Gebe mein kaum benutztes Backup (2.) Gerät ab.
Dieser Logicanalyzer mit 100Mhz Timinganalyse und eingebautem 50Mhz
2 Kanal Digitalscope mit reichlichen Analyse und Anzeigefunktionen,
sowie vielfältigen Trigger und Programmiermöglichkeiten leistet mir
immer gute Dienste bei der Mikrocontrollerentwicklung.
Dazu gibt es alle 4x8bit Probes, Miniklepse, Kabel, etc.,
also reichlich Zubehör.
Diese HP Geräte sind zwar schon einige Jahre alt, aber stecken immer
noch locker so manches Software basierte Gerät in den Sack.
Ich hab mal ein paar Daten rauskopiert.
Logic Analyzer Übersicht:
Indispensable Tool for Digital and Analog Design and Test
Powerful:
Timing, state, analog, and software performance analysis all in one
instrument
Trigger measurements on combinations of glitches, edges, voltage levels
and patterns so you can quickly track down hard-to-find problems.
Easy to Use:
A menu architecture guides you through each step in the measurement
process. All choices are clearly shown, and prompt and error messages
help eliminate setup guesswork.
Data can be displayed in eight different formats, including
microprocessor mnemonics, relocatable addresses, and user-defined
labels.
Multi-function Tool:
Combining up to five logic analysis functions in one benchtop
instrument, the HP 1631 may be your single most important tool for
digital-product design, development, and testing.
Timing analysis at 100 MHz to check hardware and status signals.
Analog analysis at 200 megasamples/second to verify data voltage
and time parameters.
Performance analysis to optimize code.
Interactive state/timing/analog analysis to integrate systems,
circuits and code.
Microprocessor preprocessors-direct connection to eight and 16-bit
microprocessor systems.
Minicomputer interfaces-eliminate loading, clocking, and demultiplexing
problems.
Ausstattung:
State Channel*Timing Channels*Analog Channels
43 - -
35 8 -
27 16 -
- 16 -
- - 2
- 16 2
27 16 2
35 8 2
43 - 2
Die Bilder zeigen einen (digitalen) Programmiervorgang eines
89LPC903 ISP Controllers, sowie die Scope Funktion mit einem 10Mhz
Sinus.
Ihr könnt mir ernstgemeinte Angebote machen.
Da das Gerät kein Spielzeug sondern ein praxistaugliches, voll
funktionsfähiges Labormeßgerät in bewährter HP/Agilent Qualität ist,
setzte ich mal >100 Eur an.
Gruß,
Markus
Hallo, ich habe Interesse. Ich würde es aber wenn persönlich abholen. Daher: Wo steht das gute Stück?
