1 | /* Name: usbconfig.h
2 | * Project: AVR USB driver
3 | * Author: Christian Starkjohann
4 | * Creation Date: 2005-04-01
5 | * Tabsize: 4
6 | * Copyright: (c) 2005 by OBJECTIVE DEVELOPMENT Software GmbH
7 | * License: GNU GPL v2 (see License.txt) or proprietary (CommercialLicense.txt)
8 | * This Revision: $Id: usbconfig-prototype.h 600 2008-05-13 10:34:56Z cs $
9 | */
10 |
11 | #ifndef __usbconfig_h_included__
12 | #define __usbconfig_h_included__
13 |
14 | /*
15 | General Description:
16 | This file is an example configuration (with inline documentation) for the USB
17 | driver. It configures AVR-USB for USB D+ connected to Port D bit 2 (which is
18 | also hardware interrupt 0 on many devices) and USB D- to Port D bit 4. You may
19 | wire the lines to any other port, as long as D+ is also wired to INT0 (or any
20 | other hardware interrupt, as long as it is the highest level interrupt, see
21 | section at the end of this file).
22 | + To create your own usbconfig.h file, copy this file to your project's
23 | + firmware source directory) and rename it to "usbconfig.h".
24 | + Then edit it accordingly.
25 | */
26 |
27 | /* ---------------------------- Hardware Config ---------------------------- */
28 |
29 | #define USB_CFG_IOPORTNAME D
30 | /* This is the port where the USB bus is connected. When you configure it to
31 | * "B", the registers PORTB, PINB and DDRB will be used.
32 | */
33 | #define USB_CFG_DMINUS_BIT 4
34 | /* This is the bit number in USB_CFG_IOPORT where the USB D- line is connected.
35 | * This may be any bit in the port.
36 | */
37 | #define USB_CFG_DPLUS_BIT 2
38 | /* This is the bit number in USB_CFG_IOPORT where the USB D+ line is connected.
39 | * This may be any bit in the port. Please note that D+ must also be connected
40 | * to interrupt pin INT0! [You can also use other interrupts, see section
41 | * "Optional MCU Description" below, or you can connect D- to the interrupt, as
42 | * it is required if you use the USB_COUNT_SOF feature. If you use D- for the
43 | * interrupt, the USB interrupt will also be triggered at Start-Of-Frame
44 | * markers every millisecond.]
45 | */
46 | #define USB_CFG_CLOCK_KHZ (16000)
47 | /* Clock rate of the AVR in MHz. Legal values are 12000, 15000, 16000, 16500
48 | * and 20000. The 16.5 MHz version of the code requires no crystal, it
49 | * tolerates +/- 1% deviation from the nominal frequency. All other rates
50 | * require a precision of 2000 ppm and thus a crystal!
51 | * Default if not specified: 12 MHz
52 | */
53 |
54 | /* ----------------------- Optional Hardware Config ------------------------ */
55 |
56 | /* #define USB_CFG_PULLUP_IOPORTNAME D */
57 | /* If you connect the 1.5k pullup resistor from D- to a port pin instead of
58 | * V+, you can connect and disconnect the device from firmware by calling
59 | * the macros usbDeviceConnect() and usbDeviceDisconnect() (see usbdrv.h).
60 | * This constant defines the port on which the pullup resistor is connected.
61 | */
62 | /* #define USB_CFG_PULLUP_BIT 4 */
63 | /* This constant defines the bit number in USB_CFG_PULLUP_IOPORT (defined
64 | * above) where the 1.5k pullup resistor is connected. See description
65 | * above for details.
66 | */
67 |
68 | /* --------------------------- Functional Range ---------------------------- */
69 |
70 | #define USB_CFG_HAVE_INTRIN_ENDPOINT 0
71 | /* Define this to 1 if you want to compile a version with two endpoints: The
72 | * default control endpoint 0 and an interrupt-in endpoint (any other endpoint
73 | * number).
74 | */
75 | #define USB_CFG_HAVE_INTRIN_ENDPOINT3 0
76 | /* Define this to 1 if you want to compile a version with three endpoints: The
77 | * default control endpoint 0, an interrupt-in endpoint 3 (or the number
78 | * configured below) and a catch-all default interrupt-in endpoint as above.
79 | * You must also define USB_CFG_HAVE_INTRIN_ENDPOINT to 1 for this feature.
80 | */
81 | #define USB_CFG_EP3_NUMBER 3
82 | /* If the so-called endpoint 3 is used, it can now be configured to any other
83 | * endpoint number (except 0) with this macro. Default if undefined is 3.
84 | */
85 | /* #define USB_INITIAL_DATATOKEN USBPID_DATA1 */
86 | /* The above macro defines the startup condition for data toggling on the
87 | * interrupt/bulk endpoints 1 and 3. Defaults to USBPID_DATA1.
88 | * Since the token is toggled BEFORE sending any data, the first packet is
89 | * sent with the oposite value of this configuration!
90 | */
91 | #define USB_CFG_IMPLEMENT_HALT 0
92 | /* Define this to 1 if you also want to implement the ENDPOINT_HALT feature
93 | * for endpoint 1 (interrupt endpoint). Although you may not need this feature,
94 | * it is required by the standard. We have made it a config option because it
95 | * bloats the code considerably.
96 | */
97 | #define USB_CFG_INTR_POLL_INTERVAL 10
98 | /* If you compile a version with endpoint 1 (interrupt-in), this is the poll
99 | * interval. The value is in milliseconds and must not be less than 10 ms for
100 | * low speed devices.
101 | */
102 | #define USB_CFG_IS_SELF_POWERED 0
103 | /* Define this to 1 if the device has its own power supply. Set it to 0 if the
104 | * device is powered from the USB bus.
105 | */
106 | #define USB_CFG_MAX_BUS_POWER 100
107 | /* Set this variable to the maximum USB bus power consumption of your device.
108 | * The value is in milliamperes. [It will be divided by two since USB
109 | * communicates power requirements in units of 2 mA.]
110 | */
111 | #define USB_CFG_IMPLEMENT_FN_WRITE 1
112 | /* Set this to 1 if you want usbFunctionWrite() to be called for control-out
113 | * transfers. Set it to 0 if you don't need it and want to save a couple of
114 | * bytes.
115 | */
116 | #define USB_CFG_IMPLEMENT_FN_READ 0
117 | /* Set this to 1 if you need to send control replies which are generated
118 | * "on the fly" when usbFunctionRead() is called. If you only want to send
119 | * data from a static buffer, set it to 0 and return the data from
120 | * usbFunctionSetup(). This saves a couple of bytes.
121 | */
122 | #define USB_CFG_IMPLEMENT_FN_WRITEOUT 0
123 | /* Define this to 1 if you want to use interrupt-out (or bulk out) endpoints.
124 | * You must implement the function usbFunctionWriteOut() which receives all
125 | * interrupt/bulk data sent to any endpoint other than 0. The endpoint number
126 | * can be found in 'usbRxToken'.
127 | */
128 | #define USB_CFG_HAVE_FLOWCONTROL 0
129 | /* Define this to 1 if you want flowcontrol over USB data. See the definition
130 | * of the macros usbDisableAllRequests() and usbEnableAllRequests() in
131 | * usbdrv.h.
132 | */
133 | #define USB_CFG_LONG_TRANSFERS 0
134 | /* Define this to 1 if you want to send/receive blocks of more than 254 bytes
135 | * in a single control-in or control-out transfer. Note that the capability
136 | * for long transfers increases the driver size.
137 | */
138 | /* #define USB_RX_USER_HOOK(data, len) if(usbRxToken == (uchar)USBPID_SETUP) blinkLED(); */
139 | /* This macro is a hook if you want to do unconventional things. If it is
140 | * defined, it's inserted at the beginning of received message processing.
141 | * If you eat the received message and don't want default processing to
142 | * proceed, do a return after doing your things. One possible application
143 | * (besides debugging) is to flash a status LED on each packet.
144 | */
145 | /* #define USB_RESET_HOOK(resetStarts) if(!resetStarts){hadUsbReset();} */
146 | /* This macro is a hook if you need to know when an USB RESET occurs. It has
147 | * one parameter which distinguishes between the start of RESET state and its
148 | * end.
149 | */
150 | /* #define USB_SET_ADDRESS_HOOK() hadAddressAssigned(); */
151 | /* This macro (if defined) is executed when a USB SET_ADDRESS request was
152 | * received.
153 | */
154 | #define USB_COUNT_SOF 0
155 | /* define this macro to 1 if you need the global variable "usbSofCount" which
156 | * counts SOF packets. This feature requires that the hardware interrupt is
157 | * connected to D- instead of D+.
158 | */
159 | #define USB_CFG_HAVE_MEASURE_FRAME_LENGTH 0
160 | /* define this macro to 1 if you want the function usbMeasureFrameLength()
161 | * compiled in. This function can be used to calibrate the AVR's RC oscillator.
162 | */
163 |
164 | /* -------------------------- Device Description --------------------------- */
165 |
166 | #define USB_CFG_VENDOR_ID 0xc0, 0x16
167 | /* USB vendor ID for the device, low byte first. If you have registered your
168 | * own Vendor ID, define it here. Otherwise you use one of obdev's free shared
169 | * VID/PID pairs. Be sure to read USBID-License.txt for rules!
170 | * + This template uses obdev's shared VID/PID pair: 0x16c0/0x5dc.
171 | * + Use this VID/PID pair ONLY if you understand the implications!
172 | */
173 | #define USB_CFG_DEVICE_ID 0xdc, 0x05
174 | /* This is the ID of the product, low byte first. It is interpreted in the
175 | * scope of the vendor ID. If you have registered your own VID with usb.org
176 | * or if you have licensed a PID from somebody else, define it here. Otherwise
177 | * you use obdev's free shared VID/PID pair. Be sure to read the rules in
178 | * USBID-License.txt!
179 | * + This template uses obdev's shared VID/PID pair: 0x16c0/0x5dc.
180 | * + Use this VID/PID pair ONLY if you understand the implications!
181 | */
182 | #define USB_CFG_DEVICE_VERSION 0x00, 0x01
183 | /* Version number of the device: Minor number first, then major number.
184 | */
185 | #define USB_CFG_VENDOR_NAME 'o', 'b', 'd', 'e', 'v', '.', 'a', 't'
186 | #define USB_CFG_VENDOR_NAME_LEN 8
187 | /* These two values define the vendor name returned by the USB device. The name
188 | * must be given as a list of characters under single quotes. The characters
189 | * are interpreted as Unicode (UTF-16) entities.
190 | * If you don't want a vendor name string, undefine these macros.
191 | * ALWAYS define a vendor name containing your Internet domain name if you use
192 | * obdev's free shared VID/PID pair. See the file USBID-License.txt for
193 | * details.
194 | */
195 | #define USB_CFG_DEVICE_NAME 'T', 'e', 'm', 'p', 'l', 'a', 't', 'e'
196 | #define USB_CFG_DEVICE_NAME_LEN 8
197 | /* Same as above for the device name. If you don't want a device name, undefine
198 | * the macros. See the file USBID-License.txt before you assign a name if you
199 | * use a shared VID/PID.
200 | */
201 | /*#define USB_CFG_SERIAL_NUMBER 'N', 'o', 'n', 'e' */
202 | /*#define USB_CFG_SERIAL_NUMBER_LEN 0 */
203 | /* Same as above for the serial number. If you don't want a serial number,
204 | * undefine the macros.
205 | * It may be useful to provide the serial number through other means than at
206 | * compile time. See the section about descriptor properties below for how
207 | * to fine tune control over USB descriptors such as the string descriptor
208 | * for the serial number.
209 | */
210 | #define USB_CFG_DEVICE_CLASS 0xff /* set to 0 if deferred to interface */
211 | #define USB_CFG_DEVICE_SUBCLASS 0
212 | /* See USB specification if you want to conform to an existing device class.
213 | * Class 0xff is "vendor specific".
214 | */
215 | #define USB_CFG_INTERFACE_CLASS 0 /* define class here if not at device level */
216 | #define USB_CFG_INTERFACE_SUBCLASS 0
217 | #define USB_CFG_INTERFACE_PROTOCOL 0
218 | /* See USB specification if you want to conform to an existing device class or
219 | * protocol. The following classes must be set at interface level:
220 | * HID class is 3, no subclass and protocol required (but may be useful!)
221 | * CDC class is 2, use subclass 2 and protocol 1 for ACM
222 | */
223 | #define USB_CFG_HID_REPORT_DESCRIPTOR_LENGTH 0
224 | /* Define this to the length of the HID report descriptor, if you implement
225 | * an HID device. Otherwise don't define it or define it to 0.
226 | * If you use this define, you must add a PROGMEM character array named
227 | * "usbHidReportDescriptor" to your code which contains the report descriptor.
228 | * Don't forget to keep the array and this define in sync!
229 | */
230 |
231 | /* #define USB_PUBLIC static */
232 | /* Use the define above if you #include usbdrv.c instead of linking against it.
233 | * This technique saves a couple of bytes in flash memory.
234 | */
235 |
236 | /* ------------------- Fine Control over USB Descriptors ------------------- */
237 | /* If you don't want to use the driver's default USB descriptors, you can
238 | * provide our own. These can be provided as (1) fixed length static data in
239 | * flash memory, (2) fixed length static data in RAM or (3) dynamically at
240 | * runtime in the function usbFunctionDescriptor(). See usbdrv.h for more
241 | * information about this function.
242 | * Descriptor handling is configured through the descriptor's properties. If
243 | * no properties are defined or if they are 0, the default descriptor is used.
244 | * Possible properties are:
245 | * + USB_PROP_IS_DYNAMIC: The data for the descriptor should be fetched
246 | * at runtime via usbFunctionDescriptor().
247 | * + USB_PROP_IS_RAM: The data returned by usbFunctionDescriptor() or found
248 | * in static memory is in RAM, not in flash memory.
249 | * + USB_PROP_LENGTH(len): If the data is in static memory (RAM or flash),
250 | * the driver must know the descriptor's length. The descriptor itself is
251 | * found at the address of a well known identifier (see below).
252 | * List of static descriptor names (must be declared PROGMEM if in flash):
253 | * char usbDescriptorDevice[];
254 | * char usbDescriptorConfiguration[];
255 | * char usbDescriptorHidReport[];
256 | * char usbDescriptorString0[];
257 | * int usbDescriptorStringVendor[];
258 | * int usbDescriptorStringDevice[];
259 | * int usbDescriptorStringSerialNumber[];
260 | * Other descriptors can't be provided statically, they must be provided
261 | * dynamically at runtime.
262 | *
263 | * Descriptor properties are or-ed or added together, e.g.:
264 | * #define USB_CFG_DESCR_PROPS_DEVICE (USB_PROP_IS_RAM | USB_PROP_LENGTH(18))
265 | *
266 | * The following descriptors are defined:
267 | * USB_CFG_DESCR_PROPS_DEVICE
268 | * USB_CFG_DESCR_PROPS_CONFIGURATION
269 | * USB_CFG_DESCR_PROPS_STRINGS
270 | * USB_CFG_DESCR_PROPS_STRING_0
271 | * USB_CFG_DESCR_PROPS_STRING_VENDOR
272 | * USB_CFG_DESCR_PROPS_STRING_PRODUCT
273 | * USB_CFG_DESCR_PROPS_STRING_SERIAL_NUMBER
274 | * USB_CFG_DESCR_PROPS_HID
275 | * USB_CFG_DESCR_PROPS_HID_REPORT
276 | * USB_CFG_DESCR_PROPS_UNKNOWN (for all descriptors not handled by the driver)
277 | *
278 | */
279 |
280 | #define USB_CFG_DESCR_PROPS_DEVICE 0
281 | #define USB_CFG_DESCR_PROPS_CONFIGURATION 0
282 | #define USB_CFG_DESCR_PROPS_STRINGS 0
283 | #define USB_CFG_DESCR_PROPS_STRING_0 0
284 | #define USB_CFG_DESCR_PROPS_STRING_VENDOR 0
285 | #define USB_CFG_DESCR_PROPS_STRING_PRODUCT 0
286 | #define USB_CFG_DESCR_PROPS_STRING_SERIAL_NUMBER 0
287 | #define USB_CFG_DESCR_PROPS_HID 0
288 | #define USB_CFG_DESCR_PROPS_HID_REPORT 0
289 | #define USB_CFG_DESCR_PROPS_UNKNOWN 0
290 |
291 | /* ----------------------- Optional MCU Description ------------------------ */
292 |
293 | /* The following configurations have working defaults in usbdrv.h. You
294 | * usually don't need to set them explicitly. Only if you want to run
295 | * the driver on a device which is not yet supported or with a compiler
296 | * which is not fully supported (such as IAR C) or if you use a differnt
297 | * interrupt than INT0, you may have to define some of these.
298 | */
299 | /* #define USB_INTR_CFG MCUCR */
300 | /* #define USB_INTR_CFG_SET ((1 << ISC00) | (1 << ISC01)) */
301 | /* #define USB_INTR_CFG_CLR 0 */
302 | /* #define USB_INTR_ENABLE GIMSK */
303 | /* #define USB_INTR_ENABLE_BIT INT0 */
304 | /* #define USB_INTR_PENDING GIFR */
305 | /* #define USB_INTR_PENDING_BIT INTF0 */
306 | /* #define USB_INTR_VECTOR SIG_INTERRUPT0 */
307 |
308 | #endif /* __usbconfig_h_included__ */
