1 | #include <stdlib.h>
2 | #include <avr/io.h>
3 | #include <util/delay.h>
4 | #include <avr/interrupt.h>
5 | #include <inttypes.h>
6 | #include <string.h>
7 |
8 | #define LENGTH 15
9 |
10 | #ifndef F_CPU
11 | #warning "F_CPU was not defined yet, now make up with 4000000"
12 | #define F_CPU 4000000L // Systemtakt in Hz
13 | #endif
14 |
15 |
16 | #define BAUD 9600L
17 | #define UBRR_VAL ((F_CPU+BAUD * 8)/(BAUD*16)-1) //clever round
18 | #define BAUD_REAL (F_CPU/(16*(UBRR_VAL+1))) //real baud rate
19 | #define BAUD_ERROR ((BAUD_REAL*1000)/BAUD-1000) //Error per thousand
20 |
21 |
22 | #if ((BAUD_ERROR>10)||(BAUD_ERROR<-10))
23 | #error Systematic error in the baud rate more than 1% and thus too high!
24 | #endif
25 |
26 |
27 | // constants and macros
28 | /* size of RX/TX buffers */
29 | #define UART_RX_BUFFER_MASK ( UART_RX_BUFFER_SIZE - 1)
30 | #define UART_TX_BUFFER_MASK ( UART_TX_BUFFER_SIZE - 1)
31 |
32 | #if ( UART_RX_BUFFER_SIZE & UART_RX_BUFFER_MASK )
33 | #error RX buffer size is not a power of 2
34 | #endif
35 | #if ( UART_TX_BUFFER_SIZE & UART_TX_BUFFER_MASK )
36 | #error TX buffer size is not a power of 2
37 | #endif
38 |
39 | /** Size of the circular receive buffer, must be power of 2 */
40 | #ifndef UART_RX_BUFFER_SIZE
41 | #define UART_RX_BUFFER_SIZE 32
42 | #endif
43 | /** Size of the circular transmit buffer, must be power of 2 */
44 | #ifndef UART_TX_BUFFER_SIZE
45 | #define UART_TX_BUFFER_SIZE 32
46 | #endif
47 |
48 | /* test if the size of the circular buffers fits into SRAM */
49 | #if ( (UART_RX_BUFFER_SIZE+UART_TX_BUFFER_SIZE) >= (RAMEND-0x60 ) )
50 | #error "size of UART_RX_BUFFER_SIZE + UART_TX_BUFFER_SIZE larger than size of SRAM"
51 | #endif
52 |
53 | /*
54 | ** high byte error return code of uart_getc()
55 | */
56 | #define UART_FRAME_ERROR 0x0800 // Framing Error by UART
57 | #define UART_OVERRUN_ERROR 0x0400 // Overrun condition by UART
58 | #define UART_BUFFER_OVERFLOW 0x0200 // receive ringbuffer overflow
59 | #define UART_NO_DATA 0x0100 // no receive data available
60 |
61 |
62 |
63 | // ATmega with two USART
64 | #define ATMEGA_USART0
65 | #define ATMEGA_USART1
66 | #define UART0_RECEIVE_INTERRUPT SIG_UART0_RECV
67 | #define UART1_RECEIVE_INTERRUPT SIG_UART1_RECV
68 | #define UART0_TRANSMIT_INTERRUPT SIG_UART0_DATA
69 | #define UART1_TRANSMIT_INTERRUPT SIG_UART1_DATA
70 |
71 | #define UART0_STATUS UCSR0A
72 | #define UART0_CONTROL UCSR0B
73 | #define UART0_DATA UDR0
74 | #define UART0_UDRIE UDRIE0
75 |
76 | #define UART1_STATUS UCSR1A
77 | #define UART1_CONTROL UCSR1B
78 | #define UART1_DATA UDR1
79 | #define UART1_UDRIE UDRIE1
80 |
81 |
82 | //module global variables
83 |
84 | //ATMEGA_USART0
85 | static volatile unsigned char UART0_TxBuf[UART_TX_BUFFER_SIZE];
86 | static volatile unsigned char UART0_RxBuf[UART_RX_BUFFER_SIZE];
87 | static volatile unsigned char UART0_TxHead;
88 | static volatile unsigned char UART0_TxTail;
89 | static volatile unsigned char UART0_RxHead;
90 | static volatile unsigned char UART0_RxTail;
91 | static volatile unsigned char UART0_LastRxError;
92 |
93 | //ATMEGA_USART1
94 | static volatile unsigned char UART1_TxBuf[UART_TX_BUFFER_SIZE];
95 | static volatile unsigned char UART1_RxBuf[UART_RX_BUFFER_SIZE];
96 | static volatile unsigned char UART1_TxHead;
97 | static volatile unsigned char UART1_TxTail;
98 | static volatile unsigned char UART1_RxHead;
99 | static volatile unsigned char UART1_RxTail;
100 | static volatile unsigned char UART1_LastRxError;
101 |
102 |
103 |
104 | SIGNAL(UART0_RECEIVE_INTERRUPT)
105 | /*************************************************************************
106 | Function: UART Receive Complete interrupt
107 | Purpose: called when the UART has received a character
108 | **************************************************************************/
109 | {
110 | unsigned char tmphead;
111 | unsigned char data;
112 | unsigned char usr;
113 | unsigned char lastRxError;
114 |
115 |
116 | // read UART status register and UART data register
117 | usr = UART0_STATUS;
118 | data = UART0_DATA;
119 |
120 | // defined( ATMEGA_USART0 )
121 | lastRxError = (usr & (_BV(FE0)|_BV(DOR0)) );
122 |
123 | // calculate buffer index
124 | tmphead = ( UART0_RxHead + 1) & UART_RX_BUFFER_MASK;
125 |
126 | if ( tmphead == UART0_RxTail )
127 | // error: receive buffer overflow
128 | lastRxError = UART_BUFFER_OVERFLOW >> 8;
129 |
130 | else
131 | {
132 | // store new index
133 | UART0_RxHead = tmphead;
134 | // store received data in buffer
135 | UART0_RxBuf[tmphead] = data;
136 | }
137 |
138 | UART0_LastRxError = lastRxError;
139 | }
140 |
141 |
142 | SIGNAL(UART0_TRANSMIT_INTERRUPT)
143 | /*************************************************************************
144 | Function: UART Data Register Empty interrupt
145 | Purpose: called when the UART is ready to transmit the next byte
146 | **************************************************************************/
147 | {
148 | unsigned char tmptail;
149 |
150 |
151 | if ( UART0_TxHead != UART0_TxTail)
152 | {
153 | // calculate and store new buffer index
154 | tmptail = (UART0_TxTail + 1) & UART_TX_BUFFER_MASK;
155 | UART0_TxTail = tmptail;
156 | // get one byte from buffer and write it to UART
157 | UART0_DATA = UART0_TxBuf[tmptail]; // start transmission
158 | }
159 | else
160 | // tx buffer empty, disable UDRE interrupt
161 | UART0_CONTROL &= ~_BV(UART0_UDRIE);
162 | }
163 |
164 |
165 | /*************************************************************************
166 | Function: uart0_init()
167 | Purpose: initialize UART and set baudrate
168 | Input: baudrate using macro UART_BAUD_SELECT()
169 | Returns: none
170 | **************************************************************************/
171 | void uart0_init(void)
172 | {
173 | UART0_TxHead = 0;
174 | UART0_TxTail = 0;
175 | UART0_RxHead = 0;
176 | UART0_RxTail = 0;
177 |
178 |
179 |
180 | //defined (ATMEGA_USART0 )
181 |
182 | UBRR0H = (unsigned char)(UBRR_VAL>>8);
183 | UBRR0L = (unsigned char) UBRR_VAL;
184 |
185 | // Enable USART receiver and transmitter and receive complete interrupt
186 | UART0_CONTROL = _BV(RXCIE0)|(1<<RXEN0)|(1<<TXEN0);
187 |
188 | // Set frame format: asynchronous, 8data, no parity, 1stop bit
189 | #ifdef URSEL0
190 | UCSR0C = (1<<URSEL0)| (1<<UCSZ01)|(1<<UCSZ00);
191 | #else
192 | UCSR0C = (1<<UCSZ01)|(1<<UCSZ00);
193 | #endif
194 |
195 | }// uart_init
196 |
197 |
198 | /*************************************************************************
199 | Function: uart0_getc()
200 | Purpose: return byte from ringbuffer
201 | Returns: lower byte: received byte from ringbuffer
202 | higher byte: last receive error
203 | **************************************************************************/
204 | unsigned char uart0_getc(void)
205 | {
206 | unsigned char tmptail;
207 | unsigned char data;
208 |
209 |
210 | if ( UART0_RxHead == UART0_RxTail ) {
211 | return (unsigned char) UART_NO_DATA; // no data available
212 | }
213 |
214 | // calculate /store buffer index
215 | tmptail = (UART0_RxTail + 1) & UART_RX_BUFFER_MASK;
216 | UART0_RxTail = tmptail;
217 |
218 | // get data from receive buffer
219 | data = UART0_RxBuf[tmptail];
220 |
221 | return (UART0_LastRxError << 8) + data;
222 |
223 | }// uart_getc
224 |
225 | /*************************************************************************
226 | Function: uart0_gets()
227 | Purpose: function which receive a String Through usart
228 | Returns: lower byte: received byte from ringbuffer
229 | higher byte: last receive error
230 | **************************************************************************/
231 | void uart0_gets (char* string, unsigned int Length)
232 | {
233 | uint8_t i;
234 | char c;
235 | char* s;
236 |
237 | s=string;
238 | i=0;
239 | do
240 | {
241 | c=uart0_getc();
242 | if (c!='\r')
243 | {
244 | *s=c;
245 | s++;
246 | i++;
247 | }
248 | }
249 | while( i!=Length && c!='\r');
250 | *s = '\0';
251 |
252 | }//end UART_Gets
253 |
254 |
255 | /*************************************************************************
256 | Function: uart_putc()
257 | Purpose: write byte to ringbuffer for transmitting via UART
258 | Input: byte to be transmitted
259 | Returns: none
260 | **************************************************************************/
261 | void uart0_putc(unsigned char data)
262 | {
263 | unsigned char tmphead;
264 |
265 | // calculate /store buffer index
266 | tmphead = (UART0_TxHead + 1) & UART_TX_BUFFER_MASK;
267 |
268 | while ( tmphead == UART0_TxTail ){
269 | ;// wait for free space in buffer
270 | }
271 |
272 | UART0_TxBuf[tmphead] = data;
273 | UART0_TxHead = tmphead;
274 |
275 | // enable UDRE interrupt
276 | UART0_CONTROL |= _BV(UART0_UDRIE);
277 |
278 | }// uart_putc
279 |
280 | /*void USART_Putc(unsigned char c)
281 | {
282 | while (!(UCSRA & (1<<UDRE))); // Do nothing until data have been transmited
283 |
284 | UDR = c; // Put data into Buffer, sends the data
285 | _delay_ms(10);
286 | }//end USART_Putc()*/
287 | /*************************************************************************
288 | Function: uart_puts()
289 | Purpose: transmit string to UART
290 | Input: string to be transmitted
291 | Returns: none
292 | **************************************************************************/
293 | void uart0_puts(char *s )
294 | {
295 | while (*s != '\0' )
296 | uart0_putc(*s++);
297 |
298 | }// uart_puts
299 |
300 |
301 | /*************************************************************************
302 | Function: uart_puts_p()
303 | Purpose: transmit string from program memory to UART
304 | Input: program memory string to be transmitted
305 | Returns: none
306 | **************************************************************************/
307 | void uart0_puts_p(const char *progmem_s )
308 | {
309 | register char c;
310 |
311 | while ( (c = pgm_read_byte(progmem_s++)) )
312 | uart0_putc(c);
313 |
314 | }//uart_puts_p
315 |
316 |
317 | /*
318 | * these functions are only for ATMEGA_USART1
319 | */
320 |
321 | SIGNAL(UART1_RECEIVE_INTERRUPT)
322 | /*************************************************************************
323 | Function: UART1 Receive Complete interrupt
324 | Purpose: called when the UART1 has received a character
325 | **************************************************************************/
326 | {
327 | unsigned char tmphead;
328 | unsigned char data;
329 | unsigned char usr;
330 | unsigned char lastRxError;
331 |
332 |
333 | /* read UART status register and UART data register */
334 | usr = UART1_STATUS;
335 | data = UART1_DATA;
336 |
337 | /* */
338 | lastRxError = (usr & (_BV(FE1)|_BV(DOR1)) );
339 |
340 | /* calculate buffer index */
341 | tmphead = ( UART1_RxHead + 1) & UART_RX_BUFFER_MASK;
342 |
343 | if ( tmphead == UART1_RxTail )
344 | /* error: receive buffer overflow */
345 | lastRxError = UART_BUFFER_OVERFLOW >> 8;
346 |
347 | else
348 | {
349 | /* store new index */
350 | UART1_RxHead = tmphead;
351 | /* store received data in buffer */
352 | UART1_RxBuf[tmphead] = data;
353 | }
354 |
355 | UART1_LastRxError = lastRxError;
356 | }
357 |
358 |
359 | SIGNAL(UART1_TRANSMIT_INTERRUPT)
360 | /*************************************************************************
361 | Function: UART1 Data Register Empty interrupt
362 | Purpose: called when the UART1 is ready to transmit the next byte
363 | **************************************************************************/
364 | {
365 | unsigned char tmptail;
366 |
367 |
368 | if ( UART1_TxHead != UART1_TxTail)
369 | {
370 | /* calculate and store new buffer index */
371 | tmptail = (UART1_TxTail + 1) & UART_TX_BUFFER_MASK;
372 | UART1_TxTail = tmptail;
373 | /* get one byte from buffer and write it to UART */
374 | UART1_DATA = UART1_TxBuf[tmptail]; /* start transmission */
375 | }
376 | else
377 | /* tx buffer empty, disable UDRE interrupt */
378 | UART1_CONTROL &= ~_BV(UART1_UDRIE);
379 | }
380 |
381 |
382 | /*************************************************************************
383 | Function: uart1_init()
384 | Purpose: initialize UART1 and set baudrate
385 | Input: baudrate using macro UART_BAUD_SELECT()
386 | Returns: none
387 | **************************************************************************/
388 | void uart1_init()
389 | {
390 | UART1_TxHead = 0;
391 | UART1_TxTail = 0;
392 | UART1_RxHead = 0;
393 | UART1_RxTail = 0;
394 |
395 |
396 | UBRR1H = (unsigned char)(UBRR_VAL>>8);
397 | UBRR1L = (unsigned char) UBRR_VAL;
398 |
399 | // Enable USART receiver and transmitter and receive complete interrupt
400 | UART1_CONTROL = _BV(RXCIE1)|(1<<RXEN1)|(1<<TXEN1);
401 |
402 | // Set frame format: asynchronous, 8data, no parity, 1stop bit
403 | #ifdef URSEL1
404 | UCSR1C = (1<<URSEL1)|(3<<UCSZ10);
405 | #else
406 | UCSR1C = (3<<UCSZ10);
407 | #endif
408 |
409 | }// uart_init
410 |
411 |
412 | /*************************************************************************
413 | Function: uart1_getc()
414 | Purpose: return byte from ringbuffer
415 | Returns: lower byte: received byte from ringbuffer
416 | higher byte: last receive error
417 | **************************************************************************/
418 | unsigned char uart1_getc(void)
419 | {
420 | unsigned char tmptail;
421 | unsigned char data;
422 |
423 |
424 | if ( UART1_RxHead == UART1_RxTail ) {
425 | return (unsigned char) UART_NO_DATA; // no data available
426 | }
427 |
428 | // calculate /store buffer index
429 | tmptail = (UART1_RxTail + 1) & UART_RX_BUFFER_MASK;
430 | UART1_RxTail = tmptail;
431 |
432 | // get data from receive buffer
433 | data = UART1_RxBuf[tmptail];
434 |
435 | return (UART1_LastRxError << 8) + data;
436 |
437 | }// uart1_getc
438 |
439 | /*************************************************************************
440 | Function: uart1_gets()
441 | Purpose: function which receive a String Through usart
442 | Returns: lower byte: received byte from ringbuffer
443 | higher byte: last receive error
444 | **************************************************************************/
445 | void uart1_gets (char* string, unsigned int Length)
446 | {
447 | uint8_t i;
448 | char c;
449 | char* s;
450 |
451 | s=string;
452 | i=0;
453 | do
454 | {
455 | c=uart1_getc();
456 | if (c!='\r')
457 | {
458 | *s=c;
459 | s++;
460 | i++;
461 | }
462 | }
463 | while( i!=Length && c!='\r');
464 | *s = '\0';
465 |
466 | }//end uart1_gets
467 |
468 | /*************************************************************************
469 | Function: uart1_putc()
470 | Purpose: write byte to ringbuffer for transmitting via UART
471 | Input: byte to be transmitted
472 | Returns: none
473 | **************************************************************************/
474 | void uart1_putc(unsigned char data)
475 | {
476 | unsigned char tmphead;
477 |
478 |
479 | tmphead = (UART1_TxHead + 1) & UART_TX_BUFFER_MASK;
480 |
481 | while ( tmphead == UART1_TxTail ){
482 | ;// wait for free space in buffer
483 | }
484 |
485 | UART1_TxBuf[tmphead] = data;
486 | UART1_TxHead = tmphead;
487 |
488 | // enable UDRE interrupt
489 | UART1_CONTROL |= _BV(UART1_UDRIE);
490 |
491 | }// uart1_putc
492 |
493 |
494 | /*************************************************************************
495 | Function: uart1_puts()
496 | Purpose: transmit string to UART1
497 | Input: string to be transmitted
498 | Returns: none
499 | **************************************************************************/
500 | void uart1_puts(const char *s )
501 | {
502 | while (*s)
503 | uart1_putc(*s++);
504 |
505 | }// uart1_puts
506 |
507 |
508 |
509 | int main(void)
510 | {
511 |
512 | DDRD = 0xFF; // PORTD auf Eingang
513 | PORTD = 0xFF; //Internal pull ups resistance for key inputs PortD2 and portD3 was activated
514 |
515 | DDRC = 0xFF; // outputs for LEDs
516 | PORTC = 0x00; // LEDs off
517 |
518 | // Initialize UART library, pass baudrate and AVR cpu clock with the macro
519 | uart0_init();
520 | uart1_init();
521 |
522 | // now enable interrupt, since UART library is interrupt controlled
523 | sei();
524 |
525 | char Command [LENGTH+1];
526 |
527 | for(;;)
528 | {
529 | PORTC = 0xAA;
530 |
531 | uart0_gets( Command, LENGTH );
532 | uart0_puts( Command );
533 | uart0_puts( "\r\n" );
534 |
535 |
536 | if(strcmp(Command, "start") == 0)
537 | {
538 | PORTC = 0xFA;
539 | for(int i=0; i<19; i++)
540 | uart1_puts("start");
541 | _delay_ms(10);
542 | }
543 | else if(strcmp(Command, "exit") == 0)
544 | {
545 | PORTC = 0xBA;
546 | for(int i=0; i<19; i++)
547 | uart1_puts("exit");
548 | _delay_ms(10);
549 | }
550 | }
551 | return 0;
552 | }
