undefine Symbol delay_us(1000); Folgender Fehler ist bei meinen Code! Der Compiler ist CodeVison! Kann mir bitte einer Helfen! Vielen Dank Daniel /********************************************* This program was produced by the CodeWizardAVR V1.0.2.1b Evaluation Automatic Program Generator © Copyright 1998-2001 Pavel Haiduc, HP InfoTech S.R.L. http://infotech.ir.ro e-mail:dhptechn@ir.ro , hpinfotech@xnet.ro Chip type : AT90S8535 Clock frequency : 8.000000 MHz Memory model : Small Internal SRAM size : 512 External SRAM size : 0 Data Stack size : 128 *********************************************/ #include <90s8535.h> // Declare your global variables here /* void delay() { unsigned char ch1,ch2; for(ch1=0;ch1=255;ch1++) for(ch2=0;ch2=255;ch2++); } */ void main(void) { // Declare your local variables here unsigned char sec=0,min=0,hour=12,d; // Input/Output Ports initialization // Port A PORTA=0x00; DDRA=0xFF; // Port B PORTB=0x00; DDRB=0xFF; // Port C PORTC=0x00; DDRC=0xFF; // Port D PORTD=0x00; DDRD=0xFF; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Output Compare // OC0 output: Disconnected TCCR0=0x05; TCNT0=0xFF; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer 1 Stopped // Mode: Output Compare // OC1A output: Discon. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge TCCR1A=0x00; TCCR1B=0x00; TCNT1H=0x1E; TCNT1L=0x84; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off GIMSK=0x00; MCUCR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; while (1) { // Place your code here again: delay(1000); if(sec>=59) { min++; sec=0; } else sec++; if(min>=59) { hour++; min=0; } if(hour>=23) hour=0; PORTA=sec; PORTB=min; PORTC=hour; goto again; }; }
Moin! Wie waers wenn Du die delay routine fuer den Compiler zugaegig machst. Ist anscheinend "auskommentiert". gruß, Bjoern
>undefine Symbol delay_us(1000); undefine Daniel! >Folgender Fehler ist bei meinen Code! Wo folgt der Fehler! >Der Compiler ist CodeVison! Persönliches Pech! >Kann mir bitte einer Helfen! Nein! >Vielen Dank Bitte! Gern geschehen!
Danke! Für eure Hilfe! Nur für den Dalai Lama habe ich keine Erleuchtung übrig! :D
Wird die Delay-Funktion bei CodeVision anders geschrieben? Bei GCC hieße es _delay_us(1000); (mit Unterstrich am Anfang) und der maximale Wert beträgt 765.
@ Power >es _delay_us(1000); (mit Unterstrich am Anfang) und der maximale Wert >beträgt 765. Nöö, stimmt nicht. Das gilt bei 1 MHz Prozessortakt. Bei 10 MHz sind es nur noch 76, bei 100kHz sind es 7650. Aber DIESE Funktion gibte es SO nur in der libc des WINAVR. Beim Codevision Compiler ist das wahrscheinlich anders. MfG Falk
@Falk: Laut der Lib des WINAVR heißt es: "The maximal possible delay is 768 us / F_CPU in MHz." Das interpretiere ich so, dass 768 / 1MHz = 768µs sind. Mehr als 786µs bei 1MHz geht nicht, alles was höher eingetragen wird, wird auf 768µs begrenzt.
Nachtrag: deshalb macht es keinen Sinn höhere Werte anzugeben.
Da wären wir schon wieder beim alten Thema: The maximal possible delay is ...
Beim Codevision heißt die Funktion 'delay_us()' und ist in der <delay.h> deklariert. Die Funktion akzeptiert Werte bis 65535 und wartet auch dementsprechend. - Michael
