EEPROM 24C256 / 24C512 nicht erreichbar
Gast #145038
Ich versuche mit codevision auf die 24Cxx (xx= 512 oder 256) zu
zugreifen aber ohne Erfolg. Ich werde für jede Hilfe dankbar. Wie gehe
ich vor:
24Cxx (xx= 512 oder 256)<--- ->  uC(AT90S8515)
SCL(Pin 6) ------------------->  PORTB.4
SDA(Pin 5) ------------------->  PORTB.5
PINs A0, A1 --> GND
WP -----------> GND
Program:
#include <90s8515.h>
// Standard Input/Output functions
#include <stdio.h>
#include <delay.h>
// I2C Bus functions
#asm
   .equ __i2c_port=0x18 ;PORTB
   .equ __scl_bit=4
   .equ __sda_bit=5
#endasm
#include <i2c.h>
/* read a byte from the EEPROM */
unsigned char eeprom_read(unsigned int address) {
   unsigned char data;
   i2c_start();
   i2c_write(EEPROM_BUS_ADDRESS);
   i2c_write(0x00FF & (address>>8));//(0x1F & (addr>>8))
   i2c_write(0x00FF & address);//(0xFF & addr);
   i2c_start();
   i2c_write(EEPROM_BUS_ADDRESS | 1);
   data=i2c_read(0);
   i2c_stop();
return data;
/* write a byte to the EEPROM */
void eeprom_write(unsigned int address, unsigned char data) {
   i2c_start();
   i2c_write(data);
   i2c_stop();
    delay_ms(5);
void main(void)
// Declare your local variables here
   unsigned char device;
   unsigned char i, eepVar;
   int temp = 0;
   PORTA=0x07;
   DDRA=0x07;
// UART initialization
   UCR=0x18;
   UBRR=0x19;
// I2C Bus initialization
   i2c_init();
   eeprom_write(0x00aa,0x55); //0x55
   eepVar = eeprom_read(0x00aa);
   if(eepVar){
      printf("EEprom:  %-X", eepVar);
      putchar(eepVar);
      printf("\n\t");
   else
      printf("\n\tEEPROM ERROR !");
   while (1){
      eeprom_write(0x0011,0x0A); //0x55
      printf("EEPROM: %-X\n", eeprom_read(0x0011));
Was ist hier falsch mit den write und read programme?
Danke
