Hallo zusammen, ich bekomme beim compilieren folgende Fehler von ISE 6.2.04i: ERROR:PhysDesignRules:368 - The signal <PG_DC_AC_OBUF> is incomplete. The signal ERROR:PhysDesignRules:368 - The signal <Ethernet_OnOff_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <FPGA_IO_117_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <Seriel_IN_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <MPC5200_REQ_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <Seriel_Ex_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <FunfV_OnOff_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <FunfVP_OnOff_OBUF> is incomplete. The ERROR:PhysDesignRules:368 - The signal <LCD_OnOff_OBUF> is incomplete. The ERROR:PhysDesignRules:10 - The network <PG_DC_AC_OBUF> is completely unrouted. ERROR:PhysDesignRules:10 - The network <Ethernet_OnOff_OBUF> is completely ERROR:PhysDesignRules:10 - The network <FPGA_IO_117_OBUF> is completely ERROR:PhysDesignRules:10 - The network <Seriel_IN_OBUF> is completely unrouted. ERROR:PhysDesignRules:10 - The network <MPC5200_REQ_OBUF> is completely ERROR:PhysDesignRules:10 - The network <Seriel_Ex_OBUF> is completely unrouted. ERROR:PhysDesignRules:10 - The network <FunfV_OnOff_OBUF> is completely ERROR:PhysDesignRules:10 - The network <FunfVP_OnOff_OBUF> is completely ERROR:PhysDesignRules:10 - The network <LCD_OnOff_OBUF> is completely unrouted. ERROR:Bitgen:25 - DRC detected 18 errors and 110 warnings. Kann da jemand mir sagen, was ich falsch mache? Herzlichen dank.
1 | ERROR:PhysDesignRules:368 - The signal <PG_DC_AC_OBUF> is incomplete. |
Da fehlt doch noch was an der Meldung, oder? Egal, Du instanzierst einen Ausgangstreiber. Und dem Fehlen offenbar ein paar Leitungen. Wo kommt denn Dein Signal PG_DC_AC her? Rick
