AVR32 Linux und X-Org
OP #1137164
Hallo Leute,
Ich versuche gerade relativ erfolglos den X-Server zu kompellieren... :(
Nach einem dummen Fehler mit wchar und locale (das Standardfile war
angegeben und da kann ich rumstellen was ich will ;) ) bin ich jetzt bei
fontconfig hängen geblieben
Hier die letzten ausgaben
make[4]: Betrete Verzeichnis '/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0/fc-case'
/usr/bin/gcc    -L/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib -L/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/usr/lib -o fc-case fc-case.o
/usr/bin/ld: skipping incompatible /home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0 when searching for /home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0
/usr/bin/ld: cannot find /home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0
collect2: ld gab 1 als Ende-Status zurück
make[4]: *** [fc-case] Fehler 1
make[4]: Verlasse Verzeichnis '/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0/fc-case'
make[3]: *** [all] Fehler 2
make[3]: Verlasse Verzeichnis '/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0/fc-case'
make[2]: *** [all-recursive] Fehler 1
make[2]: Verlasse Verzeichnis '/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0'
make[1]: *** [all] Fehler 2
make[1]: Verlasse Verzeichnis '/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0'
make: *** [/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/fontconfig-2.6.0/.stamp_built] Fehler 2
bubi@bubi-laptop:~/avr32/buildroot-avr32-v2.3.0$ /usr/bin/ld: cannot find /home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0
bash: /usr/bin/ld:: No such file or directory
bubi@bubi-laptop:~/avr32/buildroot-avr32-v2.3.0$ ld /home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0
/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/libc.so.0: could not read symbols: File in wrong format
Sagt das jemanden was? Ich stehe hier komplett aufn Schlauch :(
Gast #1137348
Was ist ein Kompeller?
Dem Lader stößt eine inkompatible Bibliothek auf:
>/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/lib c.so.0
>when searching for
und deshalb fällt das Linken auf die Nase:
Meine nächste Aktion währe mal mittels des Programms "file"
herausbekommen zu wollen was denn
>"/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_dir/lib/li
bc.so.0"
überhaupt für eine Datei ist...
Ich halte Deine Chancen für verhältnismäßig gering das Problem zu lösen
wenn Du mit der Fehlermeldung nichts anfangen kannst.
Gruß,
Holm
#1137729
Soll das Fontconfig auf dem Host oder dem Target laufen ?
Für das Target stimmt der Compiler nicht -> /usr/bin/gcc .
Wenn es für den Host bestimmt ist stimmt der ldpath nicht ->
.so.0
Wie rufst Du den das make auf? Hat xorg nicht automake&co ?
Wenn kein automake vorhanden ist mache ich das immer so :
CC=arm-linux-gnueabi-gcc make
Das überschreibt temporär die CC Variable mit dem von dir gewählten
Compiler.
Es bietet sich auch an das /bin deiner Toolchain in die PATH Variable zu
übernehmen
Mit automake :
./configure --host=arm-linux-gnueabi --prefix=/wo_auch_immer_hin
OP #1137936
So 3 dumme Fehler...
- Vergessen zu sagen das es sich um buildroot handelt und es wohl etwas
mit den Makefiles von fontconfig zu tun hat. -> wär sonst aber aus dem
Pfad herauszulesen gewesen, ist aber natürlich leicht zu übersehen, ich
überfliege Pfadangaben auch meist ;)
- eine Zeile zuviel mitkopiert
>/home/bubi/avr32/buildroot-avr32-v2.3.0/build_avr32/staging_di/lib/libc .so.0
Die nächste sollte das interresante sein.
- das ich auf Grund von Müdigkeit kompilieren nicht schreiben konnte ;)
Ich tippe ja eigentlich darauf das fc-case, für irgendwelche checktools
notwendig ist -> falsche Bibliotek. Sollte es für das Target sein ->
falscher gcc...
Irgendwas scheint in den Makefiles von buildroot nicht zu stimmen.
Nur leider spuckt google nicht viel zu dem Problem aus, nur das
fontconfig auch auf ARM Maschinen scheinbar teils Probleme bereitet.
Michael
