import numpy as np import matplotlib.pyplot as plt #place the paramters here: ... # T = 50 dt = 0.01 time = np.arange(0, T + dt, dt) I_ext = np.zeros(len(time)) I_ext[1000:2000] = 10 def alpha_n(V): return 0.01 * (V + 55) / (1 - np.exp(-0.1 * (V + 55))) def beta_n(V): return 0.125 * np.exp(-0.0125 * (V + 65)) def alpha_m(V): return 0.1 * (V + 40) / (1 - np.exp(-0.1 * (V + 40))) def beta_m(V): return 4.0 * np.exp(-0.0556 * (V + 65)) def alpha_h(V): return 0.07 * np.exp(-0.05 * (V + 65)) def beta_h(V): return 1 / (1 + np.exp(-0.1 * (V + 35))) V = -65.0 n = alpha_n(V) / (alpha_n(V) + beta_n(V)) m = alpha_m(V) / (alpha_m(V) + beta_m(V)) h = alpha_h(V) / (alpha_h(V) + beta_h(V)) V_values = [] n_values = [] m_values = [] h_values = [] for t in time: I_Na = (m**3) * g_Na * h * (V - E_Na) I_K = (n**4) * g_K * (V - E_K) I_L = g_L * (V - E_L) dV = (I_ext[int(t / dt)] - I_Na - I_K - I_L) / C_m V += dV * dt dn = (alpha_n(V) * (1 - n) - beta_n(V) * n) * dt dm = (alpha_m(V) * (1 - m) - beta_m(V) * m) * dt dh = (alpha_h(V) * (1 - h) - beta_h(V) * h) * dt n += dn m += dm h += dh V_values.append(V) n_values.append(n) m_values.append(m) h_values.append(h) V_values = np.array(V_values) n_values = np.array(n_values) m_values = np.array(m_values) h_values = np.array(h_values) plt.figure(figsize=(12, 8)) plt.subplot(2, 1, 1) plt.plot(time, V_values, label='Membrane Potential (V)') plt.title('Hodgkin-Huxley Neuron Model') plt.ylabel('Membrane Potential (mV)') plt.legend() plt.subplot(2, 1, 2) plt.plot(time, I_ext, label='External Current (I_ext)', color='r') plt.xlabel('Time (ms)') plt.ylabel('Current (uA/cm^2)') plt.legend() plt.tight_layout() plt.show()
