1 | #include "global.h" // Globale Lib
2 |
3 | int main(void)
4 | {
5 | char data; //Received data stored here
6 |
7 | cli(); // Disable all interrupts
8 | spi_init_master(); // SPI Inizalisierung
9 | // spi_init_slave ();
10 | initPort(); // Inizalisierung der Ports
11 | sei(); // enable all interrupts
12 |
13 | while(1)
14 | {
15 | SWITCH_LED1;
16 | _delay_ms(500);
17 | data = 0x00; //Reset ACK in "data"
18 | data = spi_tranceiver('Hallo', PIN_SPI_CS1);
19 | SET_LED3;
20 | }
21 | }
22 |
23 | in der global.h
24 |
25 | // SPI
26 | #define PORT_SPI PORTB
27 | #define DDR_SPI DDRB
28 | #define PIN_SPI_MISO 3 // PB3
29 | #define PIN_SPI_MOSI 2 // PB2
30 | #define PIN_SPI_SCK 1 // PB1
31 | #define PORT_SPI_CS PORTC
32 | #define DDR_SPI_CS DDRC
33 | #define PIN_SPI_CS1 7 // PC7
34 | #define PIN_SPI_CS2 6 // PC6
35 | #define PIN_SPI_CS3 5 // PC5
36 |
37 | in der spi_master_slave.c
38 | /*
39 | * spi_master_slave.c
40 | *
41 | * Created: 12.02.2015 14:08:46
42 | * Author: u308488
43 | */
44 |
45 | #include "spi_master_slave.h"
46 |
47 | /*
48 | // SPI Transmission/reception complete ISR
49 | ISR(SPI_STC_vect)
50 | {
51 | // Code to execute
52 | // whenever transmission/reception
53 | // is complete.
54 | }
55 | */
56 |
57 | void spi_init_slave (void)
58 | {
59 | DDR_SPI |= (1<<PIN_SPI_MISO); // MISO als Ausgang definieren
60 | SPCR |= (1<<SPE); //Enable SPI
61 |
62 | }
63 |
64 | //Initialize SPI Master Device
65 | void spi_init_master (void)
66 | {
67 | DDR_SPI = (1<<PIN_SPI_MOSI) | (1<<PIN_SPI_SCK); // MOSI und SCK als
68 | Ausgang definieren
69 | DDR_SPI &= ~(1<<PIN_SPI_MISO); // MISO als Eingang definieren
70 | PORT_SPI = (1<<PIN_SPI_MOSI) | (1<<PIN_SPI_SCK);
71 |
72 | // SPCR = (1<<SPR1)|(1<<SPR0); // Prescaler: Fosc/128,
73 | Enable Interrupts
74 | // SPCR = (1<<SPI2X); // Prescaler: Fosc/2,
75 | SPCR = (1<<MSTR); // Set as Master
76 | SPCR = (1<<SPE); // Enable SPI
77 | // SPCR = (1<<SPIE); // SPI Interrupt Enable
78 |
79 | SPSR |= (0 << SPIF); // SPIF zum Start löschen
80 | _delay_ms(10);
81 | }
82 |
83 | //Function to send and receive data
84 | char spi_tranceiver (char data, unsigned char cs)
85 | {
86 | PORT_SPI_CS &= ~(1<<cs); //SS am Slave Low --> Beginn der Übertragung
87 | SWITCH_LED2;
88 | SPDR = data; //Load data into the buffer
89 | while(!(SPSR & (1<<SPIF))); //Wait until transmission complete
90 | PORT_SPI_CS |= (1<<cs); //SS High --> Ende der Übertragung
91 | return SPDR; //Return received data
92 | }
