Hi, is it possible to run an atmega8a at 3.3V with 8mhz? I can't find any specification about the frequency in relation to the voltage. Thank you!
Figure 30-1 in: http://ww1.microchip.com/downloads/en/DeviceDoc/Microchip%208bit%20mcu%20AVR%20ATmega8A%20data%20sheet%2040001974A.pdf
@kwall-e (Gast) >is it possible to run an atmega8a at 3.3V with 8mhz? Yes. >I can't find any specification about the frequency in relation to the >voltage. How about the data sheet? 30.2 Speed Grades.
Oh, that seems to be a part I missed. Thanks. However, if I interpret the graph the right way, it requires at least 3.6V for 12MHz, doesn't it?
kwall-e schrieb: > However, if I interpret the graph the right way, it requires at least > 3.6V for 12MHz, doesn't it? Yes it does.
