AVR (Atmega16, Atmega32) Minimum System Development Board Ich habe ein unbenutztes Entwicklungsboard mit Textool Sockel für Atmega 16, Atmega32 für € 6 plus Versand anzubieten. Technische Daten des Herstellers: 1. 32 I/O pin all the leads. 2. Classic ATmega16 minimum system, eliminating the hassle of soldering 3. Crystal: The socket hole welding facilitate the buyer to replace the crystal, 12M crystal 4. support chips: ATmega16/ATmega32 and chip which pin-compatible 5. Power supply: power adapter or external expansion pin power supply (not support ISP download interface power supply) 6. DC-005 Power Block (supporting the transposon is 5.5*2.1mm) 7. expand outside 4 channel VCC, GND 8. Reset: Power-on reset and reset button 9. Power LED (D1) and the program run indicator (D2) 10 standard ISP download interface
