1 | USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
2 | 1000 21170 0.0 0.1 6536 2824 ? SN Apr17 0:01 sw-cp-server: worker process
3 | 108 419 0.0 0.0 3472 1372 ? Ss Apr11 0:00 dbus-daemon --system --fork --activation=upstart
4 | avahi 444 0.0 0.0 3408 440 ? S Apr11 0:00 avahi-daemon: chroot helper
5 | avahi 441 0.0 0.0 3516 1392 ? S Apr11 0:00 avahi-daemon: running [h123.local]
6 | bind 801 0.0 0.1 59940 2232 ? Ssl Apr11 0:00 /usr/sbin/named -t /var/named/run-root -c /etc/nam
7 | clamav 975 0.1 0.0 16004 1728 ? Ss Apr11 38:03 /usr/bin/freshclam -d --quiet
8 | mysql 19166 1.0 0.5 161440 10604 pts/1 Dl+ 16:21 0:00 /usr/sbin/mysqld --bootstrap --user=mysql --skip-g
9 | new_user 19124 0.5 0.5 48000 11808 ? S 16:20 0:00 /usr/bin/php5-cgi -c /var/www/vhosts/system/neu
10 | new_user 14169 0.0 0.1 7132 4092 ? SLs 16:15 0:00 proftpd: new_user - 1.2.3.4: IDLE
11 | popuser 9689 0.0 0.0 4472 1116 ? S 15:17 0:00 /usr/bin/imapd Maildir
12 | popuser 9690 0.0 0.0 4400 1020 ? S 15:17 0:00 /usr/bin/imapd Maildir
13 | popuser 9695 0.0 0.0 4400 1004 ? S 15:17 0:00 /usr/bin/imapd Maildir
14 | popuser 9696 0.0 0.0 4400 984 ? S 15:17 0:00 /usr/bin/imapd Maildir
15 | popuser 9697 0.0 0.0 4400 1000 ? S 15:17 0:00 /usr/bin/imapd Maildir
16 | popuser 9707 0.0 0.0 4400 1068 ? S 15:17 0:00 /usr/bin/imapd Maildir
17 | popuser 9708 0.0 0.0 4400 980 ? S 15:17 0:00 /usr/bin/imapd Maildir
18 | popuser 11281 0.0 0.0 4400 1056 ? S 16:09 0:00 /usr/bin/imapd Maildir
19 | postfix 1119 0.0 0.0 66516 1512 ? Ssl Apr11 0:45 /usr/lib/plesk-9.0/psa-pc-remote -p inet:12768@127
20 | postfix 12551 0.0 0.0 4552 1332 ? S 16:12 0:00 anvil -l -t unix -u -c
21 | postfix 19151 0.0 0.1 4960 2192 ? S 16:21 0:00 cleanup -z -t unix -u -c
22 | postfix 10553 0.0 0.0 4552 1408 ? S 16:00 0:00 pickup -l -t fifo -u -c
23 | postfix 19153 0.0 0.0 4556 1448 ? S 16:21 0:00 pipe -n plesk_virtual -t unix flags=DORhu user=pop
24 | postfix 12544 0.0 0.0 4552 1356 ? S 16:12 0:00 proxymap -t unix -u
25 | postfix 1408 0.0 0.0 4696 1552 ? S Apr11 1:59 qmgr -l -t fifo -u
26 | postfix 12543 0.0 0.2 9604 4864 ? S 16:12 0:00 smtpd -n smtp -t inet -u -c -o stress= -s 2
27 | postfix 7578 0.0 0.1 7256 2812 ? S Apr11 0:01 tlsmgr -l -t unix -u -c
28 | postfix 19152 0.0 0.1 5612 2732 ? S 16:21 0:00 trivial-rewrite -n rewrite -t unix -u -c
29 | root 10718 0.0 0.2 9208 4248 pts/3 Ss 16:02 0:00 -bash
30 | root 19114 1.9 0.2 9208 4248 pts/5 Ss 16:20 0:00 -bash
31 | root 3 0.0 0.0 0 0 ? S Apr11 0:00 [khelper/2078364]
32 | root 2 0.0 0.0 0 0 ? S Apr11 0:00 [kthreadd/207836]
33 | root 12 0.0 0.0 0 0 ? S Apr11 0:00 [nfsiod/2078364]
34 | root 4 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
35 | root 5 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
36 | root 6 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
37 | root 7 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
38 | root 8 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
39 | root 9 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
40 | root 10 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
41 | root 11 0.0 0.0 0 0 ? S Apr11 0:00 [rpciod/2078364/]
42 | root 18950 0.0 0.0 6464 1540 pts/1 S+ 16:20 0:00 /bin/bash -e /var/lib/dpkg/info/mysql-server-5.5.p
43 | root 113 0.0 0.0 3148 1360 ? Ss Apr11 0:00 /sbin/udevd --daemon
44 | root 9691 0.0 0.0 4456 1944 ? S 15:17 0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplo
45 | root 9692 0.0 0.0 4456 1940 ? S 15:17 0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplo
46 | root 9693 0.0 0.0 4456 1940 ? S 15:17 0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplo
47 | root 9704 0.0 0.0 4456 1940 ? S 15:17 0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplo
48 | root 18377 0.1 0.2 9508 4352 pts/1 Ss+ 16:19 0:00 /usr/bin/dpkg --status-fd 35 --configure libcurl3-
49 | root 18940 1.0 0.4 15536 9672 pts/1 S+ 16:20 0:00 /usr/bin/perl -w /usr/share/debconf/frontend /var/
50 | root 1843 0.0 0.2 33480 4740 ? Sl Apr11 4:26 /usr/bin/python /usr/bin/fail2ban-server -b -s /va
51 | root 1001 0.0 0.0 5108 1004 ? S Apr11 0:00 /usr/lib/courier-authlib/authdaemond
52 | root 1017 0.0 0.0 5348 1796 ? S Apr11 0:01 /usr/lib/courier-authlib/authdaemond
53 | root 1018 0.0 0.0 5348 1756 ? S Apr11 0:01 /usr/lib/courier-authlib/authdaemond
54 | root 1019 0.0 0.0 5348 1756 ? S Apr11 0:01 /usr/lib/courier-authlib/authdaemond
55 | root 1020 0.0 0.0 5348 1756 ? S Apr11 0:01 /usr/lib/courier-authlib/authdaemond
56 | root 1021 0.0 0.0 5348 1760 ? S Apr11 0:01 /usr/lib/courier-authlib/authdaemond
57 | root 1024 0.0 0.0 3844 716 ? S Apr11 0:00 /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxp
58 | root 1042 0.0 0.0 3844 692 ? S Apr11 0:02 /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxp
59 | root 1059 0.0 0.0 3844 692 ? S Apr11 0:01 /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxp
60 | root 1077 0.0 0.0 3844 684 ? S Apr11 0:00 /usr/lib/couriertcpd -address=0 -maxprocs=40 -maxp
61 | root 1845 0.0 0.0 3952 1168 ? S Apr11 0:38 /usr/lib/gamin/gam_server
62 | root 809 0.0 0.0 28608 2084 ? Sl Apr11 0:26 /usr/lib/policykit-1/polkitd --no-debug
63 | root 1378 0.0 0.0 4532 1408 ? Ss Apr11 3:00 /usr/lib/postfix/master
64 | root 3220 0.0 1.0 69744 21852 ? Ss Apr11 0:46 /usr/sbin/apache2 -k start
65 | root 1000 0.0 0.0 2104 432 ? S Apr11 0:00 /usr/sbin/courierlogger -name=courier-authdaemon -
66 | root 1023 0.0 0.0 2104 432 ? S Apr11 0:00 /usr/sbin/courierlogger -name=imapd -pid=/var/run/
67 | root 1041 0.0 0.0 2104 428 ? S Apr11 0:00 /usr/sbin/courierlogger -name=imapd-ssl -pid=/var/
68 | root 1058 0.0 0.0 2104 428 ? S Apr11 0:00 /usr/sbin/courierlogger -name=pop3d -pid=/var/run/
69 | root 1076 0.0 0.0 2104 432 ? S Apr11 0:00 /usr/sbin/courierlogger -name=pop3d-ssl -pid=/var/
70 | root 18697 0.3 0.1 11076 3444 ? Ss 16:20 0:00 /usr/sbin/cupsd -F
71 | root 668 0.0 0.0 7096 1320 ? Ss Apr11 0:00 /usr/sbin/modem-manager
72 | root 640 0.0 0.0 6636 1628 ? Ss Apr11 0:00 /usr/sbin/sshd -D
73 | root 12518 0.0 0.0 2516 984 ? Ss 16:12 0:00 /usr/sbin/xinetd -dontfork -pidfile /var/run/xinet
74 | root 726 0.0 0.0 2128 416 ? Ss Apr11 0:00 acpid -c /etc/acpi/events -s /var/run/acpid.socket
75 | root 10936 0.0 1.2 37164 27040 pts/3 S+ 16:04 0:00 apt-get upgrade
76 | root 9699 0.0 0.0 4456 1932 ? S 15:17 0:00 couriertls -statusfd=7 -printx509=9 -localfd=5 -tc
77 | root 9701 0.0 0.0 4456 1936 ? S 15:17 0:00 couriertls -statusfd=7 -printx509=9 -localfd=5 -tc
78 | root 9710 0.0 0.0 4456 1932 ? S 15:17 0:00 couriertls -statusfd=7 -printx509=9 -localfd=5 -tc
79 | root 11283 0.0 0.0 4456 1936 ? S 16:09 0:00 couriertls -statusfd=7 -printx509=9 -localfd=5 -tc
80 | root 729 0.0 0.0 2572 744 ? Ss Apr11 0:04 cron
81 | root 1 0.0 0.0 3472 1752 ? Ss Apr11 0:01 init
82 | root 722 0.0 0.0 28500 968 ? Ssl Apr11 0:00 lightdm
83 | root 19167 0.0 0.0 5372 636 pts/1 S+ 16:21 0:00 logger -p daemon.err -t mysqld_safe -i
84 | root 773 0.0 0.1 26840 3072 ? Ssl Apr11 0:32 NetworkManager
85 | root 19179 0.0 0.0 6112 1128 pts/5 R+ 16:21 0:00 ps aux
86 | root 10615 0.0 0.1 10264 3268 ? Ss 16:01 0:00 sshd: root@pts/3
87 | root 18938 0.1 0.1 10264 3276 ? Ss 16:20 0:00 sshd: root@pts/5
88 | root 21168 0.0 0.0 5960 872 ? SNs Apr17 0:00 sw-cp-server: master process /usr/sbin/sw-cp-serve
89 | root 32592 0.0 0.3 70240 6912 ? SNs 08:03 0:00 sw-engine-fpm: master process (/etc/sw-engine/sw-e
90 | root 357 0.0 0.0 2800 476 ? S Apr11 0:00 upstart-socket-bridge --daemon
91 | root 111 0.0 0.0 2788 580 ? S Apr11 0:00 upstart-udev-bridge --daemon
92 | syslog 782 0.0 0.0 2356 684 ? Ss Apr11 0:39 /sbin/syslogd -u syslog
93 | www-data 8199 0.0 0.5 51328 12356 ? S Apr27 0:09 /usr/sbin/apache2 -k start
94 | www-data 10454 0.0 0.8 70312 17384 ? S 15:59 0:00 /usr/sbin/apache2 -k start
95 | www-data 10467 0.0 0.8 70272 17252 ? S 15:59 0:00 /usr/sbin/apache2 -k start
96 | www-data 10468 0.0 0.8 70240 17156 ? S 15:59 0:00 /usr/sbin/apache2 -k start
97 | www-data 10469 0.0 0.8 70280 17288 ? S 15:59 0:00 /usr/sbin/apache2 -k start
98 | www-data 10579 0.0 0.8 70280 17260 ? S 16:01 0:00 /usr/sbin/apache2 -k start
99 | www-data 10582 0.0 0.8 70292 17280 ? S 16:01 0:00 /usr/sbin/apache2 -k start
100 | www-data 11153 0.0 0.8 70296 17272 ? S 16:06 0:00 /usr/sbin/apache2 -k start
101 | www-data 25830 0.0 1.9 90052 40064 ? S 05:58 0:03 /usr/sbin/apache2 -k start
102 | www-data 25882 0.0 1.2 74288 26032 ? S 06:00 0:01 /usr/sbin/apache2 -k start
103 | www-data 27394 0.0 1.2 75060 27128 ? S 07:31 0:03 /usr/sbin/apache2 -k start
