SLdt 2406241720 fuer Johannes T. Fechner main.asm: ; == Do the NVM operation == ldiz 2*szSendingSts0 rcall uart_putSz ldi tmp0, low(NVMCTRL_CTRLA) ldi tmp1, high(NVMCTRL_CTRLA) ; ldi tmp2, NVMCTRL_CMD_FUSEWRITE_gc ldi tmp2,0x13 ; DD: EEERWR EEPROM Erase and Write Enable rcall sendSts rcall wait5ms ; ? lds tmp0, writeFuseAddrL_ram lds tmp1, writeFuseAddrH_ram lds tmp2, writeFuseData_ram rcall sendSts rcall wait5ms ; ? /* forget it: ; Write address LSB: rcall updi_wait25ms ldi tmp0, low(NVMCTRL_ADDR) ldi tmp1, high(NVMCTRL_ADDR) lds tmp2, writeFuseAddrL_ram rcall sendSts cpi tmp3, 0 brne loop_writeFuse_sts01 ldiz 2*szOK rcall uart_putSz ldiz 2*szLineBreak rcall uart_putSz rjmp loop_writeFuse_sts1 loop_writeFuse_sts01: cpi tmp3, 1 brne loop_writeFuse_sts02 rjmp loop_timeout loop_writeFuse_sts02: ldiz 2*szLineBreak rcall uart_putSz ldiz 2*szErrInvAnswer rcall uart_putSz rjmp loop_exit loop_writeFuse_sts1: ldiz 2*szSendingSts1 rcall uart_putSz ; Write address MSB: rcall updi_wait25ms ldi tmp0, low(NVMCTRL_ADDR+1) ldi tmp1, high(NVMCTRL_ADDR+1) lds tmp2, writeFuseAddrH_ram rcall sendSts cpi tmp3, 0 brne loop_writeFuse_sts11 ldiz 2*szOK rcall uart_putSz ldiz 2*szLineBreak rcall uart_putSz rjmp loop_writeFuse_sts2 loop_writeFuse_sts11: cpi tmp3, 1 brne loop_writeFuse_sts12 rjmp loop_timeout loop_writeFuse_sts12: ldiz 2*szLineBreak rcall uart_putSz ldiz 2*szErrInvAnswer rcall uart_putSz rjmp loop_exit loop_writeFuse_sts2: ldiz 2*szSendingSts2 rcall uart_putSz ; Write data: rcall updi_wait25ms ldi tmp0, low(NVMCTRL_DATA) ldi tmp1, high(NVMCTRL_DATA) lds tmp2, writeFuseData_ram rcall sendSts cpi tmp3, 0 brne loop_writeFuse_sts21 ldiz 2*szOK rcall uart_putSz ldiz 2*szLineBreak rcall uart_putSz rjmp loop_writeFuse_sts3 loop_writeFuse_sts21: cpi tmp3, 1 brne loop_writeFuse_sts22 rjmp loop_timeout loop_writeFuse_sts22: ldiz 2*szLineBreak rcall uart_putSz ldiz 2*szErrInvAnswer rcall uart_putSz rjmp loop_exit loop_writeFuse_sts3: ldiz 2*szSendingSts3 rcall uart_putSz ; Issue Write Fuse command: rcall updi_wait25ms ldi tmp0, low(NVMCTRL_CTRLA) ldi tmp1, high(NVMCTRL_CTRLA) ldi tmp2, NVMCTRL_CMD_FUSEWRITE_gc ldi tmp2,0x13; EEERWR rcall sendSts cpi tmp3, 0 brne loop_writeFuse_sts31 ldiz 2*szOK rcall uart_putSz ldiz 2*szLineBreak rcall uart_putSz rjmp loop_writeFuse_waitNvm loop_writeFuse_sts31: cpi tmp3, 1 brne loop_writeFuse_sts32 rjmp loop_timeout loop_writeFuse_sts32: ldiz 2*szLineBreak rcall uart_putSz ldiz 2*szErrInvAnswer rcall uart_putSz rjmp loop_exit loop_writeFuse_waitNvm: ; == Wait while NVMCTRL is busy == rcall waitForNvm sbrc tmp3, 0 rjmp loop_timeout ldiz 2*szNvmctrlStatus rcall uart_putSz mov tmp0, tmp2 rcall uart_putHexByte ldiz 2*szLineBreak rcall uart_putSz */ ; == Issue a System Reset to the target device == ldiz 2*szReset ;********************************************************** rcall updi_tx wait_ns_ 10000,0 ; Wait for first 'ACK' from Target UPDI: sendSts_wait0: ;********************************************************** rjmp sendSts_wait0 ; updiUartData_ram now contains the received byte. rcall wait1ms lds tmp0, updiUartDataBuf_ram ;********************************************************** ;********************************************************** .macro wait_ns_ ; ns, -Takte ; nach 'Klaus2m5' .set cycle_time_ns = (1000000 / fkHz) .set cycles = ((@0 + cycle_time_ns - 1) / cycle_time_ns - @1) .if (cycles > (255 * 3 + 2)) .error "wait_ns_ overflow" .else .if (cycles > 6) .set loop_cycles = (cycles / 3) ldi tmp0,loop_cycles dec tmp0 brne pc-1 .set cycles = (cycles - (loop_cycles * 3)) .endif .if (cycles > 0) .if (cycles & 4) rjmp pc+1 rjmp pc+1 .endif .if (cycles & 2) rjmp pc+1 .endif .if (cycles & 1) nop .endif .endif .endif .endmacro
