/* One Pole Motor - Field Coil - Rotor Coil - AS5600 hall encoder - current sensors ACS712x05B - L298 dual motor bridge - PiPico MCU 2024-07-09 ch */ // L298 pins #define EnA 16 #define EnB 17 #define In1 21 #define In2 20 #define In3 19 #define In4 18 // current sensors #define PIN_ROTORCURRENT A1 #define PIN_FIELDCURRENT A0 #define PIN_AS5600ANALOG A2 #define MySerial Serial // Serial1 is output for pipico debug probe float VALUE_field = 0; float VALUE_rotor = 0; float VALUE_angle = 0; void setFieldCoil(int16_t value) { if (value > 0) { digitalWrite(In1, LOW); digitalWrite(In2, HIGH); } else { digitalWrite(In1, HIGH); digitalWrite(In2, LOW); } analogWrite(EnA, abs(value)); } void setRotorCoil(int16_t value) { if (value > 0) { digitalWrite(In3, LOW); digitalWrite(In4, HIGH); } else { digitalWrite(In3, HIGH); digitalWrite(In4, LOW); } analogWrite(EnB, abs(value)); } static uint32_t lastTime; void setup() { //MySerial.begin(115200); MySerial.begin(1000000); pinMode(LED_BUILTIN, OUTPUT); pinMode(In1, OUTPUT); pinMode(In2, OUTPUT); pinMode(In3, OUTPUT); pinMode(In4, OUTPUT); analogWriteFreq(1000); lastTime = micros(); } uint16_t iFieldCoil; uint16_t iRotorCoil; uint16_t phi; void showMeasurements() { uint32_t dt = micros() - lastTime; MySerial.print(dt); lastTime = micros(); MySerial.print(" "); MySerial.print(iFieldCoil); MySerial.print(" "); MySerial.print(iRotorCoil); MySerial.print(" "); MySerial.println(phi); } #define STATE_IDLE 0 #define STATE_MEASURE 1 #define STATE_COMMUTEFIELD 2 #define STATE_COMMUTEROTOR 3 void loop() { static uint8_t state = STATE_IDLE; if (Serial.available()) { uint8_t c = Serial.read(); switch (c) { case 'm': { state = STATE_MEASURE; } break; case 'f': { state = STATE_COMMUTEFIELD; VALUE_field = 255; VALUE_rotor = 180; VALUE_angle = 2300; digitalWrite(LED_BUILTIN, HIGH); } break; case 'r': { state = STATE_COMMUTEROTOR; VALUE_field = 255; VALUE_rotor = 180; VALUE_angle = 2300; digitalWrite(LED_BUILTIN, HIGH); } break; case ' ': { state = STATE_IDLE; setRotorCoil(0); setFieldCoil(0); digitalWrite(LED_BUILTIN, LOW); } break; //default: state = STATE_IDLE; } } phi = analogRead(PIN_AS5600ANALOG) * 4; phi = (phi + (int16_t)VALUE_angle) & 0xFFF; iFieldCoil = analogRead(PIN_FIELDCURRENT); iRotorCoil = analogRead(PIN_ROTORCURRENT); if (state == STATE_MEASURE) { showMeasurements(); } if (state == STATE_COMMUTEFIELD) { if (phi > 2048) setFieldCoil(-VALUE_rotor); else setFieldCoil(VALUE_rotor); setRotorCoil(VALUE_field); showMeasurements(); } if (state == STATE_COMMUTEROTOR) { if (phi > 2048) setRotorCoil(-VALUE_rotor); else setRotorCoil(VALUE_rotor); setFieldCoil(VALUE_field); showMeasurements(); } }
