Nach der Installation der AVRLIB habe ich testweise die mmctest.c compiliert und erhalte folgenden Output: > "make.exe" all avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=mmctest.lst -mmcu=atmega163 -I. mmctest.c -o mmctest.o In file included from mmctest.c:27: C:\Programme\AVRlib/mmc.h:35:1: warning: multi-line comment avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/buffer.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/buffer.c -o C:\Programme\AVRlib/buffer.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/uart.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/uart.c -o C:\Programme\AVRlib/uart.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/rprintf.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/rprintf.c -o C:\Programme\AVRlib/rprintf.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/timer.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/timer.c -o C:\Programme\AVRlib/timer.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/vt100.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/vt100.c -o C:\Programme\AVRlib/vt100.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/spi.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/spi.c -o C:\Programme\AVRlib/spi.o avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/mmc.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/mmc.c -o C:\Programme\AVRlib/mmc.o In file included from C:\Programme\AVRlib/mmc.c:31: C:\Programme\AVRlib/mmc.h:35:1: warning: multi-line comment avr-gcc -c -g -Os -Wall -Wstrict-prototypes -IC:\Programme\AVRlib -Wa,-ahlms=C:\Programme\AVRlib/debug.lst -mmcu=atmega163 -I. C:\Programme\AVRlib/debug.c -o C:\Programme\AVRlib/debug.o avr-gcc mmctest.o C:\Programme\AVRlib/buffer.o C:\Programme\AVRlib/uart.o C:\Programme\AVRlib/rprintf.o C:\Programme\AVRlib/timer.o C:\Programme\AVRlib/vt100.o C:\Programme\AVRlib/spi.o C:\Programme\AVRlib/mmc.o C:\Programme\AVRlib/debug.o -Wl,-Map=mmctest.map,--cref -mmcu=atmega163 -o mmctest.elf avr-objcopy --debugging -O coff-ext-avr \ --change-section-address .data-0x800000 \ --change-section-address .bss-0x800000 \ --change-section-address .noinit-0x800000 \ --change-section-address .eeprom-0x810000 \ mmctest.elf mmctest.cof Warning: file C:/DOCUME~1/EWEDDI~1/LOCALS~1/Temp/cceudaaa.s not found in symbol table, ignoring Warning: ignoring function __vectors() outside any compilation unit Warning: ignoring function __bad_interrupt() outside any compilation unit avr-objcopy -O binary -R .eeprom mmctest.elf mmctest.bin avr-objcopy -O ihex -R .eeprom mmctest.elf mmctest.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -O ihex mmctest.elf mmctest.eep avr-size mmctest.elf text data bss dec hex filename 6292 0 179 6471 1947 mmctest.elf Errors: none rm C:\Programme\AVRlib/rprintf.o C:\Programme\AVRlib/uart.o C:\Programme\AVRlib/debug.o C:\Programme\AVRlib/mmc.o C:\Programme\AVRlib/vt100.o C:\Programme\AVRlib/spi.o C:\Programme\AVRlib/buffer.o C:\Programme\AVRlib/timer.o > Process Exit Code: 0 > Time Taken: 00:03 Interessant ist dieser Teil: Warning: file C:/DOCUME~1/EWEDDI~1/LOCALS~1/Temp/cceudaaa.s not found in symbol table, ignoring Warning: ignoring function __vectors() outside any compilation unit Warning: ignoring function __bad_interrupt() outside any compilation unit Wo steht denn bitte die "Verlinkung" nach <<C:/DOCUME~1/EWEDDI~1/LOCALS~1/Temp/cceudaaa.s>> Ich habe garkein Userprofil namnes EWEDDI irgentwas... komisch. Ich wollte endlich mal anfangen - nun wieder nichts -oder einfach ignorieren? Danke AxelR.
Axel Rühl wrote: > Interessant ist dieser Teil: > Warning: file C:/DOCUME~1/EWEDDI~1/LOCALS~1/Temp/cceudaaa.s not found in > symbol table, ignoring > Wo steht denn bitte die "Verlinkung" nach > <<C:/DOCUME~1/EWEDDI~1/LOCALS~1/Temp/cceudaaa.s>> Auf Eric Weddington (eweddington)'s Entwicklungsrechner. Er hat wohl vergessen, eine der ausgelieferten Bibliotheken zu avr-strip -g'en. > Warning: ignoring function __vectors() outside any compilation unit > Warning: ignoring function __bad_interrupt() outside any compilation > unit Known issue des COFF-Konverters. Wird nicht mehr repariert. Solange es nicht mehr als diese beiden sind, ist es harmlos. Leider kann der Konverter die harmlosen Dinge wie diese hier nicht von ggf. wirklich wichtigen unterscheiden.
Jörg Wunsch wrote: > > Er hat wohl vergessen, eine der ausgelieferten Bibliotheken zu > avr-strip -g'en. > Danke für die rasche Reaktion! Was mach ich denn jetzt? Denn die compilierte Datei rprintf.hex, die man ja - wenn man das alles nach Anleitung macht, weil man nicht so der C-Profi ist - inm Testlauf auf der Konsole compiliert, ist nur halb so groß, wie im Netz beschrieben, wenn man mal die Ausgaben vergleicht. Selbst strip -g'en kann ich wohl vergessen, da mir die Quelle fehlt. Ob ich mal den Eric 'ne Mail schreibe? Ich bin doch sicher der erste und einzige, dem das auffällt, oder doch? Andererseits ist es ja nur eine Warnung und kein Error, aber die erzeugte Dateigröße sollte doch wohl mit der aus der Anleitung übereinstimmen.. (Sch.. wenn man keine Ahnung hat ;-) ) Schönen Abend und vielen Dank nochmal AxelR.
> Selbst strip -g'en kann ich wohl vergessen, da mir die Quelle fehlt. Nein, das bezieht sich auf die Objektdatei. Ich kann dir nur nicht sagen, auf welche. ;-) Ich vermute, eine der vielen crt*.o-Dateien (oder alle). Du darfst alle *.a und *.o-Dateien, die du im WinAVR- Baum findest, mit avr-strip -g behandeln (aber bitte nicht ohne das -g). Das entfernt die Debug-Information, die dir ohnehin nichts nützt, da du den Quellcode ja nicht installiert hast. > Ich bin doch sicher der erste und einzige, dem das auffällt, oder doch? Bist du nicht, ja. > Andererseits ist es ja nur eine Warnung und kein Error, aber die > erzeugte Dateigröße sollte doch wohl mit der aus der Anleitung > übereinstimmen.. Keine Ahnung, über welche Dateigröße du schreibst. Aber ,rohe' Dateigrößen spielen bei Objektdateien (und in gewissem Maße bei Intel-Hex-Dateien) keine Rolle. Die tatsächliche Größe des erzeugten Codes hast du ja oben bereits zitiert.
Ich habe mich nun eingehend in der FAQ und der Hilfe belesen... Hätte ich mal gleich machen sollen - Danke trotzdem! AxelR. Da muss man die ersten Tage wahrscheinlich ganz geschmeidig an die Sache rangehen... Ist halt neu für mich
