Avr-gcc Bugs
Bugs
PR Description Note
92606 Invalid merge of symbols in progmem and data sections (WA: -fno-ipa-icf-variables) IPA
87376 Miscompilation with __memx and long long addition 86635
86869 ICE when taking address of array member of __memx struct pointer
86776 Need updating for CVE-2017-5753
86635 Wrong code with __memx and __gtsf2
81073 Link failure as C++ misses to instanciate some objects C++
80573 ICE: in assign_temp, at function.c:961
78707 ICE: in push_reload, at reload.c:1349 (sscanf_flt-f1.c)
78497 -save-temps adds -Wimplicit-fallthrough warnings
68384 LTO error for global register variables
67352 incorrect warning with -Waddr-space-convert and struct in __flash
65657 read from __memx tramples function argument 86635
64331 avr.c:reg_unused_after uses outdated reg_dead notes
63630 ICE: Spill fail
62084 ICE: in convert_debug_memory_address (__memx, -g) middle-end → 52472
57597 ICE: in get_section, Segmentation fault with -fmerge-all-constants varasm
Binutils / avr-libc
PR Description Note
binutils
31687 Output of avr-objdump -P mem-usage missing .rodata
16005 Linker crash with --relax
binutils fixed
31321 Remove PROVIDE from definition of symbol __flmap_init_label 2.43
31124 Support new Emulations for Devices with FLMAP 2.42 rodata-in-flash
31177 Use __TEXT_REGION_ORIGIN__ as start for MEMORY region text 2.42
21621 Wrong / missing warning "skipping two-word instruction" 2.29.x
21849 Locate .progmemx.* at a higher address 2.29.x
21683 Support __gcc_isr pseudo-instruction 2.29
21583 Move .jumptables to a higher address 2.29
21569 Merge avr.sc and avrtiny.sc 2.29
21472 Add new emulation for ATtiny416 et al. (don't put .rodata in RAM) 2.29 rodata-in-flash
21404 Assertion fail in bfd/elf32-avr.c:2145 2.28
20849 Don't put .rodata in RAM on AVR_TINY. 2.28 rodata-in-flash
20789 Fix relaxation of negative DIFF relocs. 2.26
20254 Relocs at end of section are not processed with .align. 2.26
20221 Wrong code with .align and linker relaxation. 2.26
15043 Support -mrmw option for LAC, LAT, LAS and XCH. 2.25
avr-libc
57114 Do not #define abs / labs →57071
57071 Fix math.h and function names that block 64-bit double 2.2
49567 Use meta-info from --print-multi-lib and --print-multi-directory 2.2
P-9416 [patch,AVR_TINY] Avoid constraint "w" in delay_basic.h Patch
P-9400 [patch] Add avrxmega3 multilibs
P-9187 [patch,AVR_TINY] Support 16-bit xtoa functons and more string functions.
P-8729 [patch,avr/interrupt.h] Add ISR_NOICF, ISR_FLATTEN. Fix namespace of identifiers.
38125 Distribute gcrt1.S
34695 stdint.h fixed-width int types without __attribute__((mode))
33698 RJMP/RCALL can cause "relocation truncated to fit: R_AVR_13_PCREL" linker error √ ?
Optimierung
PR Optimization Note
110093 Move frenzy leading to code bloat. Regression
109910 Prologue/epilogue saves/restores regs that are never changed.
109907 Code bloat for single bit extractions
88209 Inefficient array initialization
84211 Perform a post-reload register optimization pass Patch
82658 Right-shifting 8-bit unsigned integers. C++
81625 v4.7 ... v8 is bloating code by > 25% compared to v3.4
81611 gcc un-learned loop / post-increment optimization
81540 tree-switch-conversion leads to code bloat tree-ssa
81533 Constructing an object that can be initialized at at load-time c++
80929 Division with constant no more optimized to mult middle-end
65082 Wasted cycles when using a register based varible
56439 unnecessary spill for global and local register variables
Debug-Info, Build, ...
52641 Test cases fail for 16-bit int targets testsuite
Erweiterungen
PR Extensions Note
84163 Allow address space qualifier for compound literals C
57390 Support fixed-point types in C++ C++
Ungültig
PR Invalid Note
61044 Computed goto with label differences does not work → Label differences not suported on AVR:
Labels as Values
57501 crttn24a.o missing path with -mmcu=attiny24a → Caused by AVR-LibC #35407
PR Won't fix Note
14406 Support .progmem<N>.data sections in the default ld script Begründung + Beispiel für ld-Skript Erweiterung
49857 Put constant switch-tables into flash (patch)
43745 Put VTABLES in Flash
38342 __attribute__((progmem)) not propagated from typedef to data avr-libc #33716
Fixed
PR Fixed Note
114100 Better indirect addressing on reduced Tiny 14
113156 avr build broken: ICE: 'global_options' are modified in local context 14
112944 Support .rodata in Flash for Devices with FLMAP 14
112830 ICE (__memx): in convert_memory_address_addr_space_1, at explow.cc:302 14
101188 Uses content of a clobbered register 14
113927 [avr-tiny] Sets up a stack-frame even for trivial code 13.3
105523 Avoid diagnostic "array subscript 0 is outside array bounds of 'volatile uint8_t[0] [-Warray-bounds]" 13.3
53372 Section attribute ignored with address space 13.3
113824 ATA5795 in wrong multilib set 13.3, 12.4
112952 Fix attributes address, io and io_low 13.3, 12.4
107201 -nodevicelib not working together with -mmcu=avr* devices 13.3, 12.4
109650 Wrong code with -Os (cc0 → CCmode fallout) 13.2, 12.4
105753 ICE: in add_clobbers, at config/avr/avr-dimode.md:2705 13.2, 12.4
99184 Wrong rounding in double to 32-bit and 16-bit integer conversions in libgcc. 12.3, 11.4, 10.5
90706 Useless code generated for stack / register operations 12.3
92729 Switch from cc0 to CCmode so avr-gcc can be kept in GCC v11+ 11.0
92055 Support 64-bit double 10.0
86040 RAMPZ not cleared after reading from __flashN 9.3, 8.4, 7.5
85805 Wrong code for 64 bit comparisons on avr-gcc 8.3 combine
85495 lto-wrapper.exe: fatal error: file too short: No error 8.0 LTO
83801 String constant in __flash not put into .progmem 8.0 C
83729 ICE in convert_memory_address_addr_space_1 at explow.c:300 8.0 C
83738 Don't save registers in main / auto-add OS_task to main 8.0
81754 Building of avr compiler broken 8.0
20296
81268
Speeding up small ISRs
8.0
81075 Move jump-tables out of .text 8.0
81072 Add XMEGA devices with flash seen in RAM address space 8.0
84209 Don't split SP in split2 7.4
81910 ICE with "address" attribute on type 7.3, 6.5, 5.5
81487 ld.exe: error: asprintf failed 7.2, 6.5, 5.5 mingw32
81473 Build fails due to INT8_MIN and friends 7.2
81407 C++: Error if a variable in progmem needs constructing 7.2, 6.5, 5.5
81305 avrtiny uses LDS for SREG with -O0 7.2, 6.5, 5.5
80492 Wrong code whith loop unrolling and local asm regs 7.2, 6.4 tree
79883 i18n: untranslated "interrupt" or "signal" 7.2, 6.5, 5.5
75964 Insn-combiner removes comparison after ABS 7.2, 6.5, 5.5 rtl
78883 ICE triggered by change to combine.c 7.0
78562 Wrong warning for built-in functions with -flto 7.0
78093 New variable attribute "absdata" to enable LDS / STS on Reduced Tiny 7.0
71948 Make progmem work on reduced Tiny by adding 0x4000 to symbols 7.0
71678 ICE from switch / case on long long (casesi + DImode) 7.0
71676 casesi won't handle switch values larger than 16 bits 7.0
60300 Minor prologue improvement w.r.t code size 7.0
41076 Pessimal code for logical OR of 8-bit fields 7.0
67353 Option-ize Warning "appears to be a misspelled signal / interrupt handler" 6.5, 5.5
80462 Incorrect warning: uninitialized variable 'xxx' put into program memory area 6.4, 5.5
77326 Invalid optimization omits comparison 6.3, 5.5
72767 Some branches report too small insn length 6.2, 5.5
71976 insn-combine removes 64-bit shift 6.2, 5.5
71151 Strings in .progmem.gcc_sw_section with -fdata-sections + const merging 6.2
71103 ICE: unrecognizable insn: QImode subreg of symbol_ref, const or label_ref 6.2, 5.5, 4.9.4
71053 volatile read-and-test loop optimized to test loop (without read) 6.2
70677 Disable -fcaller-saves per default 6.2
30417 Wrap spec generating -Tdata into %{!Tdata:...} 6.2, 5.5, 4.9.4
67839 Bit addressable instructions generated for invalid memory address 6.0
65296 fix various issues with avr specs files 5.2 → avr-libc #44574
65192 ICE: attiny: In tiny_valid_direct_memory_access_range 5.0 (transient)
52472 ICE: in convert_debug_memory_address, at cfgexpand.c (__memx, -g) 5.0
Älter als v5
PR Fixed Note
65196 ICE: avr_adjust_insn_length uses recog_memoized on invalid insn 4.9.3
64452 ICE: When passing struct member to varargs function 4.9.3, 4.8.5
63633 ICE: unrecognizable insn with mult insns 4.9.3
63223 Make jumptables work with -Wl,--section-start,.text= 4.9.2
61443 ICE: unrecognizable insn when varargs argument is indirect addr-space access 4.9.1, 4.8.4
61055 Wrong test instruction after increment (-O1 or -fno-peephole2) 4.9.1, 4.8.3, 4.7.4
60991 Stack corruption when using __memx pointers or __int24 in large stack frame 4.9.1, 4.8.3, 4.7.4
50807 Constructor writing to RAM for variable in Flash 4.9.0
60486 Superfluous or missing comparision after addition or subtraction 4.8.3
59396 Wrong warning with ISR() and LTO 4.8.3, 4.8.1
57844 ICE: unrecognizable addqi3 insn with -msp8 and frame size of 128 bytes 4.8.2, 4.7.4
57631 Use assembler name for sanity checking of ISR names 4.8.2, 4.7.4
57516 Incorrect fixed-point rounding result in the overflow case 4.8.2
57506 Some devices are present twice in avr-mcus.def 4.8.2, 4.7.4
50293 -flto fails if GCC is installed in directory with space in path name 4.7.3
52261 Add XMEGA support 4.7.0
