Arduino: 1.8.19 (Windows 10), Board: "AVR DB-series (Optiboot), AVR128DB64, 20 MHz crystal, 2.85V, Enabled/Enabled, PF6: Reset (default boot entry on reset pin & SW resets, 1 sec timeout), Default (see documentation), TCB4 (64-pin parts only), Default (doesn't print floats, 1.4k flash use), On all pins, with new implementation., Disabled (burn bootloader req'd), 8ms, 1x Wire, Master or Slave (least Flash & RAM), USART2 (alt): TX PF4, RX PF5 (>28 pin only), Disabled (recommended), No delay before window "opens", Use last FLMAP section, lock FLMAP, provide PROGMEM_MAPPED" C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_268176 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_430724 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\_Examples\TCA0_Timertakt\TCA0_Timertakt.ino C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\libraries -fqbn=DxCore:megaavr:avrdbopti:chip=avr128db64,clock=20crystal,bodvoltage=2v85,bodmode=enabled,resetpin=reset,entrycond=default,millis=tcb4,printf=default,attach=allenabled,mvioopti=disabled,startuptime=8,wiremode=mors,bootloaderusart=ser2_alt,WDTtimeout=disabled,WDTwindow=disabled,flmap=lockdefault -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_268176 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_430724 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avrdude-6.3.0-arduino17or18.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avrdude\6.3.0-arduino17or18 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-azduino7b1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.python3.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\megaTinyCore\tools\python3\3.7.2-post1 -verbose C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\sketchbook\_Examples\TCA0_Timertakt\TCA0_Timertakt.ino Using board 'avrdbopti' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Using core 'dxcore' from platform in folder: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11 Detecting libraries used... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -v -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\sketch\\TCA0_Timertakt.ino.cpp" -o nul Generating function prototypes... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -v -Wl,-v -w -x c++ -E -CC -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"$\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\sketch\\TCA0_Timertakt.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\preproc\\ctags_target_for_gcc_minus_e.cpp" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-flto' '-v' '-w' '-E' '-CC' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="$"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\preproc\ctags_target_for_gcc_minus_e.cpp' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -E -quiet -CC -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="$" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\preproc\ctags_target_for_gcc_minus_e.cpp -mn-flash=2 -mno-skip-bug -mmcu=avrxmega4 -std=gnu++17 -Wall -Wno-error=narrowing -w -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -g -fworking-directory -Os -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\preproc\\ctags_target_for_gcc_minus_e.cpp" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-flto' '-v' '-w' '-E' '-CC' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="$"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\preproc\ctags_target_for_gcc_minus_e.cpp' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' Sketch wird kompiliert... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\sketch\\TCA0_Timertakt.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\sketch\\TCA0_Timertakt.ino.cpp.o" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase TCA0_Timertakt.ino.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccc3nAPa.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' Compiling libraries... Compiling core... c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o C:\Users\Worker\AppData\Local\Temp\ccc3nAPa.s GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.S" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_pulse.S.o" LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\sketch\TCA0_Timertakt.ino.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\hooks.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PG.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PD.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_pulse.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_digital.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PF.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PA.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PA.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PB.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PB.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_analog.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_shift.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PE.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\pinswap.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WInterrupts_PC.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\WMath.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART1.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART0.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\wiring_extra.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_extra.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\Tone.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART4.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\abi.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Print.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Common.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\main.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART5.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\PluggableUSB.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\String.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\RingBuffer.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\IPAddress.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART3.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\api\\Stream.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\new.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -v -Wl,-v -mmcu=avr128db64 -DF_CPU=20000000L -DCLOCK_SOURCE=1 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB4 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION3 -DARDUINO=10819 -DARDUINO_avrdb -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DSERIAL_PORT_BOOT=Serial2 -DSERIAL_PORT_BOOT_PORTMUX=1 -DUSING_OPTIBOOT "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\64pin-standard" "C:\\Arduino IDE Portable\\AVRxDB\\arduino-1.8.19\\portable\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore\\UART2.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART2.cpp.o" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\WMath.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase WMath.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccZvkESm.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART0.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART0.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccr4WP0m.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART1.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART1.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccJ3t1Ul.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\wiring_extra.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase wiring_extra.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccTQhacm.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART4.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART4.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccFVdFlm.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccrAeUmq.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\abi.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase abi.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccXwbyqq.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\Tone.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase Tone.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccf2Ffyp.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\main.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase main.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cctbiBYp.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\Print.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase Print.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccXOwJ5o.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\Common.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase Common.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccNdRvap.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\PluggableUSB.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase PluggableUSB.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\cchj5Dlo.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART5.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART5.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccpzfvqo.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\String.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase String.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccTgzjMo.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\RingBuffer.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase RingBuffer.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccfwMVzs.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\IPAddress.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase IPAddress.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccJdTtcs.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART3.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART3.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccTuWCnr.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\api\Stream.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase Stream.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccn25tsr.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\new.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase new.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccR1R9Hq.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-g++ Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000L -D CLOCK_SOURCE=1 -D TWI_MORS_SINGLE -D MILLIS_USE_TIMERB4 -D CORE_ATTACH_ALL -D LOCK_FLMAP -D FLMAPSECTION3 -D ARDUINO=10819 -D ARDUINO_avrdb -D ARDUINO_ARCH_MEGAAVR -D DXCORE="${DOWNLOADED_FILE#"v"}" -D DXCORE_MAJOR=1UL -D DXCORE_MINOR=5UL -D DXCORE_PATCH=11UL -D DXCORE_RELEASED=1 -D SERIAL_PORT_BOOT=Serial2 -D SERIAL_PORT_BOOT_PORTMUX=1 -D USING_OPTIBOOT C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore\UART2.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase UART2.cpp -mmcu=avrxmega4 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o -g -Os -Wall -Wextra -Wno-error=narrowing -std=gnu++17 -version -fno-exceptions -fpermissive -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccfMhw0q.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o C:\Users\Worker\AppData\Local\Temp\ccZvkESm.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o C:\Users\Worker\AppData\Local\Temp\ccr4WP0m.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o C:\Users\Worker\AppData\Local\Temp\ccJ3t1Ul.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o C:\Users\Worker\AppData\Local\Temp\ccTQhacm.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o C:\Users\Worker\AppData\Local\Temp\ccFVdFlm.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o C:\Users\Worker\AppData\Local\Temp\ccrAeUmq.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o C:\Users\Worker\AppData\Local\Temp\ccXwbyqq.s GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o C:\Users\Worker\AppData\Local\Temp\cctbiBYp.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o C:\Users\Worker\AppData\Local\Temp\ccf2Ffyp.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o C:\Users\Worker\AppData\Local\Temp\ccNdRvap.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o C:\Users\Worker\AppData\Local\Temp\ccXOwJ5o.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o C:\Users\Worker\AppData\Local\Temp\cchj5Dlo.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o C:\Users\Worker\AppData\Local\Temp\ccpzfvqo.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o C:\Users\Worker\AppData\Local\Temp\ccfwMVzs.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o C:\Users\Worker\AppData\Local\Temp\ccTgzjMo.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o C:\Users\Worker\AppData\Local\Temp\ccJdTtcs.s GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o C:\Users\Worker\AppData\Local\Temp\ccn25tsr.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o C:\Users\Worker\AppData\Local\Temp\ccTuWCnr.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o C:\Users\Worker\AppData\Local\Temp\ccR1R9Hq.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -I C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o C:\Users\Worker\AppData\Local\Temp\ccfMhw0q.s COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\WMath.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART0.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\wiring_extra.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\RingBuffer.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Print.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART4.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Common.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\main.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART1.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\PluggableUSB.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\abi.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART5.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\new.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_pulse.S.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART3.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\UART2.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts.c.o" LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\Tone.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PA.c.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\String.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PB.c.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\IPAddress.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu++17' '-fno-exceptions' '-fpermissive' '-ffunction-sections' '-fdata-sections' '-fno-threadsafe-statics' '-Wno-error=narrowing' '-MMD' '-flto' '-v' '-D' 'F_CPU=20000000L' '-D' 'CLOCK_SOURCE=1' '-D' 'TWI_MORS_SINGLE' '-D' 'MILLIS_USE_TIMERB4' '-D' 'CORE_ATTACH_ALL' '-D' 'LOCK_FLMAP' '-D' 'FLMAPSECTION3' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_avrdb' '-D' 'ARDUINO_ARCH_MEGAAVR' '-D' 'DXCORE="${DOWNLOADED_FILE#"v"}"' '-D' 'DXCORE_MAJOR=1UL' '-D' 'DXCORE_MINOR=5UL' '-D' 'DXCORE_PATCH=11UL' '-D' 'DXCORE_RELEASED=1' '-D' 'SERIAL_PORT_BOOT=Serial2' '-D' 'SERIAL_PORT_BOOT_PORTMUX=1' '-D' 'USING_OPTIBOOT' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore' '-I' 'C:\Arduino IDE Portable\AVRxDB\arduino-1.8.19\portable\packages\DxCore\hardware\megaavr\1.5.11\variants\64pin-standard' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_268176\core\api\Stream.cpp.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PC.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PD.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PE.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PF.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WInterrupts_PG.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\pinswap.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART4.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\UART5.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\core\\wiring_extra.cpp.o" Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Worker\AppData\Local\Temp\arduino_cache_430724\core\core_10ba67014c910c57c04950a9125b31e3.a Linking everything together... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -mrelax -Wl,--gc-sections,--section-start=.text=0x200,--section-start=.FLMAP_SECTION1=0x8000,--section-start=.FLMAP_SECTION2=0x10000,--section-start=.FLMAP_SECTION3=0x18000 -mmcu=avr128db64 -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176/TCA0_Timertakt.ino.elf" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176\\sketch\\TCA0_Timertakt.ino.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176/core\\core.a" "-LC:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_268176" -lm c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: --relax and -r may not be used together collect2.exe: error: ld returned 1 exit status lto-wrapper.exe: fatal error: C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub/bin/avr-gcc returned 1 exit status compilation terminated. c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed collect2.exe: error: ld returned 1 exit status exit status 1 Fehler beim Kompilieren für das Board AVR DB-series (Optiboot).
