Arduino: 1.8.19 (Windows 10), Board: "AVR DB-series (Optiboot), AVR128DB64, 20 MHz crystal, 2.85V, Enabled/Enabled, PF6: Reset (default boot entry on reset pin & SW resets, 1 sec timeout), Default (see documentation), TCB4 (64-pin parts only), Default (doesn't print floats, 1.4k flash use), On all pins, with new implementation., Disabled (burn bootloader req'd), 8ms, 1x Wire, Master or Slave (least Flash & RAM), USART2 (alt): TX PF4, RX PF5 (>28 pin only), Disabled (recommended), No delay before window "opens", Use last FLMAP section, lock FLMAP, provide PROGMEM_MAPPED" C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_360282 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_906174 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\_Examples\TCA0_Timertakt\TCA0_Timertakt.ino C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_360282 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_906174 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\_Examples\TCA0_Timertakt\TCA0_Timertakt.ino Using board 'avrdbopti' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Using core 'dxcore' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Detecting libraries used... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\sketch\\TCA0_Timertakt.ino.cpp" -o nul Generating function prototypes... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\sketch\\TCA0_Timertakt.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\preproc\\ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\sketch\\TCA0_Timertakt.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\sketch\\TCA0_Timertakt.ino.cpp.o" Compiling libraries... Compiling core... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.S" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PB.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PB.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PE.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\hooks.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PG.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\pinswap.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_shift.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_analog.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PC.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PF.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PA.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PA.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_digital.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PD.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART4.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART3.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\main.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Common.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\abi.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\RingBuffer.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART5.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\String.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_extra.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_extra.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Stream.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\PluggableUSB.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WMath.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART1.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\Tone.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Print.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART2.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\new.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART0.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\IPAddress.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PA.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PB.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\core\\wiring_extra.cpp.o" Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Worker\AppData\Local\Temp\arduino_cache_906174\core\core_10ba67014c910c57c04950a9125b31e3.a Linking everything together... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -mrelax -Wl,--gc-sections,--section-start=.text=0x200,--section-start=.FLMAP_SECTION1=0x8000,--section-start=.FLMAP_SECTION2=0x10000,--section-start=.FLMAP_SECTION3=0x18000 -mmcu=avr128db64 -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282/TCA0_Timertakt.ino.elf" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282\\sketch\\TCA0_Timertakt.ino.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282/core\\core.a" "-LC:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_360282" -lm c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: --relax and -r may not be used together collect2.exe: error: ld returned 1 exit status lto-wrapper.exe: fatal error: C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc returned 1 exit status compilation terminated. c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed collect2.exe: error: ld returned 1 exit status exit status 1 Fehler beim Kompilieren für das Board AVR DB-series (Optiboot).
