9 unterschiedlich programmierbare Codes die sich in den ersten 4 Bits unterscheiden. Jeder Code hat ein On/Off-Signal jeweils 4 unterschiedliche Pakete stellen das selbe Signal dar. working Codes that switch on and off (from:https://github.com/sui77/rc-switch/pull/4) (using original Timing) : ‭101001 00 0110 0010 1010 1100‬ 0xA462AC 1on ‭101001 11 0111 1100 1011 1100‬ 0xA77CBC 1off (invert this) ‭101011 01 1010 0110 0000 0101‬ 0xADA605 2on ‭101000 01 0101 1010 0100 0101‬ 0xA15A45 2off (invert this) ‭101000 00 1100 1001 0111 1110‬ 0xA0C97E 3on ‭101010 11 1011 0000 0101 1110‬ 0xABB05E 3off (invert this) ON Codes (match below OFF Codes): 0 0 0 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 1 on #1) >0x07EEAE 0 0 0 0 0 0 0 1 0 0 0 1 1 0 1 1 1 0 0 1 1 1 1 0 (Code 1 on #2) >0x011B9E 0 0 0 0 0 1 0 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 (Code 1 on #3) >0x04AAEE 0 0 0 0 1 1 0 0 1 0 0 1 0 0 1 0 0 1 0 1 1 1 1 0 (Code 1 on #4) >0x0C925E 1 0 0 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 2 on #1) >0x87EEAE 1 0 0 0 0 0 0 1 0 0 0 1 1 0 1 1 1 0 0 1 1 1 1 0 (Code 2 on #2) >0x811B9E 1 0 0 0 0 1 0 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 (Code 2 on #3) >0x84AAEE 1 0 0 0 1 1 0 0 1 0 0 1 0 0 1 0 0 1 0 1 1 1 1 0 (Code 2 on #4) >0x8C925E 0 1 0 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 3 on #1) >0x47EEAE 0 1 0 0 0 0 0 1 0 0 0 1 1 0 1 1 1 0 0 1 1 1 1 0 (Code 3 on #2) >0x411B9E 0 1 0 0 0 1 0 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 (Code 3 on #3) >0x44AAEE 0 1 0 0 1 1 0 0 1 0 0 1 0 0 1 0 0 1 0 1 1 1 1 0 (Code 3 on #4) >0x4C925E 1 1 0 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 4 on #1) >0xC7EEAE 1 1 0 0 0 0 0 1 0 0 0 1 1 0 1 1 1 0 0 1 1 1 1 0 (Code 4 on #2) >0xC11B9E 1 1 0 0 0 1 0 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 (Code 4 on #3) >0xC4AAEE 1 1 0 0 1 1 0 0 1 0 0 1 0 0 1 0 0 1 0 1 1 1 1 0 (Code 4 on #4) >0xCC925E 0 0 1 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 5 on #1) >0x27EEAE 0 0 1 0 0 0 1 0 1 0 1 0 0 0 0 1 0 1 1 1 1 1 1 0 (Code 5 on #2) >0x22A17E 0 0 1 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 0 (Code 5 on #3) >0x2F0F3E 0 0 1 0 1 0 1 1 0 0 1 1 0 1 0 1 0 0 1 0 1 1 1 0 (Code 5 on #4) >0x2B352E 1 0 1 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 6 on #1) >0xA7EEAE 1 0 1 0 0 0 1 0 1 0 1 0 0 0 0 1 0 1 1 1 1 1 1 0 (Code 6 on #2) >0xA2A17E 1 0 1 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 0 (Code 6 on #3) >0xAF0F3E 1 0 1 0 1 0 1 1 0 0 1 1 0 1 0 1 0 0 1 0 1 1 1 0 (Code 6 on #4) >0xAB352E 0 1 1 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 7 on #1) >0x67EEAE 0 1 1 0 0 0 1 0 1 0 1 0 0 0 0 1 0 1 1 1 1 1 1 0 (Code 7 on #2) >0x62A17E 0 1 1 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 0 (Code 7 on #3) >0x6F0F3E 0 1 1 0 1 0 1 1 0 0 1 1 0 1 0 1 0 0 1 0 1 1 1 0 (Code 7 on #4) >0x6B352E 1 1 1 0 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 8 on #1) >0xE7EEAE 1 1 1 0 0 0 1 0 1 0 1 0 0 0 0 1 0 1 1 1 1 1 1 0 (Code 8 on #2) >0xE2A17E 1 1 1 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 0 (Code 8 on #3) >0xEF0F3E 1 1 1 0 1 0 1 1 0 0 1 1 0 1 0 1 0 0 1 0 1 1 1 0 (Code 8 on #4) >0xEB352E 0 0 0 1 0 1 1 1 1 1 1 0 1 1 1 0 1 0 1 0 1 1 1 0 (Code 9 on #1) >0x17EEAE 0 0 0 1 0 0 0 1 0 0 0 1 1 0 1 1 1 0 0 1 1 1 1 0 (Code 9 on #2) >0x111B9E 0 0 0 1 0 1 0 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 (Code 9 on #3) >0x14AAEE 0 0 0 1 1 1 0 0 1 0 0 1 0 0 1 0 0 1 0 1 1 1 1 0 (Code 9 on #4) >0x1C925E corresponding OFF Codes: 0 0 0 0 0 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 1 1 1 0 (Code 1 off #1) >0x05C3DE 0 0 0 0 1 0 0 1 1 0 0 0 1 1 0 0 0 1 1 1 1 1 1 0 (Code 1 off #2) >0x098C7E 0 0 0 0 1 0 1 1 0 1 1 1 0 1 0 0 0 1 0 0 1 1 1 0 (Code 1 off #3) >0x0B744E 0 0 0 0 1 1 1 1 1 1 0 1 1 0 0 0 1 0 0 0 1 1 1 0 (Code 1 off #4) >0x0FD88E 1 0 0 0 0 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 1 1 1 0 (Code 2 off #1) >0x85C3DE 1 0 0 0 1 0 0 1 1 0 0 0 1 1 0 0 0 1 1 1 1 1 1 0 (Code 2 off #2) >0x898C7E 1 0 0 0 1 0 1 1 0 1 1 1 0 1 0 0 0 1 0 0 1 1 1 0 (Code 2 off #3) >0x8B744E 1 0 0 0 1 1 1 1 1 1 0 1 1 0 0 0 1 0 0 0 1 1 1 0 (Code 2 off #4) >0x8FD88E 0 1 0 0 0 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 1 1 1 0 (Code 3 off #1) >0x45C3DE 0 1 0 0 1 0 0 1 1 0 0 0 1 1 0 0 0 1 1 1 1 1 1 0 (Code 3 off #2) >0x498C7E 0 1 0 0 1 0 1 1 0 1 1 1 0 1 0 0 0 1 0 0 1 1 1 0 (Code 3 off #3) >0x4B744E 0 1 0 0 1 1 1 1 1 1 0 1 1 0 0 0 1 0 0 0 1 1 1 0 (Code 3 off #4) >0x4FD88E 1 1 0 0 0 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 1 1 1 0 (Code 4 off #1) >0xC5C3DE 1 1 0 0 1 0 0 1 1 0 0 0 1 1 0 0 0 1 1 1 1 1 1 0 (Code 4 off #2) >0xC98C7E 1 1 0 0 1 0 1 1 0 1 1 1 0 1 0 0 0 1 0 0 1 1 1 0 (Code 4 off #3) >0xCB744E 1 1 0 0 1 1 1 1 1 1 0 1 1 0 0 0 1 0 0 0 1 1 1 0 (Code 4 off #4) >0xCFD88E 0 0 1 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0 0 1 1 1 1 0 (Code 5 off #1) >0x25131E 0 0 1 0 0 1 1 0 1 1 0 1 0 0 1 0 1 0 0 1 1 1 1 0 (Code 5 off #2) >0x26D29E 0 0 1 0 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 1 1 1 0 (Code 5 off #3) >0x2879FE 0 0 1 0 1 1 1 0 1 0 0 1 1 0 1 1 0 0 0 0 1 1 1 0 (Code 5 off #4) >0x2E9B0E 1 0 1 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0 0 1 1 1 1 0 (Code 6 off #1) >0xA5131E 1 0 1 0 0 1 1 0 1 1 0 1 0 0 1 0 1 0 0 1 1 1 1 0 (Code 6 off #2) >0xA6D29E 1 0 1 0 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 1 1 1 0 (Code 6 off #3) >0xA879FE 1 0 1 0 1 1 1 0 1 0 0 1 1 0 1 1 0 0 0 0 1 1 1 0 (Code 6 off #4) >0xAE9B0E 0 1 1 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0 0 1 1 1 1 0 (Code 7 off #1) >0x65131E 0 1 1 0 0 1 1 0 1 1 0 1 0 0 1 0 1 0 0 1 1 1 1 0 (Code 7 off #2) >0x66D29E 0 1 1 0 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 1 1 1 0 (Code 7 off #3) >0x6879FE 0 1 1 0 1 1 1 0 1 0 0 1 1 0 1 1 0 0 0 0 1 1 1 0 (Code 7 off #4) >0x6E9B0E 1 1 1 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0 0 1 1 1 1 0 (Code 8 off #1) >0xE5131E 1 1 1 0 0 1 1 0 1 1 0 1 0 0 1 0 1 0 0 1 1 1 1 0 (Code 8 off #2) >0xE6D29E 1 1 1 0 1 0 0 0 0 1 1 1 1 0 0 1 1 1 1 1 1 1 1 0 (Code 8 off #3) >0xE879FE 1 1 1 0 1 1 1 0 1 0 0 1 1 0 1 1 0 0 0 0 1 1 1 0 (Code 8 off #4) >0xEE9B0E 0 0 0 1 0 1 0 1 1 1 0 0 0 0 1 1 1 1 0 1 1 1 1 0 (Code 9 off #1) >0x15C3DE 0 0 0 1 1 0 0 1 1 0 0 0 1 1 0 0 0 1 1 1 1 1 1 0 (Code 9 off #2) >0x198C7E 0 0 0 1 1 0 1 1 0 1 1 1 0 1 0 0 0 1 0 0 1 1 1 0 (Code 9 off #3) >0x1B744E 0 0 0 1 1 1 1 1 1 1 0 1 1 0 0 0 1 0 0 0 1 1 1 0 (Code 9 off #4) >0x1FD88E
