn_FreqGen in Version 0.1.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\AVRxDB_TCAn_FreqGen wird verwendet Bibliothek AVRxDB_TCAn in Version 0.9.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\AVRxDB_TCAn wird verwendet Bibliothek MyEncoder in Version 1.0.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyEncoder wird verwendet Bibliothek MyFramControl in Version 0.7.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFramControl wird verwendet Bibliothek MyFRAM_I2C in Version 0.4.0 im Ordner: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries\MyFRAM_I2C wird verwendet exit status 1 Fehler beim Kompilieren für das Board AVR DB-series (Optiboot).
