1 | @00000057: main
2 | ---- main.c ---------------------------------------------------------------------------------------
3 | 5: {
4 | +00000057: 93DF PUSH R29 Push register on stack
5 | +00000058: 93CF PUSH R28 Push register on stack
6 | +00000059: B7CD IN R28,0x3D In from I/O location
7 | +0000005A: B7DE IN R29,0x3E In from I/O location
8 | +0000005B: 50C0 SUBI R28,0x00 Subtract immediate
9 | +0000005C: 40D2 SBCI R29,0x02 Subtract immediate with carry
10 | +0000005D: B60F IN R0,0x3F In from I/O location
11 | +0000005E: 94F8 CLI Global Interrupt Disable
12 | +0000005F: BFDE OUT 0x3E,R29 Out to I/O location
13 | +00000060: BE0F OUT 0x3F,R0 Out to I/O location
14 | +00000061: BFCD OUT 0x3D,R28 Out to I/O location
15 | 9: funktion2(buffer);
16 | +00000062: 01CE MOVW R24,R28 Copy register pair
17 | +00000063: 9601 ADIW R24,0x01 Add immediate to word
18 | +00000064: 940E007F CALL 0x0000007F Call subroutine
19 | 11: }
20 | +00000066: E080 LDI R24,0x00 Load immediate
21 | +00000067: E090 LDI R25,0x00 Load immediate
22 | +00000068: 50C0 SUBI R28,0x00 Subtract immediate
23 | +00000069: 4FDE SBCI R29,0xFE Subtract immediate with carry
24 | +0000006A: B60F IN R0,0x3F In from I/O location
25 | +0000006B: 94F8 CLI Global Interrupt Disable
26 | +0000006C: BFDE OUT 0x3E,R29 Out to I/O location
27 | +0000006D: BE0F OUT 0x3F,R0 Out to I/O location
28 | +0000006E: BFCD OUT 0x3D,R28 Out to I/O location
29 | +0000006F: 91CF POP R28 Pop register from stack
30 | +00000070: 91DF POP R29 Pop register from stack
31 | +00000071: 9508 RET Subroutine return
32 | @00000072: funktion
33 | ---- test.c ---------------------------------------------------------------------------------------
34 | 5: {
35 | +00000072: 01FC MOVW R30,R24 Copy register pair
36 | +00000073: E020 LDI R18,0x00 Load immediate
37 | +00000074: E030 LDI R19,0x00 Load immediate
38 | +00000075: C004 RJMP PC+0x0005 Relative jump
39 | 10: *buffer++ = SPDR;
40 | +00000076: B58E IN R24,0x2E In from I/O location
41 | +00000077: 9381 ST Z+,R24 Store indirect and postincrement
42 | 8: for(i = 0; i < zahl; ++i)
43 | +00000078: 5F2F SUBI R18,0xFF Subtract immediate
44 | +00000079: 4F3F SBCI R19,0xFF Subtract immediate with carry
45 | +0000007A: 1726 CP R18,R22 Compare
46 | +0000007B: 0737 CPC R19,R23 Compare with carry
47 | +0000007C: F3C8 BRCS PC-0x06 Branch if carry set
48 | 14: }
49 | +0000007D: E081 LDI R24,0x01 Load immediate
50 | +0000007E: 9508 RET Subroutine return
51 | @0000007F: funktion2
52 | 18: {
53 | +0000007F: 01FC MOVW R30,R24 Copy register pair
54 | +00000080: E020 LDI R18,0x00 Load immediate
55 | +00000081: E030 LDI R19,0x00 Load immediate
56 | 23: *buffer++ = SPDR;
57 | +00000082: B58E IN R24,0x2E In from I/O location
58 | +00000083: 9381 ST Z+,R24 Store indirect and postincrement
59 | 21: for(i = 0; i < zahl; ++i)
60 | +00000084: 5F2F SUBI R18,0xFF Subtract immediate
61 | +00000085: 4F3F SBCI R19,0xFF Subtract immediate with carry
62 | +00000086: E082 LDI R24,0x02 Load immediate
63 | +00000087: 3020 CPI R18,0x00 Compare with immediate
64 | +00000088: 0738 CPC R19,R24 Compare with carry
65 | +00000089: F7C1 BRNE PC-0x07 Branch if not equal
66 | 27: }
67 | +0000008A: E081 LDI R24,0x01 Load immediate
68 | +0000008B: 9508 RET Subroutine return
69 | +0000008C: 94F8 CLI Global Interrupt Disable
70 | +0000008D: CFFF RJMP PC-0x0000 Relative jump
71 | +0000008E: 83FF STD Y+7,R31 Store indirect with displacement
72 | +0000008F: 8389 STD Y+1,R24 Store indirect with displacement
73 | +00000090: 8129 LDD R18,Y+1 Load indirect with displacement
74 | +00000091: 813A LDD R19,Y+2 Load indirect with displacement
75 | +00000092: 818D LDD R24,Y+5 Load indirect with displacement
76 | +00000093: 819E LDD R25,Y+6 Load indirect with displacement
77 | +00000094: 1728 CP R18,R24 Compare
78 | +00000095: 0739 CPC R19,R25 Compare with carry
79 | +00000096: F348 BRCS PC-0x16 Branch if carry set
80 | +00000097: E081 LDI R24,0x01 Load immediate
81 | +00000098: 9626 ADIW R28,0x06 Add immediate to word
82 | +00000099: B60F IN R0,0x3F In from I/O location
83 | +0000009A: 94F8 CLI Global Interrupt Disable
84 | +0000009B: BFDE OUT 0x3E,R29 Out to I/O location
85 | +0000009C: BE0F OUT 0x3F,R0 Out to I/O location
86 | +0000009D: BFCD OUT 0x3D,R28 Out to I/O location
87 | +0000009E: 91CF POP R28 Pop register from stack
88 | +0000009F: 91DF POP R29 Pop register from stack
89 | +000000A0: 9508 RET Subroutine return
90 | +000000A1: 93DF PUSH R29 Push register on stack
91 | +000000A2: 93CF PUSH R28 Push register on stack
92 | +000000A3: D000 RCALL PC+0x0001 Relative call subroutine
93 | +000000A4: D000 RCALL PC+0x0001 Relative call subroutine
94 | +000000A5: B7CD IN R28,0x3D In from I/O location
95 | +000000A6: B7DE IN R29,0x3E In from I/O location
96 | +000000A7: 839C STD Y+4,R25 Store indirect with displacement
97 | +000000A8: 838B STD Y+3,R24 Store indirect with displacement
98 | +000000A9: 821A STD Y+2,R1 Store indirect with displacement
99 | +000000AA: 8219 STD Y+1,R1 Store indirect with displacement
100 | +000000AB: C010 RJMP PC+0x0011 Relative jump
101 | +000000AC: E4EE LDI R30,0x4E Load immediate
102 | +000000AD: E0F0 LDI R31,0x00 Load immediate
103 | +000000AE: 8180 LDD R24,Z+0 Load indirect with displacement
104 | +000000AF: 81EB LDD R30,Y+3 Load indirect with displacement
105 | +000000B0: 81FC LDD R31,Y+4 Load indirect with displacement
106 | +000000B1: 8380 STD Z+0,R24 Store indirect with displacement
107 | +000000B2: 818B LDD R24,Y+3 Load indirect with displacement
108 | +000000B3: 819C LDD R25,Y+4 Load indirect with displacement
109 | +000000B4: 9601 ADIW R24,0x01 Add immediate to word
110 | +000000B5: 839C STD Y+4,R25 Store indirect with displacement
111 | +000000B6: 838B STD Y+3,R24 Store indirect with displacement
112 | +000000B7: 8189 LDD R24,Y+1 Load indirect with displacement
113 | +000000B8: 819A LDD R25,Y+2 Load indirect with displacement
114 | +000000B9: 9601 ADIW R24,0x01 Add immediate to word
115 | +000000BA: 839A STD Y+2,R25 Store indirect with displacement
116 | +000000BB: 8389 STD Y+1,R24 Store indirect with displacement
117 | +000000BC: 8189 LDD R24,Y+1 Load indirect with displacement
118 | +000000BD: 819A LDD R25,Y+2 Load indirect with displacement
119 | +000000BE: E022 LDI R18,0x02 Load immediate
120 | +000000BF: 3080 CPI R24,0x00 Compare with immediate
121 | +000000C0: 0792 CPC R25,R18 Compare with carry
122 | +000000C1: F350 BRCS PC-0x15 Branch if carry set
123 | +000000C2: E081 LDI R24,0x01 Load immediate
124 | +000000C3: 900F POP R0 Pop register from stack
125 | +000000C4: 900F POP R0 Pop register from stack
126 | +000000C5: 900F POP R0 Pop register from stack
127 | +000000C6: 900F POP R0 Pop register from stack
128 | +000000C7: 91CF POP R28 Pop register from stack
129 | +000000C8: 91DF POP R29 Pop register from stack
130 | +000000C9: 9508 RET Subroutine return
131 | +000000CA: 94F8 CLI Global Interrupt Disable
132 | +000000CB: CFFF RJMP PC-0x0000 Relative jump
133 | +000000CC: FFFF ??? Data or unknown opcode
