1 | /*
2 | * Soundmodul_WTV020.c
3 | *
4 | * Created: 27.05.2014 08:52:39
5 | * Author: Admin
6 | */
7 |
8 | // F_CPU = 1000000 Eingetragen unter ATtiny2313 -> AVR/GNU C Compiler -> Toolchain -> Symbols
9 |
10 | #include <avr/io.h>
11 | #include <avr/interrupt.h>
12 | #include <util/delay.h>
13 | #include <avr/sleep.h>
14 |
15 | /* * Set I/Os */
16 | #define WTV_PORT PORTD
17 | #define WTV_DDR DDRD
18 | #define WTV_PIN PIND
19 | #define WTV_BUSY PD2
20 | #define WTV_DO PD3
21 | #define WTV_CL PD4
22 | #define WTV_RES PD5
23 |
24 |
25 | /* * Defines for Commands
26 | * Send with wtv020_sendCommand(COMMAND) to execute */
27 | #define PLAY_PAUSE 0xFFFE //play/pause file
28 | #define STOP 0xFFFF //stop playing
29 | #define VOLUME_MIN 0xFFF0 //mute
30 | #define VOLUME_0 0xFFF0 //available volume levels
31 | #define VOLUME_1 0xFFF1 //...
32 | #define VOLUME_2 0xFFF2
33 | #define VOLUME_3 0xFFF3
34 | #define VOLUME_4 0xFFF4
35 | #define VOLUME_5 0xFFF5
36 | #define VOLUME_6 0xFFF6
37 | #define VOLUME_7 0xFFF7
38 | #define VOLUME_MAX 0xFFF7 //unmute
39 |
40 |
41 | /*
42 | * Data Clock Cycle Length in Microseconds
43 | * change this if you have problems with sending valid data
44 | */
45 | //#define CLK 100
46 | #define CLK 100
47 |
48 | ISR (TIMER0_OVF_vect) // every 10ms
49 | {
50 | static uint8_t ct0, ct1;
51 |
52 | uint8_t i;
53 |
54 | TCNT0 = (uint8_t)(int16_t)-(F_CPU / 64 / 2 * 10e-3 + 0.5); // preload for 5ms
55 |
56 | i = key_state ^ ~KEY_PIN; // key changed ?
57 | ct0 = ~( ct0 & i ); // reset or count ct0
58 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
59 | i &= ct0 & ct1; // count until roll over ?
60 | key_state ^= i; // then toggle debounced state
61 | key_press |= key_state & i; // 0->1: key press detect
62 | key_release |= ~key_state & i; // 1->0: key release detect
63 |
64 | if (sleep)
65 | sleep--;
66 |
67 | flag_5ms++;
68 | }
69 |
70 |
71 | /* * Send command to WTV020
72 | * 0x0000 to 0x01FF (0 to 511 decimal) will play the files 0000.ad4 to 0511.ad4
73 | * All other commands are defined in wtv020.h */
74 | void wtv020_sendCommand(uint16_t command) {
75 |
76 | WTV_PORT &= ~(1 << WTV_CL); //Pull CL low for 2ms for start
77 | _delay_ms(2);
78 |
79 | for (int i=15; i>=0; i--){ //for each bit of 16bit data
80 | _delay_us(CLK/4);
81 |
82 | if(((command>>i)&0x0001 )>0) //when bit=1 DO high else low
83 | WTV_PORT |= (1 << WTV_DO);
84 | else
85 | WTV_PORT &= ~(1 << WTV_DO);
86 |
87 | _delay_us(CLK/4); //CL high pulse
88 | WTV_PORT |= (1 << WTV_CL);
89 | _delay_us(CLK/2);
90 | if(i==0){ //if last bit, stop transmission
91 | WTV_PORT |= (1 << WTV_CL);
92 | WTV_PORT &= ~(1 << WTV_DO);
93 | }
94 | else //else begin new clock cycle
95 | WTV_PORT &= ~(1 << WTV_CL);
96 | }
97 | _delay_ms(70); //wait for BUSY-Flag available
98 | }
99 |
100 |
101 | /* * Reset the chip */
102 | void wtv020_reset(){
103 | WTV_PORT |= (1 << WTV_CL); //CL high, DO low
104 | WTV_PORT &= ~(1 << WTV_DO);
105 | _delay_ms(5);
106 |
107 | WTV_PORT |= (1 << WTV_RES); //RES pulse
108 | _delay_ms(100);
109 | WTV_PORT &= ~(1 << WTV_RES);
110 | _delay_ms(10);
111 | WTV_PORT |= (1 << WTV_RES);
112 |
113 | _delay_ms(500); //wait until module is ready
114 | }
115 |
116 | /* * Initialize the pins */
117 | void wtv020_init(void){
118 | WTV_DDR |= (1 << WTV_RES) | (1 << WTV_CL) | (1 << WTV_DO); //RES, CL, DO output
119 | WTV_DDR &= ~(1 << WTV_BUSY); //BUSY input
120 | WTV_PORT &= ~(1 << WTV_BUSY); //Pull-Up off
121 | wtv020_reset(); //Initial Reset
122 | }
123 |
124 | /* * Play file until its end.
125 | * BLOCKING FUNCTION!
126 | * waits for BUSY-FLAG */
127 | void wtv020_playVoice(uint16_t voiceNumber){
128 | wtv020_sendCommand(voiceNumber); //Send song number
129 | // while(WTV_PIN & (1 << WTV_BUSY)); //Wartet bis File abgespielt wurde
130 | }
131 |
132 |
133 | ISR (PCINT_B_vect) {
134 |
135 | }
136 |
137 | int main(void)
138 | {
139 | // Digital IO
140 | // Standart DDRx = 0x00 (Eingang)
141 | // Standart PORTx = 0x00
142 | // DDRx=0x00 Eingang
143 | // DDRx=0xFF Ausgang
144 |
145 | // PORTx=0x00 Ausgang auf 0 Eingang Pull Up deaktivieren
146 | // PORTx=0xFF Ausgang auf 1 Eingang Pull Up aktivieren
147 |
148 | // Unbeschaltete Pins auf Input und Pull Up aktivieren!
149 | // Pin 76543210
150 | DDRA = 0b00000011; // EEEEEEAA
151 | PORTA= 0b11111100; // Aus
152 |
153 | // Pin 76543210
154 | DDRB = 0b00000000; // EEEEEEEE
155 | PORTB= 0b11111111; // Pull up ein
156 |
157 | // Pin 76543210
158 | DDRD = 0b11111111; // AAAAAAAA
159 | PORTD= 0b00000000; // Aus
160 |
161 | _delay_ms(2000);
162 | wtv020_init();
163 | _delay_ms(2000);
164 | wtv020_sendCommand(VOLUME_MAX);
165 | _delay_ms(1000);
166 |
167 | wtv020_playVoice(0);
168 |
169 | TCCR0B = (0<<CS02) | (1<<CS01) | (1<<CS00); // mit Vorteiler 64
170 | TIMSK = (1<<TOIE0); // Timer Interrupt 1 ein
171 |
172 | PCMSK0 = 0xFF; // Alle Pins auswählen
173 | GIMSK = (1<<PCIE0); // Pin Change Interrupt aktivieren für PCINT7..0
174 |
175 | sei();
176 |
177 | while(1){
178 |
179 | wtv020_playVoice(1);
180 | _delay_ms(20000);
181 | wtv020_playVoice(2);
182 | _delay_ms(20000);
183 |
184 | }
