#define _CRT_SECURE_NO_WARNINGS //#define NDEBUG #include #include #include #include #include #include #include #include #include #include "rclcpp/rclcpp.hpp" #include "tf2_ros/transform_listener.h" #include "tf2_ros/buffer.h" #include "tf2_ros/transform_broadcaster.h" #include "geometry_msgs/msg/transform_stamped.hpp" using namespace std::chrono_literals; std::vector butterworth_filter(const std::vector& input, double cutoff_frequency, double sampling_rate, int order) { int N = input.size(); std::vector output(N, 0.0); // cf, init double nyquist = 0.5 * sampling_rate; double normalized_cutoff = cutoff_frequency / nyquist; std::vector a(order + 1, 0.0); std::vector b(order + 1, 0.0); double theta = M_PI * normalized_cutoff; double d = 1.0 / std::tan(theta); double d_squared = d * d; a[0] = 1.0 / (1.0 + std::sqrt(2.0) * d + d_squared); a[1] = 2.0 * a[0]; a[2] = a[0]; b[1] = 2.0 * (1.0 - d_squared) * a[0]; b[2] = (1.0 - std::sqrt(2.0) * d + d_squared) * a[0]; for (int i = 2; i < N; ++i) { #ifdef NDEBUG #else printf("\nFiltering index: %i\n",i); #endif output[i] = a[0] * input[i] + a[1] * input[i - 1] + a[2] * input[i - 2] - b[1] * output[i - 1] - b[2] * output[i - 2]; } return output; } class Filter { public: Filter() {} void set_history_size(size_t new_size) { history_size_ = new_size; if (x_history_.size() > history_size_) x_history_.resize(history_size_); if (y_history_.size() > history_size_) y_history_.resize(history_size_); if (z_history_.size() > history_size_) z_history_.resize(history_size_); } geometry_msgs::msg::TransformStamped apply_filter(const geometry_msgs::msg::TransformStamped& transform) { x_history_.push_back(transform.transform.translation.x); y_history_.push_back(transform.transform.translation.y); z_history_.push_back(transform.transform.translation.z); if (x_history_.size() > history_size_) x_history_.pop_front(); if (y_history_.size() > history_size_) y_history_.pop_front(); if (z_history_.size() > history_size_) z_history_.pop_front(); #ifdef NDEBUG #else printf("\nHistory Size: %zu", history_size_); printf("\nDeque x_history_ size: %zu", x_history_.size()); printf("\nDeque y_history_ size: %zu", y_history_.size()); printf("\nDeque z_history_ size: %zu", z_history_.size()); #endif geometry_msgs::msg::TransformStamped filtered_transform = transform; if (x_history_.size() >= history_size_) { std::vector x_filtered = butterworth_filter( std::vector(x_history_.begin(), x_history_.end()), cutoff_frequency_, sampling_rate_, order_); std::vector y_filtered = butterworth_filter( std::vector(y_history_.begin(), y_history_.end()), cutoff_frequency_, sampling_rate_, order_); std::vector z_filtered = butterworth_filter( std::vector(z_history_.begin(), z_history_.end()), cutoff_frequency_, sampling_rate_, order_); filtered_transform.transform.translation.x = x_filtered.back(); filtered_transform.transform.translation.y = y_filtered.back(); filtered_transform.transform.translation.z = z_filtered.back(); } return filtered_transform; } private: std::deque x_history_; std::deque y_history_; std::deque z_history_; size_t history_size_ = 20; double cutoff_frequency_ = 10.0; double sampling_rate_ = 100.0; int order_ = 2; }; class FrameListener : public rclcpp::Node { public: FrameListener() : Node("frame_listener_node"), buffer_(get_clock()), listener_(buffer_), filter_(std::make_shared()) { timer_ = this->create_wall_timer(50ms, std::bind(&FrameListener::timer_callback, this)); publisher_ = this->create_publisher("LHR_BFB7B3C7_filtered", 10); } private: void timer_callback() { geometry_msgs::msg::TransformStamped transformStamped; try { transformStamped = buffer_.lookupTransform("libsurvive_world", "LHR-BFB7B3C7", tf2::TimePointZero); RCLCPP_INFO(this->get_logger(), "Received transform (unfiltered): " "Translation: [%f, %f, %f], " "Rotation: [x: %f, y: %f, z: %f, w: %f]", transformStamped.transform.translation.x, transformStamped.transform.translation.y, transformStamped.transform.translation.z, transformStamped.transform.rotation.x, transformStamped.transform.rotation.y, transformStamped.transform.rotation.z, transformStamped.transform.rotation.w); geometry_msgs::msg::TransformStamped filtered_transform = filter_->apply_filter(transformStamped); publisher_->publish(filtered_transform); #ifdef NDEBUG #else RCLCPP_INFO(this->get_logger(), "Published unfiltered transform."); #endif } catch (tf2::TransformException& ex) { RCLCPP_WARN(this->get_logger(), "Could not transform 'LHR-BFB7B3C7' to 'libsurvive_world': %s", ex.what()); } } tf2_ros::Buffer buffer_; tf2_ros::TransformListener listener_; rclcpp::Publisher::SharedPtr publisher_; rclcpp::TimerBase::SharedPtr timer_; std::shared_ptr filter_; }; class FramePublisher : public rclcpp::Node { public: FramePublisher() : Node("frame_publisher_node"), buffer_(get_clock()), listener_(buffer_) { timer_ = this->create_wall_timer(50ms, std::bind(&FramePublisher::timer_callback, this)); broadcaster_ = std::make_shared(this); } private: void timer_callback() { geometry_msgs::msg::TransformStamped transformStamped; try { transformStamped = buffer_.lookupTransform("libsurvive_world", "LHR-BFB7B3C7", tf2::TimePointZero); RCLCPP_INFO(this->get_logger(), "Publishing transform (filtered): " "Translation: [%f, %f, %f], " "Rotation: [x: %f, y: %f, z: %f, w: %f]", transformStamped.transform.translation.x, transformStamped.transform.translation.y, transformStamped.transform.translation.z, transformStamped.transform.rotation.x, transformStamped.transform.rotation.y, transformStamped.transform.rotation.z, transformStamped.transform.rotation.w); transformStamped.child_frame_id = "LHR-BFB7B3C7_filtered"; broadcaster_->sendTransform(transformStamped); #ifdef NDEBUG #else RCLCPP_INFO(this->get_logger(), "Published filtered transform."); #endif } catch (tf2::TransformException& ex) { RCLCPP_WARN(this->get_logger(), "Could not transform 'LHR-BFB7B3C7' to 'libsurvive_world': %s", ex.what()); } } tf2_ros::Buffer buffer_; tf2_ros::TransformListener listener_; std::shared_ptr broadcaster_; rclcpp::TimerBase::SharedPtr timer_; }; int main(int argc, char* argv[]) { rclcpp::init(argc, argv); #ifdef NDEBUG #else printf("\nROS run"); #endif auto frame_listener_node = std::make_shared(); auto frame_publisher_node = std::make_shared(); rclcpp::executors::SingleThreadedExecutor executor; executor.add_node(frame_listener_node); executor.add_node(frame_publisher_node); executor.spin(); rclcpp::shutdown(); return 0; }
