1 | #include "msp430x26x.h"
2 |
3 | unsigned char RxByte;
4 | volatile unsigned char RxData[256];
5 | unsigned char TxByte;
6 | volatile unsigned int i;
7 |
8 | void main(void)
9 | {
10 | WDTCTL = WDTPW + WDTHOLD; // Stop WDT
11 | //DCOCTL = CALDCO_8MHZ; // Load 8MHz constants
12 | //BCSCTL1 = CALBC1_8MHZ;
13 | BCSCTL1 |= XTS ; // ACLK = LFXT1 = HF XTAL
14 | BCSCTL3 |= LFXT1S1; // 3 – 16MHz crystal
15 |
16 | do
17 | {
18 | IFG1 &= ~OFIFG; // Clear OSCFault flag
19 | for (i = 0xFF; i > 0; i--); // Time for flag to set
20 | }
21 | while (IFG1 & OFIFG); // OSCFault flag still set?
22 |
23 | BCSCTL2 |= SELM_3; // MCLK = LFXT1 (safe)
24 | P1OUT &= ~0x01; // Clear P1.0
25 | P1DIR |= 0x01; // P1.0 output
26 | P3OUT &= ~(BIT4+BIT5);
27 | P3SEL |= 0x30; // Use P3.4/P3.5 for USCI_A0
28 | UCA0CTL1 |= UCSWRST; // Set SW Reset
29 | UCA0CTL1 = UCSSEL_1 + UCSWRST; // Use SMCLK, keep SW reset
30 | UCA0BR0 = 104; // 8MHz/52=153.8KHz
31 | UCA0BR1 = 0;
32 | UCA0MCTL = UCBRF_1 + UCOS16; // Set 1st stage modulator to 1
33 |
34 | //UCA0MCTL = UCBRS_7 + UCBRF_0 + UCOS16; // Set 1st stage modulator to 1
35 | // 16-times oversampling mode
36 | UCA0IRTCTL = UCIRTXPL2 + UCIRTXPL0 + UCIRTXCLK + UCIREN;
37 | // Pulse length = 6 half clock cyc
38 | // Enable BITCLK16, IrDA enc/dec
39 | UCA0CTL1 &= ~UCSWRST; // Resume operation
40 | TxByte = 0x53;
41 | //TxByte = 0xAB; // TX data and pointer, 8-bit
42 | //TxByte = 0x00;
43 | IE2 |= UCA0RXIE;
44 | while (1)
45 | {
46 | for (i = 1000; i; i--); // Small delay
47 | while (!(IFG2 & UCA0TXIFG)); // USCI_A0 TX buffer ready?
48 | UCA0TXBUF = TxByte; // TX character
49 | P1OUT ^= 0x01;
50 | //TxByte++;
51 |
52 | __disable_interrupt();
53 | IE2 |= UCA0RXIE; // Enable RX int
54 | __bis_SR_register(GIE); // Enter LPM0 w/ interrupts
55 | }
56 | }
57 | #pragma vector = USCIAB0RX_VECTOR
58 | __interrupt void USCIAB0RX_ISR(void)
59 | {
60 | RxByte = UCA0RXBUF; // Get RXed character
61 | IE2 &= ~UCA0RXIE; // Disable RX int
62 | //TxByte = RxByte;
63 | if (TxByte != RxByte) // RX OK?
64 | {
65 | P1DIR |= 0x01;
66 | P1OUT |= 0x01; // LED P1.0 on
67 | }
68 | //__bic_SR_register_on_exit(CPUOFF); // Exit LPM0
69 |
70 | }
