c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>build_threadx_sample.bat c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>arm-none-eabi-gcc -c -g -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=vfpv4 -mthumb cortexm4_vectors.S c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>arm-none-eabi-gcc -c -g -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=vfpv4 -mthumb cortexm4_crt0.S c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>arm-none-eabi-gcc -c -g -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=vfpv4 -mthumb tx_initialize_low_level.S c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>arm-none-eabi-gcc -c -g -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=vfpv4 -mthumb -I../../../../common/inc -I../inc sample_threadx.c c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build>arm-none-eabi-gcc -g -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=vfpv4 -mthumb -T sample_threadx.ld -ereset_handler -nostartfiles -o sample_threadx.out -Wl,-Map=sample_threadx.map cortexm4_vectors.o cortexm4_crt0.o tx_initialize_low_level.o sample_threadx.o tx.a c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: cortexm4_crt0.o: in function `memory_set_done': c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:21: undefined reference to `__text_load_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:22: undefined reference to `__text_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:23: undefined reference to `__text_end__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:25: undefined reference to `__fast_load_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:26: undefined reference to `__fast_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:27: undefined reference to `__fast_end__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:29: undefined reference to `__ctors_load_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:33: undefined reference to `__dtors_load_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:37: undefined reference to `__rodata_load_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:38: undefined reference to `__rodata_start__' c:/sysgcc/arm-eabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: c:\Workspace\VS2019\RpPicoThX-Test01\threadx\ports\cortex_m4\gnu\example_build/cortexm4_crt0.S:39: undefined reference to `__rodata_end__' collect2.exe: error: ld returned 1 exit status
