;******************************************************************* ; ; Inductance & Capacitance Meter ; ;******************************************************************* ; ; First, let us choose our weapon - 16F84 or 16F628 ; ; ; Comment out the next line [;#define F84] if using a 16F628 #ifndef F84 #define F628 #endif ;******************************************************************* ; ; LC002 - THIS ONE WORKS FINE WITH A WELL BEHAVED DISPLAY ; ; Deleted CpyBin subroutine and one call to it ; ; Modified B2_BCD to take its input directly from ; ; Modified "oscillator test" so it copies F3 to ; ; Fixed Get_Lcal so it gets the correct number ; ; Minor adjustment to MS100 timing to correct frequency display ; ; Check for oscillator too slow when measuring L or C. ; ; ;******************************************************************* ; ; LC003 - Optimised / Modified to handle "bad" displays ; ; Removed duplicated code in DATS subroutine ; ; Added code to fix crook display (select by jumper on B4 - 10) ; ; Optimised L & C formatting code ; ; Optimised "Display" subroutine ; ; Cleaned up LCDINIT ; ; ;******************************************************************* ; ; LC004 - Deleted timer Interrupt Service Routine ; ; Modified way oscillator "out of range" condition is detected ; ; ;******************************************************************* ; ; LC628 - LC004 code ported to 16F628 by Egbert Jarings PA0EJH. ; Mem starts now at 0x20 ; InitIO modified , 628 PortA start's up in Analog Mode ; So changed to Digital Mode (CMCON) ; ; Display's "Calibrating" to fill up dead Display time ; when first Powerd Up. ; ; Changed pmsg Routine, EEADR trick wont work with 628, ; PCL was always 0x00 so restart occurs. EEADR is now Etemp. ; ; Also changed EEADR in FP routine to Etemp ; ; Bad Display isn't bad at all, its a Hitachi HD44780, as ; 80% of all Display's are. Adress as 2 Lines x 8 Char. ; So LCDINIT modified for 2 x 8 Display's. (0x28 added) ; ;******************************************************************* ; ; LC005 - Cosmetic rewrite of RAM allocation from LC004 ; ; No change to address of anything - I hope ; Identified unused RAM & marked for later removal. ; ; ;******************************************************************* ; ; LC006 - Merge LC005 and LC628 ; ; All "#ifdef" F628 parts by Egbert Jarings PA0EJH. ; (or derived from his good work) ; ; Cleaned up RAM allocation. ; ; Added message re: processor type, just to verify selection ; ; Included extra initialisation (2 line) command by PA0EJH ; ;******************************************************************* ; ; lc007 Changed strings to EEPROM (it's not used for anything else) ; ; Added "error collector" code to catch "all" FP errors ; ; Addded macros ; ; ;******************************************************************* ; ; lc008 initialised FP flags ; ; bsf FPFLAGS,RND ; FP round to nearest ; bsf FPFLAGS,SAT ; FP SAturate to appropriate ; ;******************************************************************* ;o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o-----o ;******************************************************************* ; ; Some frequently used code fragments ; Use macros to make mistreaks consistently. ; ;------------------------------------------------------------------- ; Select Register Bank 0 bank0 macro errorlevel +302 ; Re-enable bank warning bcf STATUS,RP0 ; Select Bank 0 endm ;------------------------------------------------------------------- ; Select Register Bank 1 bank1 macro bsf STATUS,RP0 ; Select Bank 1 errorlevel -302 ; disable warning endm ;------------------------------------------------------------------- ; Swap bytes in register file via W swap macro this,that movf this,w ; get this xorwf that,f ; Swap using Microchip xorwf that,w ; Tips'n Tricks xorwf that,f ; #18 movwf this endm ;------------------------------------------------------------------- ; Copy bytes in register file via W copy macro from,to MOVF from,W MOVWF to endm ;******************************************************************* ; ; CPU configuration ; #ifdef F84 MESSG "Processor = 16F84" #define RAMStart 0x0C ; by VK3BHR processor 16f84 include __config _HS_OSC & _PWRTE_ON & _WDT_OFF #endif #ifdef F628 MESSG "Processor = 16F628" #define RAMStart 0x20 ; by PA0EJH processor 16f628 include __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC & _BODEN_ON & _LVP_OFF #endif ;********************************************************** ; ; I/O Assignments. Luckily, the same assignments ; work on both the 16F84 and the 16F628. ; #define ENA PORTA,0x02 ; Display "E" #define RS PORTA,0x03 ; Display "RS" #define relay PORTA,0x01 ; 0 = energise relay #define FIXIT PORTB,0x04 ; Pin 10, 0 = "fix bad display" ; Floating 1 = "good display" #define setup PORTB,0x06 ; Pin 12, 0 = "Setup" #define functn PORTB,0x07 ; Pin 13, 0 = "Inductor" ;******************************************************************* ; ; file register declarations: uses only registers in bank0 ; bank 0 file registers begin at 0x0c in the 16F84 ; and at 0x20 in the 16F628 ; ;******************************************************************* cblock RAMStart ; ; Floating Point Stack and other locations used by FP.TXT ; ; FP Stack: TOS A = AEXP:AARGB0:AARGB1:AARGB3:AARGB4 ; B = BEXP:BARGB0:BARGB1:BARGB2 ; C = CEXP:CARGB0:CARGB1 AARGB4 AARGB3 AARGB2 AARGB1 AARGB0 AEXP ; 8 bit biased exponent for argument A SIGN ; save location for sign in MSB FPFLAGS ; floating point library exception flags BARGB2 BARGB1 BARGB0 BEXP ; 8 bit biased exponent for argument B TEMPB3 ; 1 Unused byte TEMPB2 ; 1 Unused byte TEMPB1 ; Used TEMPB0 ; 1 Unused byte CARGB1 CARGB0 ; most significant byte of argument C CEXP ; 8 bit biased exponent for argument C ; ; "Main" Program Storage ; COUNT ; Bin to BCD convert (bit count) cnt ; (BCD BYTES) COUNT1 ; Used by delay routines ; and "prescaler flush" COUNT2 ; Timing (100ms) CHR F1:2 F2:2 F3:2 bcd:4 ; BCD, MSD first TabStop ; Used to fix bad displays. TabTemp FPE ; Collect FP errors in here R_sign ; Holds "+" or " " (sign) endc EXP equ AEXP ; Used by FP.TXT TEMP equ TEMPB0 ;AARG equ AARGB0 ; Unused ;BARG equ BARGB0 ; Unused ;CARG equ CARGB0 ; Unused ;******************************************************************* ; ; GENERAL MATH LIBRARY DEFINITIONS ; ; ; define assembler constants B0 equ 0 B1 equ 1 B2 equ 2 B3 equ 3 B4 equ 4 B5 equ 5 B6 equ 6 B7 equ 7 MSB equ 7 LSB equ 0 ; STATUS bit definitions #define _C STATUS,0 #define _Z STATUS,2 ;******************************************************************* ; ; FLOATING POINT literal constants ; EXPBIAS equ D'127' ; ; floating point library exception flags ; IOV equ 0 ; bit0 = integer overflow flag FOV equ 1 ; bit1 = floating point overflow flag FUN equ 2 ; bit2 = floating point underflow flag FDZ equ 3 ; bit3 = floating point divide by zero flag NAN equ 4 ; bit4 = not-a-number exception flag DOM equ 5 ; bit5 = domain error exception flag RND equ 6 ; bit6 = floating point rounding flag, 0 = truncation ; 1 = unbiased rounding to nearest LSB SAT equ 7 ; bit7 = floating point saturate flag, 0 = terminate on ; exception without saturation, 1 = terminate on ; exception with saturation to appropriate value ;********************************************************** ; ; Motorola syntax branches ; #define beq bz #define BEQ bz #define BNE bnz #define bne bnz #define BCC bnc #define bcc bnc #define BCS bc #define bcs bc #define BRA goto #define bra goto ;********************************************************** ; ; Begin Executable Stuff(tm) ; org 0 GO clrwdt ; 0 << Reset call InitIO ; 1 INITIALISE PORTS CLRF PORTA ; 2 ; goto START ; 3 ;********************************************************** ; ; Main Program ; START bsf FPFLAGS,RND ; FP round to nearest bsf FPFLAGS,SAT ; FP Saturate to appropriate bsf relay ; de-energise relay CLRF PORTB CALL LCDINIT ; INITIALIZE LCD MODULE cmdloop call HOME btfsc setup ; Doing initial oscillator test? goto Chk4Z ; ; Measure & display osc freq for initial setup ; call Measure ; Measure Local Osc Freq. btfss INTCON,T0IF ; Set = Counter overflow? goto Do_Disp MOVLW ovr-0x2100 ; Over-range message call pmsg goto cmdloop Do_Disp clrf AARGB0 ; Copy to 24 bit number movf F3,W ; in AARGB0, 1, 2 movwf AARGB1 ; for display movf F3+1,W movwf AARGB2 call Display goto cmdloop ; ; "Zero" the meter. ; Chk4Z MOVLW Calibr-0x2100 ; Display's " Calibrating " call pmsg ; to entertain the punters call Measure ; Dummy Run to stabilise oscillator. call MS200 ; was MS300 call Measure ; Get freq in F3 copy F3+0,F1+0 ; Copy F3 to F1 copy F3+1,F1+1 bcf relay ; Add standard capacitor call MS200 call Measure ; Get freq in F3 copy F3+0,F2+0 ; Copy F3 to F2 copy F3+1,F2+1 bsf relay ; Remove standard capacitor call MS200 ; ; Now we resume our regular pogrom ; M_F3 call HOME call Measure ; Measure F3 & leave it there movf F3,w ; test for "too low" frequency beq OORange ; F < 2560Hz ? btfss INTCON,T0IF ; test for "too high" frequency goto OK2GO ; F > 655359Hz ? OORange MOVLW ovr-0x2100 ; Over/Under range message call pmsg goto M_F3 ; ; Precompute major bracketed terms cos ; we need 'em both for all calculations ; OK2GO clrf FPE ; Declare "error free" call F1_F2 call F1_F3 ; ; See what mode we are in ; btfss functn ; 0=Inductor goto Do_Ind ; ; OK, we've been told it's a capacitor ; Do_Cap call C_calc movf FPE,f ; Any FP errors? bne complain movlw Cintro-0x2100 ; C = call pmsg call C_disp goto M_F3 ; ; Now, they reckon it's a @#$*! inductor ; Do_Ind call L_calc movf FPE,f ; Any FP errors? bne complain movlw Lintro-0x2100 ; L = call pmsg call L_disp goto M_F3 ; ; Got a Floating Point Error of some sort ; complain movlw ovr-0x2100 ; Over Range call pmsg goto M_F3 ;********************************************************** ; ; Print String addressed by W ; Note: Strings are in EEPROM ; We do a lotta bank switching here. #ifdef F84 pmsg movwf EEADR ; pointer pm1 bank1 BSF EECON1,RD ; EE Read bank0 MOVF EEDATA,W ; W = EEDATA, affects Z bit btfsc STATUS,Z ; ZERO = All done return ; so quit call DATS ; Byte -> display INCF EEADR,F ; bump address goto pm1 #endif ;----------------------------------------------------------- #ifdef F628 pmsg bank1 movwf EEADR ; pointer pm1 BSF EECON1,RD ; EE Read MOVF EEDATA,W ; W = EEDATA, affects Z bit bank0 ; Does not change Z bit btfsc STATUS,Z ; ZERO = All done return ; so quit call DATS ; Byte -> display bank1 INCF EEADR,F ; bump address goto pm1 #endif ;********************************************************** ; ; Delay for 2ms (untrimmed) ; MS2 MOVLW 0xFD ; DELAY 2ms MOVWF COUNT1 MOVLW 0x66 MOVWF COUNT2 goto L3 ;********************************************************** ; ; Delay for about 200ms or 300ms (untrimmed) ; MS300 call MS100 MS200 call MS100 ;********************************************************** ; ; Delay for about 100ms ; MS100 MOVLW 0x7e ; Count up MOVWF COUNT1 ; to roll-over MOVLW 0x20 ; was 0x19, then 0x25, then 1f MOVWF COUNT2 L3 INCFSZ COUNT2,F GOTO L3 INCFSZ COUNT1,F GOTO L3 RETLW 0 ;********************************************************** ; ; Put a BCD nybble to display ; PutNyb ANDLW 0x0F ; MASK OFF OTHER PACKED BCD DIGIT ADDLW 0x30 ; Convert BIN to ASCII ;********************************************************** ; ; Put a byte to display ; DATS decf TabStop,F ; Time to tickle bad display? bne DAT1 ; Not yet movwf TabTemp ; Save character btfss FIXIT ; Check if we got a crook one. CALL LINE2 ; Skip this if good movf TabTemp,W ; Restore character DAT1 BSF RS ; SELECT DATA REGISTER CM MOVWF CHR ; STORE CHAR TO DISPLAY SWAPF CHR,W ; SWAP UPPER AND LOWER NIBBLES (4 BIT MODE) call PB_dly MOVF CHR,W ; GET CHAR AGAIN ;********************************************************** ; ; Put 4 bits to LCD & wait (untrimmed) ; PB_dly ANDLW 0x0F ; MASK OFF UPPER 4 BITS MOVWF PORTB ; SEND DATA TO DISPLAY BSF ENA ; ENA HIGH NOP BCF ENA ; ENA LOW ; goto D200us ; Fall into DELAY subroutine ;********************************************************** ; ; Delay for 200us (untrimmed) ; D200us MOVLW 0x42 ; DELAY 200us MOVWF COUNT1 NXT5 DECFSZ COUNT1,F GOTO NXT5 RETLW 0 ;****************************************************************** ; ; Convert 24-bit binary number at into a bcd number ; at . Uses Mike Keitz's procedure for handling bcd ; adjust; Modified Microchip AN526 for 24-bits. ; B2_BCD b2bcd movlw .24 ; 24-bits movwf COUNT ; make cycle counter clrf bcd+0 ; clear result area clrf bcd+1 clrf bcd+2 clrf bcd+3 b2bcd2 movlw bcd ; make pointer movwf FSR movlw .4 movwf cnt ; Mike's routine: b2bcd3 movlw 0x33 addwf INDF,f ; add to both nybbles btfsc INDF,3 ; test if low result > 7 andlw 0xf0 ; low result >7 so take the 3 out btfsc INDF,7 ; test if high result > 7 andlw 0x0f ; high result > 7 so ok subwf INDF,f ; any results <= 7, subtract back incf FSR,f ; point to next decfsz cnt,f goto b2bcd3 rlf AARGB2,f ; get another bit rlf AARGB1,f rlf AARGB0,f rlf bcd+3,f ; put it into bcd rlf bcd+2,f rlf bcd+1,f rlf bcd+0,f decfsz COUNT,f ; all done? goto b2bcd2 ; no, loop return ; yes ;*********** INITIALISE LCD MODULE 4 BIT MODE *********************** LCDINIT CALL MS100 ; WAIT FOR LCD MODULE HARDWARE RESET BCF RS ; REGISTER SELECT LOW BCF ENA ; ENABLE LINE LOW MOVLW 0x03 ; 1 call PB_dly CALL MS100 ; WAIT FOR DISPLAY TO CATCH UP MOVLW 0x03 ; 2 call PB_dly MOVLW 0x03 ; 3 call PB_dly MOVLW 0x02 ; Fn set 4 bits call PB_dly MOVLW 0x0C ; 0x0C DISPLAY ON CALL ST200us MOVLW 0x28 ; DISPLAY 2 Line , 5x7 Dot's CALL ST200us ; New in LC628/LC006 version MOVLW 0x06 ; 0x06 ENTRY MODE SET CALL ST200us ; Fall into CLEAR ;************ CLEAR DISPLAY *************************** CLEAR MOVLW 0x01 ; CLEAR DISPLAY goto Home2 ; LONGER DELAY NEEDED WHEN CLEARING DISPLAY ;*********** MOVE TO HOME ***************************** HOME movlw 0x09 ; Count characters movwf TabStop ; before tickling display. MOVLW 0x02 ; HOME DISPLAY Home2 CALL STROBE goto MS2 ;********************************************************** ; ; SENDS DATA TO LCD DISPLAY MODULE (4 BIT MODE) ; STROBE BCF RS ; SELECT COMMAND REGISTER GOTO CM ;************ MOVE TO START OF LINE 2 ***************** LINE2 MOVLW 0xC0 ; ADDRESS FOR SECOND LINE OF DISPLAY ST200us CALL STROBE goto D200us ;******************************************************************** ; Initialise Input & Output devices ;******************************************************************** InitIO #ifdef F628 BSF CMCON,CM0 ; By PA0EJH BSF CMCON,CM1 ; Set Comp to digital I/O BSF CMCON,CM2 ; #endif bank1 movlw 0x37 ; Option register movwf OPTION_REG ; Port B weak pull-up enabled ; INTDEG Don't care ; Count RA4/T0CKI ; Count on falling edge ; Prescale Timer/counter ; divide Timer/counter by 256 ; PORTA:- movlw 0x10 ; initialise data direction ; 1 = input ; 0 = output ; ; PORTA has 5 pins 4 3 2 1 0 ; 0x10 = 0 0 0 1 0 0 0 0 ; movwf TRISA ; PORTA<0> = CLAMP count input ; PORTA<1> = Relay. 0 = energise ; PORTA<2> = LCD "E" ; PORTA<3> = LCD "RS" ; PORTA<4> = Count Input ; PORTA<5:7> = not implemented in 16F84 ; ; PORTB:- movlw 0xf0 ; initialise data direction ; PORTB has 8 pins ; port pin 7 6 5 4 3 2 1 0 ; 0xf0 = 1 1 1 1 0 0 0 0 ; movwf TRISB ; PORTB<0> = LCD "DB4" ; PORTB<1> = "DB5" ; PORTB<2> = "DB6" ; PORTB<3> = "DB7" ; PORTB<4> = Input ; PORTB<5> = Input ; PORTB<6> = Input ; PORTB<7> = Input bank0 return ;********************************************************** ; ; Measure Frequency. Stash in "F3 and F3+1" ; Measure bcf INTCON,T0IF ; Declare "Not yet Over-range" CLRF TMR0 ; RESET INTERNAL COUNT (INCLUDING PRESCALER) ; See page 27 Section 6.0 bsf PORTA,0 ; Part of Osc gating CLRF F3 ; Ready to receive 16 bit number CLRF F3+1 ; OPEN GATE bank1 ; PORTA:- movlw 0x11 ; initialise data direction ; 1 = input ; 0 = output ; PORTA has 5 pins 4 3 2 1 0 ; 0x10 = 0 0 0 1 0 0 0 1 movwf TRISA ; PORTA<0> = ; PORTA<1> = ; PORTA<2> = LCD "E" ; PORTA<3> = LCD "RS" ; PORTA<4> = Input ; PORTA<5:7> = not implemented in 16F84 CALL MS100 ; 100MS DELAY ; CLOSE GATE (COUNT COMPLETE) ; PORTA:- movlw 0x10 ; initialise data direction ; 1 = input ; 0 = output ; PORTA has 5 pins 4 3 2 1 0 ; 0x10 = 0 0 0 1 0 0 0 0 movwf TRISA ; PORTA<0> = ; PORTA<1> = ; PORTA<2> = LCD "E" ; PORTA<3> = LCD "RS" ; PORTA<4> = Input ; PORTA<5:7> = not implemented in 16F84 bank0 MOVF TMR0,W ; GET HIGH BYTE MOVWF F3 ; Copy to Big end of 16 bit result ; The 311 "outputting" a 1 'cos we've forced it high ; so T0CKI=1. PSC1 bank1 bsf OPTION_REG,T0SE ; Clock the prescaler nop bcf OPTION_REG,T0SE bank0 DECF F3+1,F ; Decrement the counter movf TMR0,W ; Has TMR0 changed? xorwf F3,W ; if unchanged, XOR -> 0 beq PSC1 return ; F3 : F3+1 now holds 16 bit result ;********************************************************** ; ; Display contents of AARGB0,1,2 on LCD ; First convert to BCD, Then ASCII (nybble at a time) ; Display CALL B2_BCD ; CONVERT COUNT TO BCD call Swap0 ; GET NEXT DIGIT call Move0 ; GET OTHER BCD DIGIT call Swap1 call Move1 call Swap2 call Move2 call Swap3 goto Move3 ; includes return ;********************************************************** ; ; Formatted display of BCD work area for Capacitor ; C_disp movf R_sign,w ; Sign call DATS F_C1 MOVF bcd+0,W ANDLW 0x0F beq F_C2 CALL PutNyb call Swap1 call Move1 CALL DoDP ; Print DP call Swap2 goto F_C3U ;-------------------------------------------------- F_C2 swapf bcd+1,W ANDLW 0x0F beq F_C3 CALL PutNyb call Move1 CALL DoDP ; Print DP call Swap2 call Move2 goto F_C3U ; print nF. includes RETURN ;-------------------------------------------------- F_C3 MOVF bcd+1,W ANDLW 0x0F beq F_C4 CALL PutNyb CALL DoDP ; Print DP call Swap2 call Move2 call Swap3 F_C3U movlw Unit1-0x2100 ; nF goto pmsg ; includes RETURN ;-------------------------------------------------- F_C4 SWAPF bcd+2,W ; Digit1 == 0 ? ANDLW 0x0F bne NoB1_C MOVLW 0x20 ; YES PRINT A SPACE call DATS MOVF bcd+2,W ; Digit2 == 0 ? ANDLW 0x0F bne NoB2_C MOVLW 0x20 ; YES PRINT A SPACE call DATS bra NoB3_C NoB1_C call Swap2 ; 1 NoB2_C call Move2 ; 2 NoB3_C call Swap3 ; 3 CALL DoDP ; Print DP call Move3 ; 4 movlw Unit2-0x2100 ; pF goto pmsg ; includes RETURN ;********************************************************** ; ; Formatted display of BCD work area for Inductor ; L_disp movf R_sign,w ; Sign call DATS F_L1 MOVF bcd+0,W ANDLW 0x0F beq F_L2 CALL PutNyb call Swap1 CALL DoDP ; Print DP call Move1 call Swap2 goto F_L2U ; Print mH. includes RETURN ;-------------------------------------------------- F_L2 swapf bcd+1,W ANDLW 0x0F beq F_L3 CALL PutNyb CALL DoDP ; Print DP call Move1 call Swap2 call Move2 F_L2U movlw Unit3-0x2100 ; mH goto pmsg ; includes RETURN ;-------------------------------------------------- F_L3 MOVF bcd+1,W ANDLW 0x0F beq F_L4 CALL PutNyb call Swap2 call Move2 CALL DoDP ; Print DP call Swap3 goto F_L4U ; Print uH. includes RETURN ;-------------------------------------------------- F_L4 SWAPF bcd+2,W ; Digit1 == 0 ? ANDLW 0x0F bne NoB1_L MOVLW 0x20 ; YES PRINT A SPACE call DATS goto NoB2_L NoB1_L call Swap2 ; 1 NoB2_L call Move2 ; 2 CALL DoDP ; Print DP call Swap3 ; 3 call Move3 ; 4 F_L4U movlw Unit4-0x2100 ; uH goto pmsg ; includes RETURN ;-------------------------------------------------- ; ; Common subroutine for formatted output ; DoDP MOVLW '.' ; Print DP goto DATS ; Return from DATS Swap0 SWAPF bcd+0,W ; GET NEXT DIGIT goto PutNyb ; DISPLAY IT Move0 MOVF bcd+0,W ; GET OTHER BCD DIGIT goto PutNyb Swap1 SWAPF bcd+1,W goto PutNyb Move1 MOVF bcd+1,W goto PutNyb Swap2 SWAPF bcd+2,W goto PutNyb Move2 MOVF bcd+2,W goto PutNyb Swap3 SWAPF bcd+3,W goto PutNyb Move3 MOVF bcd+3,W goto PutNyb ;******************************************************************** ; ; Stack operations ; ;******************************************************************** ;add call FPA24 ; goto S_fix subtract call FPS24 goto S_fix divide call FPD24 goto S_fix multiply call FPM24 ; goto S_fix ; ; Fix stack after add, subtract, divide & multiply ; AND Collect ALL Floating Point Errors in FPE S_fix iorwf FPE,f ; W may hold Error (0xff) copy CARGB1,BARGB1 ; C -> B copy CARGB0,BARGB0 copy CEXP,BEXP return ; ; Push stack (duplicates TOS) ; S_push copy BARGB1,CARGB1 ; B -> C copy BARGB0,CARGB0 copy BEXP,CEXP copy AARGB1,BARGB1 ; A -> B copy AARGB0,BARGB0 copy AEXP,BEXP return ; ; Swap A and B S_swap swap AARGB1,BARGB1 ; A <-> B swap AARGB0,BARGB0 swap AEXP,BEXP return ;******************************************************************** ; ; Calculate Unknown Capacitance OR inductance ; ; Output: 24 bit positive integer (scaled) ; right justified in AARGB0, AARGB1, AARGB2 ; also as BCD in bcd:bcd+1:bcd+2:bcd+3 ; ;******************************************************************** C_calc call divide call Get_Ccal ; Times 10,000 ( = 1000.0pF) call multiply goto PorM ; includes return ;-------------------------------------------------------------------- L_calc call multiply call Get_Lcal ; Precomputed 1/(Ccal*4*PI*PI) call multiply L_divF1 call Get_F1 ; Divide by F1^2 call S_push call multiply call S_swap call divide ; ; Handle space or - in front of FP number ; PorM btfss AARGB0,7 ; test sign goto Pplus Pminus movlw 0x2d ; minus goto PMdisp Pplus movlw 0x20 ; plus PMdisp movwf R_sign ; save for later display bcf AARGB0,7 ; make plus anyway ; ; Format as raw BCD string in bcd:bcd+1:bcd+2:bcd+3 ; call INT2424 ; To INT in AARGB0 etc. iorwf FPE,f ; W may hold Error (0xff) goto B2_BCD ; includes return ;******************************************************************** ; ; Calculate (F1/F3)^2-1, leave result on stack ; ;******************************************************************** F1_F3 call Get_F3 goto F1_F1 ;******************************************************************** ; ; Calculate (F1/F2)^2-1, leave result on stack ; ;******************************************************************** F1_F2 call Get_F2 F1_F1 call Get_F1 call divide ; F1/Fx call S_push call multiply ; (F1/Fx)^2 call Get_One call S_swap goto subtract ; (F1/Fx)^2-1 ; includes return ;******************************************************************** ; Fetch assorted things used for the calculation ; of Unknown L and C ; ;******************************************************************** Get_Lcal call S_push ; make room first movlw 0xAB ; 2.53303e+13 movwf AEXP ; Create FP version of movlw 0x38 ; Precomputed 1/(Ccal*4*PI*PI) movwf AARGB0 ; times any needed movlw 0x4D ; fiddle factor (1/100) goto B1_2_stak Get_Ccal call S_push ; make room first movlw 0x8c ; 10,000 movwf AEXP ; Create FP version of movlw 0x1C ; Precomputed Ccal movwf AARGB0 ; times any needed movlw 0x40 ; fiddle factor B1_2_stak movwf AARGB1 return Get_One call S_push ; make room first clrf AEXP ; Create a binary 1 clrf AARGB0 clrf AARGB1 movlw 0x01 goto LSB2stak Get_F1 movlw F1 ; Includes stack push goto W2stak Get_F2 movlw F2 ; Includes stack push goto W2stak Get_F3 movlw F3 ; Includes stack push ; goto W2stak ;******************************************************************** ; Copy 16 bit number, pointed to by W, to stack ; and convert to FP (positive value only) ; via a 24 bit number in AARGB0,1,2 ;******************************************************************** W2stak movwf FSR call S_push ; make room first clrf AEXP clrf AARGB0 movf INDF,W ; Big Byte first movwf AARGB1 incf FSR,F ; then little byte movf INDF,W LSB2stak movwf AARGB2 CALL FLO2424 ; 24 bit int -> 24 bit FP iorwf FPE,f ; W may hold Error (0xff) RETURN ;******************************************************************** INCLUDE ;******************************************************************** ; ; Text Strings (stored in data EEPROM) ; ORG 0x2100 ovr de " Over Range ",0 Unit1 de " nF",0 Unit2 de " pF",0 Unit3 de " mH",0 Unit4 de " uH",0 Cintro de " C = ",0 Lintro de " L = ",0 Calibr de " Calibrating ",0 END
