1 | #include <stdio.h>
2 | #include <stdlib.h>
3 | #include <avr\io.h>
4 | #include <avr/interrupt.h> //for the interupts for receiving via UART
5 | #include <string.h> //for building strings of characters
6 | #include <avr/pgmspace.h> //for PSTR for handling the location of characters
7 |
8 | //Set the baud rate of the communication
9 |
10 | #define BAUD 9600UL // Baudrate
11 |
12 | // Berechnungen
13 | #define UBRR_VAL ((F_CPU+BAUD*8)/(BAUD*16)-1) // clever runden
14 | #define BAUD_REAL (F_CPU/(16*(UBRR_VAL+1))) // Reale Baudrate
15 | #define BAUD_ERROR ((BAUD_REAL*1000)/BAUD) // Fehler in Promille, 1000 = kein Fehler.
16 |
17 | #if ((BAUD_ERROR<990) || (BAUD_ERROR>1010))
18 | #error Systematischer Fehler der Baudrate grösser 1% und damit zu hoch!
19 | #endif
20 |
21 |
22 | //Four variables for buffering of received messages
23 | volatile char c; //The temp place to dump the character we just received
24 | volatile char buffer[30]; // The array holding the characters that have been sent
25 | volatile int bufferlocation; //The current location in the buffer
26 | volatile int bufferflag; //A flag to tell whether there is complete data in the buffer to be processed
27 |
28 | //Declare the location of the stream for the output
29 | void uart_printchar(char c, FILE *stream){
30 | // Wait until UDR ready
31 | while(!(UCSR0A & (1 << UDRE0)));
32 | UDR0 = c; // send character
33 | }
34 |
35 | //USART RX interrupt this code is executed when we recieve a character
36 | ISR(USART0_RX_vect){
37 | c = UDR0; //Read the value out of the UART buffer
38 | buffer[bufferlocation] = c; //Dump that value out into the buffer array
39 | bufferlocation++; //Increment the bufferlocation so its ready to write next time
40 |
41 | if (c == 13) //Number 13 is carrage return
42 | bufferflag = 1; //If its a carriage return then mark the string as ready to process
43 | }
44 |
45 | int BaudRateRegister;
46 |
47 | int main(void){
48 | //---------------Start of Initalisation---------------
49 |
50 | //Configure the UART registers
51 | UCSR0B = ((1<<RXCIE0)|(1<<RXEN0)|(1<<TXEN0));
52 | //RXCIE0 Enable interupt after recieved
53 | //RXEN0 Reciever enabled
54 | //TXEN0 Transmit enabled
55 |
56 | UCSR0C = ((1<<UCSZ00)|(1<<UCSZ01));
57 | //UCSZ00 and UCSZ01 use 8 bit character size
58 |
59 | //Set the baud rate
60 | BaudRateRegister=F_CPU/16/BAUD-1;
61 | UBRR0H=((BaudRateRegister>>8)&0x00FF);
62 | UBRR0L=(BaudRateRegister&0x00FF);
63 |
64 | //Define and initialise stream used for printing to uart
65 | FILE uart_str = FDEV_SETUP_STREAM(uart_printchar, NULL, _FDEV_SETUP_RW);
66 |
67 | //Redirect stdout, so that printf() knows where to go
68 | stdout = &uart_str;
69 |
70 | //Enable interrupts
71 | sei();
72 | //---------------End of Initalisation---------------
73 | printf_P(PSTR("..."));
74 | printf_P(PSTR("Running"));
75 | printf_P(PSTR("BaudRateRegister set to %u\n"),BaudRateRegister);
76 | printf_P(PSTR("Wait"));
77 | //Start of infinate while loop
78 | while(1){
79 | if (bufferflag == 1){
80 | printf_P(PSTR("Got instruction"));
81 | bufferflag = 0; //Reset the buffer flag to say its been processed
82 | bufferlocation =0; //Restart the buffer location
83 | }
84 | }
85 | //End of infinate while loop
86 |
87 | }
88 | //End of main routine
