1 | 00000000 RJMP PC+0x004A Relative jump
2 | 00000001 NOP No operation
3 | 00000002 RJMP PC+0x0058 Relative jump
4 | 00000003 NOP No operation
5 | 00000004 RJMP PC+0x0056 Relative jump
6 | 00000005 NOP No operation
7 | 00000006 RJMP PC+0x0054 Relative jump
8 | 00000007 NOP No operation
9 | 00000008 RJMP PC+0x0052 Relative jump
10 | 00000009 NOP No operation
11 | 0000000A RJMP PC+0x0050 Relative jump
12 | 0000000B NOP No operation
13 | 0000000C RJMP PC+0x004E Relative jump
14 | 0000000D NOP No operation
15 | 0000000E RJMP PC+0x004C Relative jump
16 | 0000000F NOP No operation
17 | 00000010 RJMP PC+0x004A Relative jump
18 | 00000011 NOP No operation
19 | 00000012 RJMP PC+0x0048 Relative jump
20 | 00000013 NOP No operation
21 | 00000014 RJMP PC+0x0046 Relative jump
22 | 00000015 NOP No operation
23 | 00000016 RJMP PC+0x0044 Relative jump
24 | 00000017 NOP No operation
25 | 00000018 RJMP PC+0x0043 Relative jump
26 | 00000019 NOP No operation
27 | 0000001A RJMP PC+0x0040 Relative jump
28 | 0000001B NOP No operation
29 | 0000001C RJMP PC+0x003E Relative jump
30 | 0000001D NOP No operation
31 | 0000001E RJMP PC+0x003C Relative jump
32 | 0000001F NOP No operation
33 | 00000020 RJMP PC+0x003A Relative jump
34 | 00000021 NOP No operation
35 | 00000022 RJMP PC+0x0038 Relative jump
36 | 00000023 NOP No operation
37 | 00000024 RJMP PC+0x0036 Relative jump
38 | 00000025 NOP No operation
39 | 00000026 RJMP PC+0x0034 Relative jump
40 | 00000027 NOP No operation
41 | 00000028 RJMP PC+0x0032 Relative jump
42 | 00000029 NOP No operation
43 | 0000002A RJMP PC+0x0030 Relative jump
44 | 0000002B NOP No operation
45 | 0000002C RJMP PC+0x002E Relative jump
46 | 0000002D NOP No operation
47 | 0000002E RJMP PC+0x002C Relative jump
48 | 0000002F NOP No operation
49 | 00000030 RJMP PC+0x002A Relative jump
50 | 00000031 NOP No operation
51 | 00000032 RJMP PC+0x0028 Relative jump
52 | 00000033 NOP No operation
53 | 00000034 RJMP PC+0x0026 Relative jump
54 | 00000035 NOP No operation
55 | 00000036 RJMP PC+0x0024 Relative jump
56 | 00000037 NOP No operation
57 | 00000038 RJMP PC+0x0022 Relative jump
58 | 00000039 NOP No operation
59 | 0000003A RJMP PC+0x0020 Relative jump
60 | 0000003B NOP No operation
61 | 0000003C RJMP PC+0x001E Relative jump
62 | 0000003D NOP No operation
63 | 0000003E RJMP PC+0x001C Relative jump
64 | 0000003F NOP No operation
65 | 00000040 RJMP PC+0x001A Relative jump
66 | 00000041 NOP No operation
67 | 00000042 RJMP PC+0x0018 Relative jump
68 | 00000043 NOP No operation
69 | 00000044 RJMP PC+0x0016 Relative jump
70 | 00000045 NOP No operation
71 | 00000046 RJMP PC+0x0014 Relative jump
72 | 00000047 NOP No operation
73 | 00000048 RJMP PC+0x0012 Relative jump
74 | 00000049 NOP No operation
75 | 0000004A CLR R1 Clear Register
76 | 0000004B OUT 0x3F,R1 Out to I/O location
77 | 0000004C SER R28 Set Register
78 | 0000004D LDI R29,0x10 Load immediate
79 | 0000004E OUT 0x3E,R29 Out to I/O location
80 | 0000004F OUT 0x3D,R28 Out to I/O location
81 | 00000050 LDI R18,0x01 Load immediate
82 | 00000051 LDI R26,0x00 Load immediate
83 | 00000052 LDI R27,0x01 Load immediate
84 | 00000053 RJMP PC+0x0002 Relative jump
85 | 00000054 ST X+,R1 Store indirect and postincrement
86 | 00000055 CPI R26,0x04 Compare with immediate
87 | 00000056 CPC R27,R18 Compare with carry
88 | 00000057 BRNE PC-0x03 Branch if not equal
89 | 00000058 RCALL PC+0x0034 Relative call subroutine
90 | 00000059 RJMP PC+0x0082 Relative jump
91 | 0000005A RJMP PC-0x005A Relative jump
92 | {
93 | 0000005B PUSH R1 Push register on stack
94 | 0000005C PUSH R0 Push register on stack
95 | 0000005D IN R0,0x3F In from I/O location
96 | 0000005E PUSH R0 Push register on stack
97 | 0000005F CLR R1 Clear Register
98 | 00000060 PUSH R24 Push register on stack
99 | 00000061 PUSH R25 Push register on stack
100 | ir_cnt++;
101 | 00000062 LDS R24,0x0102 Load direct from data space
102 | 00000064 LDS R25,0x0103 Load direct from data space
103 | 00000066 ADIW R24,0x01 Add immediate to word
104 | 00000067 STS 0x0103,R25 Store direct to data space
105 | 00000069 STS 0x0102,R24 Store direct to data space
106 | wdt_reset();
107 | 0000006B WDR Watchdog reset
108 | }
109 | 0000006C POP R25 Pop register from stack
110 | 0000006D POP R24 Pop register from stack
111 | 0000006E POP R0 Pop register from stack
112 | 0000006F OUT 0x3F,R0 Out to I/O location
113 | 00000070 POP R0 Pop register from stack
114 | 00000071 POP R1 Pop register from stack
115 | 00000072 RETI Interrupt return
116 | wdt_enable(WDTO_15MS); // Watchdog aktiveren - Reset nach 15ms wenn keine triggerung erfolgt
117 | 00000073 LDI R18,0x08 Load immediate
118 | 00000074 LDI R24,0x18 Load immediate
119 | 00000075 LDI R25,0x00 Load immediate
120 | 00000076 IN R0,0x3F In from I/O location
121 | 00000077 CLI Global Interrupt Disable
122 | 00000078 WDR Watchdog reset
123 | 00000079 STS 0x0060,R24 Store direct to data space
124 | 0000007B OUT 0x3F,R0 Out to I/O location
125 | 0000007C STS 0x0060,R18 Store direct to data space
126 | TCCR1B = (1 << WGM12) | (1 << CS12); // CTC OCR1A, 1/256 Prescaler // 16�s pro Takt
127 | 0000007E LDI R24,0x0C Load immediate
128 | 0000007F STS 0x0081,R24 Store direct to data space
129 | OCR1A=15625; // 250 ms
130 | 00000081 LDI R24,0x09 Load immediate
131 | 00000082 LDI R25,0x3D Load immediate
132 | 00000083 STS 0x0089,R25 Store direct to data space
133 | 00000085 STS 0x0088,R24 Store direct to data space
134 | TIMSK1= (1 << OCIE1A);
135 | 00000087 LDI R24,0x02 Load immediate
136 | 00000088 STS 0x006F,R24 Store direct to data space
137 | sei();
138 | 0000008A SEI Global Interrupt Enable
139 | 0000008B RET Subroutine return
140 | sys_init();
141 | 0000008C RCALL PC-0x0019 Relative call subroutine
142 | OCR1A=30000; // Reset zu sp�t
143 | 0000008D LDI R24,0x30 Load immediate
144 | 0000008E LDI R25,0x75 Load immediate
145 | 0000008F STS 0x0089,R25 Store direct to data space
146 | 00000091 STS 0x0088,R24 Store direct to data space
147 | if(cnt%1000==0)cnt=0; // darf nie erreicht werden, da davor watchdog reset erfolgen soll
148 | 00000093 LDI R18,0xE8 Load immediate
149 | 00000094 LDI R19,0x03 Load immediate
150 | cnt++;
151 | 00000095 LDS R24,0x0100 Load direct from data space
152 | 00000097 LDS R25,0x0101 Load direct from data space
153 | 00000099 ADIW R24,0x01 Add immediate to word
154 | 0000009A STS 0x0101,R25 Store direct to data space
155 | 0000009C STS 0x0100,R24 Store direct to data space
156 | __builtin_avr_delay_cycles(__ticks_dc);
157 | 0000009E SER R20 Set Register
158 | 0000009F LDI R24,0xF9 Load immediate
159 | 000000A0 LDI R25,0x00 Load immediate
160 | 000000A1 SUBI R20,0x01 Subtract immediate
161 | 000000A2 SBCI R24,0x00 Subtract immediate with carry
162 | 000000A3 SBCI R25,0x00 Subtract immediate with carry
163 | 000000A4 BRNE PC-0x03 Branch if not equal
164 | 000000A5 RJMP PC+0x0001 Relative jump
165 | 000000A6 NOP No operation
166 | if(cnt%1000==0)cnt=0; // darf nie erreicht werden, da davor watchdog reset erfolgen soll
167 | 000000A7 LDS R24,0x0100 Load direct from data space
168 | 000000A9 LDS R25,0x0101 Load direct from data space
169 | 000000AB MOVW R22,R18 Copy register pair
170 | 000000AC RCALL PC+0x0008 Relative call subroutine
171 | 000000AD OR R24,R25 Logical OR
172 | 000000AE BRNE PC-0x19 Branch if not equal
173 | --- No source file -------------------------------------------------------------
174 | 000000AF STS 0x0101,R1 Store direct to data space
175 | 000000B1 STS 0x0100,R1 Store direct to data space
176 | 000000B3 RJMP PC-0x001E Relative jump
177 | 000000B4 BST R25,7 Bit store from register to T
178 | 000000B5 MOV R0,R23 Copy register
179 | 000000B6 BRTC PC+0x03 Branch if T flag cleared
180 | 000000B7 COM R0 One's complement
181 | 000000B8 RCALL PC+0x0007 Relative call subroutine
182 | 000000B9 SBRC R23,7 Skip if bit in register cleared
183 | 000000BA RCALL PC+0x0009 Relative call subroutine
184 | 000000BB RCALL PC+0x000C Relative call subroutine
185 | 000000BC SBRC R0,7 Skip if bit in register cleared
186 | 000000BD RCALL PC+0x0006 Relative call subroutine
187 | 000000BE BRTC PC+0x08 Branch if T flag cleared
188 | 000000BF COM R25 One's complement
189 | 000000C0 NEG R24 Two's complement
190 | 000000C1 SBCI R25,0xFF Subtract immediate with carry
191 | 000000C2 RET Subroutine return
192 | --- No source file -------------------------------------------------------------
193 | 000000C3 COM R23 One's complement
194 | 000000C4 NEG R22 Two's complement
195 | 000000C5 SBCI R23,0xFF Subtract immediate with carry
196 | 000000C6 RET Subroutine return
197 | 000000C7 SUB R26,R26 Subtract without carry
198 | 000000C8 SUB R27,R27 Subtract without carry
199 | 000000C9 LDI R21,0x11 Load immediate
200 | 000000CA RJMP PC+0x0008 Relative jump
201 | 000000CB ROL R26 Rotate Left Through Carry
202 | 000000CC ROL R27 Rotate Left Through Carry
203 | 000000CD CP R26,R22 Compare
204 | 000000CE CPC R27,R23 Compare with carry
205 | 000000CF BRCS PC+0x03 Branch if carry set
206 | 000000D0 SUB R26,R22 Subtract without carry
207 | 000000D1 SBC R27,R23 Subtract with carry
208 | 000000D2 ROL R24 Rotate Left Through Carry
209 | 000000D3 ROL R25 Rotate Left Through Carry
210 | 000000D4 DEC R21 Decrement
211 | 000000D5 BRNE PC-0x0A Branch if not equal
212 | 000000D6 COM R24 One's complement
213 | 000000D7 COM R25 One's complement
214 | 000000D8 MOVW R22,R24 Copy register pair
215 | 000000D9 MOVW R24,R26 Copy register pair
216 | 000000DA RET Subroutine return
217 | 000000DB CLI Global Interrupt Disable
218 | --- No source file -------------------------------------------------------------
219 | 000000DC RJMP PC-0x0000 Relative jump
