1  | void HRPWM1_Config(period)
2  | {
3  |
4  | EALLOW;
5  |
6  | EPwm1Regs.TBPRD = period/2;              // Period = 585,37 TBCLK counts
7  |   EPwm1Regs.TBPHS.half.TBPHS = 0;          // Set Phase register to zero
8  |
9  |   EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;   // Symmetrical mode
10  |   EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;      // Master module
11  |   EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
12  |   EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
13  |   EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;    // TBCLK = SYSCLKOUT
14  |   EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
15  |   EPwm1Regs.TBCTL.bit.FREE_SOFT = 3;
16  |
17  |     EPwm1Regs.ETSEL.bit.SOCAEN  = 1;
18  |      EPwm1Regs.ETSEL.bit.SOCASEL  = ET_CTR_ZERO;
19  |      EPwm1Regs.ETPS.bit.SOCAPRD   = ET_1ST;
20  |
21  |   EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
22  |   EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
23  |   EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD;  // load on CTR=Zero
24  |
25  | //  EPwm1Regs.AQCTLA.bit.CBU = AQ_SET;        // set actions for EPWM1B
26  | //  EPwm1Regs.AQCTLA.bit.CBD = AQ_CLEAR;        // if using this one TBPRD = 147
27  |   EPwm1Regs.AQCTLA.bit.ZRO = AQ_TOGGLE;
28  |   EDIS;
29  | }
30  |
31  | void HRPWM3_Config(period)
32  | {
33  |
34  |
35  | // ePWM3 register configuration with HRPWM
36  | // ePWM3A toggle high/low with MEP control on falling edge
37  |
38  |   EPwm3Regs.TBCTL.bit.PRDLD = TB_SHADOW;          // set Immediate load
39  |   EPwm3Regs.TBPRD = period-1;                        // PWM frequency = 1 / period
40  |   EPwm3Regs.CMPA.half.CMPA = period / 2;              // set duty 50% initially
41  |   EPwm3Regs.CMPA.half.CMPAHR = (1 << 8);              // initialize HRPWM extension
42  |   EPwm3Regs.TBPHS.all = 0;
43  |   EPwm3Regs.TBCTR = 0;
44  |
45  |
46  |
47  |   EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
48  |   EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE;            // EPwm3 is the Master
49  |   EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
50  |   EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;
51  |   EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;
52  |
53  |   EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD;
54  |   EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_PRD;
55  |   EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
56  |   EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
57  |
58  |   EPwm3Regs.AQCTLA.bit.ZRO = AQ_SET;                  // PWM toggle high/low
59  |   EPwm3Regs.AQCTLA.bit.CAU = AQ_CLEAR;
60  |   EPwm3Regs.AQCTLB.bit.ZRO = AQ_SET;
61  |   EPwm3Regs.AQCTLB.bit.CBU = AQ_CLEAR;
62  |
63  |   EALLOW;
64  |   EPwm3Regs.HRCNFG.all = 0x0;
65  |   EPwm3Regs.HRCNFG.bit.EDGMODE = HR_BEP;               //MEP control on falling edge
66  |   EPwm3Regs.HRCNFG.bit.CTLMODE = HR_CMP;
67  |   EPwm3Regs.HRCNFG.bit.HRLOAD  = HR_CTR_PRD;
68  |   EDIS;
69  | }
