1 | [ 0.000000] L2C: failed to init: -19
2 | [ 0.000000] rockchip_clk_register_branches: unknown clock type 9
3 | [ 1.506512] vcc_sd: regulator get failed, ret=-517
4 | [ 1.506917] vcc_flash: regulator get failed, ret=-517
5 | [ 2.185904] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
6 | [ 2.187620] rk-vcodec ff9a0000.vpu-service: could not find power_model node
7 | [ 2.188089] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
8 | [ 2.189531] rk-vcodec ff9c0000.hevc-service: could not find power_model node
9 | [ 2.276168] rockchip-spi ff130000.spi: no high_speed pinctrl state
10 | [ 2.288235] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
11 | [ 2.300406] Rockchip WiFi SYS interface (V1.00) ...
12 | [ 2.307694] ff540000.usb supply vusb_d not found, using dummy regulator
13 | [ 2.315123] ff540000.usb supply vusb_a not found, using dummy regulator
14 | [ 2.436886] ff580000.usb supply vusb_d not found, using dummy regulator
15 | [ 2.444329] ff580000.usb supply vusb_a not found, using dummy regulator
16 | [ 2.451950] dwc2 ff580000.usb: dwc2_core_reset() HANG! Soft Reset GRSTCTL=80000001
17 | [ 2.571761] dwc2 ff580000.usb: dwc2_wait_for_mode: Couldn't set device mode
18 | [ 2.849156] tinker-mcu: send_cmds: send command failed, ret = -6
19 | [ 2.855855] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6
20 | [ 2.872950] rockchip-sy-mipi-dphy ff770000.syscon:mipi-phy-rx0: invalid resource
21 | [ 2.885551] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
22 | [ 2.911600] rockchip_cpuclk_pre_rate_change: Invalid rate : 500000000 for cpuclk
23 | [ 2.993716] ff960000.dsi.0 supply power not found, using dummy regulator
24 | [ 3.001247] dw-mipi-dsi ff960000.dsi: device mode is unsupported
25 | [ 3.007974] panel-simple-dsi: probe of ff960000.dsi.0 failed with error -22
26 | [ 3.015736] ------------[ cut here ]------------
27 | [ 3.020867] WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x78/0x88()
28 | [ 3.029247] sysfs: cannot create duplicate filename '/devices/platform/ff960000.dsi/ff960000.dsi.0'
29 | [ 3.039257] Modules linked in:
30 | [ 3.042640] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.199-rockchip #37
31 | [ 3.050238] Hardware name: Rockchip (Device Tree)
32 | [ 3.055453] [<c011126c>] (unwind_backtrace) from [<c010cb54>] (show_stack+0x20/0x24)
33 | [ 3.064033] [<c010cb54>] (show_stack) from [<c06298fc>] (dump_stack+0x90/0xa4)
34 | [ 3.072035] [<c06298fc>] (dump_stack) from [<c01207f4>] (warn_slowpath_common+0x94/0xc4)
35 | [ 3.080995] [<c01207f4>] (warn_slowpath_common) from [<c0120864>] (warn_slowpath_fmt+0x40/0x48)
36 | [ 3.090628] [<c0120864>] (warn_slowpath_fmt) from [<c02df158>] (sysfs_warn_dup+0x78/0x88)
37 | [ 3.099685] [<c02df158>] (sysfs_warn_dup) from [<c02df250>] (sysfs_create_dir_ns+0x94/0xa0)
38 | [ 3.108935] [<c02df250>] (sysfs_create_dir_ns) from [<c062c328>] (kobject_add_internal+0xa4/0x2d4)
39 | [ 3.118856] [<c062c328>] (kobject_add_internal) from [<c062c5ac>] (kobject_add+0x54/0x9c)
40 | [ 3.127914] [<c062c5ac>] (kobject_add) from [<c0758744>] (device_add+0x100/0x5b0)
41 | [ 3.136203] [<c0758744>] (device_add) from [<c0726cb0>] (mipi_dsi_host_register+0x100/0x1dc)
42 | [ 3.145550] [<c0726cb0>] (mipi_dsi_host_register) from [<c0a331dc>] (dw_mipi_dsi_probe+0x80/0xc8)
43 | [ 3.155376] [<c0a331dc>] (dw_mipi_dsi_probe) from [<c075d740>] (platform_drv_probe+0x60/0xbc)
44 | [ 3.164817] [<c075d740>] (platform_drv_probe) from [<c075b938>] (driver_probe_device+0x1f4/0x2e8)
45 | [ 3.174644] [<c075b938>] (driver_probe_device) from [<c075bac0>] (__driver_attach+0x94/0x98)
46 | [ 3.183987] [<c075bac0>] (__driver_attach) from [<c0759a08>] (bus_for_each_dev+0x5c/0xac)
47 | [ 3.193044] [<c0759a08>] (bus_for_each_dev) from [<c075b1d0>] (driver_attach+0x2c/0x30)
48 | [ 3.201908] [<c075b1d0>] (driver_attach) from [<c075adc4>] (bus_add_driver+0x19c/0x220)
49 | [ 3.210771] [<c075adc4>] (bus_add_driver) from [<c075c514>] (driver_register+0x88/0x104)
50 | [ 3.219729] [<c075c514>] (driver_register) from [<c075d688>] (__platform_driver_register+0x50/0x58)
51 | [ 3.229747] [<c075d688>] (__platform_driver_register) from [<c124bd3c>] (dw_mipi_dsi_driver_init+0x1c/0x20)
52 | [ 3.240535] [<c124bd3c>] (dw_mipi_dsi_driver_init) from [<c0101b0c>] (do_one_initcall+0xa0/0x1f0)
53 | [ 3.250362] [<c0101b0c>] (do_one_initcall) from [<c1200fbc>] (kernel_init_freeable+0x1e8/0x28c)
54 | [ 3.259997] [<c1200fbc>] (kernel_init_freeable) from [<c0d3eb98>] (kernel_init+0x18/0x118)
55 | [ 3.269152] [<c0d3eb98>] (kernel_init) from [<c0108110>] (ret_from_fork+0x14/0x24)
56 | [ 3.277578] ---[ end trace 8535bac3d55643c8 ]---
57 | [ 3.282712] kobject_add_internal failed for ff960000.dsi.0 with -EEXIST, don't try to register things with the same name in the same directory.
58 | [ 3.296969] dw-mipi-dsi ff960000.dsi: failed to add DSI device /dsi@ff960000/mipi-panel: -17
59 | [ 3.308501] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops 0xc0ec512c): -517
60 | [ 3.756271] usb 3-1: config 1 has an invalid interface number: 255 but max is 6
61 | [ 3.764558] usb 3-1: config 1 has no interface number 6
62 | [ 3.882013] tinker-ft5406: tinker_ft5406_probe: wait connected timeout
63 | [ 3.889355] [board_info] create Board_info_proc_file sucessed!
64 | [ 3.895958] project_id_2:0x0, project_id_1:0x0, project_id_0:0x0
65 | [ 3.902782] ram_id_2:0x0, ram_id_1:0x1, ram_id_0:0x0
66 | [ 3.908443] pcb_id_2:0x0, pcb_id_1:0x1, pcb_id_0:0x0
67 | [ 6.079881] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
68 | [ 6.199189] ff960000.dsi.0 supply power not found, using dummy regulator
69 | [ 6.210087] dw-mipi-dsi ff960000.dsi: device mode is unsupported
70 | [ 6.216907] panel-simple-dsi: probe of ff960000.dsi.0 failed with error -22
71 | [ 6.224765] ------------[ cut here ]------------
72 | [ 6.229957] WARNING: CPU: 1 PID: 102 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x78/0x88()
73 | [ 6.238598] sysfs: cannot create duplicate filename '/devices/platform/ff960000.dsi/ff960000.dsi.0'
74 | [ 6.248675] Modules linked in:
75 | [ 6.252113] CPU: 1 PID: 102 Comm: kworker/u8:1 Tainted: G W 4.4.199-rockchip #37
76 | [ 6.261588] Hardware name: Rockchip (Device Tree)
77 | [ 6.266828] Workqueue: deferwq deferred_probe_work_func
78 | [ 6.272654] [<c011126c>] (unwind_backtrace) from [<c010cb54>] (show_stack+0x20/0x24)
79 | [ 6.281279] [<c010cb54>] (show_stack) from [<c06298fc>] (dump_stack+0x90/0xa4)
80 | [ 6.289326] [<c06298fc>] (dump_stack) from [<c01207f4>] (warn_slowpath_common+0x94/0xc4)
81 | [ 6.298332] [<c01207f4>] (warn_slowpath_common) from [<c0120864>] (warn_slowpath_fmt+0x40/0x48)
82 | [ 6.308014] [<c0120864>] (warn_slowpath_fmt) from [<c02df158>] (sysfs_warn_dup+0x78/0x88)
83 | [ 6.317119] [<c02df158>] (sysfs_warn_dup) from [<c02df250>] (sysfs_create_dir_ns+0x94/0xa0)
84 | [ 6.326401] [<c02df250>] (sysfs_create_dir_ns) from [<c062c328>] (kobject_add_internal+0xa4/0x2d4)
85 | [ 6.336315] [<c062c328>] (kobject_add_internal) from [<c062c5ac>] (kobject_add+0x54/0x9c)
86 | [ 6.345364] [<c062c5ac>] (kobject_add) from [<c0758744>] (device_add+0x100/0x5b0)
87 | [ 6.353646] [<c0758744>] (device_add) from [<c0726cb0>] (mipi_dsi_host_register+0x100/0x1dc)
88 | [ 6.362985] [<c0726cb0>] (mipi_dsi_host_register) from [<c0a331dc>] (dw_mipi_dsi_probe+0x80/0xc8)
89 | [ 6.372802] [<c0a331dc>] (dw_mipi_dsi_probe) from [<c075d740>] (platform_drv_probe+0x60/0xbc)
90 | [ 6.382236] [<c075d740>] (platform_drv_probe) from [<c075b938>] (driver_probe_device+0x1f4/0x2e8)
91 | [ 6.392055] [<c075b938>] (driver_probe_device) from [<c075bb7c>] (__device_attach_driver+0xb8/0xc4)
92 | [ 6.402065] [<c075bb7c>] (__device_attach_driver) from [<c0759ad8>] (bus_for_each_drv+0x54/0xa4)
93 | [ 6.411786] [<c0759ad8>] (bus_for_each_drv) from [<c075b668>] (__device_attach+0x9c/0x124)
94 | [ 6.420929] [<c075b668>] (__device_attach) from [<c075bbe4>] (device_initial_probe+0x1c/0x20)
95 | [ 6.430357] [<c075bbe4>] (device_initial_probe) from [<c075ab00>] (bus_probe_device+0x94/0x9c)
96 | [ 6.439883] [<c075ab00>] (bus_probe_device) from [<c075af6c>] (deferred_probe_work_func+0x74/0xa0)
97 | [ 6.449794] [<c075af6c>] (deferred_probe_work_func) from [<c0139d00>] (process_one_work+0x1f8/0x508)
98 | [ 6.459895] [<c0139d00>] (process_one_work) from [<c013ad64>] (worker_thread+0x68/0x558)
99 | [ 6.468845] [<c013ad64>] (worker_thread) from [<c01403f0>] (kthread+0x118/0x120)
100 | [ 6.477027] [<c01403f0>] (kthread) from [<c0108110>] (ret_from_fork+0x14/0x24)
