1 | // +----------------------------------------------------------------------+
2 | // | |
3 | // | Comfort Keyhandling Code |
4 | // | |
5 | // | (C) 13/02/2008 - Daniel Porzig - www.base32.de |
6 | // +----------------------------------------------------------------------+
7 | //
8 | //
9 | //
10 | // How to use:
11 | //
12 | // 1.) If available, enable internal pull-up resistors, otherwise you
13 | // have to use external pull-up resistors for every key you use.
14 | // 2.) Call InitKeys();
15 | // 3.) Setup Keys by calling "setup_key" for every key.
16 | // 4.) Call "CheckKeys()" about every 50ms
17 | // 5.) Check the key states by calling KeyPress(..) or KeyLongPress(..)
18 | // for every key you want to use
19 | //
20 | //
21 | //
22 |
23 | // how many keys should be used
24 | #define NUM_KEYS 7
25 |
26 | // key states
27 | #define KS_RELEASED 0
28 | #define KS_PRESSED 1
29 | #define KS_LONGPRESSED 2
30 |
31 | // key modes
32 | #define KM_ACT_ON_PRESS 0x01
33 | #define KM_ACT_ON_RELEASE 0x02
34 | #define KM_ACT_ON_LONGPRESS 0x03
35 |
36 | // Key Data Structure (for each key)
37 | struct key_struct
38 | {
39 | int8 _mode; // key mode (const)
40 | int8 _repeat_delay; // delay for repeatedly pressed keys (const)
41 | int8 _longpress_delay; // how long the key has to be pressed before a longpress gets activated
42 | int8 state;
43 | int8 counter;
44 | int8 longpress_cnt;
45 | };
46 | struct key_struct keys[NUM_KEYS];
47 |
48 | // key state variables
49 | int8 last_keystate = 0xFF;
50 | int8 key_actions = 0x00;
51 | int8 key_longpress_actions = 0x00;
52 |
53 |
54 | // Configure a single button
55 | // num - which key to configure
56 | // mode - configure how the key reacts (KM_ACT_ON_PRESS, KM_ACT_ON_RELEASE or KM_ACT_ON_LONGPRESS)
57 | // repeat_delay - when a button is (long)pressed continuously, this value sets the delay between
58 | // repeatedly triggered actions
59 | // longpress_delay - configures how long a key (with key-mode == KM_ACT_ON_LONGPRESS) has to be hold down before
60 | // a longpress action is triggered
61 | void setup_key(int8 num, int8 mode, int8 repeat_delay, int8 longpress_delay)
62 | {
63 | keys[num]._mode = mode;
64 | keys[num]._repeat_delay = repeat_delay;
65 | keys[num]._longpress_delay = longpress_delay;
66 | }
67 |
68 | // initializes Key data for all keys
69 | // call this function before first call of "CheckKeys()"
70 | void InitKeys()
71 | {
72 | int8 a;
73 | for(a=0; a<NUM_KEYS; a++)
74 | {
75 | keys[a].state = KS_RELEASED;
76 | keys[a].counter = 0;
77 | keys[a].longpress_cnt = 0;
78 | }
79 | last_keystate = 0xFF;
80 | }
81 |
82 | // Returns true if the standard action for key(num) has to be executed
83 | int1 KeyPress(int8 num)
84 | {
85 | return bit_test(key_actions, num);
86 | }
87 |
88 | // Returns true if the key(num) is currently longpressed
89 | int1 KeyLongpress(int8 num)
90 | {
91 | return bit_test(key_longpress_actions, num);
92 | }
93 |
94 | // Returns true if one or more keys are currently pressed or have changed state since last CheckKeys()
95 | int1 KeyActivity()
96 | {
97 | return (key_longpress_actions || key_actions)||(last_keystate!=0xFF);
98 | }
99 |
100 | // This function does all the keyhandling. Call this function about every 50ms.
101 | void CheckKeys()
102 | {
103 | int8 i, diff;
104 | int8 keystate = 0xFF;
105 |
106 | // get current state of keys
107 | keystate = input_b();
108 |
109 | // reset action flags
110 | key_actions = 0x00;
111 | key_longpress_actions = 0x00;
112 |
113 | // determin the difference between current and last keystate
114 | diff = last_keystate ^ keystate;
115 |
116 | // loop through all keys
117 | for(i=0; i<NUM_KEYS; i++)
118 | {
119 | // key has changed?
120 | if(bit_test(diff,i))
121 | {
122 | switch(keys[i].state)
123 | {
124 | case KS_PRESSED: // key was in pressed state before
125 | keys[i].state = KS_RELEASED; // change keystate
126 | keys[i].counter = 0; // reset longpress counter
127 |
128 | if(keys[i]._mode == KM_ACT_ON_RELEASE)
129 | {
130 | // +---------------------+
131 | // | DO STANDARD ACTION! |
132 | // +---------------------+
133 | bit_set(key_actions,i);
134 | }
135 | else
136 | if(keys[i]._mode == KM_ACT_ON_LONGPRESS)
137 | {
138 | // key was released, but key was not in Longpress state yet.
139 | // +---------------------+
140 | // | DO STANDARD ACTION! |
141 | // +---------------------+
142 | bit_set(key_actions,i);
143 | }
144 | else
145 | {
146 | // KM_ACT_ON_PRESS: DO NOTHING
147 | }
148 | break;
149 | case KS_RELEASED: // key was in released state before
150 | keys[i].state = KS_PRESSED; // change keystate
151 | if(keys[i]._mode == KM_ACT_ON_PRESS)
152 | {
153 | keys[i].counter = 0; // reset keypress counter
154 | // +---------------------+
155 | // | DO STANDARD ACTION! |
156 | // +---------------------+
157 | bit_set(key_actions,i);
158 | }
159 | else if(keys[i]._mode == KM_ACT_ON_LONGPRESS)
160 | {
161 | // action is triggered later
162 | keys[i].longpress_cnt = 0; // reset longpress counter
163 | }
164 | else
165 | {
166 | // KM_ACT_ON_RELEASE: DO NOTHING
167 | }
168 | break;
169 | case KS_LONGPRESSED: // key was released after a Longpress. Special handling!
170 | keys[i].state = KS_RELEASED; // change keystate
171 |
172 | // does this key have lonpress mode enabled?
173 | if(keys[i]._mode == KM_ACT_ON_LONGPRESS)
174 | {
175 | // When a key was released after a longpress, nothing should happen!
176 | }
177 | else
178 | {
179 | // KM_ACT_ON_RELEASE: DO NOTHING
180 | // KM_ACT_ON_PRESS: DO NOTHING
181 | }
182 | break;
183 | }
184 | }
185 | else
186 | {
187 | // check keys whose states DID NOT change here!
188 | // (autofire, longpress repeat)
189 |
190 | if(keys[i].state == KS_PRESSED)
191 | {
192 | if(keys[i]._mode == KM_ACT_ON_RELEASE)
193 | {
194 | // key is either still pressed or still released so
195 | // no action needed here
196 | }
197 | else
198 | if(keys[i]._mode == KM_ACT_ON_PRESS) // check "autofire" function
199 | {
200 | // key is still pressed
201 | keys[i].counter++; // increase keypress counter
202 | if(keys[i].counter >= keys[i]._repeat_delay)
203 | {
204 | keys[i].counter = 0;
205 | // +---------------------+
206 | // | DO STANDARD ACTION! |
207 | // +---------------------+
208 | bit_set(key_actions,i);
209 | }
210 | }
211 | else
212 | if(keys[i]._mode == KM_ACT_ON_LONGPRESS)
213 | {
214 | // key is still pressed
215 | keys[i].longpress_cnt++; // increase keypress counter
216 |
217 | // do we have to trigger the longpress action?
218 | if(keys[i].longpress_cnt >= keys[i]._longpress_delay)
219 | {
220 | keys[i].counter = 0;
221 | // +----------------------+
222 | // | DO LONGPRESS ACTION! |
223 | // +----------------------+
224 | keys[i].state = KS_LONGPRESSED; // set key into longpressed state
225 | bit_set(key_longpress_actions,i);
226 | }
227 | }
228 | }
229 | else
230 | if(keys[i].state == KS_LONGPRESSED) // check longpressed button "autofire" function
231 | {
232 | // key is still (long)pressed
233 | // (we don't have to check the key's mode here since only a KM_ACT_ON_LONGPRESS-
234 | // button can get into the KS_LONGPRESSED state
235 | keys[i].counter++; // increase keypress counter
236 |
237 | // do we have to trigger the longpress action again?
238 | if(keys[i].counter >= keys[i]._repeat_delay)
239 | {
240 | keys[i].counter = 0;
241 | // +----------------------+
242 | // | DO LONGPRESS ACTION! |
243 | // +----------------------+
244 | bit_set(key_longpress_actions,i);
245 | }
246 | }
247 | }
248 | }
249 | // save current keystate
250 | last_keystate = keystate;
251 | }
