GPS-Geraet streikt
Gast #652399
ich habe mir einen kleinen GPS-Empfaenger gebastelt. Komischerweise
resetet sich das ding in etwa jede Sekunde und ab und zu funktioniert es
per Zufall, kann mir jemand weiterhelfen? Hier der Sourcecode:
$regfile = "m8def.dat"
$crystal = 16000000
$baud = 4800
Config Portb = Output
Config Portd = Input
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 ,
Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 20 * 4
Cls
Cursor Off
Dim C As Byte
Dim I As Byte
Dim Time As String * 6
Dim Av As String * 2
Dim Lat As String * 8
Dim Ns As String * 2
Dim Lon As String * 9
Dim Ew As String * 2
Dim Spd As String * 6
Dim Crs As String * 6
Dim Leng As Byte
Dim Xx As Bit
Dim A As Byte
Declare Sub Wait_for_string(byval S As String)
Declare Function Read_string() As String
Cls
Wait 1
   Upperline
   Lcd ""
   Lowerline
   Lcd ""
   Thirdline
   Lcd ""
   Fourthline
   Lcd ""
Wait 3
Cls
Config Serialin = Buffered , Size = 100                     ' Konfig.
der ser. Eingabe
Enable Interrupts
' $GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a*hh
Do
   Call Wait_for_string( "$GPRMC,")                         ' Warte auf
$GPRMC
   Time = Read_string()
   Av = Read_string()
   Lat = Read_string()
   Leng = Len(lat) - 1
   Lat = Left(lat , Leng)
   Ns = Read_string()
   Leng = Len(ns) - 1
   Ns = Left(ns , Leng)
   Lon = Read_string()
   Leng = Len(lon) - 1
   Lon = Left(lon , Leng)
   Ew = Read_string()
   Leng = Len(ew) - 1
   Ew = Left(ew , Leng)
   Spd = Read_string()
   Leng = Len(spd) - 1
   Spd = Left(spd , Leng)
   Crs = Read_string()
   Leng = Len(crs) - 1
   Crs = Left(crs , Leng)
   If Av = "A," Then
   Locate 1 , 1
   Lcd "LAT: "
   Locate 2 , 1
   Lcd "LON: "
   Locate 3 , 1
   Lcd "HDG: "
   Locate 4 , 1
   Lcd "SPD:"
   Locate 1 , 6
   Lcd Lat
   Lcd Ns
   Locate 2 , 6
   Lcd Lon
   Lcd Ew
   Locate 3 , 6
   Lcd Crs
   Locate 4 , 6
   Lcd Spd
   Locate 1 , 16
   Lcd "    "
   Locate 2 , 16
   Lcd "    "
   Locate 3 , 11
   Lcd "          "
   Locate 4 , 11
   Lcd "          "
   Locate 4 , 5
   Lcd " "
   'Spdkm = Val(spd)
   'Spdkm = Spdkm * 1852
   'Lcd Spdkm
   'If Av = "V," Then Av = "*"
   'If Av = "A," Then Av = " "
   'Locate 4 , 11
   'Lcd Av
   End If
   Toggle Xx
Loop
End
Sub Wait_for_string(byval S As String) As String
Local Ii As Byte
Local Cc As Byte
Ii = 1
M1:
   Cc = Waitkey()
   If Cc <> Mid(s , Ii , 1) Then
      Goto M1
   Else
      Incr Ii
      If Ii > Len(s) Then Goto M2
      Goto M1
   End If
M2:
End Sub
Local Cc As Byte
Local Ss As String * 10
Ss = ""
Do
   Cc = Waitkey()
   Ss = Ss + Chr(cc)
Loop Until Cc = ","
Read_string = Left(ss , 10)
End Function
'_____________________________________________________
Gast #653028
Das NMEA Signal ist perfekt und so vorhanden, wie es sein soll. Nur
spuckt der GPS-Empfaenger das signal in LVTTL Logik aus, sollte aber
kein Problem sein.
Selbst, wenn das Signal total im Arsch sein sollte, wieso sollte sich
der controller resetten?
Gast #653214
Kann das Display eventuell etwas verursachen? Denn vorher habe ich ein 2
 16 Display benutzt und nun ein 20  4. Ich hatte dies zuerst als
fehlerwuelle ausgeschlossen, da ich bereits zwei neue Displays versucht
habe, jedes Mal der Gleiche Fehler...
