Hey, Wie der Titel schon sagt versuch ich gerade rauszufinden welches CRC16 Verfahren SD Karten verwenden. Die Spec sagt einem zwar das es eine CRC-16 mit dem polynom x^16+x^12+x^5+1 (1021) ist, allerdings find ich keine Angabe zu init-Value, Xorout, refin, refout. Das Tool SRP16, welches einem aus einem Datensatz + CRC-Value die möglichen Verfahren ermitteln kann, hat mir folgendes geliefert: Found known algorithm: CRC-16/ZMODEM CRC=$7fa1 Poly=$1021 init=$0000 xorout=$0000 refin=false refout=false Stimmt das? gilt das Verfahren für alle SD-Karten? und hat jemand ne Beispielimplementierung?
Findest du in der SD-Spec. Genauer Part 1, Physical Layer, Kapitel 4.5. Ist auch in der (kostenlosen) Simplified Specification. "CRC7 The CRC7 check is used for all commands, for all responses except type R3, and for the CSD and CID registers. The CRC7 is a 7-bit value and is computed as follows: Generator polynomial: G(x) = x7 + x3 + 1. M(x) = (first bit) * xn + (second bit) * xn-1 +...+ (last bit) * x0 CRC[6...0] = Remainder [(M(x) * x7)/G(x)] The first bit is the most left bit of the corresponding bit string (of the command, response, CID or CSD). The degree n of the polynomial is the number of CRC protected bits decreased by one. The number of bits to be protected is 40 for commands and responses (n = 39), and 120 for the CSD and CID (n = 119). CRC7 Examples The CRC section of the command/response is bolded. CMD0 (Argument=0) --> 01 000000 00000000000000000000000000000000 "1001010" 1 CMD17 (Argument=0) --> 01 010001 00000000000000000000000000000000 "0101010" 1 Response of CMD17 --> 00 010001 00000000000000000000100100000000 "0110011" 1 " "CRC16 In the case of one DAT line usage, the CRC16 is used for payload protection in block transfer mode. The CRC check sum is a 16-bit value and is computed as follows: Generator polynomial G(x) = x16 +x12 +x5 +1 M(x) = (first bit) * xn + (second bit)* xn-1 +...+ (last bit) * x0 CRC[15...0] = Remainder [(M(x) * x16)/G(x)] The first bit is the first data bit of the corresponding block. The degree n of the polynomial denotes the number of bits of the data block decreased by one (e.g. n = 4095 for a block length of 512 bytes). The generator polynomial G(x) is a standard CCITT polynomial. The code has a minimal distance d=4 and is used for a payload length of up to 2048 Bytes (n <= 16383). The same CRC16 method shall be used in single DAT line mode and in wide bus mode. In wide bus mode, the CRC16 is done on each line separately." "512 bytes with 0xFF data --> CRC16 = 0x7FA1"
