Arduino: 1.8.19 (Windows 10), Board: "ATmega4809, Nano Every, EEPROM retained, Reset, BOD 2.6V, Internal 16 MHz, No bootloader" C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\sketchbook\libraries -fqbn=MegaCoreX:megaavr:4809:pinout=nano_every,eeprom=keep,resetpin=reset,BOD=2v6,clock=internal_16MHz,bootloader=no_bootloader -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_961633 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_397193 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\tools\avrdude\7.1-arduino.1 -prefs=runtime.tools.avrdude-7.1-arduino.1.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\tools\avrdude\7.1-arduino.1 -verbose C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\sketchbook\libraries\Streaming\examples\StreamingExample\StreamingExample.ino C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\hardware -hardware C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\tools-builder -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\hardware\tools\avr -tools C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages -built-in-libraries C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\libraries -libraries C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\sketchbook\libraries -fqbn=MegaCoreX:megaavr:4809:pinout=nano_every,eeprom=keep,resetpin=reset,BOD=2v6,clock=internal_16MHz,bootloader=no_bootloader -ide-version=10819 -build-path C:\Users\Worker\AppData\Local\Temp\arduino_build_961633 -warnings=all -build-cache C:\Users\Worker\AppData\Local\Temp\arduino_cache_397193 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\tools\avrdude\7.1-arduino.1 -prefs=runtime.tools.avrdude-7.1-arduino.1.path=C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\tools\avrdude\7.1-arduino.1 -verbose C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\sketchbook\libraries\Streaming\examples\StreamingExample\StreamingExample.ino Using board '4809' from platform in folder: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2 Using core 'coreX-corefiles' from platform in folder: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2 Detecting libraries used... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp" -o nul Alternatives for Streaming.h: [Streaming@6.1.1] ResolveLibrary(Streaming.h) -> candidates: [Streaming@6.1.1] "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp" -o nul Generating function prototypes... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -Wl,-v -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\preproc\\ctags_target_for_gcc_minus_e.cpp" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\preproc\\ctags_target_for_gcc_minus_e.cpp" Sketch wird kompiliert... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\sketchbook\\libraries\\Streaming\\src" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp.o" Compiling libraries... Compiling library "Streaming" Compiling core... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring_pulse.S" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring_pulse.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\WInterrupts.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring_analog.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring_shift.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\hooks.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -v "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\wiring_digital.c" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_digital.c.o" Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\wiring_pulse.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase wiring_pulse.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccxQLcvh.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\wiring.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase wiring.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\cctQRRFh.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\wiring_analog.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase wiring_analog.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccXXtLQg.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\WInterrupts.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase WInterrupts.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccfrWeTg.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\wiring_shift.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase wiring_shift.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccHzJthh.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\hooks.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase hooks.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccjff9og.s Using built-in specs. Reading specs from c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/device-specs/specs-atmega4809 COLLECT_GCC=C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc Target: avr Configured with: ../../downloads/gcc/configure --prefix=/home/ubuntixer/local/avrWindows64/ --target=avr --disable-nls --host=x86_64-w64-mingw32 --build=x86_64-linux-gnu --enable-languages=c,c++,lto --with-gnu-as --with-gnu-ld --disable-shared --with-dwarf2 --enable-mingw-wildcard Thread model: single gcc version 8.5.0 (GCC) COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/cc1.exe -quiet -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -imultilib avrxmega3 -iprefix c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/ -MMD C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.d -MQ C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o -D__AVR_ATmega4809__ -U__AVR_PM_BASE_ADDRESS__ -D__AVR_PM_BASE_ADDRESS__=0x4000 -D__AVR_DEVICE_NAME__=atmega4809 -D F_CPU=16000000L -D ARDUINO=10819 -D ARDUINO_AVR_ATmega4809 -D ARDUINO_ARCH_MEGAAVR C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles\wiring_digital.c -mn-flash=1 -mno-skip-bug -quiet -dumpbase wiring_digital.c -mrelax -mmcu=avrxmega3 -auxbase-strip C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o -g -Os -Wall -Wextra -std=gnu11 -version -ffunction-sections -fdata-sections -flto -fno-fat-lto-objects -o C:\Users\Worker\AppData\Local\Temp\ccJasKzg.s GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o C:\Users\Worker\AppData\Local\Temp\ccxQLcvh.s GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 ignoring nonexistent directory "c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/include-fixed" ignoring nonexistent directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/sys-include" ignoring duplicate directory "c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/lib/gcc/../../lib/gcc/avr/8.5.0/../../../../avr/include" #include "..." search starts here: #include <...> search starts here: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/include-fixed c:\avrtoolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github\bin\../lib/gcc/avr/8.5.0/../../../../avr/include End of search list. GNU C11 (GCC) version 8.5.0 (avr) compiled by GNU C version 10-win32 20220113, GMP version 6.1.0, MPFR version 3.1.4, MPC version 1.0.3, isl version isl-0.18-GMP GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 Compiler executable checksum: df1aa3d904869068228e973ffcc33294 COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o C:\Users\Worker\AppData\Local\Temp\ccfrWeTg.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o C:\Users\Worker\AppData\Local\Temp\cctQRRFh.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o C:\Users\Worker\AppData\Local\Temp\ccjff9og.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o C:\Users\Worker\AppData\Local\Temp\ccXXtLQg.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o C:\Users\Worker\AppData\Local\Temp\ccHzJthh.s COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/as.exe -v -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles -I C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every -mmcu=avrxmega3 --mlink-relax -mgcc-isr -mno-skip-bug -o C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o C:\Users\Worker\AppData\Local\Temp\ccJasKzg.s GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_pulse.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 GNU assembler version 2.42 (avr) using BFD version (GNU Binutils) 2.42 COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\WInterrupts.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_digital.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UART2.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\CDC.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\CDC.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\WMath.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UART1.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\RingBuffer.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\USBCore.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\USBCore.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\main.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\Print.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\new.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\new.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UART0.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\Stream.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\abi.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UART.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\Tone.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UNO_compat.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UNO_compat.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\String.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\UART3.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\IPAddress.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\Common.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -Wl,-v -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_ATmega4809 -DARDUINO_ARCH_MEGAAVR -fno-sized-deallocation -Wall -Wextra "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles/api/deprecated" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles" "-IC:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\variants\\nano-every" "C:\\Arduino IDE Portable\\megaAVR0\\arduino-1.8.19\\portable\\packages\\MegaCoreX\\hardware\\megaavr\\1.1.2\\cores\\coreX-corefiles\\api\\PluggableUSB.cpp" -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\PluggableUSB.cpp.o" COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_shift.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\wiring_analog.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' COMPILER_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../libexec/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ LIBRARY_PATH=c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/avrxmega3/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/;c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/lib/ COLLECT_GCC_OPTIONS='-c' '-g' '-Os' '-Wall' '-Wextra' '-std=gnu11' '-ffunction-sections' '-fdata-sections' '-MMD' '-flto' '-fno-fat-lto-objects' '-mrelax' '-D' 'F_CPU=16000000L' '-D' 'ARDUINO=10819' '-D' 'ARDUINO_AVR_ATmega4809' '-D' 'ARDUINO_ARCH_MEGAAVR' '-v' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles/api/deprecated' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\cores\coreX-corefiles' '-I' 'C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\packages\MegaCoreX\hardware\megaavr\1.1.2\variants\nano-every' '-o' 'C:\Users\Worker\AppData\Local\Temp\arduino_build_961633\core\hooks.c.o' '-specs=device-specs/specs-atmega4809' '-mmcu=avrxmega3' "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_pulse.S.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\WInterrupts.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\hooks.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_analog.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_digital.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_pulse.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\wiring_shift.c.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\CDC.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\Tone.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART0.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART1.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART2.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UART3.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\UNO_compat.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\USBCore.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\WMath.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\abi.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Common.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\IPAddress.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\PluggableUSB.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Print.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\RingBuffer.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\Stream.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\api\\String.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\main.cpp.o" "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc-ar" rcs "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\core.a" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\core\\new.cpp.o" Gebauter Kern wird archiviert (zwischengespeichert) in: C:\Users\Worker\AppData\Local\Temp\arduino_cache_397193\core\core_fb8e274719e3d38b61512eae56b101ba.a Linking everything together... "C:\\avrToolchain\\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -mrelax -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mmcu=atmega4809 -o "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633/StreamingExample.ino.elf" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633\\sketch\\StreamingExample.ino.cpp.o" "C:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633/core\\core.a" "-LC:\\Users\\Worker\\AppData\\Local\\Temp\\arduino_build_961633" -lm c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: --relax and -r may not be used together collect2.exe: error: ld returned 1 exit status lto-wrapper.exe: fatal error: C:\avrToolchain\avr-gcc-8.5.0_mingw32_binutils2.42_avrLibc2.1GitHub/bin/avr-gcc returned 1 exit status compilation terminated. c:/avrtoolchain/avr-gcc-8.5.0_mingw32_binutils2.42_avrlibc2.1github/bin/../lib/gcc/avr/8.5.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed collect2.exe: error: ld returned 1 exit status Bibliothek Streaming in Version 6.1.1 im Ordner: C:\Arduino IDE Portable\megaAVR0\arduino-1.8.19\portable\sketchbook\libraries\Streaming wird verwendet exit status 1 Fehler beim Kompilieren für das Board ATmega4809.
