Hello I am writing to you to get help in uC Project. I am studying electronics in germany but my german is not so good. I need a small programm for Controller for timing some hours. Also Sensors must be observed to make sure all works fine. I have not done uC so far but have a test board with AVR from EBAY. How can I make small program?
Hallo Mahmud Sahed al Ashraoui, Was für einen µC wirst Du verwenden? Welche Sensoren verwendest Du? Welche Programmiersprache? Gib uns bitte Detailiertere Angaben zu Deinem Projekt, damit wir Dir zielgerichteter helfen können. Bernhard
Because you haven an AVR I think it's the best if you try to use WinAVR, you can get it here: http://winavr.sourceforge.net/ In combination with AVRStudio from Atmel you can also simulate your Program: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=2725 Because you're studying electronics I think you have worked a bit with the C programming language so it should be not a big problem. You only have to learn some basic I/O things for the uC. The Datasheet is always a good help an this page too (see AVR-GCC-Tutorial and AVR-GCC-Tutorial).
> for timing some hours...
Nanana... Der wird doch nicht...???
