// Algo from Detlef _. (detlef_a) 19.05.2024 20:53 // https://www.mikrocontroller.net/topic/567716#7668204 //typedef float median_t; //typedef int32_t index_t; typedef int16_t median_t; typedef uint8_t index_t; #define NN (3) median_t median(median_t neu) { index_t k, m; static index_t gross[NN]; static index_t w = 0; static median_t alt[NN]; //Ini if (w == 0) { for (m = 0; m < NN; m++) alt[m] = 0; for (m = 0; m < NN; m++) gross[m] = m; w = 1; } // Den ältesten rausschmeissen k = 0; while (1) { if (gross[k] == NN - 1) break; k++; } while (1) { if (k == 0) break; gross[k] = gross[k - 1]; k--; } // Wo musser denn hin? k = 0; while (1) { if (alt[gross[k + 1]] > neu) break; k++; if (k == NN - 1) break; } // Platz da m = 0; while (1) { if (k == m) break; gross[m] = gross[m + 1]; m++; } gross[k] = -1; for (m = 0; m < NN; m++) gross[m]++; // ruecken m = NN - 1; while (1) { alt[m] = alt[m - 1]; m--; if (m == 0) break; } alt[0] = neu; return (alt[gross[(NN - 1) / 2]]); } void setup() { Serial.begin(115200); } void loop() { uint32_t ts; median_t x; median_t y; x = random(-32768,32767); ts = micros(); y = median(x); uint32_t ende = micros(); Serial.println("value" + String(x) + " time used [us]: " + String(ende - ts)); delay(10); }
