1 | STMicroelectronics ST-LINK GDB server. Version 5.8.0
2 | Copyright (c) 2020, STMicroelectronics. All rights reserved.
3 |
4 | Starting server with the following options:
5 | Persistent Mode : Disabled
6 | Logging Level : 31
7 | Listen Port Number : 50000
8 | Status Refresh Delay : 15s
9 | Verbose Mode : Disabled
10 | SWD Debug : Enabled
11 |
12 | Target connection mode: Default
13 | Reading ROM table for AP 0 @0xe00fefd0
14 | Hardware watchpoint supported by the target
15 | COM frequency = 24000 kHz
16 | ST-LINK Firmware version : V3J7M2
17 | Device ID: 0x450
18 | PC: 0x80037fc
19 | ST-LINK device status: HALT_MODE
20 | ST-LINK detects target voltage = 3.29 V
21 | ST-LINK device status: HALT_MODE
22 | ST-LINK device initialization OK
23 | Waiting for debugger connection...
24 | Waiting for connection on port 50000...
25 | Accepted connection on port 50000...
26 | Debugger connected
27 | Enter STM32_AppReset() function
28 | NVIC_DFSR_REG = 0x0000000B
29 | NVIC_CFGFSR_REG = 0x00000000
30 | ------ Switching to STM32CubeProgrammer -----
31 | -------------------------------------------------------------------
32 | STM32CubeProgrammer v2.8.0
33 | -------------------------------------------------------------------
34 |
35 | ST-LINK SN : 004900313137510B33333639
36 | ST-LINK FW : V3J7M2
37 | Board : STLINK-V3MINI
38 | Voltage : 3.29V
39 | SWD freq : 24000 KHz
40 | Connect mode: Under Reset
41 | Reset mode : Hardware reset
42 | Device ID : 0x450
43 | Revision ID : Rev V
44 | Device name : STM32H7xx
45 | Flash size : 2 MBytes
46 | Device type : MCU
47 | Device CPU : Cortex-M7
48 | BL Version : 0x90
49 |
50 |
51 |
52 | Memory Programming ...
53 | Opening and parsing file: ST-LINK_GDB_server_a16228.srec
54 | File : ST-LINK_GDB_server_a16228.srec
55 | Size : 40704 Bytes
56 | Address : 0x08000000
57 |
58 |
59 | Erasing memory corresponding to segment 0:
60 | Erasing internal memory sector 0
61 | Download in Progress:
62 |
63 |
64 | File download complete
65 | Time elapsed during download operation: 00:00:00.988
66 | ------ Switching context -----
67 | Target connection mode: Default
68 | Target connection failed. Try connecting under reset
69 | Target connection failed
70 | Target no device found
