1 | //I2C test
2 |
3 | #include "DSP280x_Device.h" // DSP280x Headerfile Include File
4 | #include "DSP280x_Examples.h" // DSP280x Examples Include File
5 |
6 | // Prototype statements for functions found within this file.
7 | void I2CA_Init(void);
8 | Uint16 I2C_Write(Uint16 slvaddr, int data, Uint16 length);
9 | Uint16 I2C_Read(Uint16 slvaddr, Uint16* data, Uint16 length);
10 |
11 | Uint16 Values[6];
12 |
13 | void main(void)
14 | {
15 | InitSysCtrl(); // Step 1. Initialize System Control:
16 | InitI2CGpio(); // Step 2. Initalize GPIO only for I2C functionality
17 | I2CA_Init(); // Step 4. Initialize all the Device Peripherals
18 |
19 | for(;;) // Application loop
20 | {
21 | I2C_Write(0x70,0x02,2);
22 | I2C_Read(0x71,Values,6);
23 | } // end of for(;;)
24 | } // end of main
25 |
26 |
27 | void I2CA_Init(void)
28 | {
29 | // I2caRegs.I2CSAR = 0x38; // Slave address - EEPROM control code
30 | I2caRegs.I2CPSC.all = 6; // Prescaler - need 7-12 Mhz on module clk for 60MHz CPU
31 | I2caRegs.I2CCLKL = 4200; // NOTE: must be non zero
32 | I2caRegs.I2CCLKH = 4200; // NOTE: must be non zero
33 | I2caRegs.I2CIER.all = 0x3E; // Enable SCD,XRDY,RRDY,ARDY,NACK interrupts
34 | // I2caRegs.I2CMDR.all = 0x0020; // Take I2C out of reset, Stop I2C when suspended
35 | // I2caRegs.I2CFFTX.all = 0x6000; // Enable FIFO mode and TXFIFO
36 | // I2caRegs.I2CFFRX.all = 0x2040; // Enable RXFIFO, clear RXFFINT,
37 | return;
38 | }
39 |
40 | Uint16 I2C_Write(Uint16 slvaddr, int data, Uint16 length)
41 | {
42 | Uint16 i;
43 | while (( I2caRegs.I2CSTR.bit.BB==1 )); //bus busy?
44 | if (I2caRegs.I2CSTR.bit.BB == 1)
45 | {
46 | return I2C_BUS_BUSY_ERROR;
47 | }
48 | I2caRegs.I2CMDR.all = 0; //disable I2C during config
49 | I2caRegs.I2CCNT = length; //number of bytes to be send
50 | I2caRegs.I2CSAR = slvaddr; //setup receiver addr
51 | // Mode settings
52 | I2caRegs.I2CMDR.bit.IRS=1; //I2C module enable
53 | I2caRegs.I2CMDR.bit.STT=1; //If master -> start condition generated
54 | I2caRegs.I2CMDR.bit.STP=1; //If master -> stop condition generated if data counter=0
55 | I2caRegs.I2CMDR.bit.TRX=1; //Transmitter mode
56 | I2caRegs.I2CMDR.bit.MST=1; //Master mode
57 | I2caRegs.I2CMDR.bit.FREE=1; //I2C module runs free
58 | I2caRegs.I2CMDR.bit.RM=1;
59 |
60 | /* Transmission*/
61 | for(i=0;i<length;i++)
62 | {
63 | while(!(I2caRegs.I2CSTR.bit.XRDY|I2caRegs.I2CSTR.bit.ARDY)); //wait for xdry flag before transmit data or ardy if NACK appears
64 | if (I2caRegs.I2CSTR.bit.NACK==1) //if NACK appears -> SCL=low, STP=0
65 | {
66 | I2caRegs.I2CMDR.all=0; //reset I2C -> SCL not held low
67 | }
68 | I2caRegs.I2CDXR = data;
69 | }
70 | }
71 |
72 | Uint16 I2C_Read(Uint16 slvaddr, Uint16* data, Uint16 length)
73 | {
74 | Uint16 i;
75 | while (( I2caRegs.I2CSTR.bit.BB==1 )); //bus busy?
76 | if (I2caRegs.I2CSTR.bit.BB == 1)
77 | {
78 | return I2C_BUS_BUSY_ERROR;
79 | }
80 | I2caRegs.I2CMDR.all = 0; //disable I2C during config
81 | I2caRegs.I2CCNT = length; //number of bytes to be send
82 | I2caRegs.I2CSAR = slvaddr; //setup receiver addr
83 | // Mode settings
84 | I2caRegs.I2CMDR.bit.IRS=1; //I2C module enable
85 | I2caRegs.I2CMDR.bit.STT=1; //If master -> start condition generated
86 | I2caRegs.I2CMDR.bit.STP=1; //If master -> stop condition generated if data counter = 0
87 | I2caRegs.I2CMDR.bit.MST=1; //Master mode
88 | I2caRegs.I2CMDR.bit.FREE=1; //I2C module runs free
89 | I2caRegs.I2CMDR.bit.NACKMOD=1;
90 |
91 | /* Reception */
92 | for(i=0;i<length;i++)
93 | {
94 | while(!(I2caRegs.I2CSTR.bit.XRDY|I2caRegs.I2CSTR.bit.ARDY)); //wait for xdry flag before transmit data or ardy if NACK appears
95 | if (I2caRegs.I2CSTR.bit.NACK==1) //if NACK appears -> SCL=low, STP=0
96 | {
97 | I2caRegs.I2CMDR.all=0; //reset I2C -> SCL not held low
98 | }
99 | while(I2caRegs.I2CSTR.bit.RRDY==1);
100 | data[i] = I2caRegs.I2CDRR ;
101 | }
102 | }
103 |
104 | //EOF
