beim Starten des usbprog trat folgende Fehlermeldung auf:
" avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/rfr/.avrduderc"
User configuration file does not exist or is not a regular
file, skipping
Using Port : usb
Using Programmer : avrispv2
avrdude: usbdev_open(): Found AVRISP mk2 Clone, serno: 0000A00128255
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages
MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0
9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024
4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0
9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0
9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0
9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0
9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0
0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0
0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP V2
Programmer Model: AVRISP mkII
Hardware Version: 0
Firmware Version Master : 9.09
Vtarget : 5.0 V
SCK period : 8.00 us
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status:
Unknown status 0x00
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
-------------8<----------------------8<-----------------
Ich habe die Verbindung zwischen den Geräten bereits geprüft und sie
scheint ok.
Was kann noch als Ursache in Frage kommen?
Reicht die Stromversorgung per usbprog aus?
Gruss
Robert
> avrdude: Version 5.11.1, compiled on Oct 30 2011 Das ist uuuralt. Wie wäre es mal mit einem Update? > Reicht die Stromversorgung per usbprog aus? Das kommt drauf an(tm). Ohne Details kann man nur raten.
