------ Rebuild All started: Project: TCA_Timertakt, Configuration: Release AVR ------ Build started. Project "TCA_Timertakt.cppproj" (Clean target(s)): Target "Clean" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\Worker\Documents\Atmel Studio\7.0\WorkSpace_AVR128DB64\TCA_Timertakt\TCA_Timertakt\TCA_Timertakt.cppproj" (entry point): Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll". Task "RunCompilerTask" Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe clean rm -rf main.o rm -rf main.d rm -rf "TCA_Timertakt.elf" "TCA_Timertakt.a" "TCA_Timertakt.hex" "TCA_Timertakt.lss" "TCA_Timertakt.eep" "TCA_Timertakt.map" "TCA_Timertakt.srec" "TCA_Timertakt.usersignatures" Done executing task "RunCompilerTask". Done building target "Clean" in project "TCA_Timertakt.cppproj". Done building project "TCA_Timertakt.cppproj". Build succeeded. ------ Rebuild All started: Project: TCA_Timertakt, Configuration: Release AVR ------ Build started. Project "TCA_Timertakt.cppproj" (default targets): Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!=''). Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "C:\Users\Worker\Documents\Atmel Studio\7.0\WorkSpace_AVR128DB64\TCA_Timertakt\TCA_Timertakt\TCA_Timertakt.cppproj" (target "Build" depends on it): Task "RunCompilerTask" Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 32 --output-sync Building file: .././main.cpp Invoking: AVR8/GNU C Compiler : 8.5.0 Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-avr128db64 rename spec link to old_link COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-g++.exe Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DF_CPU=20000000UL -DNDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include" -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -Wundef -mmcu=avr128db64 -c -std=gnu++17 -flto -Wl,-v -v -MD -MP -MF "main.d" -MT"main.d" -MT"main.o" -o "main.o" ".././main.cpp" Finished building: .././main.cpp COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'F_CPU=20000000UL' '-D' 'NDEBUG' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-Wundef' '-c' '-std=gnu++17' '-flto' '-v' '-MD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-MT' 'main.o' '-o' 'main.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/cc1plus.exe -quiet -v -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include -imultilib avrxmega4 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/ -MD main.d -MF main.d -MP -MT main.d -MT main.o -D__AVR_AVR128DB64__ -D__AVR_DEVICE_NAME__=avr128db64 -D__AVR_DEV_LIB_NAME__=avr128db64 -D F_CPU=20000000UL -D NDEBUG .././main.cpp -mn-flash=2 -mno-skip-bug -quiet -dumpbase main.cpp -mmcu=avrxmega4 -auxbase-strip main.o -Os -Wall -Wundef -std=gnu++17 -version -funsigned-char -funsigned-bitfields -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -flto -mn-flash=2 -mno-skip-bug -fno-rtti -fno-enforce-eh-specs -fno-exceptions -o C:\Users\Worker\AppData\Local\Temp\ccvN5nwe.s GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/avr/avrxmega4" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include/c++/8.5.0/backward" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C++17 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: d000853d84d24099aba95c21583122aa COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'F_CPU=20000000UL' '-D' 'NDEBUG' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-Wundef' '-c' '-std=gnu++17' '-flto' '-v' '-MD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-MT' 'main.o' '-o' 'main.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include -mmcu=avrxmega4 -mgcc-isr -mno-skip-bug -o main.o C:\Users\Worker\AppData\Local\Temp\ccvN5nwe.s GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega4/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.2github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-funsigned-char' '-funsigned-bitfields' '-D' 'F_CPU=20000000UL' '-D' 'NDEBUG' '-I' 'C:\Program Files (x86)\Atmel\Studio\7.0\Packs\Atmel\AVR-Dx_DFP\2.5.294\include' '-Os' '-ffunction-sections' '-fdata-sections' '-fpack-struct' '-fshort-enums' '-Wall' '-Wundef' '-c' '-std=gnu++17' '-flto' '-v' '-MD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-MT' 'main.o' '-o' 'main.o' '-specs=device-specs/specs-avr128db64' '-mmcu=avrxmega4' Building target: TCA_Timertakt.elf Invoking: AVR8/GNU Linker : 8.5.0 "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-g++.exe" -o TCA_Timertakt.elf main.o -Wl,-Map="TCA_Timertakt.map" -Wl,--start-group -Wl,-lm -Wl,--end-group -Wl,--gc-sections -mmcu=avr128db64 Finished building target: TCA_Timertakt.elf "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "TCA_Timertakt.elf" "TCA_Timertakt.hex" "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-objcopy.exe" -j .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0 --no-change-warnings -O ihex "TCA_Timertakt.elf" "TCA_Timertakt.eep" || exit 0 "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-objdump.exe" -h -S "TCA_Timertakt.elf" > "TCA_Timertakt.lss" "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "TCA_Timertakt.elf" "TCA_Timertakt.srec" "C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.2GitHub\bin\avr-size.exe" "TCA_Timertakt.elf" text data bss dec hex filename 358 0 0 358 166 TCA_Timertakt.elf Done executing task "RunCompilerTask". Using "RunOutputFileVerifyTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll". Task "RunOutputFileVerifyTask" Program Memory Usage : 358 bytes 0,3 % Full Data Memory Usage : 0 bytes 0,0 % Full Warning: Memory Usage estimation may not be accurate if there are sections other than .text sections in ELF file Done executing task "RunOutputFileVerifyTask". Done building target "CoreBuild" in project "TCA_Timertakt.cppproj". Target "PostBuildEvent" skipped, due to false condition; ('$(PostBuildEvent)' != '') was evaluated as ('' != ''). Target "Build" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Avr.common.targets" from project "C:\Users\Worker\Documents\Atmel Studio\7.0\WorkSpace_AVR128DB64\TCA_Timertakt\TCA_Timertakt\TCA_Timertakt.cppproj" (entry point): Done building target "Build" in project "TCA_Timertakt.cppproj". Done building project "TCA_Timertakt.cppproj". Build succeeded. ========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
