Forum: PC-Programmierung Doxygen: Enum-Felder Gemeinsamkeiten dokumentieren
von Walter T. (nicolas)
Guten Morgen,
ich bin gerade dabei, Teile eines alten Projektteils in Doxygen zu
übernehmen. Dabei gibt es ein großes Enum (Offset-Tabelle), bei dem oft
mehre Felder hintereinander Gemeinsamkeiten haben, aber natürlich auch
Einzel-Eigenschaften:
    /** Font header data offsets:
       All Font header data is uncompressed */
    enum u8g2_font_header_offset_e
        u8g2_font_header_offset_number_of_glyphs = 0,
        u8g2_font_header_offset_bounding_box_mode = 1,
        u8g2_font_header_offset_bits_per_0 = 2,            /**< Encoding run lenght (Zeros) */
        u8g2_font_header_offset_bits_per_1 = 3,            /**< Encoding run lenght (Ones) */
        /* Encoding lengths of glyph bounding box components */
        u8g2_font_header_offset_bits_per_char_width = 4,
        u8g2_font_header_offset_bits_per_char_height = 5,
        u8g2_font_header_offset_bits_per_char_x = 6,
        u8g2_font_header_offset_bits_per_char_y = 7,
        u8g2_font_header_offset_bits_per_delta_x = 8,
        /* Font Bounding box; bytes are int8_t */
        u8g2_font_header_offset_max_char_width = 9,
        u8g2_font_header_offset_max_char_height = 10,
        u8g2_font_header_offset_x_offset = 11,
        u8g2_font_header_offset_y_offset = 12,
        /* Ascent and Descent of selected characters 'A', 'g' and '(' for specifc
24
           calculation of line pitch
25
           bytes are int8_t */
26
        u8g2_font_header_offset_ascent_A = 13,
27
        u8g2_font_header_offset_descent_g = 14,
28
        u8g2_font_header_offset_ascent_parenthesis = 15,
29
        u8g2_font_header_offset_descent_parenthesis = 16,
30
31
        /* Start Posistion (Offset) of specific Glyphs ('A', 'a', 255) in Font Array.
32
           This accelerates search for the correct glyph. Would still work, if all
33
           zeroes, thus slower */
34
        u8g2_font_header_offset_start_pos_upper_A = 17,   /**< Glyphs starting from 'A' */
35
        u8g2_font_header_offset_start_pos_lower_a = 19,   /**< Glyphs starting from 'a' */
36
        u8g2_font_header_offset_start_pos_unicode = 21,   /**< Glyphs starting from 255 */
37
Bei normalen Kommentaren kann ich das ja einfach optisch gruppieren, wie
es oben zu sehen ist. Gibt es einen Weg in Doxygen?
