Forum: PC-Programmierung Zigbee2Mqtt keine Weboberfläche
von Chandler B. (chandler)
ich möchte auf einem Rasperry-Pi verschiedene Docker laufen lassen und
habe da bei mosquitto und zigbee2mqtt ein Problem.
Tree:
home/docker-compose/mosquitto/docker-compose.yml
home/docker-compose/nodered/docker-compose.yml
home/docker-compose/pihole/docker-compose.yml
nodered und pihole starten und ich kann auch auf die weboderfläche
zugreifen
home/docker-compose/mosquitto/mosquitto/config/
home/docker-compose/mosquitto/mosquitto/data/
home/docker-compose/mosquitto/mosquitto/log/
home/docker-compose/mosquitto/mosquitto/pwfile/
home/docker-compose/mosquitto/zigbee2mqtt/configuration.yaml
home/docker-compose/mosquitto/zigbee2mqtt/coorinator_backup.json
home/docker-compose/mosquitto/zigbee2mqtt/database.db
home/docker-compose/mosquitto/zigbee2mqtt/log/
home/docker-compose/mosquitto/zigbee2mqtt/state.json
home/docker-compose/mosquitto/docker-compose.yml:
(version: "3.6"
services:
  mosquitto:
    container_name: mosquitto
    image: eclipse-mosquitto:latest
    restart: unless-stopped
    environment:
      - TZ=Europe/Berlin
    ports:
      - "1883:1883"
      - "9001:9001"
    volumes:
      - ./mosquitto/config:/config
      - ./mosquitto/data:/data
      - ./mosquitto/log:/log
      - ./mosquitto/pwfile:/pwfile
  zigbee2mqtt:
    container_name: zigbee2mqtt
    image: koenkk/zigbee2mqtt:latest
    environment:
23
      - TZ=Europe/Berlin
24
      - ZIGBEE2MQTT_CONFIG_MQTT_SERVER=mqtt://mosquitto:1883
25
      - ZIGBEE2MQTT_CONFIG_FRONTEND=true
26
      - ZIEGBEE2MQTT_CONFIG_ADVANCED_LOG_SYMLINK_CURRENT=true
27
      - DEBUG=zigbee-herdsman*
28
    ports:
29
      - "8080:8080"
30
    volumes:
31
      - ./zigbee2mqtt/data:/app/data
32
    devices:
33
      - /dev/ttyUSB0:/dev/ttyACM0
34
35
    depends_on:
36
      - mosquitto
ausgabe
docker ps
CONTAINER ID   IMAGE                       COMMAND                  CREATED          STATUS                    PORTS        NAMES
c7ebc0126ecf   koenkk/zigbee2mqtt:latest   "docker-entrypoint.s…"   11 minutes ago   Up 2 seconds              0.0.0.0:8080->8080/tcp, :::8080->8080/tcp        zigbee2mqtt
4c5ca5d2045b   eclipse-mosquitto:latest    "/docker-entrypoint.…"   11 minutes ago   Up 11 minutes             0.0.0.0:1883->1883/tcp, :::1883->1883/tcp, 0.0.0.0:9001->9001/tcp, :::9001->9001/tcp                              mosquitto
bffd3fd2611e   nodered_node-red            "./entrypoint.sh"        2 hours ago      Up 14 minutes (healthy)   0.0.0.0:1880->1880/tcp, :::1880->1880/tcp        node-red
a05ffd890a79   pihole/pihole:latest        "/s6-init"               5 hours ago      Up 14 minutes (healthy)   0.0.0.0:53->53/tcp, :::53->53/tcp, 0.0.0.0:80->80/tcp, 0.0.0.0:53->53/udp, :::80->80/tcp, :::53->53/udp, 67/udp   pihole
Wenn ich jetzt allerdings
192.168.178.25:8080 im Browser aufrufe, bekomme ich den Fehler, dass die
Verbindung nicht aufgebaut werden kann.
Im Log steht
debug 2024-10-08 13:12:19: Loaded state from file /app/data/state.json
info  2024-10-08 13:12:19: Logging to console and directory: '/app/data/log/2024-10-08.13-12-19' filename: log.txt
debug 2024-10-08 13:12:19: Removing old log directory '/app/data/log/2024-10-08.13-08-28'
info  2024-10-08 13:12:20: Starting Zigbee2MQTT version 1.33.2 (commit #9996c93)
info  2024-10-08 13:12:20: Starting zigbee-herdsman (0.21.0)
debug 2024-10-08 13:12:20: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[43,108,88,248,115,234,161,123],"networkKey":"HIDDEN","panID":27581},"serialPort":{"path":"/dev/ttyACM0"}}'
error 2024-10-08 13:12:22: Configuration is not consistent with adapter state/backup!
error 2024-10-08 13:12:22: - PAN ID: configured=27581, adapter=44797
error 2024-10-08 13:12:22: - Extended PAN ID: configured=2b6c58f873eaa17b, adapter=925a544669ced9b5
error 2024-10-08 13:12:22: - Network Key: configured=905e45b18fee9ae5a4ac58ac2f4b1949, adapter=633debc31e579e82dd927d9a5efa32dd
error 2024-10-08 13:12:22: - Channel List: configured=11, adapter=11
error 2024-10-08 13:12:22: Please update configuration to prevent further issues.
error 2024-10-08 13:12:22: If you wish to re-commission your network, please remove coordinator backup at /app/data/coordinator_backup.json.
error 2024-10-08 13:12:22: Re-commissioning your network will require re-pairing of all devices!
error 2024-10-08 13:12:22: Error while starting zigbee-herdsman
error 2024-10-08 13:12:22: Failed to start zigbee
error 2024-10-08 13:12:22: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
error 2024-10-08 13:12:22: Exiting...
error 2024-10-08 13:12:22: Error: startup failed - configuration-adapter mismatch - see logs above for more information
    at ZnpAdapterManager.determineStrategy (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:229:35)
    at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:63:26)
    at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
23
    at Zigbee.start (/app/lib/zigbee.ts:60:27)
24
    at Controller.start (/app/lib/controller.ts:101:27)
25
    at start (/app/index.js:107:5)
wo finde ich den ordner /app/data/?
das Problem ist wahrscheinlich schon in der ersten debug-Nachricht?
Es ist zwar gestartet, aber im Nodered wird auch nichts gefunden.
Ziel ist es ein Bewegungsmelder von LIDL (Zigbee) in nodered einzubinden
und damit eine HUE-Lampe schalten
von Εrnst B. (ernst)
Das Frontend startet nicht, wenn das Backend nicht starten kann.
Hast du zwischendurch mal den USB-Stick gewechselt oder dem eine andere
ID draufgeflasht?
Dann genauso machen wie's in deiner Fehlermeldung steht:
da wo du ihn in deiner docker-compose.yml hinkonfiguriert hast:
>    volumes:
also Ordner zigbee2mqtt/data
PS: die "ZIEGE" da entfernen:
Wobei das nicht dein Problem verursacht.
> ID draufgeflasht?
Nein, den Raspberry pi habe ich mal neu gestartet und das alte docker
gelöscht und jetzt neu gemacht.
Das ist mir auch schon aufgefallen und habe es geändert.
>>    volumes:
Habe den kompletten Ordner zigbee2mqtt gelöscht, den docker gestoppt und
neu gestartet.
Der Ordner wurde neu erzeugt, aber auf der oberfläche komme ich immer
noch nicht drauf
> neu gestartet.
Falsche Reihenfolge. Erst Container stoppen, dann Ordner löschen, dann
Neustarten. (echtes Recreate vom Container, ggfs. docker-compose rm
zigbee2mqtt)
Wie ist die Fehlermeldung dann? "Erinnert" sich dein Container trotzdem
noch an einen Adapter 905e45b18fee9ae5a4ac58ac2f4b1949 obwohl du den
Adapter 633debc31e579e82dd927d9a5efa32dd eingesteckt hast?
zum Vergleich, Ausschnitt aus meiner docker-compose.yml, wo zigbee2mqtt
problemlos läuft:
  zigbee2mqtt:
    volumes:
      - ./zigbee:/app/data
      - /run/udev:/run/udev:ro
    ports:
      - "127.0.0.1:8087:8080"
      - "192.168.99.66:8087:8080"
    environment:
      - TZ=Europe/Berlin
    devices:
      - /dev/serial/by-id/usb-1a86_USB_Single_Serial_550D016712-if00:/dev/ttyACM0
(Bin mir gerade nicht sicher, für was "/run/udev" gebraucht wird, war
aber so in der Vorlage auf der zb2mqtt-Homepage)
https://www.zigbee2mqtt.io/guide/installation/02_docker.html#docker-compose
Anfang meiner ./zigbee(/data)/configuration.yaml:
homeassistant: false
availability: true
frontend: true
permit_join: false
advanced: ....
> zigbee2mqtt)
Habe jetzt den Docker gestoppt, "docker system prune" ausgeführt, den
Ordner gelöscht und neu gestartet.
Habe auch
      - /zigbee2mqtt/run/udev:/run/udev:ro
und
devices:
  - /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0:/dev/ttyACM0
abgeändert.
Jetzt habe ich aber das Problem, dass state from file
/app/data/state.json nicht geladen werden kann, da diese datei gar nicht
existiert
debug 2024-10-08 16:52:02: Can't load state from file /app/data/state.json (doesn't exist)
sowie
error 2024-10-08 16:52:27: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
info  2024-10-08 16:52:02: Logging to console and directory: '/app/data/log/2024-10-08.16-52-02' filename: log.txt
info  2024-10-08 16:52:02: Starting Zigbee2MQTT version 1.33.2 (commit #9996c93)
info  2024-10-08 16:52:02: Starting zigbee-herdsman (0.21.0)
debug 2024-10-08 16:52:03: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[104,80,184,165,246,184,192,193],"networkKey":"HIDDEN","panID":14971},"serialPort":{"path":"/dev/ttyACM0"}}'
info  2024-10-08 16:52:26: zigbee-herdsman started (reset)
info  2024-10-08 16:52:26: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
debug 2024-10-08 16:52:26: Zigbee network parameters: {"channel":11,"extendedPanID":"0x6850b8a5f6b8c0c1","panID":14971}
info  2024-10-08 16:52:26: Currently 0 devices are joined:
info  2024-10-08 16:52:26: Zigbee: disabling joining new devices.
info  2024-10-08 16:52:26: Connecting to MQTT server at mqtt://mosquitto:1883
debug 2024-10-08 16:52:26: Using MQTT anonymous login
error 2024-10-08 16:52:27: MQTT failed to connect, exiting...
info  2024-10-08 16:52:27: Stopping zigbee-herdsman...
error 2024-10-08 16:52:28: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:29: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:30: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:31: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:32: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:33: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 16:52:34: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
23
error 2024-10-08 16:52:35: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
24
error 2024-10-08 16:52:36: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
25
error 2024-10-08 16:52:37: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
26
error 2024-10-08 16:52:38: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
Wenn ich die Datei manuell wieder hinzufüge, bekomme ich ebenfalls den
Fehler
error 2024-10-08 17:00:11: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:11: MQTT failed to connect, exiting...
debug 2024-10-08 17:00:07: Loaded state from file /app/data/state.json
info  2024-10-08 17:00:07: Logging to console and directory: '/app/data/log/2024-10-08.17-00-07' filename: log.txt
debug 2024-10-08 17:00:07: Removing old log directory '/app/data/log/2024-10-08.16-54-44'
info  2024-10-08 17:00:07: Starting Zigbee2MQTT version 1.33.2 (commit #9996c93)
info  2024-10-08 17:00:07: Starting zigbee-herdsman (0.21.0)
debug 2024-10-08 17:00:07: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[104,80,184,165,246,184,192,193],"networkKey":"HIDDEN","panID":14971},"serialPort":{"path":"/dev/ttyACM0"}}'
info  2024-10-08 17:00:10: zigbee-herdsman started (resumed)
info  2024-10-08 17:00:10: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
debug 2024-10-08 17:00:10: Zigbee network parameters: {"channel":11,"extendedPanID":"0x6850b8a5f6b8c0c1","panID":14971}
info  2024-10-08 17:00:10: Currently 0 devices are joined:
info  2024-10-08 17:00:10: Zigbee: disabling joining new devices.
info  2024-10-08 17:00:10: Connecting to MQTT server at mqtt://mosquitto:1883
debug 2024-10-08 17:00:10: Using MQTT anonymous login
info  2024-10-08 17:00:11: Stopping zigbee-herdsman...
error 2024-10-08 17:00:12: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:13: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:14: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:15: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:16: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
error 2024-10-08 17:00:17: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
23
error 2024-10-08 17:00:18: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
24
error 2024-10-08 17:00:19: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
25
error 2024-10-08 17:00:20: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
26
error 2024-10-08 17:00:21: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
27
error 2024-10-08 17:00:22: MQTT error: connect ECONNREFUSED 172.20.0.2:1883
28
info  2024-10-08 17:00:22: Stopped zigbee-herdsman
das ist falsch. Falls das image den /run/udev-Ordner braucht, braucht es
auch den echten.
ist beim ersten Start normal. Muss ja erstmal den Dongle und die
Zigbee-Geräte anlernen.
dein mosquitto-Container läuft nicht oder ist falsch konfiguriert.
auch mal das Log von dem prüfen.
von J. S. (jojos)
Mal probieren ob der MQTT Zugriff lokal möglich ist von 127.1. für
externe Zugriffe muss das in der Konfigdatei explizit erlaubt werden.
